mine lehele eelmine  1, 2, 3 ... 55, 56, 57 ... 319, 320, 321  järgmine
sõnum 24.05.2017 21:20:53 vasta tsitaadiga
Hehe, streamisin veidi gameplay ja pandud, et automaatselt recordiks ka kettale. Ok, vaatasin mängides, et CPU usage on kuidagi vähe kõrgem kui tavaliselt aga frame ei droppinud ega midagi, seega probleemi ei näinud.
Pärast siis vaatan, et olin unustanud OBSi recordimise seadeid veidi muuta icon_biggrin.gif . Ühesõnaga encodes siis ühe profiiliga pilti striimi, lisaks teise profiiliga pilti kettale ja toimetas ka veel mängu jooksutamisega icon_lol.gif Ja no problems thumbs_up.gif
anubis
anubis
sõnum 26.05.2017 14:41:55 vasta tsitaadiga
http://www.anandtech.com/show/11447/amd-announces-ryzen-agesa-1006-update
With this new AGESA version, AMD has added 26 new memory-related parameters. The most dramatic improvement is the significant expansion of memory speed options. If we exclude base block overclocking - which relatively few motherboards support - the AM4 platform has thus far been effectively limited to memory speeds of DDR4-3200. Not only that, but the supported range of options from DDR4-1866 to DDR4-3200 was in large 266MT/s increments. With AGESA 1.0.0.6, memory frequencies have not only been expanded all the way up to DDR4-4000, but between DDR4-2667 and DDR4-4000 the increments have been reduced to 133MT/s. Not only does this mean that more memory kits will be able to be run at their rated speed - and not get kicked down to the nearest supported speed - but it also significantly reduces the high-speed memory gap that the AM4 platform had with Intel's mainstream LGA1151 platform.
The other important announcement is the unlocking of about two dozen memory timings. Up until now, only five primary memory timings have been adjustable and there wasn't even a command rate option, which was natively locked to the most aggressive 1T setting. All of this should help improve overclocking and most importantly compatibility with large swathe of DDR4 memory kits that have largely been engineered with Intel platforms in mind.
The last addition should excite those interested in virtualization. AMD has announced "fresh support" for PCI Express Access Control Services (ACS), which enables the ability to manually assign PCIe graphics cards within IOMMU groups. This should be a breath of fresh air to those who have previously tried to dedicate a GPU to a virtual machine on a Ryzen system, since it has thus far been fraught with difficulties.
jt234
jt234
sõnum 26.05.2017 14:45:44 vasta tsitaadiga
Dima oli siin
Kommentaarid: 132 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 124
sõnum 26.05.2017 21:07:40 vasta tsitaadiga
Väga kena. Nüüd tuleb kuu aega oodata kuni laisad tootjad enamus plaatidele suudavad uuenduse tuua. Paistab, et juuni kuus tuleb jälle kõvasti ryzen mem testing videosi vaadata icon_biggrin.gif thumbs_up.gif
Ennast huvitab eelkõige kuidas nelja pulga 3200+ peal jooksutamine paraneb. Hetkel saab nelja pulgaga max 2666 kätte kui ma ei eksi.
anubis
anubis
sõnum 26.05.2017 21:55:30 vasta tsitaadiga
Version 0612
Description PRIME B350M-A BIOS 0612
Improve system stability
Note: Updating BIOS method suggested
2017/05/24
Mu odav-käkile midagi tuli just.
edit: eip, mäluosas sama seis. Miski üldine heakorratöö-vaheaste vist.
xpander
xpander
sõnum 27.05.2017 17:31:55 vasta tsitaadiga
Tomorrow kirjutas:
just. Mul 2666 peal 4 pulka.. tahaks 3200 kätte saada.. eks ootame uuendusi
Linux Gaming Videos: Xpander69
DeTHiCa.
DeTHiCa.
sõnum 30.05.2017 01:02:51 vasta tsitaadiga
Packing all the power of AMD's new AM4 series into an astonishingly compact space-saving Mini-ITX footprint, ASRock will also be launching and demonstrating the new Fatal1ty X370 Gaming-ITX/ac and the Fatal1ty AB350 Gaming-ITX/ac. Apart from the chilling killer design, two boards come with two HDMI outputs, 802.11ac WiFi solution, 7.1-CH with Realtek ALC 1220 codec, heatsinks that effectively improve heat dissipation and promotes overall performance.
s1155 asrocki mITX platega jäin väga rahule, arvan et siit tuleb samuti midagi head. thumbs_up.gif
Braien
Braien
sõnum 30.05.2017 08:11:23 vasta tsitaadiga
Tundub päris vinge, asrock on ikka arenenud korralikult, vanasti poleks assrock plaati julgenud omada, nüüd üks parematest imo.
sooty
sõnum 30.05.2017 08:16:50 vasta tsitaadiga
Plaadid on neil vist jah head, aga saadavus oli ryzeni launchi ajal väga kehv. Loodetavasti oskavad nüüd arvestada.
