videvik
08.01.2018 20:09:18
viimased kaks linki on siin üsna offtopic.
_________________ - londiste
216 |
196 |
7 :: |
360 |
M00t
| Kommentaarid: 73 loe/lisa |
69 |
| Kommentaarid: 92 loe/lisa |
09.01.2018 09:40:30
https://support.microsoft.com/en-us/help/4073707/windows-operating-system-security-update-block-for-some-amd-based-devi
| Microsoft has reports of customers with some AMD devices getting into an unbootable state after installing recent Windows operating system security updates. After investigating, Microsoft has determined that some AMD chipsets do not conform to the documentation previously provided to Microsoft to develop the Windows operating system mitigations to protect against the chipset vulnerabilities known as Spectre and Meltdown. To prevent AMD customers from getting into an unbootable state, Microsoft will temporarily pause sending the following Windows operating system updates to devices with impacted AMD processors at this time: |
216 |
09.01.2018 09:44:08
AMD probleem on tegelikult juba mitu päeva vana uudis.
Uus uudis on pigem see, et
- neid AMD prosasid võib olla palju rohkem mudeleid kui on senini välja hõigatud.
- ka mõnede Inteli enda prosadega võib süsteem samamoodi kokku lennata.
Väike tsitaat Softpedia mitu päeva vana loo - kuid uuendatud tänaseks - kommentaariumist:
I am incurring the same issue with an Intel Core i5 64-bit procecessor!
ning lisaks ohtralt näiteid AMD prosade kohta.
Windows 10 Cumulative Update KB4056892 (Meltdown & Spectre Fix) Fails to Install UPDATED
Users complaining of boot issues after installing the patch
http://news.softpedia.com/news/windows-10-cumulative-update-kb4056892-meltdown-spectre-fix-fails-to-install-519238.shtml
211 |
09.01.2018 09:47:50
uuenduste ebaõnnestumiseid ikka aeg-ajalt juhtub. sellest pole veel mõtet kaugeleulatuvaid järeldusi teha.
216 |
seeru
09.01.2018 10:58:16
| londiste kirjutas: |
Alles eile öösel muudkui ronis ja ronis vägisi peale.
Õnneks olid taastuspunktid olemas.
viimati muutis seeru 09.01.2018 10:59:47, muudetud 1 kord |
Gap
| Kommentaarid: 21 loe/lisa |
17 |
216 |
seeru
09.01.2018 11:03:04
seeru, sa elad vana athloni või phenomi otsas?
jooksid sama ebaõnnestuva installi otsa, kuidas probleemi lahendasid? |
Mul on kümmekond arvutit pidevas testolukorras. Ka mõned vanad.
Vajutad paar korda power off, liigud advanced settinguteni ja kasutad taastuspunkti. (kui on). Minu omadel on.
09.01.2018 11:28:43
| seeru kirjutas: |
Vajutad paar korda power off, liigud advanced settinguteni ja kasutad taastuspunkti. (kui on). Minu omadel on. |
Microsoft ise ka ei oska midagi muud soovitada, kui Taastamist kasutada,
Ning sama soovituse andis MS ka Inteli chippide tarbeks - kui samamoodi "kinni lendamine on" nagu AMD protsessorite korral:
Q: security update patch for Intel chip issues
I just installed the brand new security update for the processor chip security issues.We have window 10 with an Intel chip and when it rebooted all i am getting is a blank screen and the key board is not working .I know people with AMD chips wete having tjis issue today with the update.How do I get my computer working again? Help!!!!!!
Alden Rey replied on Microsoft
Hi,
The concern you have encountered may be due to a corrupted file or a misconfigured setting. In this case, we suggest you perform a system restore. System restore is a utility tool by the Microsoft in Windows Operating System and by using this tool, you can make your computer’s operating system back to normal if you're facing issues. To do this, simply click on the article below and follow the steps accordingly.
Recovery options in Windows 10
Should you need further information, don't hesitate to contact us.
Regards.
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/security-update-patch-for-intel-chip-issues/4dc88398-9857-47e2-a57d-dbdf0e03f176?auth=1
211 |
Alan
09.01.2018 15:51:59
Tegin ühed UnixBenchi runnid enne ja pärast kerneli patchi Xeon E5-2670 peal:
Vasak = Enne
Parem = Pärast
File Copy sai päris korraliku põntsu.
121 |
7 :: |
360 |
DVDRW
| Kommentaarid: 28 loe/lisa |
XeStAiSy
Aeg Maha 2a
10.01.2018 10:03:34
Selle kuu lõpus tuleb veel intelilt patche mikrokoodi 5 aastavanused cpud saavad uue patchi, aga vist mitte vanemad.
Ilmselt tootjad ei paku neid uuendusi z97 ja vanema peale ja BIOS tuleb ise muuta.
| Kommentaarid: 12 loe/lisa |
10.01.2018 11:03:20
understanding the performance impact of spectre and meltdown mitigations on windows systems (microsoft secure blog)
Here is the summary of what we have found so far:
- With Windows 10 on newer silicon (2016-era PCs with Skylake, Kabylake or newer CPU), benchmarks show single-digit slowdowns, but we don’t expect most users to notice a change because these percentages are reflected in milliseconds.
