mine lehele eelmine  1, 2, 3 ... 177, 178, 179 ... 635, 636, 637  järgmine
sõnum 26.02.2018 17:00:31 vasta tsitaadiga
Tekstina: https://www.gamersnexus.net/guides/3244-amd-r5-2400g-memory-kit-benchmarks-and-single-vs-dual-channel
Kokkuvõte
"One thing’s for certain: Going with multi-channel configurations is a must on the Raven Ridge APUs – at least, it is for the games we tested. If debating between 1x8GB stick and 2x4GB sticks, go 2x4GB. It will matter in the games we’ve tested, and likely many others. Keep in mind that, as usual, there are about a million variables at play. Switching motherboards, BIOS revisions, or memory kits will impact performance. A lot of the performance testing here is based upon auto XMP configurations, which means that further tuning can be done by the user or the motherboard manufacturers to boost performance. That’s not what our test goal was, though.
Back to the content, though, memory certainly matters – but not every region can spend just a few dollars to go from 2933 to 3200. And besides, even if it’s “only” another $15, that doesn’t make it worth it. As the results show, 2933 can be perfectly adequate and barely disparate in performance; further still, adding $15 means you really might as well re-evaluate whether a dGPU + cheap CPU will achieve the same goals, because every dollar counts in these budget classes. There is no room for being wishy-washy. You either are buying Raven Ridge or you aren’t, and that will be predicated entirely on the budget. Memory is part of the budget."
anubis
anubis
sõnum 26.02.2018 22:22:03 vasta tsitaadiga
Ma olen üsna kindel, et järgmise põlvkonna APU tippmudel saab endale 4GB HBM2 klotsi kõrvale.
Näiteks Zen2 CCX (mitte Zen+) <-> Navi moodul+HBM2
Viilutaja
Viilutaja
sõnum 26.02.2018 22:53:53 vasta tsitaadiga
Ma mõtlen, et nad oleks võinud seda juba praegu teha... mitte Intelile oma techi pakkuda.
Aga see Inteli i7-8809G 4/8 prose ja Vega M gpu on päris võimekas juba thumbs_up.gif GTX770 tasemel.
https://ark.intel.com/products/130409/Intel-Core-i7-8809G-Processor-with-Radeon-RX-Vega-M-GH-graphics-8M-Cache-up-to-4_20-GHz
https://www.techpowerup.com/gpudb/3056/radeon-rx-vega-m-gh
Kogu kupatus ainult 100W TDP.
See võib päris populaarseks saada kui nüüd kohe välja tuleb ja sobiv odav emme ka olemas on. Sest GPU'de hinnad on päris kirved. Kuid selle Vegaga saaks juba pelada 1440p resol. thumbs_up.gif
anubis
anubis
sõnum 26.02.2018 22:57:19 vasta tsitaadiga
AMD vajab raha, Intelil seda on. Lisaks interposer-less ühilduva tehnoloogia kasutusõigus.
Win-win.
Navi on esimene infinity fabricut toetav GPU, loogiline oleks siis CPU ja GPU juppe omavahel siduma hakata. Pole vaja jalgratast leiutada vaid saab lihtsalt Legodega mängida.
Viilutaja
Viilutaja
sõnum 26.02.2018 23:04:05 vasta tsitaadiga
anubis kirjutas:
Win-win.
Njah, kuid kas nad seda tehnoloogiat pärast oma CPU+GPU "liitmisel" tohivad kasutada?
sõnum 26.02.2018 23:05:50 vasta tsitaadiga
enam kui tõenäoliselt ei tohi. mitte, et sama techi väljatöötamine amd-le üle jõu peaks käima. okei, mitte sama sellepärast et patendid ja asjad, aga midagi sarnast.
- londiste
anubis
anubis
sõnum 26.02.2018 23:09:32 vasta tsitaadiga
CPU ja GPU oleks omavahel infinity fabricuga seotud, samamoodi nagu hetkel Zen moodulid Threadripperi/Epyc'u peal.
Inteli interposerless GPU<->HBM2 samas võimaldab AMD'l neid Navi klotse odavalt piisavalt kiire mäluga siduda samal pakil, ilma suure interposeri lahmakata millel nad kõik istuvad (nagu hetkel Suur Vega/GP100/GV100).
