uus teema   vasta Uudised »  Riistvara »  Intel protsessorites avastati tõsine viga, turvaparandus vähendab jõudlust 5-30% märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
sõnum 03.01.2018 12:09:51 Intel protsessorites avastati tõsine viga, turvaparandus vähendab jõudlust 5-30% vasta tsitaadiga
Kõikides 10 aasta jooksul toodetud Intel protsessorites avastati tõsine arhitektuuriline viga, testide järgi Linux kerneli turvaparandus vähendab jõudlust 5-30%. Microsofti turvaparandus on alles tulemas.
Väidetavalt ei kannata arhitektuurilise vea all AMD protsessorid. Uudis on täiendamisel.
Allikad: https://www.theregister.co.uk/2018/01/02/intel_cpu_design_flaw/
http://www.dsogaming.com/news/upcoming-security-fix-may-decrease-performance-on-intels-cpus-by-up-to-30/
Sünteetilise IO testid: https://www.phoronix.com/scan.php?page=article&item=linux-415-x86pti&num=2
Mängutestid pole õnneks nii palju mõjutatud
https://www.phoronix.com/scan.php?page=news_item&px=x86-PTI-Initial-Gaming-Tests
HV-s ID-kaardiga autentimine
viimati muutis Tanel 03.01.2018 12:14:05, muudetud 1 kord
sõnum 03.01.2018 12:13:01 vasta tsitaadiga
“It allows normal user programs – from database applications to JavaScript in web browsers – to discern to some extent the contents of protected kernel memory.
The fix is to separate the kernel’s memory completely from user processes using what’s called Kernel Page Table Isolation, or KPTI. At one point, Forcefully Unmap Complete Kernel With Interrupt Trampolines, aka FUCKWIT, was mulled by the Linux kernel team, giving you an idea of how annoying this has been for the developers.
Whenever a running program needs to do anything useful – such as write to a file or open a network connection – it has to temporarily hand control of the processor to the kernel to carry out the job. To make the transition from user mode to kernel mode and back to user mode as fast and efficient as possible, the kernel is present in all processes’ virtual memory address spaces, although it is invisible to these programs. When the kernel is needed, the program makes a system call, the processor switches to kernel mode and enters the kernel. When it is done, the CPU is told to switch back to user mode, and reenter the process. While in user mode, the kernel’s code and data remains out of sight but present in the process’s page tables.
The downside to this separation is that it is relatively expensive, time wise, to keep switching between two separate address spaces for every system call and for every interrupt from the hardware. These context switches do not happen instantly, and they force the processor to dump cached data and reload information from memory. This increases the kernel’s overhead, and slows down the computer.”
ufo56
ufo56
sõnum 03.01.2018 12:31:19 vasta tsitaadiga
 Lae pildid -> pilt.io
sõnum 03.01.2018 12:32:26 vasta tsitaadiga
“AMD processors are not subject to the types of attacks that the kernel page table isolation feature protects against. The AMD microarchitecture does not allow memory references, including speculative references, that access higher privileged data when running in a lesser privileged mode when that access would result in a page fault.”
Andrus Luht
itimees.ee
Andrus Luht
sõnum 03.01.2018 12:49:18 vasta tsitaadiga
Kõlab nagu massiivne tagasikutsumine või class-action lawsuit mikidemaal... -30% perf loss'i on ikka kolossaalne... Isegi -5% on kohutavalt palju suuremates süsteemides...
Kommentaarid: 377 loe/lisa Kasutajad arvavad:  :: 5 :: 1 :: 318
sõnum 03.01.2018 12:51:47 vasta tsitaadiga
Tagumine aeg lühikeseks minna
mTim
mTim
sõnum 03.01.2018 12:53:26 vasta tsitaadiga
Jee, siis saan arvutit kokku hakata panema, kui kõik hakkavad oma inteli prosesid müüma. Saaks kuskilt listi, mis prosed on seotud sellega
Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 42
sooty
sõnum 03.01.2018 13:07:39 vasta tsitaadiga
mTim kirjutas:
Kui veast õigesti aru saan, siis paikamata jätmisel saab suvaline veebileht driveby'ga miljon rootkitti installida, sest tahtsid paar eurot kokku hoida? Ei tundu väga mõistlik.
sõnum 03.01.2018 13:16:30 vasta tsitaadiga
https://downloadcenter.intel.com/download/27150
keegi võiks selle uuenduse lingi ka anda "if any".
i3-2120 @ w7 64bit igatahes katki pole.