One
sõnum 30.05.2017 09:55:21 vasta tsitaadiga
Milleks sellele kaks hdmi pesa kui seni prosedel igp puudub icon_biggrin.gif
anubis
anubis
sõnum 30.05.2017 10:00:37 vasta tsitaadiga
Ryzen+Vega kombo jaoks. AM4 on pikaajaline investeering AMD jaoks.
coolmode
coolmode
sõnum 30.05.2017 12:21:09 vasta tsitaadiga
Keegi oskab öelda, miks arvuti pildi mustaks lööb kui alt tabida vahest mõnest mängust nii et peab restardi tegema ? Ryzen 1700, ning juurde keeratud 3,7ghzni, temperatuurid jms kõik ok (mängides 42)
anubis
anubis
sõnum 30.05.2017 12:30:22 vasta tsitaadiga
Driveri kala pigem, kas OCta reprod seda? Kui jah siis võta OCd vähemaks.
BIOSi uuendused + driverite update (videokaart + chipset) võibolla abiks. Võid ka error reportingut kasutada, ehk tuvastavad midagi.
KyBer
KyBer
sõnum 30.05.2017 18:00:22 vasta tsitaadiga
anubis kirjutas:
Kas vega hakkab läbi emaplaadi pesade pilti näitama?
Kommentaarid: 114 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 98
anubis
anubis
sõnum 30.05.2017 18:06:19 vasta tsitaadiga
Uus APU, mõtlesin.
Denkeš
Denkeš
sõnum 30.05.2017 18:21:24 vasta tsitaadiga
anubis kirjutas:
Uus APU, mõtlesin.
Vana Bristol Ridge APU ka tegelikult.
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
Firefly
Firefly
sõnum 30.05.2017 19:35:05 vasta tsitaadiga
AMD uus "threadripper" socket - https://youtu.be/nynBEGCtg90?t=1m50s. Näeb välja nagu kaks ryzenit on kokku pandud.
Kommentaarid: 152 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 142
One
sõnum 30.05.2017 20:50:22 vasta tsitaadiga
anubis
anubis
sõnum 30.05.2017 21:23:29 vasta tsitaadiga
Threadripper ongi kaks Zeppelini ühel plaadil Infinityfabricuga kokkuseotult. AMD kogu Ryzeni ökosüsteemi mõte on mitme väikse kivi sidumine ülikiire toruga üheks vs hiiglasliku monoliitse kivi tootmine (millejaoks neil lihtsalt majanduslikult mõtet pole).
Paistab sama socket olevat mis Epyc'ul, ehk siis AMD saab oma pakkumise tõsta praeguse 16c/32t (2xZeppelin 8c/16t IFga seotult ühel plaadil) pealt 32c/64t (4xZeppelin 8c/16t) peale, Zeppelin2 või mis iganes tema nimi olema saab osas tähendaks see siis maksimaalselt 48c/96t (4x12c/24t).
Sama socket meigib senssi, pole mõtet kolmandat teha, eriti AMD'l. AM4 ja see TR4 (Threadripper/Epyc pesa) on mõlemad pikaajalised investeeringud.
Killhoven
OC`er
Killhoven
sõnum 30.05.2017 21:32:22 vasta tsitaadiga
Unetutele meeldetuletuseks, et kella viiest hommikul hakkab AMD Computex 2017 konverents. Peaks kuulma uudiseid Vega ja Threadripperi teemadel.
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
A-Circus.
A-Circus.
sõnum 31.05.2017 15:46:30 vasta tsitaadiga
anubis kirjutas:
Teoorias vast isegi saaks 32 tuumalise sinna lükata, kuid samas tähendaks see seda, et iga 8 tuuma (nagu Ryzen 7) kohta jääks ainult 1 mälukanal- kuna X399 toetab nelja kanalit. Praegu teame, et isegi 2 mälukanaliga vajab Ryzen 7 nii mõneski rakenduses väga kõrgel sagedusel töötavaid mälusid et oma potentsiaali realiseerida. 32 tuuma puhul jääks mälu läbilase ilmselt väga suureks piduriks.
anubis
anubis
sõnum 31.05.2017 15:53:55 vasta tsitaadiga
https://www.techpowerup.com/233888/first-amd-threadripper-motherboards-pictured-they-look-glorious
DeTHiCa.
DeTHiCa.
sõnum 31.05.2017 15:59:45 vasta tsitaadiga
inteli logo amd mobo peal, on ikka jultumust.
