videvik
08.01.2018 20:09:18
viimased kaks linki on siin üsna offtopic.
_________________ - londiste
217 |
196 |
09.01.2018 02:43:58
Haakub natuke teemaga
https://randomascii.wordpress.com/2018/01/07/finding-a-cpu-design-bug-in-the-xbox-360/
The recent reveal of Meltdown and Spectre reminded me of the time I found a related design bug in the Xbox 360 CPU – a newly added instruction whose mere existence was dangerous.
Back in 2005 I was the Xbox 360 CPU guy. I lived and breathed that chip. I still have a 30-cm CPU wafer on my wall, and a four-foot poster of the CPU’s layout. I spent so much time understanding how that CPU’s pipelines worked that when I was asked to investigate some impossible crashes I was able to intuit how a design bug must be their cause. But first, some background… |
7 :: |
364 |
M00t
| Kommentaarid: 77 loe/lisa |
73 |
| Kommentaarid: 92 loe/lisa |
09.01.2018 09:40:30
https://support.microsoft.com/en-us/help/4073707/windows-operating-system-security-update-block-for-some-amd-based-devi
| Microsoft has reports of customers with some AMD devices getting into an unbootable state after installing recent Windows operating system security updates. After investigating, Microsoft has determined that some AMD chipsets do not conform to the documentation previously provided to Microsoft to develop the Windows operating system mitigations to protect against the chipset vulnerabilities known as Spectre and Meltdown. To prevent AMD customers from getting into an unbootable state, Microsoft will temporarily pause sending the following Windows operating system updates to devices with impacted AMD processors at this time: |
217 |
09.01.2018 09:44:08
AMD probleem on tegelikult juba mitu päeva vana uudis.
Uus uudis on pigem see, et
- neid AMD prosasid võib olla palju rohkem mudeleid kui on senini välja hõigatud.
- ka mõnede Inteli enda prosadega võib süsteem samamoodi kokku lennata.
Väike tsitaat Softpedia mitu päeva vana loo - kuid uuendatud tänaseks - kommentaariumist:
I am incurring the same issue with an Intel Core i5 64-bit procecessor!
ning lisaks ohtralt näiteid AMD prosade kohta.
Windows 10 Cumulative Update KB4056892 (Meltdown & Spectre Fix) Fails to Install UPDATED
Users complaining of boot issues after installing the patch
http://news.softpedia.com/news/windows-10-cumulative-update-kb4056892-meltdown-spectre-fix-fails-to-install-519238.shtml
211 |
09.01.2018 09:47:50
uuenduste ebaõnnestumiseid ikka aeg-ajalt juhtub. sellest pole veel mõtet kaugeleulatuvaid järeldusi teha.
217 |
seeru
09.01.2018 10:58:16
| londiste kirjutas: |
Alles eile öösel muudkui ronis ja ronis vägisi peale.
Õnneks olid taastuspunktid olemas.
viimati muutis seeru 09.01.2018 10:59:47, muudetud 1 kord |
Gap
| Kommentaarid: 21 loe/lisa |
17 |
217 |
seeru
09.01.2018 11:03:04
seeru, sa elad vana athloni või phenomi otsas?
jooksid sama ebaõnnestuva installi otsa, kuidas probleemi lahendasid? |
Mul on kümmekond arvutit pidevas testolukorras. Ka mõned vanad.
Vajutad paar korda power off, liigud advanced settinguteni ja kasutad taastuspunkti. (kui on). Minu omadel on.
09.01.2018 11:28:43
| seeru kirjutas: |
Vajutad paar korda power off, liigud advanced settinguteni ja kasutad taastuspunkti. (kui on). Minu omadel on. |
Microsoft ise ka ei oska midagi muud soovitada, kui Taastamist kasutada,
Ning sama soovituse andis MS ka Inteli chippide tarbeks - kui samamoodi "kinni lendamine on" nagu AMD protsessorite korral:
Q: security update patch for Intel chip issues
I just installed the brand new security update for the processor chip security issues.We have window 10 with an Intel chip and when it rebooted all i am getting is a blank screen and the key board is not working .I know people with AMD chips wete having tjis issue today with the update.How do I get my computer working again? Help!!!!!!