Kommentaarid: 1159 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 725
mTim
mTim
sõnum 03.01.2018 13:20:43 vasta tsitaadiga
sooty kirjutas:
mTim kirjutas:
Ei patchida võib ju. Ma ei usu, et see 5-30% kodukasutajat väga mõjutab ja esialgne hinnang ütleb, et mänge see ka ei mõjuta. Samas 5-30% on juba selline protsent millega paljud võivad sattuda "paanikasse" ja dumpida oma intelid turule
EDIT: lisaks, arvuti "kiirus" sõltub tavakasutajale pigem taustsüsteemist ja tunnetusest. Niet paljud, kes patchi peale lasevad, võivad tõesti mõelda, et on jah aeglane, tuleb välja vahetada. Ma olen näiteks oma Core 2 Duo T9400'ga endiselt rahul. Arvuti ei tundu üldse aeglane.
M: E36 varuosad
viimati muutis mTim 03.01.2018 13:27:07, muudetud 1 kord
sooty
sõnum 03.01.2018 13:25:01 vasta tsitaadiga
laurx, teemaks olev viga hoopis teine asi. tahanteada ajab pikemalt süvenemata oma joru.
warwas
warwas
sõnum 03.01.2018 13:27:36 vasta tsitaadiga
Jep! Nagu sooty ka tähele pani, siis teemaks olev probleem on hoopis midagi uut.
Kui see uus probleem ka BIOS või microcode'iga fixitav oleks, siis poleks ju MS'il ja linuxi dev'idel midagi väga tõmmelda.
See, et AMT ussitab, pole ju mingi uudis. Sellele on tõesti fix olemas BIOS'i uuenduste näol, mida erinevad vendorid nüüd lähiajal jagama hakkavad.
viimati muutis warwas 03.01.2018 13:28:57, muudetud 1 kord
Kommentaarid: 247 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 224
NATAS999
sõnum 03.01.2018 13:28:11 vasta tsitaadiga
vb mingi 6GHZ 8gen octacore extreme i7 meestel jah pole vahet see 5-30%
kert06
kert06
sõnum 03.01.2018 13:29:20 vasta tsitaadiga
Põnev artikkel! Ootan huviga, mis edasi saama hakkab.
Kommentaarid: 175 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 156
Renka
Renka
sõnum 03.01.2018 14:05:24 vasta tsitaadiga
mTim kirjutas:
Kõik x86-64 Intel prosed
ADD
külaline
sõnum 03.01.2018 14:11:34 vasta tsitaadiga
Linux kernel 4.14.9 changelog arutab kASLR bypassi.
commit 25e2999e630c744c27c9179d1279c7f9d503385e
Author: Andy Lutomirski <luto@kernel.org>
Date: Mon Dec 4 15:07:29 2017 +0100
x86/entry/64: Make cpu_entry_area.tss read-only
commit c482feefe1aeb150156248ba0fd3e029bc886605 upstream.
The TSS is a fairly juicy target for exploits, and, now that the TSS
is in the cpu_entry_area, it's no longer protected by kASLR. Make it
read-only on x86_64.
On x86_32, it can't be RO because it's written by the CPU during task
switches, and we use a task gate for double faults. I'd also be
nervous about errata if we tried to make it RO even on configurations
without double fault handling.
[ tglx: AMD confirmed that there is no problem on 64-bit with TSS RO. So
it's probably safe to assume that it's a non issue, though Intel
might have been creative in that area. Still waiting for
confirmation. ]
https://www.kernel.org/pub/linux/kernel/v4.x/ChangeLog-4.14.9
Seega alates sellest kernelist on Linuxil juba patch valmis. Ise enda linux on Core 2 Duo masinal ja ei ole mõjutatud sellest? (Ma ei tea, ausalt)
Kernel 4.14.11 sisaldab juba tõsiseid fixe.
https://www.kernel.org/pub/linux/kernel/v4.x/ChangeLog-4.14.11
Windowsi patch tuleb välja Patch Tuesday ajal see kuu.
EDIT:
Kuupäevade järgi saab öelda, et 4. detsembril on Linuxi kernelisse hakatud antud veale erinevaid fixe tegema. Seega Intel on vähemalt kuu aega juba juhendanud Windowsi, Maci ja Linuxi dev'e.