(krt, kuskil oli mingi paber sellekohta, et AMD hakkab EMIBit kasutama..ei leia)
viimati muutis anubis 26.02.2018 23:15:54, muudetud 1 kord
sõnum 26.02.2018 23:16:14 vasta tsitaadiga
anubis, kahtlane.
eeldades, et zen2 ccx ei ole väiksem kui esimene (mis ilmselt ei ole vale eeldus), siis on see ~200 mm²
selline midrange gpu nagu 8809g peal hetkel, on ümmarguselt samuti ~200 mm²
hbm on ~90 mm²
juba puht füüsiliselt on seda am4 peale raske mahutada. tr4 socket, mingi kolmas?
8809g hinnast ei räägita targu midagi aga selle baasil nuc tuleb $999. selline legotamine on kallis lõbu.
muide, see kivide suurusjärk kokku on juba kuskil inteli hcc (18-core, a la 7980xe/18c xeonid) kandis, see peaks olema kuskile 500mm² alla.
anubis kirjutas:
ja emib on kahtlemata inteli poolt ära patenteeritud. ma ei usu küll, et konkurendil seda niisama kasutada lastakse...
- londiste
anubis
anubis
sõnum 26.02.2018 23:21:04 vasta tsitaadiga
Hops. Leidsin, juba kasutavad.
https://videocardz.com/74712/amd-finally-announces-discrete-mobile-radeon-vega
Z-height on sama mis i7-8809G pakil, seega ei ole võimalik täis-interposeri kasutus. AMD ei anna intelile lihtsalt niisama midagi, intel ei anna samamoodi AMD'le icon_smile.gif Quid pro quo.
Samas on nad ühiselt Nvidia vastu.
viimati muutis anubis 26.02.2018 23:22:10, muudetud 1 kord
sõnum 26.02.2018 23:22:41 vasta tsitaadiga
emib-ist ei räägita seal sõnagi.
- londiste
anubis
anubis
sõnum 26.02.2018 23:35:55 vasta tsitaadiga
See ei ole interposer, miks nad ta nii palju suurema teeksid? Nende äärte arvelt saaks 10-15% väiksema interposeri teha.
Radeon Vega Mobile on 1.7mm Z-height pakil ja minumeelest täis-interposeriga seda teha pole võimalik. 1.7mm Z-height on samas 1-1 Inteli EMIB
https://foorum.hinnavaatlus.ee/viewtopic.php?p=9710856#9710856
Aga eks näeb, mina kalduks selle quid pro quo poole.
sõnum 26.02.2018 23:43:25 vasta tsitaadiga
anubis, kus pakil, mis? 8809g on 1.7 mm aga see on inteli toode, mitte amd oma.
võin kihla vedada, et intel emib tehnoloogiat amd-ga ei jaga.
pilti vega mobile välja kuulutamiselt?
- londiste
anubis
anubis
sõnum 26.02.2018 23:48:43 vasta tsitaadiga
Radeon Vega Mobile discrete ja 1.7mm z-height on samal slaidil, see pole i7-8809 kohta.
Ma spekuleerin, nagu eelnevalt ka kirja panin :p
Viilutaja
Viilutaja
sõnum 26.02.2018 23:51:36 vasta tsitaadiga
londiste kirjutas:
NUC'd on üldiselt +25% kallimad ka sama võimsast lauakomplektist.
Kuid jah, see on selline kombo mis on juba joodetud emaplaadile (NUC või läpakas) ning "lauaarvuti" versiooni kahjuks vist ei tule.
sõnum 02.03.2018 14:43:56 vasta tsitaadiga
link :: Prozessorgerüchte: Ryzen 7 2700X bietet 300 MHz mehr Takt als der 1700X
Ryzen 2700x on netist silma jäänud, ca 300MHz kõrgemate kelladega kui 1700x.
ebardkonn
ebardkonn
sõnum 02.03.2018 15:16:05 vasta tsitaadiga
anubis kirjutas:
Aga muidu, mängimiseks, kärab see APU kuhjaga. Minu nõudmised, üldiselt, täidab ära. Proovisin eile:
Civ6'te, jooksis ~30fps @1080p kõik kellad-viled põhjas v.a. AA.
GTA5, 1080p medium-high kõikus 30-50 vahel.
