praegune kellaaeg 05.08.2025 05:54:36
05.11.2017 21:23:54
tsitaat: |
muutes karistused kohati võrreldavaks terrorismi ja inimkaubanduse eest saadud karistustega.
Nali kuubis.... ma koliks ära
05.11.2017 21:29:43
Ja Eesti eesistujana kiidab sellele kõigele veel takka
tsitaat: |
Another related leak from the Estonian Presidency reveals that it is letting the three countries set their agenda without interference. It seems that the Estonian Presidency is, again, choosing political expediency over the rights of European citizens and the free and open internet – and the Estonian ethos of a well-regulated, digital-friendly society. We have prepared a document to show how carefully the Estonian Presidency is following the three countries that are proposing these extreme measures. |
Ütleme nii, et kui see sigadus läbi läheb, siis ma eestlasena enam Euroopas köhatada ei julgeks.
HV valuutakalkulaator |
05.11.2017 21:32:47
Siis tuleb kontrollitult vahetada, kui kontrollimatu on karistatav...
05.11.2017 21:34:51
Etz, hostingufirma tehakse sisuliselt vastutavaks üleslaetud failide legaalsuse osas.
Ta peab kontrollima ja filtreerima igasugust sisu, mida sinna üles laetakse. Pmst lõpp hostingfirmadele.
tsitaat: |
No more hosting services
Under existing rules, internet hosting companies are not liable for unauthorised content uploaded by their users, unless they fail to act quickly to remove that content, once they are informed about it. The proposal is to leave that law in place, but redefine the services provided by hosting providers so that pretty much nobody is covered by that legislation (the e-Commerce Directive).
How is this done?
Firstly, the leaked document says that any company that allows users to upload content that could be copyrighted or subject to any property right (“other subject matter” such as, choreography, for example) is performing an act of “communication to the public”.
This means that the service provider is performing an activity that requires authorisation by rightsholders – unless at all times the provider can be sure that nothing that is, or could conceivably be, subject to a property right is being uploaded.
Specifically, the proposal is that companies “that store works or other subject-matter uploaded by their users and are actively involved in providing access to the public to such contents” should no longer be considered hosting companies, even if this is pretty much the definition of hosting. This means that hosting services (that optimise the content they store in any way) would need to carry out constant monitoring of everything that is uploaded to their services – and delete anything that might create a risk – as they will be directly liable for anything their users do.
Mandatory surveillance of all uploads
Having already made it virtually impossible to provide a hosting service without being licensed by all relevant collective rights management groups (film, audio, image, etc), the three countries go further: They demand that larger providers (those that store an undefined “significant” amount of material) should not only have to monitor everything that is being uploaded, but should also be required to “prevent the availability” of content that is identified by rightsholders (by using content identification and upload filtering). This would be flanked with an additional obligation to inform the multitude of rightsholders “on the functioning” of those measures. |
Sisuliselt pead andma meediafirmadele kontrolli oma failide üleslaadimise kohta.
viimati muutis Tanel 05.11.2017 21:39:03, muudetud 2 korda |
05.11.2017 21:35:36
Tanel, mul selline karvane tunne, et eestlased pooltel juhtudel noogutavad lihtsalt kaasa teadmata üldse teemat
05.11.2017 21:41:21
Tanel, nagu ma seda ei teaks, lihtsalt pealkirja sõnastus on niisugune, et ei saanud lihtsalt torkamata jätta...
Janar!
05.11.2017 21:43:47
Õige kah raisk, kuna terrorismi ja inimkaubanduseega on kõik korras siis tulebki muudele tähtsatele asjadele keskenduda.
sooty
05.11.2017 21:43:56
Kaua võib. Kinomeestel on ka vorsti leiva peale vaja. Kui kopeerid filmi, aitad terroristidel meie way of life'i hävitada.
05.11.2017 21:47:09
Mees kongis:"mille eest istuma pandi ja 30 aastat said?"
Teine::"killisin pommiga 80 inimest, sa?"
Esimene:"panin korra utorrenti tööle"
sooty
05.11.2017 21:52:04
jõuad saksa reisilt koju, nädal hiljem kargavad püssidega mehed akendest-ustest sisse ning lennutavad ööpimeduses Kuubasse, kus sõbranna Saksamaalt juba ees ootamas.
marcor1
05.11.2017 23:01:26
Kogu see seadusandlus tundub minevat "kirves pea kohal" suunas. Ehk kuniks sa probleeme ei tekita, seni kirves ei kuku.
Ehk demokraatia ei represseeri - ta paneb su kinni seaduste alusel. Lihtsalt tuleb palju seadusi kirjutada.
Eesti ametnike osalusest...
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
joulukas
05.11.2017 23:50:34
Nii kahju on lugeda, kuidas inimeste meedia huvi üritatakse karistada, selle asemel, et leida viise, kuidas see hoopis uueks rahamasinaks keerata. Ammu teada, et piraatluse vastu võitlemine on kallim, kui sellest saadav kahju. Kuigi autorikaitse on oluline teema, siis tänased lobistid on pigem 80ndate kassetimüügi ulmas meediakompaniid, kui tegelikult väetid autorid, kelle luuletusi ebaausalt jagatakse. Suund praks olema ikka uue generatsiooni meedia muud huvi rahuldamine, mitte vanadesse mudelitesse surumine. Kõige kurvem on aga see riikide tasemel hakkab seadusandlus selle rumalusega kaasa minema.
_________________ HinnaVaatlus liituja nr. 285 |
Reaper
06.11.2017 12:15:40
Mul on aina enam tunne, et peab Venemaal asuva serveri rentima... sinna EU pikad näpud ei ulata...
sooty
06.11.2017 12:21:09
Mille poolest nende näpud meie näppudest paremad on? Arvad, et ELi/NATO riigi kodanikuna ei paku neile sinu šantažeerimine huvi? Meie asukohta arvestades pole ametit, mille pidaja neile midagi kasulikku pakkuda ei saa.
devilman
06.11.2017 12:21:22
Piramine on ju inimõigus:(
wapper
08.11.2017 14:29:23
Reaper kirjutas: |
Mul on aina enam tunne, et peab Venemaal asuva serveri rentima... sinna EU pikad näpud ei ulata... |
See pani küll muigama. Venemaal on juba aastast 2013 olemas seadus, mis lubab õiguste omanikul nõuda kohtu ja Roskomnadzori kaudu sisu eemaldamist hosting pakkujalt. Ja see protsess ka reaalselt toimib, ja seda ka aktiivselt kasutatakse.
Mis puutub Eesti eesistumisse, miks selline paanika "eestlasena enam Euroopas köhatada ei julgeks"?
Ega Eesti pole seda initsiatiivi algatanud. Eesistuja ülesanne ongi korraldada diskussioone ja tegeleda asjadega, mis on EU poliitikas olulised. Ja Digital Single Market on oluline, ja piraatlus probleemina ilmselt ka oluline.
Eesti ei saa öelda, et me ei menetle seda algatust, kuna võim on täna meie käes ja FR, SP, PT, närige muru.
lisa lemmikuks |
