uus teema   vasta Tarkvara »  Arvutimängude foorum »  World of Tanks märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 1037, 1038, 1039 ... 1163, 1164, 1165  järgmine
Kaua oled WoT-i mänginud? Täpsusta teemas.
12-10a
41%
 41%  [ 26 ]
10-8a
17%
 17%  [ 11 ]
8-6a
11%
 11%  [ 7 ]
6-4a
8%
 8%  [ 5 ]
4-2a
4%
 4%  [ 3 ]
Vähem kui 2a
16%
 16%  [ 10 ]
hääli kokku : 62
karumaru
sõnum 15.04.2018 13:32:08 vasta tsitaadiga
Ma ka pole proovinud, vot mis mulle endale segadust tekitab on see esimese moona ikoon. Kui see on roheline, siis on üks lask olemas? Või peab teine kuul ka laaditud olema?
Vaatasin uue Frontline Returns mängustiili striimi. See tuleb siis tier 8 ja mingi päris teistmoodi asi.
Vehicles: Tier VIII vehicles
Teams: 30 players on each side with an opportunity to team up in Platoons of five.
Roles: One team plays in defense; the other attacks.
Objectives: Attackers must break through defensive fronts and destroy at least three out of five pillboxes (explained in more detail further down). Defenders must hold strong and keep at least three out of five pillboxes intact.
We revised the mode based on your suggestions from the first Frontline testing reworking the battlefield into HD and iterating on its key gameplay aspects, from the vehicle roster through to economy.
Tier VIII Vehicles: Following your vocal concerns about Tier X economy and its constraints, we made Frontline only be available for Tier VIII vehicles
New Consumables:
Smoke screen: A cloud of smoke conceals tanks
Morale boost: A tank's Crew and nearby Crews receive a bonus to their major qualifications
Engineering crew: Decreases base capture time, increases the effect of knocking down base capture, and is able to halt the base capture if placed within the borders of the base that’s being captured
Kommentaarid: 1 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 0
sakinaga
sõnum 15.04.2018 13:58:11 vasta tsitaadiga
Kui t8 tankid, mida on niigi liiga vähe, lähevad seda game mode'i mängima, siis randomis t8-ga ainult t10 näedki? icon_lol.gif
Kommentaarid: 159 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 151
Valvejoodik
Valvejoodik
sõnum 15.04.2018 14:33:05 vasta tsitaadiga
Rindel on piirang peal. Korraga ei lasta sinna tervet serverit.
vlat
sõnum 15.04.2018 16:58:43 vasta tsitaadiga
tervist, selline küsimus, kas tohiks laenata oma kontot, kas on oht kontost ilma jääda, kui see inimene kellele laenan muudab parooli ära?
Valvejoodik
Valvejoodik
sõnum 15.04.2018 17:55:39 vasta tsitaadiga
Mis sa ise arvad? Kui just väga usaldusväärne inimene ei ole, siis on küll oht...
vlat
sõnum 15.04.2018 18:11:53 vasta tsitaadiga
Oled sa 100% kindel selles? või arvad
alyster
sõnum 15.04.2018 18:34:36 vasta tsitaadiga
Konto laenamine on nagu naise usaldamine peol võõra mehe juurde. Võid ilma jääda.
sõnum 15.04.2018 19:08:50 vasta tsitaadiga
Bani võid ka saada kui laenutaja paneb kõik keelatatud modid peale ja laseb nendega 24/7 ringi. icon_lol.gif
Kusjuures ban võib ka 6 kuud hiljem tulla.
Kommentaarid: 168 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 157
Tanel468
sõnum 15.04.2018 20:46:06 vasta tsitaadiga
Kuidas selle Tiger II lood on, hetkel saaks soodsalt kätteja mind huvitakski ainult E75 selles liinis max, kas on üldse mõtet aega raisata või pressid mingit teist osa kus t10 tank kah rewardina tundub.
karumaru
sõnum 15.04.2018 20:52:20 vasta tsitaadiga
Obj. 257 on kõige parem tier 9 heavy. E75 on mõttetu ajaraiskamine, eriti veel Tiger 2 mängimine. Need tankid on kõik puhas ajalugu.
Kurat666
Kurat666
sõnum 15.04.2018 20:55:05 vasta tsitaadiga
karumaru kirjutas:
Vaidleks vastu. Õigem on öelda - kõige lollikindlam...
WoT tips: 6th sense is over-rated anyway, the other team will always let you know when you've been spotted
fellanor
sõnum 16.04.2018 00:52:40 vasta tsitaadiga
Kurat666 kirjutas:
karumaru kirjutas:
Vastu ei saa vaielda sellele osale, et King Tiger liin praeguses WoTis pask on.
