The world’s unquenchable need for entertainment has turned towards bloodlust as entertainment behemoth TEC1 is set to premiere season two of its television sensation SCUM. This new season moves the contest from the rugged, enclosed Alcatraz sector to the full grandure of Bagne de Cayenne, an island with a sordid history of violent incarceration. Both fan favorites and new prisoners will clash in a ruthless war of survival while battling for the support of viewers, producers, and corporate sponsors for fame, gifts, and a chance of life after death. SCUM evolves the multiplayer open world survival game with unprecedented levels of character customization, control, and progression where knowledge and skills are the ultimate weapons for long-term survival. Players will balance base level needs with knowledge-based skills to manage everything from nourishment, metabolic rate, and body mass to weapons proficiency, combat style, and security systems hacking. Dominate the island with your skills, cunning, and strategies to achieve higher levels of game and receive powerful gifts from corporate sponsors and, if you happen to slip up and die, get resurrected by the show’s producers with all your valuable skills still intact.
mäng kasutab uusi lähenemisi 3rd-person eeliste vähendamiseks, skillipõhist spottimist jne.
väga uudsed ideed selle žanri jaoks, jääme ootama, kuidas päris mängijate käes asi välja hakkab nägema.
arendajateks gamepires (gas guzzlers) ja croteam (serious sam)
viimati muutis DeTHiCa. 23.06.2018 17:18:08, muudetud 1 kord
having a slower buddy when zombies are chasing you...well, thats a lifesaver _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Kõik oli OK.. Seni kuni riietekotiga lombi põhja vajus ja seletas, et kott on nüüd väga raske ja peab seljast ära võtma. Fu*k logic and physics. _________________ Steam profiil
Children play Call of Duty.. Boys play Battlefield.. Men play ARMA
fragile, sul on mingi parem lahendus sellele probleemile?
mine community foorumisse ja räägi välja siis, äkki muudavad ära.
Oleks seal kivid, metall, vms. veest tihedam ja raskem materjal, siis oleks OK. Riietekott peaks just takistama sukeldumist. Oleks valik kuhu kott sättida. Selja peale või rindkere alla Teeks pükstest vms. õhupadja ja ulbiks vee peal. Veest välja tulek oleks muidugi piin..
Hästi imavad materjalid saab ikka kuivaks pigistada/väänata ja edasi vantsida.. _________________ Steam profiil
Tundub väga huvitav idee poolest olema.. aga mulle tundub, et aina popimaks lähevad need massiivsed 50-100 inimese battle royali tüüpi mängud.. kuda sellel mitmikmänguga lood olema saavad? _________________ Minu Youtube - HDTanel
Täna kohe varsti saadaval siis EA kujul. YT sai vaadatud veits videosi ja hetkel jääbi selline paremini tehtud (vähemalt tehniliselt ja võimaluste poolest) DAYZ SA tüüpi mäng. Ja hetkel tundub, et sellest võiks isegi äkki asja saada. Siin miski viimane näide...ei midagi erilist aga vähemalt näeb reaalset mängu
https://www.youtube.com/watch?v=0ZUxnJtMewU
Näha et alguse asi aga samas tundub põnev. Sittusin, oksendasin, kusesin, oleks peaaegu nälga surd jne aga lõpuks sai relv leitud ja ainsad 10 kuuli mingi roboti pihta ära taristatud.
Kas asjad tagasi ka spawnivad serverisse?
Ja mis on ENG ja kuidas selle nullist üles saab jälle? _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Ostin ära, kuna pubgi kohvrite raha oli üle . Paar tundi mängitud. Tundub lahe. Võiks öelda jah, et midagi nagu dayz ja tarkovi ristsugutis. Eks ta bugine on aga annan andeks kuna EA. Samas otseselt midagi mängu lõhkuvat ette ei sattunud. Kõige suurem probleem vist hetkel serverid ise. Kui on tublid devid siis loodan, et sellel mängul on tulevikku.
RustyZ, ja tundus et spawnivad küll ag kuidas või kui tihti ei ole kindel veel. Ja tundub, et viimase patchiga see ENG lihtsalt "katki". Muidu vist peaks see enamvähem sööki tähendama.