Kuna konkreetne exploit on praegu embargo all, siis ametlikult midagi öeldud ei ole. Embargo all mõtlen midagi sarnast, mis oli hiljuti Eesti ID-kaardi veaga. St., et konkreetsed vea üksikasjad avaldataks selle kuu jooksul, ilmselt pärast Windowsi ja Maci uuendusi. Windowsi uuendus on plaanitud 9.01.2018. Maci kohta ei oska öelda.
viimati muutis ADD 03.01.2018 16:12:31, muudetud 3 korda
lynxfelinae
sõnum 03.01.2018 14:14:12 vasta tsitaadiga
tahanteada kirjutas:
sooty kirjutas:
Selle info Ametlik Algallikas on Intel ise, kõik teised vahendavad, oma nägemuse põhjal seda mida Intel ametlikult on kirutanud.
Imelihtne ju. A ja O on alati Algallikas.
Nii, et Intel kirjutab täpselt samast Turvaprobleemist ning selle parandamisest.
Sa kirjutad Inteli IME, SPS ja TXE turvaprobleemidest, mille ametliku teavituse Intel avaldas 2017-11-20.
Seda käsitles The Register 2017-11-20 artikkel Intel finds critical holes in secret Management Engine hidden in tons of desktop, server chipsets.
Käesoleval teema esimeses postituses olevas The Register artiklis on jutt juba uuest/teisest turvaprobleemist Inteli protsessorites.
viimati muutis lynxfelinae 03.01.2018 15:05:00, muudetud 1 kord
Kommentaarid: 257 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 216
LiivaneLord
Sõpradele "Olavi"
sõnum 03.01.2018 14:56:00 vasta tsitaadiga
Ei saa aru ...
Tool Started 3.01.2018 13:36:55
Manufacturer: Gigabyte Technology Co., Ltd.
Model: To be filled by O.E.M.
Processor Name: Intel(R) Core(TM) i5-2400 CPU @ 3.10GHz
OS Version: Microsoft Windows 7 Ultimate
Status: Detection Error: This system may be vulnerable, either the Intel(R) MEI/TXEI driver is not installed (available from your system manufacturer) or the system manufacturer does not permit access to the ME/TXE from the host driver.
Tool Stopped
See logi ei too välja selle, et intel ME all on engine version - unknown ja svn on 0. Siit sain oma mudelile vaid hd graphics driver -> https://downloadcenter.intel.com/product/52207/Intel-Core-i5-2400-Processor-6M-Cache-up-to-3-40-GHz-
Samuti ütleb https://www.intel.com/content/www/us/en/support/intel-driver-support-assistant.html et uuendusi saadaval ei ole.
lynxfelinae
sõnum 03.01.2018 15:11:55 vasta tsitaadiga
LiivaneLord kirjutas:
Ei saa aru ...
Tool Stopped
GIGABYTE ametlik info Intel ME turvaprobleemide teemal.
viimati muutis lynxfelinae 03.01.2018 16:35:49, muudetud 1 kord
Renka
Renka
sõnum 03.01.2018 15:15:36 vasta tsitaadiga
Miks te seda ME teemat siia toote nüüd?
hans
Nii ränk on olla.
sõnum 03.01.2018 15:18:09 vasta tsitaadiga
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 81
LiivaneLord
Sõpradele "Olavi"
sõnum 03.01.2018 15:18:55 vasta tsitaadiga
Renka kirjutas:
sooty
sõnum 03.01.2018 15:22:25 vasta tsitaadiga
Renka kirjutas:
https://foorum.hinnavaatlus.ee/viewtopic.php?p=9705586#9705586
wezztern
sõnum 03.01.2018 15:25:35 vasta tsitaadiga
mõned vast ei oska inglisekeelt nii hästi ei saa aru millest jutt käib. kuigi reddits samamoodi tüübid kontrollivad oma arvutit ja laulavad et neil kõik korras cpu is secured, et see fix neid ei puuduta icon_biggrin.gif
lynxfelinae
sõnum 03.01.2018 16:42:14 vasta tsitaadiga
Renka kirjutas:
Üks kasutaja hakkas siin usinalt Intel ME teemal seletama ning paar kasutajat kontrollisid oma arvuteid tema viidatud allikast lähtuvalt.
Sellest lähtuvalt sai vastatud, et tegemist on teise/uue Inteli protsessoreid puudutava turvaprobleemiga ja ühele kasutajale sai antud tema emaplaadi tootja temaatiline link.