Denkeš
Denkeš
sõnum 31.05.2017 17:47:54 vasta tsitaadiga
Gigabyte omanikele midagi rõõmustavat https://www.techpowerup.com/233886/tpu-ryzen-bios-digest-issue-6
a.k.a Ummikummi
sõnum 02.06.2017 15:59:56 vasta tsitaadiga
Noctua Threaripper jahuti prototüüp: https://www.techpowerup.com/233969/noctua-ready-with-heatsink-protoypes-for-threadripper-tr4-sp3-sockets
16c/32t <900€? icon_eek.gif http://wccftech.com/amd-ryzen-threadripper-16-core-cpu-849-us-price-x399-motherboards/
14c/28t <750€?
12c/24t <600€?
10c/20t <500€?
See kõik hetkel muidugi spekulatsioon. X399 plaadid samas pidid kallid tulema arvestades ülisuurt socketit jms. Eks näis.
Samas Ryzen 7 hindu on langetatud (v.a Eestis icon_lol.gif ). 1800X on nüüd alla 500€ ja 1700 on tsipa üle 300. 1600 tsipa üle 200.
jt234
jt234
sõnum 02.06.2017 16:14:02 vasta tsitaadiga
Tomorrow kirjutas:
Dima oli siin
sama123
sõnum 02.06.2017 20:41:45 vasta tsitaadiga
Kunagi oli MHZ võistlus, nüüd corede arv! See 16/32 core on 2x standardsest suurem! Mida suurem pind prosel seda parem jahutus. Lauamasinas on ruumi laialt eriti ful toweris ja arengumaad on. Miks aga sinna 180w piirimaale jäädakse? Võiks kohe A4 pinnaga prose kompunnida millel pliidi kiirplaadi võimsus ja standardsest 16A pistikust muutub "tavatarbija" pudelikael. Mehine radikas nagu veoautol ja SUUR pump rahulikult jahutavad mingi tühised 5-10KW sooja ära, torud õue ja olekski 200/400 cor prose valmis. Pealegi siis ei peaks MHZ piirama ikka nii 5000 ja üle beer_yum.gif icon_lol.gif
Siis annaks ka eramute kütte turule siseneda ja küsimusele milline küte sul on, et eks ikka digitaalne arvuti juhitav. Õhk vesi soojuspumbaga paari..... ja kõik 100% soojust & elektrit läheks täie ette beer_yum.gif
rene p
sõnum 02.06.2017 21:09:04 vasta tsitaadiga
Keegi siinsetest Asus Prime X370-Pro omanikest beta 0801 biosega ka katsetanud on?
http://www.overclock.net/t/1626011/my-experience-with-the-asus-prime-x370-pro/960#post_26133807
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 68
anubis
anubis
sõnum 02.06.2017 21:21:37 vasta tsitaadiga
Ma olen üsna kindel, et AMD ei lähe CPU hindades $999 piirist üle.
Nüüd oleks veel vaja x399 mATX emaplaati ja mina oleks ootejärjekorras thumbs_up.gif
sõnum 02.06.2017 21:33:43 vasta tsitaadiga
rene p kirjutas:
Ei ole. Ilmselt tuleb õige ka mingi nädala jooksul
xpander
xpander
sõnum 03.06.2017 10:51:33 vasta tsitaadiga
rene p kirjutas:
mul see peal. võrreldes eelmiste betadega (0701, 0611) ja ka 0612'ga , mis ei lubanud mul isegi prose 3.7ghz peal stabiilseks saada, 0n 0801 päris asjalik, 3.9ghz peal ilma probleemideta 1.375V. Mälusid kahjuks siiani pole 2666 pealt kiiremaks saanud 4 pulgaga.
Aga nüüd on BIOSis DRAM timings all kõvasti nodi.. peab veel geardown jms proovima ja katsetama... tahaks 2933 vähemalt kätte 4st pulgast ikka saada
Diesel157
sõnum 03.06.2017 14:23:45 vasta tsitaadiga
Ei tea kas varem on postitatud, aga rammiga oli ju seda moodi... icon_question.gif icon_wink.gif
Kommentaarid: 162 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 146
parkenTOSH
sõnum 04.06.2017 00:52:06 vasta tsitaadiga
Denkeš kirjutas:
Väga hea. Nüüd töötab mu Corsair'i 3200 Hynix'i kiipidega mälu kenasti XMP profiilis (3200mHz, 1,35v). Vähemalt tund aega Prime95 blend testi pidas vastu. Rohkem ei viitsinud testida. Enne pani prime paari minuti jooksul pange (pealegi oli volt ka kõrgem).
sõnum 04.06.2017 02:26:50 vasta tsitaadiga
Diesel157 kirjutas:
See oli launchi ajal. Praeguseks on olukord märgatavalt paranenud. Mitte küll ideaalne veel (4 pulga kiirused 3200+ ja kahe pulga 4000+ kiirused on vaja veel kätte saada) but it's getting there thumbs_up.gif
anubis
anubis
sõnum 04.06.2017 07:58:48 vasta tsitaadiga
Mul launchist alates 4x DR DIMMid @2400 jooksnud.