Mnjah mul pold ka normi sööki ja laksisin terve koti meresoola sisse. Kehas oli sodiumi 3200% pärast... _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
näeb seal mängus üldse inimvastaseid ka? või ongi peamiselt selline söömine ja sittumine ning kusemine teemaks? mismoodi asi üldse välja näeb, nagu aru saan ei ole seal vist mingeid ajaliselt kindlal hetkel algavaid ja lõppevaid matche, vaid lihtsalt erinevad serverid kuhu suvalisel hetkel siis kes iganes sisse logib? peale surma saamist spawnid kuskil baasis ja oled kogu oma kraamist ilma? _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Näeb ikka. Täna sai mängitud ja juba suht mitu relva kogutud ja paar venda mahagi taristatud a no naiivselt sai sõpradega keset teed ja linna lõke tehtud et lihhi küpsetatud kui järsku rahvast kogunema hakkas. Veidi sai neid nahutatud sest kellelgil midagi asjalikku pold v olid kuulid otsas. Lõpuks tuli mingi xiiter kes eiteakust ilmus relvadega ja maha tõmbas.
Kui surma saad oled gearist ilma jah aga saad shelteri ja storage omale tekitada kuhu asju jätta ja pärast saad sinna spawnida kui sured. Kui shelterit pole spawnid lambikohta. Sellessuhtes veidi jama et kui sõbraga oled ja kaardi erinevatesse otsesse spawnid siis võtab terve igaviku et kokku saada.
Hetkel meeldib kui veel edasi ka arendatakse... Selline rahulik toksimine ja peab ikka ettevaatlik olema. Üldiselt voissis osad küsivad et kas oled sõbralik. Mul ikka komme öelda et jep olen ja siis kuvaldaga pähe taguda... _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Heh, siis on nagu Nextday:survival, süsteem sisuliselt täpselt sama.
Aga tõsi jah, seal oli enamasti sama teema, et mingid vennad kukkusid friendly juttu rääkima ja siis suvalisel hetkel killisid sind selja tagant ära ega midagi, sai siis edaspidi lihtsalt valimatult kõigile tina antud kohe kui mingi kontakt oli. Aga tegelikult muidugi sedatüüpi mängudes oleks mõistlik kui alati ja kõigile tina andma ei pea...pole ju laskemoona ka lõputult.
Mis ta muidu on selline "feels like arma 3" või? ma mõtlen liikumine ja üldine mängutunnetus _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Ise pole veel pelanud, aga vist on mingi Fame teema selles? Võibolla kunagi lähitulevikus, kui väga palju KoS hakkad, siis on ka tagajärjed?
On keegi kursis dev'ide tulevaste plaanidega?
Fame teema hetkel jah. Saad kaautada spawnides (valida sektorit nt) ja saad juurse kui tapad mängijaid, zombiesid, craftid, situd jne. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Mis siis saab kui surma saad? Mäng läbi? Või kaotad lihtsalt asjad või mis?
Kaotad asjad. Fame eest saad muidugi vist mingite asjadega spawnida. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
kurat mõtlesin ka selle ligi võtta, tuli välja, vaatasin vähe striime ja jõudsin selgusele, et paku huvi hetkel siiski. Selline dayz sugune jooksmine suht, et loodi ja ehk leiad kellegi keda maha kõmmutada.
Ma üldiselt survivalist ootan, et saad endale maja vallutada kuhu oma nodi vedada ja lõkse ja värke teha et teistel vallutamine keerulisem oleks. Või siis baaside ehitus nagu h1z1 oli või miscreated on. siis nagu oleks miski eesmärk võtta mille nimel seda manti korjata ja jamada. lisaks söök ja jook peaks üsna oluline olema ning pve element ka sees.
Ehk siis hetkel no thx, võin dayz ka joosta kui vaja. _________________ LehesFoto - Täis suvaklõpse ja muud
Ma ei tea miks seda survival mänguks nimetatakse. See on lihtsalt tavaline looting shooter.
Arendajad lisavadki võimaluse maju vallutada mitte neid ise ehitada. Söömine on ka siin mängus väga tähtis ja väga täpseks viidud. Sööd liiga palju viskab üles. Sööd toorest kraami liiga palju lööb põhja alt ära. Kui sööd pead kõigepealt seda seedima, et vajalikud ained kohale jõuaksid.
Pead jälgima millal oma vetsu hädad ära teha, muidu võib juhtuda, et poole sõdimise pealt läheb tegelane sund hädale. Kui on kõhulahtisuse kõrge taase võib iga hetk sund väljutamine toimuda.
Pead jälgima söödavaid ja kulutatavaid kaloreid, kui kulutad rohkem ei taastu energia ära. Kui sööd rämpstoitu lähed paksuks jne. Lisatakse veel haigused. Sul on hamba counter, kui hambad kõik välja lüüakse pead pehmele toidule minema muidu pekkis.
Sellel on väga palju potentsiaali arvestades mis kõik veel tulemas on.