Alden Rey replied on Microsoft
Hi,
The concern you have encountered may be due to a corrupted file or a misconfigured setting. In this case, we suggest you perform a system restore. System restore is a utility tool by the Microsoft in Windows Operating System and by using this tool, you can make your computer’s operating system back to normal if you're facing issues. To do this, simply click on the article below and follow the steps accordingly.
Recovery options in Windows 10
Should you need further information, don't hesitate to contact us.
Regards.
https://answers.microsoft.com/en-us/windows/forum/windows_10-update/security-update-patch-for-intel-chip-issues/4dc88398-9857-47e2-a57d-dbdf0e03f176?auth=1
211 |
Alan
09.01.2018 15:51:59
Tegin ühed UnixBenchi runnid enne ja pärast kerneli patchi Xeon E5-2670 peal:
Vasak = Enne
Parem = Pärast
File Copy sai päris korraliku põntsu.
121 |
7 :: |
364 |
DVDRW
| Kommentaarid: 28 loe/lisa |
XeStAiSy
Aeg Maha 2a
10.01.2018 10:03:34
Selle kuu lõpus tuleb veel intelilt patche mikrokoodi 5 aastavanused cpud saavad uue patchi, aga vist mitte vanemad.
Ilmselt tootjad ei paku neid uuendusi z97 ja vanema peale ja BIOS tuleb ise muuta.
| Kommentaarid: 12 loe/lisa |
10.01.2018 11:03:20
understanding the performance impact of spectre and meltdown mitigations on windows systems (microsoft secure blog)
Here is the summary of what we have found so far:
- With Windows 10 on newer silicon (2016-era PCs with Skylake, Kabylake or newer CPU), benchmarks show single-digit slowdowns, but we don’t expect most users to notice a change because these percentages are reflected in milliseconds.
- With Windows 10 on older silicon (2015-era PCs with Haswell or older CPU), some benchmarks show more significant slowdowns, and we expect that some users will notice a decrease in system performance.
- With Windows 8 and Windows 7 on older silicon (2015-era PCs with Haswell or older CPU), we expect most users to notice a decrease in system performance.
- Windows Server on any silicon, especially in any IO-intensive application, shows a more significant performance impact when you enable the mitigations to isolate untrusted code within a Windows Server instance. This is why you want to be careful to evaluate the risk of untrusted code for each Windows Server instance, and balance the security versus performance tradeoff for your environment. |
cpu bug patch saga: antivirus tools caught with their hands in the windows cookie jar (the register)
217 |
lynxfelinae
10.01.2018 13:43:30
HPSBHF03573 rev. 2 - Side-Channel Analysis Method
https://support.hp.com/us-en/document/c05869091
Mudelite nimekirja järgi saavad HP äriklassi toodest ka Sandy Bridge ja Ivy Bridge genratsiooni arvutid BIOSi uuenduse.
| Kommentaarid: 258 loe/lisa |
217 |
XeStAiSy
Aeg Maha 2a
OPollo
| Kommentaarid: 7 loe/lisa |
pois11
10.01.2018 19:31:32
| Kas mul tuleks ka miskit teha.. plaadaiks asus H87M-Pro ja tundub üsna vana olevat.
| Kommentaarid: 113 loe/lisa |
110 |
XeStAiSy
Aeg Maha 2a
10.01.2018 19:43:54
| pois11 kirjutas: |
| Kas mul tuleks ka miskit teha.. plaadaiks asus H87M-Pro ja tundub üsna vana olevat. |
Intel väidab et nurub tootjaid et need viie aasta vanused cpud saavad patchi. Asus hetkel mängib kuningat ja listis pole vanemaid.
Seega tuleb kuullõpp ära oodata kuniks intlel ka see viimased 10% mikrokoodidest saavad tehtud.
Kui siis ka märki pole ja tootjad ei viitsi lillegi liigutada siis tuleb ise teha. Ennast harival eesmärgil võib muidugi ise teha. Need mis tootja teeb võivadki beta jääda.