- With Windows 10 on older silicon (2015-era PCs with Haswell or older CPU), some benchmarks show more significant slowdowns, and we expect that some users will notice a decrease in system performance.
- With Windows 8 and Windows 7 on older silicon (2015-era PCs with Haswell or older CPU), we expect most users to notice a decrease in system performance.
- Windows Server on any silicon, especially in any IO-intensive application, shows a more significant performance impact when you enable the mitigations to isolate untrusted code within a Windows Server instance. This is why you want to be careful to evaluate the risk of untrusted code for each Windows Server instance, and balance the security versus performance tradeoff for your environment. |
cpu bug patch saga: antivirus tools caught with their hands in the windows cookie jar (the register)
216 |
lynxfelinae
10.01.2018 13:43:30
HPSBHF03573 rev. 2 - Side-Channel Analysis Method
https://support.hp.com/us-en/document/c05869091
Mudelite nimekirja järgi saavad HP äriklassi toodest ka Sandy Bridge ja Ivy Bridge genratsiooni arvutid BIOSi uuenduse.
| Kommentaarid: 254 loe/lisa |
214 |
XeStAiSy
Aeg Maha 2a
OPollo
| Kommentaarid: 7 loe/lisa |
pois11
10.01.2018 19:31:32
| Kas mul tuleks ka miskit teha.. plaadaiks asus H87M-Pro ja tundub üsna vana olevat.
109 |
XeStAiSy
Aeg Maha 2a
10.01.2018 19:43:54
| pois11 kirjutas: |
| Kas mul tuleks ka miskit teha.. plaadaiks asus H87M-Pro ja tundub üsna vana olevat. |
Intel väidab et nurub tootjaid et need viie aasta vanused cpud saavad patchi. Asus hetkel mängib kuningat ja listis pole vanemaid.
Seega tuleb kuullõpp ära oodata kuniks intlel ka see viimased 10% mikrokoodidest saavad tehtud.
Kui siis ka märki pole ja tootjad ei viitsi lillegi liigutada siis tuleb ise teha. Ennast harival eesmärgil võib muidugi ise teha. Need mis tootja teeb võivadki beta jääda.
10.01.2018 19:51:21
| Margus kirjutas: |
| pois11 kirjutas: |
Kui siis ka märki pole ja tootjad ei viitsi lillegi liigutada siis tuleb ise teha. Ennast harival eesmärgil võib muidugi ise teha. Need mis tootja teeb võivadki beta jääda. |
Ole ikka täpne ja ikka jälgi mida Intel "kokku on kirjutanud"...
Intel ei kirjuta Mikrokoodi Patchi ainult Microsofti sõpradele vaid kirjutas Mikrokoodi Patchi ka Linuxi sõpradele.
Loe ja imesta kuidas Intel "möllab mitmel rindel":
Intel Releases Processor Microcode Patch for Linux OSes, Here's How to Update
Linux Processor Microcode Data File 20180108 is out now
Intel has released an updated microcode patch for Linux-based operating systems to address the Meltdown and Spectre security vulnerabilities.
By now, everyone heard about Meltdown and Spectre, two severe hardware bugs that affect billions of devices, putting them at risk of attacks as unprivileged attackers could steal your sensitive data stored in kernel memory using a locally installed application or via the Internet using malicious scripts. Intel, AMD, and ARM processors are affected by these security exploits.
Intel promised last week to release updated microcode to address the Meltdown and Spectre bugs, and the patch is finally here, available for numerous of its processors released in the past five years. Users are urged to update the microcode (installation instructions are available below) immediately. The entire list is attached at the end of the article, and Intel has also listed some of the officially supported Linux-based operating systems.
These include Red Hat Enterprise Linux 7.4, 7.3, 7.2, 7.1, and 7.0, Red Hat Enterprise Linux 6.8, 6.7, 6.6, 6.5, 6.4, 6.3, and 6.2, SUSE Linux Enterprise Server 12, SP3, SP2, and SP1, SUSE Linux Enterprise Server 11, SP4, SP3, SP2, and SP1, SUSE Linux Enterprise Server (SLES) 12.2, CentOS 7.4, 7.3, 7.2, 7.1, and 7.0, Debian 8.x and 7.x, Fedora 24 and 23, as well as Ubuntu 16.04 LTS and 14.04 LTS.
Intel also lists Red Hat Linux, SUSE Linux, Ubuntu, OpenDesktop, Google Chrome OS, and Chromium OS as supported operating systems, which means that any distro based on these OSes can be updated. Therefore, we recommend all OS vendors to download this patch and port it to their GNU/Linux distribution if it's based on Ubuntu, SUSE, Red Hat, etc.
Edasi;
http://news.softpedia.com/news/intel-releases-processor-microcode-patch-for-linux-oses-here-s-how-to-update-519316.shtml
211 |