Kahjuks eemaldati eile zombied, ilmselt põhjustasid serveritele probleeme. Hetkel esineb ka desync probleeme.
Aga tegu on ka alles kolmanda päevaga ja arendajad ei arvestanud sellise koormusega mis peale tuleb, hetkel mäng steami top 10 mängitavate mängude seas.
Ka seda nüüd natuke aega mänginud. Toitu leidub hetkel väga vähe ja üsna raske on midagi hamba alla leida. Ja nagu ikka parem. Loot on seal, kus on militaarvärki. Aga seal liiguvad robotvalvurid ringi ja lasevad su lasu või kahega sodiks, kui ette peaks jääma. Siiani pole eluga veel minema pääsenud Muidu tundub täitsa äge ja panustan ilmselt veel aega asja uurimisele. Relvi olen küll leidnud, aga siis pole kuule või vastupidi. Ja kaart on küll suur. Kuskile asustusse jõuda võtab ikka omajagu vantsimist läbi metsa.
Ei ole veel Eesti servut trehvanud. Küll aga trehvasin kolmes erinevas servus Wallhack/teleporter/aimbot tüüpe. Keegi RIGGS nimeline võttis mind 3 korda maha
Ootan natuke millal nad uue patchiga välja tulevad ja anti-cheati tööle panevad.
Mäng ise päris hea ajaviide. Vahest tõesti on jama,et relvi leiad aga siis pole kuule võtta ja vastupidi. Sööki, jooki jagub enamasti, aga keeruline leida korralik seljakott kuhu asju mahutada.
5/7 mäng
Korraliku seljakoti leiab ilmselt lennuraja juurest. Siiani olen vähemalt saanud sealt. Aga kuna see militaar ala ja seal robotid kaitsevad teritooriumi, siis võib üpris kergelt surma saada. Hetkel pole veel elusana välja tulnud Sisse on kuidagi lihtsam saada
Isegi kui õnnestub relv ja sobilikud kuulid siis on vaja ka salve, vastasel juhul paneb rauda ainult ühe kuuli ja sellega midagi väga teha pole Striimereid vaadates olen näinud suht tihti automaat relvi korralike sihikute ja asjadega, ei kujuta ette kaua nende otsimine-tegemine aega võttis.
5/7 mäng
16 slotine kott on väga lihtne kohe craftida või pead silmas veel suuremat koti leidmist. Anti-cheat pandi ka peale, eks paistab kuidas töötab.
Paar päeva mängitud, ütleks, et relvi ja varustust leidub just aga sööki ei leia. Vend pidevalt nälgas Lennujaamas põhi action, mujal haruharva kui kedagi kohtad aga samas, metsad ja põõsastik nii tihe, et suht lihtne peitu joosta kui vaja. Mäng ise on ikka väga ilus ja kõik info mis sa oma tegelase kohta näed ikka väga lahe.
Üks hea koht lennujaamas, kus segamatult sniperdada
Mulle meeldib.
Kui veel mingeid missioone ka lisatakse ajapikku siis vapsee äge mäng.
Mõnusalt peab igast asjade peale mõtlema ja mängustiile on erinevaid. Kas lendad kohe kuskile sõjaväebaasi lootima või pigem käid läbi väiksemaid kohti, ehitad shelteri ja arenad end vaikselt... Tempo mõistlik. Tühja kõhu peale ärge painkillereid võtke. Mul minestas tegelane ca 5ks minutiks ära ja lebas lihtsalt mõnda aega enne kui püsti tagasi sai _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
Mulle meeldib.Tühja kõhu peale ärge painkillereid võtke. Mul minestas tegelane ca 5ks minutiks ära ja lebas lihtsalt mõnda aega enne kui püsti tagasi sai
Mind ründas karu. Tuli pea ees mulle täpselt peale. Saun pumbaga ühe lasu ka teha tema suunas, aga see ei muutnud midagi. Vana jooksis mu pikali. Esiteks arvasin, et olen surnud, aga kutt tõusis püsti ja jooksin edasi Relv kukkus maha ainult
Karu tahab üsna korralikult tappa saada, isegi SVD headshot ei võta maha. Samas, kui jagu saad lõpuks, võid omale kobeda karukostüümi meisterdada
Hetkel siin rahvaga lambises euro serveris. Pulli päris palju saanud ja trussaritega vendi vastu joost kes punuma pist sest suht hea gear seljas (AKM + scope jms). Enamasti käib mingi liigutamine suht military alade juures sest enamus rahvast tuiab otsib looti. Ise pigem asju kogund ja metsa storagesse peitnud ja vaatab mis edasi saab. Kaart nii suur et võimalusi on palju.