10.01.2018 19:51:21
| Margus kirjutas: |
| pois11 kirjutas: |
Kui siis ka märki pole ja tootjad ei viitsi lillegi liigutada siis tuleb ise teha. Ennast harival eesmärgil võib muidugi ise teha. Need mis tootja teeb võivadki beta jääda. |
Ole ikka täpne ja ikka jälgi mida Intel "kokku on kirjutanud"...
Intel ei kirjuta Mikrokoodi Patchi ainult Microsofti sõpradele vaid kirjutas Mikrokoodi Patchi ka Linuxi sõpradele.
Loe ja imesta kuidas Intel "möllab mitmel rindel":
Intel Releases Processor Microcode Patch for Linux OSes, Here's How to Update
Linux Processor Microcode Data File 20180108 is out now
Intel has released an updated microcode patch for Linux-based operating systems to address the Meltdown and Spectre security vulnerabilities.
By now, everyone heard about Meltdown and Spectre, two severe hardware bugs that affect billions of devices, putting them at risk of attacks as unprivileged attackers could steal your sensitive data stored in kernel memory using a locally installed application or via the Internet using malicious scripts. Intel, AMD, and ARM processors are affected by these security exploits.
Intel promised last week to release updated microcode to address the Meltdown and Spectre bugs, and the patch is finally here, available for numerous of its processors released in the past five years. Users are urged to update the microcode (installation instructions are available below) immediately. The entire list is attached at the end of the article, and Intel has also listed some of the officially supported Linux-based operating systems.
These include Red Hat Enterprise Linux 7.4, 7.3, 7.2, 7.1, and 7.0, Red Hat Enterprise Linux 6.8, 6.7, 6.6, 6.5, 6.4, 6.3, and 6.2, SUSE Linux Enterprise Server 12, SP3, SP2, and SP1, SUSE Linux Enterprise Server 11, SP4, SP3, SP2, and SP1, SUSE Linux Enterprise Server (SLES) 12.2, CentOS 7.4, 7.3, 7.2, 7.1, and 7.0, Debian 8.x and 7.x, Fedora 24 and 23, as well as Ubuntu 16.04 LTS and 14.04 LTS.
Intel also lists Red Hat Linux, SUSE Linux, Ubuntu, OpenDesktop, Google Chrome OS, and Chromium OS as supported operating systems, which means that any distro based on these OSes can be updated. Therefore, we recommend all OS vendors to download this patch and port it to their GNU/Linux distribution if it's based on Ubuntu, SUSE, Red Hat, etc.
Edasi;
http://news.softpedia.com/news/intel-releases-processor-microcode-patch-for-linux-oses-here-s-how-to-update-519316.shtml
211 |
friik1
10.01.2018 20:48:34
Ühe Win7 virtukaga proovisin Broadwelli peal. Päris jube ikka...
171 |
seeru
11.01.2018 11:52:18
| Margus kirjutas: |
Mis sa selle isetegemise all mõtled?
XeStAiSy
Aeg Maha 2a
11.01.2018 12:36:30
| seeru kirjutas: |
| Margus kirjutas: |
Mis sa selle isetegemise all mõtled? |
pagaldad ise bios faili mikrokoodi ja flashid.
seeru
11.01.2018 15:04:56
| Margus kirjutas: |
| seeru kirjutas: |
| Margus kirjutas: |
pagaldad ise bios faili mikrokoodi ja flashid. |
Mingi oma arvuti peal võiks isegi proovida kui õige mikrokood oleks. Kuigi ei tule meelde et oleks ise arvuti biose faile modinud.
11.01.2018 15:22:01
| seeru kirjutas: |
| Margus kirjutas: |
| seeru kirjutas: |
| Margus kirjutas: |
Mingi oma arvuti peal võiks isegi proovida kui õige mikrokood oleks. Kuigi ei tule meelde et oleks ise arvuti biose faile modinud. |
Vähemalt Linuxis, Ubuntu 18.04 korral, laeti automaatselt alla "Intel Micorocode". (Aceri läppar).