XeStAiSy
Aeg Maha 2a
sõnum 03.01.2018 17:16:45 vasta tsitaadiga
Bähh kes x86 32biti osi kasutab kõike need patchid ja testid ainult x86. Kui pole x64 mainitud siis seega suht savi ei kasuta 32 bitist värgendust juba ammu.
viimati muutis XeStAiSy 03.01.2018 17:24:16, muudetud 1 kord
siven
siven
sõnum 03.01.2018 17:24:14 vasta tsitaadiga
suht huumor on et NVEM ssd saavad korralikult rape mingi 50% ...
sata 3 ssd kõigest 17%
eks hakkab nalja saama... ja kes arvab ,et see gamingut ei mõjuta peab ikka päris rumal olema...
open world mängud ja mängud mis seemlessy datat vajavad + interneti pelud.
lisaks tahaks näha mis denuvo kaitsest saab?? ilmselt paneb veel suurema performance hiti!
lugesin igast teemasi selle kohta eile ja noo ma ei kujuta ette kui intel lihtsalt karistuseta pääseb???
inteli poolelt oleks viisakas vahetada välja kõik prosed kes ostnud viimased 2 aastat uute vastu millel seda viga pole.
aga noh ilmselt läheb ka neil kõvasti aega kuni selle fixitud saavad
Kommentaarid: 163 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 149
olka
olka
sõnum 03.01.2018 17:38:41 vasta tsitaadiga
siven kirjutas:
+1
Mulle meeldis ka see fraas MÄNGURID ärge muretsege, et mängud ei ole mõjutatud! icon_biggrin.gif Lubage naerda, saab mõjutatud ja veel kõvasti!
You, all gonna make me loose my mind, loose my mind
mannatera
mannatera
sõnum 03.01.2018 17:59:42 vasta tsitaadiga
Esialgsete benchide kohaselt mängud ei tohiks sellest mõjutatud olla: https://www.phoronix.com/scan.php?page=news_item&px=x86-PTI-Initial-Gaming-Tests
See on küll Linuxi peal tehtud ja piiratud mängud.
Ei tea kas AWS, Google Cloud, Azure jne Intelile vitsa ka annavad?
Kommentaarid: 24 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 19
vanarebane
vanarebane
sõnum 03.01.2018 18:00:54 vasta tsitaadiga
Video mis räägib turvaaugust lähemalt ja kuidas seda ära kasutada
Tähenärimine on hammastele kahjulik!
Kommentaarid: 87 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 79
siven
siven
sõnum 03.01.2018 18:01:32 vasta tsitaadiga
vanarebane kirjutas:
tekib küsimus kui seda teati nii ammu siis miks see juba fixed pole wtf?
Renka
Renka
sõnum 03.01.2018 18:03:36 vasta tsitaadiga
siven kirjutas:
See on erinev asi. Sarnane aga erinev.
pois11
sõnum 03.01.2018 18:11:27 vasta tsitaadiga
Loll küsimus. Kas see mind ka puudutab? Kastis on vana Intel Core i5-4570S
Renka
Renka
sõnum 03.01.2018 18:11:38 vasta tsitaadiga
jah
wezztern
sõnum 03.01.2018 18:24:25 vasta tsitaadiga
https://www.cnbc.com/2017/12/19/intel-ceo-in-memo-we-are-going-to-take-more-risks.html
Intel CEO to employees: 'We are going to take more risks'
Intel's Brian Krzanich wrote in a memo to employees on Tuesday that the company faces "an exciting challenge" in areas where it's an underdog.
The company's growth strategy is ultimately about data, he wrote.
ja sama aeg müüs oma inteli osakuid... ju siis oli teada, et kuskilt midagi hakkab lekkima..
https://www.fool.com/investing/2017/12/19/intels-ceo-just-sold-a-lot-of-stock.aspx?source=isafpbcs0000001&utm_campaign=firehose&utm_medium=feed&utm_source=sharewise
sõnum 03.01.2018 19:12:58 vasta tsitaadiga
icon_arrow.gif http://quotes.wsj.com/INTC
NATAS999
sõnum 03.01.2018 19:26:24 vasta tsitaadiga
mannatera kirjutas:
mitte ühtegi benchi, mitte ühegi mängu nime, mitte ühtegi numbrit ega seda, millise configa "benche" tehti ja isegi seda pole ära toodud, kas tal see auk tal patshitud või mitte.
XeStAiSy
Aeg Maha 2a
sõnum 03.01.2018 19:31:58 vasta tsitaadiga
minuarust need testid umbluu reaalselt ei ühtegi pilti testi tulemustest samas pole mainitud kas ainult 32bit opratsioonisüsteemid või ka puudutab 64bitist ka.
Renka
Renka
sõnum 03.01.2018 19:33:04 vasta tsitaadiga
Margus, wtf? Uudist lugesid ikka?