Mingeid framerate droppe pole märganud? Endal sai ostetud 2400G/Asus 350B-plus/DDR4 8GB dualis 2666mhz( icon_sad.gif ) ja näiteks Overwatchis üdliselt framerate täiesti viisakas, aga mingi x ajatagant tuleb väga korralik drop 30fps peale, mis FPS mängudes just väga meeldiv pole. Võimalik, et driverite/firmware uuendustega asi paraneb, aga hetkel suht hapu.
Kommentaarid: 6 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 5
anubis
anubis
sõnum 02.03.2018 15:19:28 vasta tsitaadiga
Kusjuures, 2133 peal, kui mul mälu kogemata default'i jooksma jäi, märkasin. 2933 peal enam väga silma ei hakanud.
Jälgi mälukasutust, äkki ta swapib. Ma panin beta biosi peale emaplaadile ja siis lubas kuni 16GB videokaardile eraldada, ma panin 4GB peale. Ei tea kas see toimis, samas. Programmid näitasid kõik nagunii 1GB.
Ahjaa, GPUz jooksutas iga kord kokku masina, sõltumata sellest kas kõik oli default või OCtud.
sõnum 02.03.2018 15:24:00 vasta tsitaadiga
anubis, GPU-Z 2.8.0 pidi selle kokkujooksmise parandama nende uute APUdega.
ebardkonn
ebardkonn
sõnum 02.03.2018 15:37:10 vasta tsitaadiga
anubis kirjutas:
Mmh, hetkel eraldasin giga. Õhtul vaatan mis elu see mälu elab. Proovin ta 3000 peale clockida. Need BALLISTIX SPORT LT pole just imelised mälud, aga will see. Peaks kelleltki ajutiselt mälu juurde laenama ja vaatama, mis nägu ta siis läheb. Kui asi paraneb kõvasti siis on ez fix.
Divisor
sõnum 02.03.2018 17:59:53 vasta tsitaadiga
Insomnia
Insomnia
sõnum 02.03.2018 22:00:39 vasta tsitaadiga
ebardkonn kirjutas:
Siin käsitletakse neid langusi
https://www.youtube.com/watch?v=Ev3s0jYVwOo
ebardkonn
ebardkonn
sõnum 03.03.2018 00:29:15 vasta tsitaadiga
Insomnia kirjutas:
ebardkonn kirjutas:
Jeee, ma pmst mingi tund aega päeval üritasin seda videot leida kuna oli meelde jäänud, et kuskil oli sellest juttu.
Aga igastahes panin kordaja 39 peale lukku, temp püsib full loadis mingi 61-62 kandis, 2666 mälud läksid 3066 peale ,aga panin nõksu tagasi 3000 peale , parandasin timinguid veits ja volt sai 1,3.
Igastahes tegin ühe Overwatchi pela ja 0 laggi või freezi ja jooksis imeliselt.
Täitsa tore oli õlle kõrvale üle pika aja masina kellasid mudida, viimati tegin seda, kui teemas oli Athlon XP 2500+ icon_biggrin.gif .
Insomnia
Insomnia
sõnum 03.03.2018 00:35:50 vasta tsitaadiga
Seal mõeldi ikka vast GPU overclocki. Ma arvan et need dropid on seotud voolujagamise mehhanismiga gpu js cpu vahel. 2400g tundub neid rohkem esinevat.
Denkeš
Denkeš
sõnum 03.03.2018 01:14:15 vasta tsitaadiga
ebardkonn kirjutas:
Siis sai suurel määral FSBga ka mängida.
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
ebardkonn
ebardkonn
sõnum 03.03.2018 01:46:24 vasta tsitaadiga
Insomnia kirjutas:
Tõsi, kuulsin valesti. Aga tundub, et hetke lahendus töötab väga hästi ja sujuvalt, nii et las ta jääda esialgu.
EDIT: proovisin hommikul üle, et mis juhub, kui cpu kordaja auto peale tgsi panna ja stutter oli tagasi. Nii et peab ütlema, et minu jaoks on fixed kordaja vajalik ja 3000mhz peal mälu good to have.
viimati muutis ebardkonn 03.03.2018 10:14:31, muudetud 2 korda
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 177, 178, 179 ... 635, 636, 637  järgmine