Ei olnud vaja midagi endal sebida.
211 |
XeStAiSy
Aeg Maha 2a
11.01.2018 15:42:41
Opponet tahanteada tea siis kui häkker sinu faili keelab ja biosis seda tuge pole siis on samahea kui lappi polegi. Eat that,
12.01.2018 08:52:52
| Margus kirjutas: |
| Opponet tahanteada tea siis kui häkker sinu faili keelab ja biosis seda tuge pole siis on samahea kui lappi polegi. Eat that, |
Järjekordne "paanika-külvajast arvutispetsialist" kes isegi seda ei tea kes pääseb faile keelama ning kes mitte.
Eriti seda Linuxi all - ja nagu ma kirjutasin, on need Inteli Mikrokoodide allalaadmised justnimelt Linuxi-maailmas.
Ja veel - näita kui palju on neid tavaarvutikasutajaid kes üleüldse omavad oskuseid, tihti ka Progammeerimis-seadmeid kus see BIOS-i kivi õigesti üle programmeerida. Ilma et seda BIOS-i kivi "telliseks" lendaks.
Teemasse kah:
Nüüd on siis AMD ise ka väljastanud Spectre parandused.
AMD Releases Linux and Windows Patches for Two Variants of Spectre Vulnerability
Urges users to update their systems accordingly.
AMD has published a press announcement on Thursday to inform its customers that it released patches for two variants of the Spectre security vulnerability disclosed to the public earlier this month.
http://news.softpedia.com/news/amd-releases-linux-and-windows-patches-for-two-variants-of-spectre-vulnerability-519343.shtml
211 |
Andrez
12.01.2018 09:15:23
| Mikrokoodi saab uuendada ka ilma BIOSi kallale minemata. Tõsi, see eeldab, et instaleeritakse vastav draiver ja mikrokood uuendatakse iga käivituse ajal. Tegelesin selle teemaga mingi kuu tagasi kui katsetasin erinevaid mikrokoode (väidetavalt pidi erinevate mikrokoodidega erinevad OC saama aga see on BS) ja ei tahtnud BIOSe mudimisega tegeleda. https://labs.vmware.com/flings/vmware-cpu-microcode-update-driver
| Kommentaarid: 86 loe/lisa |
217 |
Andrez
12.01.2018 09:23:05
| Huvitav kas ka AMD saab samasuguse jõudluse kahanemise litaka? Spectre häda on ju ka neil küljes.
12.01.2018 10:08:51
amd statement on muutunud.
https://www.amd.com/en/corporate/speculative-execution
An Update on AMD Processor Security
1/11/2018
The public disclosure on January 3rd that multiple research teams had discovered security issues related to how modern microprocessors handle speculative execution has brought to the forefront the constant vigilance needed to protect and secure data. These threats seek to circumvent the microprocessor architecture controls that preserve secure data.
At AMD, security is our top priority and we are continually working to ensure the safety of our users as new risks arise. As a part of that vigilance, I wanted to update the community on our actions to address the situation.
1. Google Project Zero (GPZ) Variant 1 (Bounds Check Bypass or Spectre) is applicable to AMD processors.
- We believe this threat can be contained with an operating system (OS) patch and we have been working with OS providers to address this issue.
- Microsoft is distributing patches for the majority of AMD systems now. We are working closely with them to correct an issue that paused the distribution of patches for some older AMD processors (AMD Opteron, Athlon and AMD Turion X2 Ultra families) earlier this week. We expect this issue to be corrected shortly and Microsoft should resume updates for these older processors by next week. For the latest details, please see Microsoft’s website.
- Linux vendors are also rolling out patches across AMD products now.
2. GPZ Variant 2 (Branch Target Injection or Spectre) is applicable to AMD processors.
- While we believe that AMD’s processor architectures make it difficult to exploit Variant 2, we continue to work closely with the industry on this threat. We have defined additional steps through a combination of processor microcode updates and OS patches that we will make available to AMD customers and partners to further mitigate the threat.
