21.06.2018 12:03:39
BSD pole linux, midagi sarnast aga jah.
Kommentaarid: 182 loe/lisa |
146 |
21.06.2018 13:21:39
openbsd kirjutas: |
SMT (Simultanious Multi Threading) implementations typically share TLBs and L1 caches between threads. This can make cache timing attacks a lot easier and we strongly suspect that this will make several spectre-class bugs exploitable. Especially on Intel's SMT implementation which is better known as Hypter-threading. We really should not run different security domains on different processor threads of the same core. Unfortunately changing our scheduler to take this into account is far from trivial. Since many modern machines no longer provide the ability to disable Hyper-threading in the BIOS setup, provide a way to disable the use of additional processor threads in our scheduler. And since we suspect there are serious risks, we disable them by default. This can be controlled through a new hw.smt sysctl. For now this only works on Intel CPUs when running OpenBSD/amd64. But we're planning to extend this feature to CPUs from other vendors and other hardware architectures.
Note that SMT doesn't necessarily have a posive effect on performance; it highly depends on the workload. In all likelyhood it will actually slow down most workloads if you have a CPU with more than two cores. |
tl;dr
smt, mitte ainult ht. hetkel on variant ainult inteli ht disablemiseks, sest muudeni pole veel jõutud.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
21.06.2018 13:59:00
Kaotab Intel, kaotavad kõik.
Kommentaarid: 92 loe/lisa |
trip
Kommentaarid: 406 loe/lisa |
303 |
dohc-48v12
Aeg maha 1p
21.06.2018 16:38:35
I9-st saab i3-d
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
Kommentaarid: 112 loe/lisa |
6 :: |
85 |
One
Kommentaarid: 1009 loe/lisa |
728 |
22.06.2018 14:39:05
Winterwind, Varsti on kuskil Baby Inside™
Veel parem on see kommentaar: Never screw each other, only screw the customers™
Killhoven
OC`er
22.06.2018 16:04:15
ot: |
Huvitav mis tegelikult toimub? Intel on juhitud väga halba seisu konkurentsi tekkimisel ja saadi aru juhtkonnas on vaja vahetust kohe ja paanika ära hoidmiseks serveeritakse CEO lahkumine kui mingi suhte teema justnagu tegelikult võiks arvata juhtkonnas on kõik ok ja tuelvik tundub kindel? |
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™ |
Kommentaarid: 402 loe/lisa |
347 |
dohc-48v12
Aeg maha 1p
22.06.2018 16:34:13
CEO oleks varem lahkunud, aga kunast tall oli siseinfot siis ta ei saanud kõiki aktsiad maha müüa... Aga olgem ausad, sise infot vallates ta müüs enne turvaugu avalikuks tulemist enda aktsiad maha, jättes niipalju aktsiaid et jääks CEO-ks ja ei saaks krimkat.
6 :: |
85 |
22.06.2018 18:41:53
Vb. karistati CEO'd, sest taolise puhul ei pea vallandamist kompenseerima, jms. Intelil suht vesi ahjus ju :]
Kommentaarid: 196 loe/lisa |
182 |
22.06.2018 18:43:09
Need naljad ja arutelu Inteli CEO üle on ju hirmnaljakad kuid äkki keskenduks protsessoritele?
146 |
22.06.2018 23:27:32
Mark0, ma ei teinud nalja. Ei välistaks kui Intel ta sealt taolise võttega lihtsalt kõrvaldas või midagi muud.
182 |
25.06.2018 11:45:12
https://wccftech.com/intel-z370-rebadge-z390-8th-gen-compatible/
Lol unustage 14nm. Unustage 10nm. Intel liigub nüüd tagurpidi . Welcome 22nm
Ok see on siis kiibistike osas õnneks mitte prosede osas. Kiibistiku puhul pole uusim tootmisprotsess eriti tähtis, kuna kiibistik võtab väga vähe voolu ja seal poleks nii suurt kasu uuemast tootmisprotsessist.
