The world’s unquenchable need for entertainment has turned towards bloodlust as entertainment behemoth TEC1 is set to premiere season two of its television sensation SCUM. This new season moves the contest from the rugged, enclosed Alcatraz sector to the full grandure of Bagne de Cayenne, an island with a sordid history of violent incarceration. Both fan favorites and new prisoners will clash in a ruthless war of survival while battling for the support of viewers, producers, and corporate sponsors for fame, gifts, and a chance of life after death. SCUM evolves the multiplayer open world survival game with unprecedented levels of character customization, control, and progression where knowledge and skills are the ultimate weapons for long-term survival. Players will balance base level needs with knowledge-based skills to manage everything from nourishment, metabolic rate, and body mass to weapons proficiency, combat style, and security systems hacking. Dominate the island with your skills, cunning, and strategies to achieve higher levels of game and receive powerful gifts from corporate sponsors and, if you happen to slip up and die, get resurrected by the show’s producers with all your valuable skills still intact.
mäng kasutab uusi lähenemisi 3rd-person eeliste vähendamiseks, skillipõhist spottimist jne.
väga uudsed ideed selle žanri jaoks, jääme ootama, kuidas päris mängijate käes asi välja hakkab nägema.
arendajateks gamepires (gas guzzlers) ja croteam (serious sam)
viimati muutis DeTHiCa. 23.06.2018 17:18:08, muudetud 1 kord
having a slower buddy when zombies are chasing you...well, thats a lifesaver _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Kõik oli OK.. Seni kuni riietekotiga lombi põhja vajus ja seletas, et kott on nüüd väga raske ja peab seljast ära võtma. Fu*k logic and physics. _________________ Steam profiil
Children play Call of Duty.. Boys play Battlefield.. Men play ARMA
fragile, sul on mingi parem lahendus sellele probleemile?
mine community foorumisse ja räägi välja siis, äkki muudavad ära.
Oleks seal kivid, metall, vms. veest tihedam ja raskem materjal, siis oleks OK. Riietekott peaks just takistama sukeldumist. Oleks valik kuhu kott sättida. Selja peale või rindkere alla Teeks pükstest vms. õhupadja ja ulbiks vee peal. Veest välja tulek oleks muidugi piin..
Hästi imavad materjalid saab ikka kuivaks pigistada/väänata ja edasi vantsida.. _________________ Steam profiil
Tundub väga huvitav idee poolest olema.. aga mulle tundub, et aina popimaks lähevad need massiivsed 50-100 inimese battle royali tüüpi mängud.. kuda sellel mitmikmänguga lood olema saavad? _________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Täna kohe varsti saadaval siis EA kujul. YT sai vaadatud veits videosi ja hetkel jääbi selline paremini tehtud (vähemalt tehniliselt ja võimaluste poolest) DAYZ SA tüüpi mäng. Ja hetkel tundub, et sellest võiks isegi äkki asja saada. Siin miski viimane näide...ei midagi erilist aga vähemalt näeb reaalset mängu
https://www.youtube.com/watch?v=0ZUxnJtMewU
Näha et alguse asi aga samas tundub põnev. Sittusin, oksendasin, kusesin, oleks peaaegu nälga surd jne aga lõpuks sai relv leitud ja ainsad 10 kuuli mingi roboti pihta ära taristatud.
Kas asjad tagasi ka spawnivad serverisse?
Ja mis on ENG ja kuidas selle nullist üles saab jälle? _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Ostin ära, kuna pubgi kohvrite raha oli üle . Paar tundi mängitud. Tundub lahe. Võiks öelda jah, et midagi nagu dayz ja tarkovi ristsugutis. Eks ta bugine on aga annan andeks kuna EA. Samas otseselt midagi mängu lõhkuvat ette ei sattunud. Kõige suurem probleem vist hetkel serverid ise. Kui on tublid devid siis loodan, et sellel mängul on tulevikku.
RustyZ, ja tundus et spawnivad küll ag kuidas või kui tihti ei ole kindel veel. Ja tundub, et viimase patchiga see ENG lihtsalt "katki". Muidu vist peaks see enamvähem sööki tähendama.
Mnjah mul pold ka normi sööki ja laksisin terve koti meresoola sisse. Kehas oli sodiumi 3200% pärast... _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
näeb seal mängus üldse inimvastaseid ka? või ongi peamiselt selline söömine ja sittumine ning kusemine teemaks? mismoodi asi üldse välja näeb, nagu aru saan ei ole seal vist mingeid ajaliselt kindlal hetkel algavaid ja lõppevaid matche, vaid lihtsalt erinevad serverid kuhu suvalisel hetkel siis kes iganes sisse logib? peale surma saamist spawnid kuskil baasis ja oled kogu oma kraamist ilma? _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Näeb ikka. Täna sai mängitud ja juba suht mitu relva kogutud ja paar venda mahagi taristatud a no naiivselt sai sõpradega keset teed ja linna lõke tehtud et lihhi küpsetatud kui järsku rahvast kogunema hakkas. Veidi sai neid nahutatud sest kellelgil midagi asjalikku pold v olid kuulid otsas. Lõpuks tuli mingi xiiter kes eiteakust ilmus relvadega ja maha tõmbas.
Kui surma saad oled gearist ilma jah aga saad shelteri ja storage omale tekitada kuhu asju jätta ja pärast saad sinna spawnida kui sured. Kui shelterit pole spawnid lambikohta. Sellessuhtes veidi jama et kui sõbraga oled ja kaardi erinevatesse otsesse spawnid siis võtab terve igaviku et kokku saada.
Hetkel meeldib kui veel edasi ka arendatakse... Selline rahulik toksimine ja peab ikka ettevaatlik olema. Üldiselt voissis osad küsivad et kas oled sõbralik. Mul ikka komme öelda et jep olen ja siis kuvaldaga pähe taguda... _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Heh, siis on nagu Nextday:survival, süsteem sisuliselt täpselt sama.
Aga tõsi jah, seal oli enamasti sama teema, et mingid vennad kukkusid friendly juttu rääkima ja siis suvalisel hetkel killisid sind selja tagant ära ega midagi, sai siis edaspidi lihtsalt valimatult kõigile tina antud kohe kui mingi kontakt oli. Aga tegelikult muidugi sedatüüpi mängudes oleks mõistlik kui alati ja kõigile tina andma ei pea...pole ju laskemoona ka lõputult.
Mis ta muidu on selline "feels like arma 3" või? ma mõtlen liikumine ja üldine mängutunnetus _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