- AMD will make optional microcode updates available to our customers and partners for Ryzen and EPYC processors starting this week. We expect to make updates available for our previous generation products over the coming weeks. These software updates will be provided by system providers and OS vendors; please check with your supplier for the latest information on the available option for your configuration and requirements.
- Linux vendors have begun to roll out OS patches for AMD systems, and we are working closely with Microsoft on the timing for distributing their patches. We are also engaging closely with the Linux community on development of “return trampoline” (Retpoline) software mitigations.
3. GPZ Variant 3 (Rogue Data Cache Load or Meltdown) is not applicable to AMD processors.
- We believe AMD processors are not susceptible due to our use of privilege level protections within paging architecture and no mitigation is required.
There have also been questions about GPU architectures. AMD Radeon GPU architectures do not use speculative execution and thus are not susceptible to these threats.
We will provide further updates as appropriate on this site as AMD and the industry continue our collaborative work to develop mitigation solutions to protect users from these latest security threats. |
217 |
The_Boss
12.01.2018 10:21:16
Mis osas muutunud?
284 |
12.01.2018 10:24:20
near-zero risk of exploitation > teeme os patche ja bios/microcode update
turva vaatepunktist on toimunud mingi probleemi tunnistamine ja alanud töö (või tunnistatud selle algamist) leevendusmeetmete kallal.
muidugi, korralik cto avaldus ka, erinevalt algsest suht suvalisest statementist.
217 |
Reaper
12.01.2018 11:31:09
Kas kuskil on lõpuks reaalne exploit ka väljas nende turvavigade põhjal?
Ma enne küll ei viitsi uuendada, kui reaalne oht olemas. Eriti kuna teeb masina aeglasemaks.
| Kommentaarid: 29 loe/lisa |
Alan
121 |
mikk55
12.01.2018 11:39:56
ID kaardi fiasko muutus ka kiirelt ju ohtlikuks (peale e-valimisi ). Ju siis keegi ju kasutab Spectre võlusid, kui patchi tehakse.
_________________ Tegelen autovõtmete lisamisega (peamiselt BMW ja Mercedes) ja osade autode puhul ka plokkide kodeerimisega jne. |
| Kommentaarid: 53 loe/lisa |
51 |
LKits
| Kommentaarid: 13 loe/lisa |
friik1
12.01.2018 14:41:43
| londiste, sisuline jutt on sama, kui ma nüüd peast seda sama AMD linki meelde tuletan ("Variant / AMD Response Matrix" osa on sama). Meltdown ei ole AMDle rakendatav, Spectre on. Kui tagasi vaadata Linuxi kerneli mailing listi vaidlustele, siis sealse fixi target oli Meltdown, mis on ainult Inteli teema.
171 |
7 :: |
364 |
siven
12.01.2018 16:32:50
windows updated panen küll peale aga biosi update küll peale ei pane...
pole mult varastada ka miskit:D
pangas käin ka smart id-ga nii ,et ei sisesta panga koode ka arvutisse...
võivad mu HV konto ja fb ära häkkida lasku käia xD
149 |
Alan
12.01.2018 16:56:16
| siven kirjutas: |
võivad mu HV konto ja fb ära häkkida lasku käia xD |
Nii ükskõikne oma turvalisuse üle ei tasu ka olla, et "pole mult midagi varastada". Näiteks identiteedivargus mõjuks igale inimesele päris valusasti.
Arvestades, et enamikel inimestel on siiani igal pool samad paroolid... mina, kellelt ka midagi olulist justkui võtta ei oleks, tunnen, et mõne mu parooliga saaks mulle küll kõvasti kahjusi teha. Kui rahaline kahju, siis ebay konto ligipääs oleks üks hull litakas.
121 |
mTim
12.01.2018 17:46:28
kui enamus mu paroolid on browserisse salvestatud, kas siis saab ka nende aukudega ligi, või peab teisi auke kasutama?
aga üldiselt on mul ka suht savi. kes tahab, see leiab tee, et varastada - ütleme, et on ka lihtsamaid viise. Ja ma pole nii palju väärt, et just minult varastada.