Tanel468
sõnum 16.04.2018 12:10:51 vasta tsitaadiga
Ok, jätan ostmata. Mul Obj. 257 on olemas, kunagi sain T-10t sõites peaaegu IS-7 lahti aga siis läks tuju ära ja peale seda kunagi vahetus selle 257 vastu.
phljuh
phljuh
sõnum 16.04.2018 13:17:44 vasta tsitaadiga
vene tier IX obj 257 ja T-10 on hetkel väga head tankid. Sakslaste tiger II ja E 75 vajaksid BUFFI
müüsin oma naeratuse maha
Kommentaarid: 53 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 51
karumaru
sõnum 16.04.2018 13:58:33 vasta tsitaadiga
Alles aasta paar tagasi Maus sai buffi ja vaevalt nad enam saksa liine buffivad. Vähemalt mõne aasta jooksul seda kindlasti ei tehta.
mcjaaxon
mcjaaxon
sõnum 16.04.2018 14:59:41 vasta tsitaadiga
karumaru kirjutas:
Ma olen telekas.
Kommentaarid: 21 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 15
alyster
sõnum 16.04.2018 18:37:44 vasta tsitaadiga
Kumba kahurit te 705 peal eelistate? See 122mm tundub nagu tiba parem, ehkki pole top. Või on 130mm APCRi eelistusest üle HEATI mingit asjalikku tolku?
KoldK
KoldK
sõnum 16.04.2018 20:07:54 vasta tsitaadiga
Ma ikka jumala vale liini võtnud siis, hetkel just Tiger liin käsil. Mõtlesin, et pressin kunagi "kauges tulevikus" E 100 ära icon_biggrin.gif
Ei teagi nüüd, mis suund võtta...
mcjaaxon
mcjaaxon
sõnum 16.04.2018 20:19:02 vasta tsitaadiga
KoldK kirjutas:
Pole sellel E100 midagi viga . Olen märganud , et värskelt suuremate tankide omanikud muutuvad liialt julgeks . See ehk ongi nende viga .
Lähevad suure lauluga peale , kuid siis surevad . Hoiad pisutki end tagasi sellel teemal ja lased võimalusel ka TD'l end toetada ja lahingud tulevad paremad icon_smile.gif
Mina näiteks ei oska eest sellele E100'le mujale lastagi , kui kett maha . Vahel harva ehk on õnnestunud jummala kämblaga saada ka dämmi teha nii või tabanud kogemata mujale siis .
Ma olen telekas.
viimati muutis mcjaaxon 16.04.2018 20:21:07, muudetud 1 kord
arny
sõnum 16.04.2018 20:19:38 vasta tsitaadiga
E100 on täielik p..k. Mõttetu toru ei tee ilma premm moonata tuhkagi. Pehme kui värske sai ja kui tahad kedagi lasta siis vastane sajatab põskedest kohe sisse lasu. Pigem maus, on vähemalt armorit. Vene liinid on kindla peale minek need ikka ülimad aparaadid.
mcjaaxon
mcjaaxon
sõnum 16.04.2018 21:06:00 vasta tsitaadiga
Millal selline ( minu arust eriti haige värk ) pihta hakkas ?
Kaotaja tiimis on nii mõnigi koll normaalse tulemuse teinud , kuid kogemusi täiesti lampi vähem , kui võitja tiimi kollil, kellel ilus 0 ?
Võin eksida , kuid nagu ei mäleta , et selline asi oleks näiteks 1,5 aastat tagasi olnud .
https://www.upload.ee/image/8335571/shot_005.jpg
Ma olen telekas.
karumaru
sõnum 16.04.2018 21:16:53 vasta tsitaadiga
Võitjad saavad 50% expi juurde. Tänapäeval nagu saab expi rohkem kui oled eesliinil, tagaliinil saab vähem.
Tanel468
sõnum 16.04.2018 21:28:14 vasta tsitaadiga
Leidsin uudise, et t-44 on buffi saanud, peab hakkama selle tanki keskmist alla sikutama icon_biggrin.gif
thomak28
sõnum 17.04.2018 10:30:47 vasta tsitaadiga
Tanel468 kirjutas:
T-44 on haige aparaat tänapäeval. Ka tier 10 MM'is täiesti korraliku impactiga. Üleminek t-44 -> 430 peale oli minule pettumus, 430 nagu mingi heavy tank T-44 kõrval, liigub aeglaselt, pöörab aegalselt, kahur potato jne. Aga see on maitse asi. T-44 ja tegelt ka T-44-100 minu arust parimad tier 8'sad hetkel mängus, vähemalt minu jaoks.
mcjaaxon
mcjaaxon
sõnum 17.04.2018 10:48:52 vasta tsitaadiga
thomak28 kirjutas:
Tanel468 kirjutas:
Sisse võtab , kuid ise lajatab vastu korralikult tavaliselt .
T-44 aga on minu jaoks õudus . Usun , et mul muidugi on kogemusi veel vähe sellega ning ilmselt on asi ka selles , et kunagi , kui seda sõicin - oli plank . Ei kitid ja ei tarvikud . Ühesõnaga olin sees veelgi munam , kui praegu olen icon_smile.gif
Ma olen telekas.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  World of Tanks mine lehele eelmine  1, 2, 3 ... 1037, 1038, 1039 ... 1163, 1164, 1165  järgmine
