Jaan
123 |
labidas
17.02.2017 17:53:00
"The single threaded (single core) performance of this Ryzen unit shows 1888 points. That is precisely on par with Core i7 6850K single core performance and that I did not expect (thus that is very positive). We know that the Intel Core i7-6850K clocks in at 6/12 (cores/threads) 3.6 GHz / 3.8 GHz (base clock / turbo clock). So compared 1:1 that is really fricken close on the per core performance. The Ryzen muli-threaded performance shows 12544 points, which is faster then a Core i7-6850K who reaches 10872 points in our own testing. "
http://www.guru3d.com/news-story/6-core-ryzen-5-1600x-benchmarks-shows-50-faster-then-core-i5-7600k.html
| Kommentaarid: 34 loe/lisa |
34 |
17.02.2017 20:53:19
196 |
sooty
17.02.2017 22:09:27
| Etz kirjutas: |
mälu, m.2 ja RX480 OC ootavad mobo & 1600X ryzenit
| Kommentaarid: 12 loe/lisa |
12 |
Optimist
17.02.2017 23:01:25
http://www.bitsandchips.it/52-english-news/8058-xfr-and-its-anchestors
Now let's talk of Ryzen. We can suppose that it has all these features. XFR is not too much far from Bristol Ridge's shadow p-states. The only difference is that XFR should go in 25MHz increments, and not be bound to p-states and thus it doesn't have any upper limits. The SMU calculates the VFTs and if the current power drawn is under the TDP limit, the temperature is under the limit and the needed Vcore is under the current calculated Vmax, the frequency increase is acknowledged. If any of these conditions are not met, the frequency is decreased until they are met. The temperature can probably be measured in multiple spots and the maximum is used. This can limit the single core boost to safe levels, in which the TDP limit is not met, but the core is too hot. Better cooler will help to raise the actual frequency at which this happens.
From these information, we could guess that XFR is a powerful automatic clocking technology, that will render hard to do better with traditional overclock. Just raise TDP and temperature limits, put a good cooler and let Ryzen clock itself higher. The only other knobs, beside TDP and temperature limits, that we foresee are Vmax offset, to allow higher Vcore and guard band relaxing on the statistics collected to calculate the VFTs. But those knobs are at your own risk. We don't know what things will be configurable by the users, but XFR seems an interesting tool to squeeze the maximum from the hardware.
Kui väidetav Ryzen5 1600X CPU-Z single core@1888 tulemus oli XFR'i+hea jahutusega lastud, siis see üksik tuum võis päris karmil taktil lipata.
| Kommentaarid: 10 loe/lisa |
eix666
18.02.2017 00:03:22
| Optimist kirjutas: |
Kui väidetav Ryzen5 1600X CPU-Z single core@1888 tulemus oli XFR'i+hea jahutusega lastud, siis see üksik tuum võis päris karmil taktil lipata. |
Multithread number oli samamoodi võrreldav Inteli vastavate prosedega, niiet päris nii polnud, et üksik tuum sai hullu takti aga kõik 6 tiksusid vaikselt ja rahulikult finišisse. Samas eks see XFR paras küsimärk ole. Lisaks veel see, et selliseid lekkinud numbreid tasub alati paraja koguse naatriumkloriidiga manustada.
| Kommentaarid: 39 loe/lisa |
39 |
18.02.2017 08:09:17
i5 6600K teeb stock 1757.
see lambi number, sest taustal asju käimas. AMD osas siit nüüd midagi head loeks kui hind tuleb soodne.
Ehk saadki 240.- asja 160-ga.
201 |
SilQ
18.02.2017 09:48:35
Magic, Arvestades, et tegu on mitte tipp seeria CPU'ga siis ma küll ühtegi halba sõna ei ütleks. Nendel 1800X ma ei usu, et single score üle 7700K läheb, aga loota võib.
Def 7700K score on 2770.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
215 |
Diesel157
18.02.2017 11:24:30
| Tegelikult miinimum mis neil vaja on haswelli kanti core perf ja vastav hind. Edasi saavad nad asja tuunida nagu intel teeb, ikka nõksu paremuse poole jne.
| Kommentaarid: 162 loe/lisa |
146 |
trip
18.02.2017 12:43:09
| SilQ kirjutas: |
Def 7700K score on 2770. |
2300
http://valid.x86.fr/bench/1
kust see 2700 number tuli
oc ilmselt
303 |
SilQ
18.02.2017 12:59:54
trip, Googeldasin kiirelt ja sain esimese vaste, ei tundu väga OC.
215 |
trip
303 |
SilQ
18.02.2017 13:18:55
trip, Selge, see pisiasi jäi kahesilma vahele , vaatasin ainult pilti, seal oli @ 4.2.