XeStAiSy
Aeg Maha 2a
sõnum 03.01.2018 19:34:49 vasta tsitaadiga
kuiskilt ei lugenud välja igalpool x86 ja ARM X64
Renka
Renka
sõnum 03.01.2018 19:35:57 vasta tsitaadiga
Margus kirjutas:
the flaw is in the Intel x86-64 hardware
ADD
külaline
sõnum 03.01.2018 19:36:06 vasta tsitaadiga
Ootab ametliku pressiteate ära. Kuna aktsia kukub nii kiirelt, siis varsti on vastust oodata. Siit midagi eriti välja ei ime enam. Delfi ka uudise üles korjanud, natukene häbi, et nii koledalt kirjutatud. Tundub, et tahanteada ME käib ka sügavalt sealt Delfist läbi, kahjuks. ME bug on erinev bug. Praeguse bugi kohta pole ametlikku teavet, kuna embargo on peal.
mannatera
mannatera
sõnum 03.01.2018 19:52:44 vasta tsitaadiga
NATAS999 kirjutas:
mannatera kirjutas:
Lehe load võtab aega, on mängude nimed, tulemused, mis raali peal testiti kõik olemas.
siven
siven
sõnum 03.01.2018 19:56:54 vasta tsitaadiga
mannatera kirjutas:
NATAS999 kirjutas:
mannatera kirjutas:
Radeon RX Vega 64 running on the Intel Core i7 8700K "Coffee Lake" system with Linux 4.15. ... cofee lake perf hit pidi väiksem olema vanematel prosdel suurem...
eks näis aga sellist pauku küll poleks elus oskand oodata... see ilmselt aasta 2018 kõige suurem flop
olavsu1
külaline
sõnum 03.01.2018 20:17:59 vasta tsitaadiga
maakeeles on ka midagi olemas:
http://forte.delfi.ee/news/digi/sinu-arvutis-on-toenaoliselt-tohutu-turvaviga-habi-intel-ja-lappimine-muudab-selle-halval-juhul-kuni-kolmandiku-vorra-aeglasemaks?id=80683771
esmalt sai aru nõnda et probleem on tolles salajases linuxis, mis laulatatud inteli protsessorite sisse. nii see vist ei ole, või on?
kui see on "pritsimisel" (ic diffusing) tehtud viga siis peaks loogiliselt järgnema protsessorite tagasikutsumine nagu seda tehaksevigaste autode puhul....
siven
siven
sõnum 03.01.2018 20:25:41 vasta tsitaadiga
olavsu1 kirjutas:
kujutad nüüd ette prosede tagasikutsumist??? isegi 10 aasta tagustel prosedel see viga ja vaja kõik uued toota seda ei saa nsm fixida...
intel läheb ennem pankroti kui suudab ära vahetada kõik prosed.lisaks neil pole ju valmis ega tootmises ühtegi prose kus seda viga ei esineks:D
Renka
Renka
sõnum 03.01.2018 20:27:30 vasta tsitaadiga
olavsu1 kirjutas:
salajases linuxis, mis laulatatud inteli protsessorite sisse. .
what? Misasi see veel on? Ärme mõtle nüüd asju välja.
olavsu1 kirjutas:
ei ole. See viga on arhitektuuri disainis (niipalju kui hetkel infot on). Tagasikutsumine tähendaks protsessori väljavahetamist. Parandada sihukest asja nüüd küll kuidagi ei saa.
Kõigi garantiiaega omavate prosede tasuta välja vahetamine oleks Intelile päris suur pauk.
Lihtsam/odavam on OS tootjaid toetada workaroundi loomisel - kuigi ma pole kindel kas sedagi tehakse. Pigem on OS tootjad ise huvitatud kiirest fixi juurutamisest.
Killer85
sõnum 03.01.2018 20:28:45 vasta tsitaadiga
Silmad hakkavad verd jooksma selle delfi artikli peale...
Reaper
Reaper
sõnum 03.01.2018 20:33:55 vasta tsitaadiga
Renka kirjutas:
olavsu1 kirjutas:
No eks mõeldi ikka selle Management engine sees olevat Minixit.
Üldiselt, unustage see Management engine teema ära, see on nii 2017 icon_biggrin.gif
Kommentaarid: 29 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 27
olavsu1
külaline
sõnum 03.01.2018 20:42:42 vasta tsitaadiga
Renka kirjutas:
olavsu1 kirjutas:
Mis, kas see on juba äraunustatud? vaevalt et see päris veatu on.
just seda ma algul mõtlesingi.
uus teema   vasta Uudised »  Riistvara »  Intel protsessorites avastati tõsine viga, turvaparandus vähendab jõudlust 5-30% mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