Hetkel meeldib. Vahel võiks kellelegi kuuli ka aint anda
EDIT: hõiska veel enne õhtut. kogu töö tühja, swipe oli mingi uuendusega
Loomade jahtimine on küll natuke sarnane wild huntiga. St zuumids näed helendavaid jälgi ja kui loomale oda sisse viskad siis jookseb jeehat ja vererea järgi leiad laiba pärast. Jumala okeilt on iga asja peale siin mängus mõeldud. _________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled)
ja kas looti peitmine storage'sse tähendab seda, et otsid kuskil mapi peal mingi suvalise kännualuse välja ning lihtsalt jätad oma kraami sinna maha? või on mängus mingid teatud ametlikud storage space'd? hea oleks kui vähemalt kuskilt oleks võimalik pärast respawni mingi osa oma kraamist, ehk siis varemalt ära peidetud kraamist tagasi saada _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Tükeldada saab kõiki. Nii zombiesid, loomi, teisi mängijaid kui ka OMA LAIPA. St sured ära leiad laiba ja pärast võid ennast ära süüa pm.
Shelteri ehitamine on hetkel craftimine. Vead oksi kokku, teed köit ja siis ehitad väikse katusealuse. Sinna saad pärast FAME pointide eest siis spawnida. Fame pointe kogud erinevate tegevuste eest - nt craftimine, tapmine jne. Tulevikus saab olemasolevaid maju turvalisemaks ehitada et sinna oma baas nö teha.
Storage on nii et pead lauajuppe puudest omale tegema (võtad puid maha ja siis raiud lauad neist) ja siis kasti ehitama. Kasti jätad shelteri juurde ja lappad hädavajalikku täis mida kaasas tassida ei taha. Peale surma vähemalt midagi siis olemas. Võimalus on et teised leiavad ja tühjaks teevad muidugi - seega Storage tuleks ehitada kohta kus kõige vähetõenäolisemalt kedagi sattuda võib. Kuna kaart on massiivne jalaliikumise jaoks siis muidugi võimalus et keegi leiab on väike (ptui ptui ptui).
Minu mängu käik on üldiselt - kiire lootring et saada vähemalt mingi relv ja seljakott (seljakotti saab craftida ka). Tappa mõni loom toiduks, süüa alguses toorest. Otsida shelteri koht ehitada shelter ja storage. Siis lõke, toit küpsema toores toit storagesse ja lõkkematerjal ka et igal ajal võtta oleks. Siis käin sama sektori linnad asjad läbi et leida kraami kuulide craftimiseks ja vaikselt tiksutan ka military baase kus parem loot. Viimastega tuleb ettevaatlik olla sest üldiselt ronivad sinna PUBGi fännid kelle mängu mõte ongi kohe laksust sind maha lasta, isegi kui sa trussarites veel ringi jooksed (see on mõttetu tegevus. kõige mõistlikum tappa mängijaid kellel on looti ka ja kes tunduvad olevat kauem elus olnud - st sa saad neilt fame pointe tappes rohkem endale).
EDIT: Kui karu leiad ja noh vaja mütsi...ehk....tavaline neljapäevaõhtu SCUMis
hmm, need shelterid seega ikka jäävad alles peale surma saamist, aga mis neist saab siis kui sa lahkud serverist ning mängust ja näiteks tuled uuesti mängima järgmine päev? ning mängid teises serveris?
kui see valmis ehitatud storage kast ja ära stashitud kraam endiselt alles on ja säilib ka järgmiseks mängu tulekuks sõltumata serverist, kus mängima hakkad siis nagu aru saan tähendab see samas ka seda, et kes iganes võib kogu selle aja vältel su looti otsa komistada ja selle tühjaks teha. ehk siis see on kõigi mängijate jaoks nähtav alati peale seda kui oled selle valmis meisterdanud? _________________ "There will be an entire generation of deaf audio enthusiasts who were brought up on CD players and Best Buy receivers, electronic music and so on. These people won't know good sound if it bites them in the ass, so in the end the industry wins."
Jah nii on. Aga kui oled oma varjualuse valmis ehitanud ja asjade hoiustamiseks kasti ka, siis on üsna vähe tõenäoline, et keegi selle otsa komistab, eriti kui on see veel kusagile tihedasse metsa ära ka peidetud. Sest mapp on ju hiiglama suur. Eks võimalus on alati, et keegi leiab muidugi.
Mis moodi neid pikki oksi kõige mõistlikum transportida on? Seni seda käes ükshaaval teinud. Jube tüütu
EDIT: Sain juba Youtube kaudu oma küsimusele vastuse.