Win7'mel on mul see teatud update DEselektitud igatahes ja vaevalt mu 10+ aastat vanale läpparile keegi biosi update'i enam väljastab
_________________ Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad
viimati muutis mTim 12.01.2018 17:50:52, muudetud 1 kord |
| Kommentaarid: 47 loe/lisa |
42 |
siven
12.01.2018 18:19:21
| Alan kirjutas: |
| siven kirjutas: |
Arvestades, et enamikel inimestel on siiani igal pool samad paroolid... mina, kellelt ka midagi olulist justkui võtta ei oleks, tunnen, et mõne mu parooliga saaks mulle küll kõvasti kahjusi teha. Kui rahaline kahju, siis ebay konto ligipääs oleks üks hull litakas. |
igalpool sama parooli kasutada ei tasu kunagi!
mängud jne mõttetu saast kasutan alati 2 erinevat parooli...
postkast on oma parooliga .
pank erinevaga
ja social life ka erinevaga.
ja mingi valuable stuff on kaitstud ka mobiili autoriseerimisega.
telefoni patchin nagunii ära ja ma ei kujuta isegi ette mida ta hakkab peale puhtalt mu username + parooliga? kui ta ikka sisse logida ju ei saa
sest ta ei saa kuskilt telefoni SMS koodi või siis autoriseerimis programmi nrit?
ja tõesti nüüd ilmselt tuleb see linnuke ära võtta ,et mäleta arvutit ja ära enam küsi.
vaid ,et küsiks igakord kui soovin sisse logida.
ja ma võin enam kui kindel olla ,et need niiõelda lapid häkitakse ära ja on vaja uusi lappe ja see jääbki nii kestma.
sest kui patch olemas näevad häkkerid täpselt kus see viga on ja oskavad õigest kohast surkida.
nii ,et siin pole midagi teha kui osta uus prose tulevikus millel seda viga pole.
lisaks veel ju osad emaplaadi tootjad juba hõikasid välja ,et nad ei suppordi vanu tooteid mingi 5+a või miskit mida nad siis peale hakkavad?
pm tundub see asi räme kahtlane inimesed kellel pole vajadust uue arvuti jne järgi on nüüd sunnitud ostma muidu rõõvitakse teid paljaks.
inteli järgmise prose reklaam lause on kindlalt new arhitecture 100% secure 30% faster kuna noh see praegune bug teeb ju eelmised prosed 30% aeglasemaks:D
seega intel ei peagi prose kiirust juurde arendama xD
https://www.bleepingcomputer.com/news/security/intel-amt-security-issue-lets-attackers-bypass-bios-and-bitlocker-passwords/
hakkab pihta juba leitakse uusi häkke ...
mark my words need vanad prosed ei saa mitte kunagi 100% turvaliseks enam!
149 |
busta
12.01.2018 18:56:32
Ei tahaks siin päris hagiteerima hakata aga väikese oletuse siiski teen:
^^Kuidas kasutajal, kellel on olnud siiani netis arvete maksmiseks ja lehe lugemiseks piisava jõudlusega raal, mis on toimetanud juba aastaid.... peavad nüüd järsku lambist hakkama uusi asju ostma. Kaupmehed vaikselt käsi hõõrumas.... pumpamine algab. Sedasi kotitakse.^^
| Kommentaarid: 16 loe/lisa |
14 |
siven
12.01.2018 19:03:21
sest ta protsessor pole enam ju turvaline:D?
äkki varastatakse ta pension ära või mis iganes... ffs meil on maailmas piisavalt viimse päeva kartjaid kes faking ehitand endale punkrid 10 aasta toiduvaruga:D
ja sa nüüd tõesti arvad ,et selline uudis ei pane inimesi uusi arvuteid ostma... usu mind küll reklaamida ostakse oma 100% super hüper turvalisi prosesi...oota ainult kui see aeg käes ja siis need eelmsied prosed tehakse veel rohkem maha kui nad seda praegu on.
149 |
