7 :: |
362 |
03.01.2018 12:13:01
“It allows normal user programs – from database applications to JavaScript in web browsers – to discern to some extent the contents of protected kernel memory.
The fix is to separate the kernel’s memory completely from user processes using what’s called Kernel Page Table Isolation, or KPTI. At one point, Forcefully Unmap Complete Kernel With Interrupt Trampolines, aka FUCKWIT, was mulled by the Linux kernel team, giving you an idea of how annoying this has been for the developers.
Whenever a running program needs to do anything useful – such as write to a file or open a network connection – it has to temporarily hand control of the processor to the kernel to carry out the job. To make the transition from user mode to kernel mode and back to user mode as fast and efficient as possible, the kernel is present in all processes’ virtual memory address spaces, although it is invisible to these programs. When the kernel is needed, the program makes a system call, the processor switches to kernel mode and enters the kernel. When it is done, the CPU is told to switch back to user mode, and reenter the process. While in user mode, the kernel’s code and data remains out of sight but present in the process’s page tables.
The downside to this separation is that it is relatively expensive, time wise, to keep switching between two separate address spaces for every system call and for every interrupt from the hardware. These context switches do not happen instantly, and they force the processor to dump cached data and reload information from memory. This increases the kernel’s overhead, and slows down the computer.” |
_________________ Erakopeerimistasu tõstmise ettepaneku tagasilükkamine
7 :: |
362 |
ufo56
| Kommentaarid: 79 loe/lisa |
67 |
7 :: |
362 |
Andrus Luht
itimees.ee
318 |
7 :: |
362 |
mTim
03.01.2018 12:53:26
Jee, siis saan arvutit kokku hakata panema, kui kõik hakkavad oma inteli prosesid müüma. Saaks kuskilt listi, mis prosed on seotud sellega
_________________ Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad |
| Kommentaarid: 47 loe/lisa |
42 |
sooty
03.01.2018 13:07:39
| mTim kirjutas: |
| Jee, siis saan arvutit kokku hakata panema, kui kõik hakkavad oma inteli prosesid müüma. Saaks kuskilt listi, mis prosed on seotud sellega |
Kui veast õigesti aru saan, siis paikamata jätmisel saab suvaline veebileht driveby'ga miljon rootkitti installida, sest tahtsid paar eurot kokku hoida? Ei tundu väga mõistlik.
| Kommentaarid: 12 loe/lisa |
12 |
| Kommentaarid: 1156 loe/lisa |
724 |
mTim
03.01.2018 13:20:43
| sooty kirjutas: |
| mTim kirjutas: |
Kui veast õigesti aru saan, siis paikamata jätmisel saab suvaline veebileht driveby'ga miljon rootkitti installida, sest tahtsid paar eurot kokku hoida? Ei tundu väga mõistlik. |
Ei patchida võib ju. Ma ei usu, et see 5-30% kodukasutajat väga mõjutab ja esialgne hinnang ütleb, et mänge see ka ei mõjuta. Samas 5-30% on juba selline protsent millega paljud võivad sattuda "paanikasse" ja dumpida oma intelid turule
EDIT: lisaks, arvuti "kiirus" sõltub tavakasutajale pigem taustsüsteemist ja tunnetusest. Niet paljud, kes patchi peale lasevad, võivad tõesti mõelda, et on jah aeglane, tuleb välja vahetada. Ma olen näiteks oma Core 2 Duo T9400'ga endiselt rahul. Arvuti ei tundu üldse aeglane.
M: E36 varuosad
viimati muutis mTim 03.01.2018 13:27:07, muudetud 1 kord |
42 |
sooty
03.01.2018 13:25:01
| laurx, teemaks olev viga hoopis teine asi. tahanteada ajab pikemalt süvenemata oma joru.
12 |
warwas
03.01.2018 13:27:36
Jep! Nagu sooty ka tähele pani, siis teemaks olev probleem on hoopis midagi uut.
Kui see uus probleem ka BIOS või microcode'iga fixitav oleks, siis poleks ju MS'il ja linuxi dev'idel midagi väga tõmmelda.