Väidetavalt siis 14nm tootmine on suuremamahuline kui algselt plaanitud ja selleks, et Z390 välja saada toodetakse see 22nm peal, sest 14nm tootmine on hõivatud prosede ja H360 tootmisega. Paraku see tähendab, et featuurid mis eelnevalt arvati olevat osa Z390 feature setist peavad nüüd emaplaaditootjad implementeerima eraldi kontrolleritega.
God, what a mess
Ma ei saa aru miks siis üldse Z390 teha kui see on erinevalt Z370-st 22nm mitte 14nm ja feature set on sama. Tehku siis Z370-le BIOS uuendus 8 tuumaliste prosede jaoks ja asi ants.
anubis
25.06.2018 11:59:31
Pole Võimalik™
(tootjaid säästetakse BIOSi uuendustest, lihtsam ja tulusam on uusi emaplaate müüa kui vanadele update võimaldada)
Kommentaarid: 332 loe/lisa |
280 |
One
25.06.2018 12:51:28
Normaalne ju, saavad siis 14nm peal varsti uue chipseti välja lasta, lollid ostavad
728 |
trip
303 |
dohc-48v12
Aeg maha 1p
25.06.2018 16:20:53
i9 9900k ? tulemas ?
6 :: |
85 |
25.06.2018 19:16:03
dohc-48v12, i9 on HEDT. Sinna tuleb see aasta 22c/44t prose aga pole veel tea mis nimega. Vb i9 7990X
See 8c/16t tuleb arvatavasti 9700K tippmudel ja 9600K 8c ilma HT.
25.06.2018 19:41:55
Tomorrow kirjutas: |
Ma ei saa aru miks siis üldse Z390 teha kui see on erinevalt Z370-st 22nm mitte 14nm ja feature set on sama. Tehku siis Z370-le BIOS uuendus 8 tuumaliste prosede jaoks ja asi ants. |
Tehku Z390 siis 14nm ja uuendatud BIOS'iga ning ärgu pakkugu seda Z370'tele... täiesti ajuvaba paanikas tõmblemine tundub Inteli leeris.
182 |
eix666
25.06.2018 20:00:06
Mulle tundub pigem asi selles, et kõlakate järgi jättis AMD ju kulude tõttu oma plaanitud z490 kiibistiku ära, eks seepeale Intel vaatas, et mis meiegi siis selle z390ga laristama hakkame, kärab see z370 küll, kasvõi uue nimega, kui vaja on.
Kommentaarid: 39 loe/lisa |
39 |
25.06.2018 20:14:50
See tundub Z370'st ka tagasiminek
182 |
Auron
26.06.2018 10:25:21
Z370 ei oleks üldse pidand eksisteerima kuid kuna oli niikähku vaja pooletoobiseid rohkemate tuumadega prozezi turule lahmida tehti ne mjasa ne rõõba asi valmis ehk 270 + tugi 8 seeria jaoks.
Okei, ideena niivõrd kuivõrd suva - kes just see hetk uuendab võtab selle mida soovib. Pigem häirib inteli puhul see mitme eri socketi ja kiibistiku vahel tõmblemine mis tõmbab maha moti soetamaks high end platet.
Kommentaarid: 154 loe/lisa |
131 |
anubis
26.06.2018 10:34:56
z170/270/370 (ja loomulikult ka madalamad tierid samal pesal) s1151 on elektriliselt (pesa pinout) identsed, ainus erinevus on selles, et Intel ei luba tarkvaralise piiranguga tagasiulatuvat ühilduvust.
280 |
Kommentaarid: 471 loe/lisa |
12 :: |
7 :: |
359 |
27.06.2018 13:08:28
Ehk siis Intel on tegelenud ajuvaba toodete nudimisega, et saaks müüa uusi plaate, kuigi vajadust selleks ei ole.
182 |