Vael
sõnum 04.06.2017 18:26:57 vasta tsitaadiga
Diesel157, see on default DDR4 kiirus. Tootjad võivad chipsetile ja DDR4-le OC lisada, et saada premaid tulemusi.
AMD puhul on kesktasemest alates "võimalik" OC-da, Inteli H\B chisettidel puudub selline võimalus absoluutselt, ehk jooksevad default DDR4 kiirustel, mis praeguseks on lükatud 2133Mhz pealt 2400\2666Mhz peale.
Diesel157
sõnum 05.06.2017 16:52:31 vasta tsitaadiga
Selge, aga näiteks mängudes eriti mingit perfi kiiremast rammist ei tule mid-kaardiga, et alates mingi Nvidia 1080 oli edasiminek vist näha alles? Oskab keegi kommida seda teemat?
DeTHiCa.
DeTHiCa.
sõnum 05.06.2017 17:10:35 vasta tsitaadiga
Diesel157 kirjutas:
saab ka mid-range kaardiga FPS juurde, aga oleneb mängust.
jt234
jt234
sõnum 05.06.2017 17:21:24 vasta tsitaadiga
60 kandis ei ole vast vahet. 144Hz peal juba on.
Dima oli siin
-kasutaja-
-kasutaja-
sõnum 05.06.2017 23:23:13 vasta tsitaadiga
Link
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 31
DeTHiCa.
DeTHiCa.
sõnum 05.06.2017 23:49:44 vasta tsitaadiga
see krdi tomb raider on nagu mingi benchmarkingu püha lehm nüüd või?
Longero
sõnum 06.06.2017 03:06:22 vasta tsitaadiga
Mis progega eelmises videos andmeid monitori serval vaadati, mingi salvestusproge?
Win ISO'd ja uuendused
Artiklid jagatud
Kommentaarid: 58 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 54
Flab
sõnum 06.06.2017 07:07:35 vasta tsitaadiga
Rivatuner?
Kommentaarid: 993 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 782
pots4t4j4
sõnum 06.06.2017 07:41:46 vasta tsitaadiga
Msi afterburneriga tuleb rivatuneri overlay kaasa.
felix kütt
felix kütt
sõnum 06.06.2017 20:09:12 vasta tsitaadiga
Tomorrow kirjutas:
14c/28t <750€?
Oleme äkki pigem tagasihoidlikud optimistid:
apt-get moo
anubis
anubis
sõnum 06.06.2017 20:22:53 vasta tsitaadiga
AMD võiks ideeliselt müüa 16c/32t (odavamat, ehk siis mitte "X") isendit ka $699ga, kuna nad müüvad Ryzen 1700 hetkel USAs $299ga.
Erinevalt Intelist ei ole tegemist kaks korda suurema kiviga vaid kaks kivi kõrvuti lahendusega, mis tänu väidetavalt äärmiselt headele yieldidele (80%+) tähendab külluses 8c/16t Zeppelinide saadavust ja väga head tootlikkust/ROI isegi nii madala hinnaga müümisel.
viimati muutis anubis 06.06.2017 20:27:29, muudetud 2 korda
pots4t4j4
sõnum 06.06.2017 21:17:33 vasta tsitaadiga
Krt varsti peab 1700 maha müüma ja miskit muud huvitavat asemele leidma icon_biggrin.gif
4ghz peal tahab raibe 1.425v et stabiilne olla
Braien
Braien
sõnum 06.06.2017 21:25:12 vasta tsitaadiga
pots4t4j4, Oota threadripper ära, siis vaata edasi.
jt234
jt234
sõnum 07.06.2017 00:19:14 vasta tsitaadiga
Ise ootan Zen 2 ära ja siis liigun vast 1700 pealt edasi.
Dima oli siin
SilQ
SilQ
sõnum 07.06.2017 09:37:16 vasta tsitaadiga
jt234 kirjutas:
icon_lol.gif Te mõtlete müügist ma ootan veel ITX platesid siiani.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Kommentaarid: 251 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 215
uus teema   vasta Raud »  Protsessorid »  AMD Zen/Ryzen/Threadripper/Epyc arutelu mine lehele eelmine  1, 2, 3 ... 55, 56, 57 ... 319, 320, 321  järgmine