See, et AMT ussitab, pole ju mingi uudis. Sellele on tõesti fix olemas BIOS'i uuenduste näol, mida erinevad vendorid nüüd lähiajal jagama hakkavad.
viimati muutis warwas 03.01.2018 13:28:57, muudetud 1 kord |
224 |
NATAS999
03.01.2018 13:28:11
| vb mingi 6GHZ 8gen octacore extreme i7 meestel jah pole vahet see 5-30%
| Kommentaarid: 41 loe/lisa |
39 |
kert06
03.01.2018 13:29:20
| Põnev artikkel! Ootan huviga, mis edasi saama hakkab.
156 |
Renka
03.01.2018 14:05:24
| mTim kirjutas: |
Kõik x86-64 Intel prosed
61 |
ADD
külaline
03.01.2018 14:11:34
Linux kernel 4.14.9 changelog arutab kASLR bypassi.
commit 25e2999e630c744c27c9179d1279c7f9d503385e
Author: Andy Lutomirski <luto@kernel.org>
Date: Mon Dec 4 15:07:29 2017 +0100
x86/entry/64: Make cpu_entry_area.tss read-only
commit c482feefe1aeb150156248ba0fd3e029bc886605 upstream.
The TSS is a fairly juicy target for exploits, and, now that the TSS
is in the cpu_entry_area, it's no longer protected by kASLR. Make it
read-only on x86_64.
On x86_32, it can't be RO because it's written by the CPU during task
switches, and we use a task gate for double faults. I'd also be
nervous about errata if we tried to make it RO even on configurations
without double fault handling.
[ tglx: AMD confirmed that there is no problem on 64-bit with TSS RO. So
it's probably safe to assume that it's a non issue, though Intel
might have been creative in that area. Still waiting for
confirmation. ] |
https://www.kernel.org/pub/linux/kernel/v4.x/ChangeLog-4.14.9
Seega alates sellest kernelist on Linuxil juba patch valmis. Ise enda linux on Core 2 Duo masinal ja ei ole mõjutatud sellest? (Ma ei tea, ausalt)
Kernel 4.14.11 sisaldab juba tõsiseid fixe.
https://www.kernel.org/pub/linux/kernel/v4.x/ChangeLog-4.14.11
Windowsi patch tuleb välja Patch Tuesday ajal see kuu.
EDIT:
Kuupäevade järgi saab öelda, et 4. detsembril on Linuxi kernelisse hakatud antud veale erinevaid fixe tegema. Seega Intel on vähemalt kuu aega juba juhendanud Windowsi, Maci ja Linuxi dev'e.
Kuna konkreetne exploit on praegu embargo all, siis ametlikult midagi öeldud ei ole. Embargo all mõtlen midagi sarnast, mis oli hiljuti Eesti ID-kaardi veaga. St., et konkreetsed vea üksikasjad avaldataks selle kuu jooksul, ilmselt pärast Windowsi ja Maci uuendusi. Windowsi uuendus on plaanitud 9.01.2018. Maci kohta ei oska öelda.
viimati muutis ADD 03.01.2018 16:12:31, muudetud 3 korda |
lynxfelinae
03.01.2018 14:14:12
| tahanteada kirjutas: |
| sooty kirjutas: |
| laurx, teemaks olev viga hoopis teine asi. tahanteada ajab pikemalt süvenemata oma joru. |
Õpi siis Kuupäevi vaatama ning loe alati infot Algallikast.
Selle info Ametlik Algallikas on Intel ise, kõik teised vahendavad, oma nägemuse põhjal seda mida Intel ametlikult on kirutanud.
Imelihtne ju. A ja O on alati Algallikas.
Nii, et Intel kirjutab täpselt samast Turvaprobleemist ning selle parandamisest. |
Sa kirjutad Inteli IME, SPS ja TXE turvaprobleemidest, mille ametliku teavituse Intel avaldas 2017-11-20.
Seda käsitles The Register 2017-11-20 artikkel Intel finds critical holes in secret Management Engine hidden in tons of desktop, server chipsets.
Käesoleval teema esimeses postituses olevas The Register artiklis on jutt juba uuest/teisest turvaprobleemist Inteli protsessorites.
viimati muutis lynxfelinae 03.01.2018 15:05:00, muudetud 1 kord |
| Kommentaarid: 257 loe/lisa |
216 |
LiivaneLord
Sõpradele "Olavi"
| Kommentaarid: 20 loe/lisa |
19 |
lynxfelinae
03.01.2018 15:11:55
GIGABYTE ametlik info Intel ME turvaprobleemide teemal.
viimati muutis lynxfelinae 03.01.2018 16:35:49, muudetud 1 kord |
216 |
Renka
03.01.2018 15:15:36
Miks te seda ME teemat siia toote nüüd?
61 |
hans
Nii ränk on olla.
03.01.2018 15:18:09
jesss, ostsin just uue arvuti, ca 30% parem benchides kui vana
_________________ ------ |
81 |
LiivaneLord
Sõpradele "Olavi"
03.01.2018 15:18:55
| Renka kirjutas: |
| Miks te seda ME teemat siia toote nüüd? |
Mina ei tea.
19 |
sooty
12 |
wezztern
03.01.2018 15:25:35
mõned vast ei oska inglisekeelt nii hästi ei saa aru millest jutt käib. kuigi reddits samamoodi tüübid kontrollivad oma arvutit ja laulavad et neil kõik korras cpu is secured, et see fix neid ei puuduta
lynxfelinae
03.01.2018 16:42:14
| Renka kirjutas: |
Üks kasutaja hakkas siin usinalt Intel ME teemal seletama ning paar kasutajat kontrollisid oma arvuteid tema viidatud allikast lähtuvalt.
Sellest lähtuvalt sai vastatud, et tegemist on teise/uue Inteli protsessoreid puudutava turvaprobleemiga ja ühele kasutajale sai antud tema emaplaadi tootja temaatiline link.
216 |
XeStAiSy
Aeg Maha 2a
03.01.2018 17:16:45
Bähh kes x86 32biti osi kasutab kõike need patchid ja testid ainult x86. Kui pole x64 mainitud siis seega suht savi ei kasuta 32 bitist värgendust juba ammu.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 03.01.2018 17:24:16, muudetud 1 kord |
siven
03.01.2018 17:24:14
suht huumor on et NVEM ssd saavad korralikult rape mingi 50% ...
sata 3 ssd kõigest 17%
eks hakkab nalja saama... ja kes arvab ,et see gamingut ei mõjuta peab ikka päris rumal olema...
open world mängud ja mängud mis seemlessy datat vajavad + interneti pelud.
lisaks tahaks näha mis denuvo kaitsest saab?? ilmselt paneb veel suurema performance hiti!
lugesin igast teemasi selle kohta eile ja noo ma ei kujuta ette kui intel lihtsalt karistuseta pääseb???
inteli poolelt oleks viisakas vahetada välja kõik prosed kes ostnud viimased 2 aastat uute vastu millel seda viga pole.
aga noh ilmselt läheb ka neil kõvasti aega kuni selle fixitud saavad
149 |
olka
03.01.2018 17:38:41
| siven kirjutas: |
+1
Mulle meeldis ka see fraas MÄNGURID ärge muretsege, et mängud ei ole mõjutatud! Lubage naerda, saab mõjutatud ja veel kõvasti!
_________________ You, all gonna make me loose my mind, loose my mind |
| Kommentaarid: 18 loe/lisa |
16 |
mannatera
| Kommentaarid: 24 loe/lisa |
19 |
vanarebane
| Kommentaarid: 87 loe/lisa |
79 |
siven
03.01.2018 18:01:32
tekib küsimus kui seda teati nii ammu siis miks see juba fixed pole wtf?
149 |
Renka
03.01.2018 18:03:36
| siven kirjutas: |
tekib küsimus kui seda teati nii ammu siis miks see juba fixed pole wtf? |
See on erinev asi. Sarnane aga erinev.
61 |
pois11
03.01.2018 18:11:27
| Loll küsimus. Kas see mind ka puudutab? Kastis on vana Intel Core i5-4570S
109 |
Renka
03.01.2018 18:11:38
jah
61 |
wezztern
7 :: |
362 |
NATAS999
03.01.2018 19:26:24
mitte ühtegi benchi, mitte ühegi mängu nime, mitte ühtegi numbrit ega seda, millise configa "benche" tehti ja isegi seda pole ära toodud, kas tal see auk tal patshitud või mitte.
39 |
XeStAiSy
Aeg Maha 2a
03.01.2018 19:31:58
minuarust need testid umbluu reaalselt ei ühtegi pilti testi tulemustest samas pole mainitud kas ainult 32bit opratsioonisüsteemid või ka puudutab 64bitist ka.
Renka
03.01.2018 19:33:04
Margus, wtf? Uudist lugesid ikka?
61 |
XeStAiSy
Aeg Maha 2a
03.01.2018 19:34:49
kuiskilt ei lugenud välja igalpool x86 ja ARM X64
Renka
03.01.2018 19:35:57
| Margus kirjutas: |
| kuiskilt ei lugenud välja igalpool x86 ja ARM X64 |
| the flaw is in the Intel x86-64 hardware |
61 |
ADD
külaline
03.01.2018 19:36:06
| Ootab ametliku pressiteate ära. Kuna aktsia kukub nii kiirelt, siis varsti on vastust oodata. Siit midagi eriti välja ei ime enam. Delfi ka uudise üles korjanud, natukene häbi, et nii koledalt kirjutatud. Tundub, et tahanteada ME käib ka sügavalt sealt Delfist läbi, kahjuks. ME bug on erinev bug. Praeguse bugi kohta pole ametlikku teavet, kuna embargo on peal.
mannatera
03.01.2018 19:52:44
| NATAS999 kirjutas: |
mitte ühtegi benchi, mitte ühegi mängu nime, mitte ühtegi numbrit ega seda, millise configa "benche" tehti ja isegi seda pole ära toodud, kas tal see auk tal patshitud või mitte. |
Lehe load võtab aega, on mängude nimed, tulemused, mis raali peal testiti kõik olemas.
19 |
siven
03.01.2018 19:56:54
| mannatera kirjutas: |
Lehe load võtab aega, on mängude nimed, tulemused, mis raali peal testiti kõik olemas. |
Radeon RX Vega 64 running on the Intel Core i7 8700K "Coffee Lake" system with Linux 4.15. ... cofee lake perf hit pidi väiksem olema vanematel prosdel suurem...
eks näis aga sellist pauku küll poleks elus oskand oodata... see ilmselt aasta 2018 kõige suurem flop
149 |
olavsu1
külaline
siven
03.01.2018 20:25:41
kujutad nüüd ette prosede tagasikutsumist??? isegi 10 aasta tagustel prosedel see viga ja vaja kõik uued toota seda ei saa nsm fixida...
intel läheb ennem pankroti kui suudab ära vahetada kõik prosed.lisaks neil pole ju valmis ega tootmises ühtegi prose kus seda viga ei esineks:D
149 |
Renka
03.01.2018 20:27:30
| olavsu1 kirjutas: |
| salajases linuxis, mis laulatatud inteli protsessorite sisse. . |
what? Misasi see veel on? Ärme mõtle nüüd asju välja.
| olavsu1 kirjutas: |
| kui see on "pritsimisel" (ic diffusing) tehtud viga siis peaks loogiliselt järgnema protsessorite tagasikutsumine nagu seda tehaksevigaste autode puhul.... |
ei ole. See viga on arhitektuuri disainis (niipalju kui hetkel infot on). Tagasikutsumine tähendaks protsessori väljavahetamist. Parandada sihukest asja nüüd küll kuidagi ei saa.
Kõigi garantiiaega omavate prosede tasuta välja vahetamine oleks Intelile päris suur pauk.
Lihtsam/odavam on OS tootjaid toetada workaroundi loomisel - kuigi ma pole kindel kas sedagi tehakse. Pigem on OS tootjad ise huvitatud kiirest fixi juurutamisest.
61 |
Killer85
03.01.2018 20:28:45
| Silmad hakkavad verd jooksma selle delfi artikli peale...
| Kommentaarid: 69 loe/lisa |
67 |
Reaper
03.01.2018 20:33:55
| Renka kirjutas: |
| olavsu1 kirjutas: |
No eks mõeldi ikka selle Management engine sees olevat Minixit.
Üldiselt, unustage see Management engine teema ära, see on nii 2017
| Kommentaarid: 29 loe/lisa |
olavsu1
külaline
03.01.2018 20:42:42
| Renka kirjutas: |
| olavsu1 kirjutas: |
what? Misasi see veel on? Ärme mõtle nüüd asju välja. |
Mis, kas see on juba äraunustatud? vaevalt et see päris veatu on.
| No eks mõeldi ikka selle Management engine sees olevat Minixit. |
just seda ma algul mõtlesingi.