Aga anyway, loodan et 1800X singel core tuleks sama jõudlusega.
Tegelikult, see test on natuke naljakas, lasin for fun kodu masinal ka selle testi, selle tabeli järgi saan profiili masinaga 4590 non K käest ka põske. Kuigi muudes benchmarkidest on pea poole kiirem.
215 |
sooty
18.02.2017 14:06:17
Crosshair VI Hero Unboxing and First Look
Kas keegi veel Taiwanis ka toodab? Sellel tagumisel poolel selgelt kirjas 'made in china'
12 |
18.02.2017 15:37:54
Loodan täiega, et AMD kaardile tagasi tuleb... kui nad oma GPU'd oma CPU'dega veel eriti hästi koos toimima saaksid, siis oleks megahea...
VB. pole läbi käinud veel:
www.digitaltrends.com/computing/ryzen-leaked-slides/ "Technical slides reveal new truths about Ryzen's power management "
182 |
pots4t4j4
18.02.2017 16:29:14
| Täpp.
401 |
erick
18.02.2017 17:02:39
| rmc kirjutas: |
www.digitaltrends.com/computing/ryzen-leaked-slides/ "Technical slides reveal new truths about Ryzen's power management " |
Kui ma nüüd seda õigesti lugesin, siis XFR toob meile per-core automaatse overlockingu? Väidetavalt siis Ryzen on võimeline ise aru saama, millised tema tuumadest on head kellujad, ja andma igal tuumale just talle optimaalse pinge, et igast tuumast eraldiseisvalt maksimaalne sagedus välja võluda. Nõrgemad tuumad siis jäävad madalamatele sagedustele ja paremad tuumad lükatakse nii üles kui võimalik. Vot see on küll üsna huvitav!
Räniloterii saab samuti uue tähenduse - parimad chipid siis need, millel maksimaalne arv tuumasid ennast ise võimalikult kõrgele klokivad.
96 |
18.02.2017 17:29:48
erick, mhm, sain sellest ise samuti nii aru... igatahes tundub see kõik väga huvitav. Tahaks ainult teada, kas see AUTO OC on piisavalt täpne, et asendada käsitsi-OC'd või jääb täppis-OC siiski lae saavutamisel domineerima..
182 |
pots4t4j4
18.02.2017 19:09:49
| Ma ei saa aru miks seda XFR niiväga vaja on? Kes tahab kellab manuaalselt ja kes ei taha see ei kella ja ongi kõik? XFR pole ju boost.
401 |
DeTHiCa.
18.02.2017 19:14:40
| automaat oc paneb voldi üldiselt veidi kõrgemale et garanteerida stabiilsus. käsitsi kruttides saab alati parema tulemuse, prose kah jahedam kui volt madalam.
140 |
Auron
18.02.2017 19:18:02
| erick kirjutas: |
| Räniloterii saab samuti uue tähenduse - parimad chipid siis need, millel maksimaalne arv tuumasid ennast ise võimalikult kõrgele klokivad. |
Lõhnab handpicked black editionite järele kui tõsi.
133 |
SilQ
18.02.2017 19:19:25
| pots4t4j4 kirjutas: |
| Ma ei saa aru miks seda XFR niiväga vaja on? Kes tahab kellab manuaalselt ja kes ei taha see ei kella ja ongi kõik? XFR pole ju boost. |
See on pigem sellisele inimesele kes arvutitest, clokkimisest ja biosist siblimisest midagi ei tea, aga samas tahaks võimalikult palju pauku. Siis ma ei pane üldse pahaks kui ta selle eest rohkem raha välja käib.
215 |
sooty
18.02.2017 19:39:38
| Auron kirjutas: |
| erick kirjutas: |
Lõhnab handpicked black editionite järele kui tõsi. |
Loodetevasti AMD ülevaatajatele cherry picked näidiseid ei saada, aga kindel ei või olla. Kas keegi tänapäeval oma prosed ja muu kraami poest ka toob, või teevad kõik ülevaated "tasuta" saadud tehnikaga?
12 |
Metsjeesus
18.02.2017 20:01:15
| Magic kirjutas: |
Ehk saadki 240.- asja 160-ga. |
Eks ta nii ole. Vahetasin oma 4a 1700punkti peal tiksunud 2500k välja, mis sisuliselt 70 euro prose. AMD puhul see xfr võiks justkui asja päästa, paljud oleksid nõus nö muretu OC eest grammi lisa maksma. Mõnel juhul on ju ikka väga isane Performance tõus.
Vaatame.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
18.02.2017 20:29:15
| sooty kirjutas: |
| Auron kirjutas: |
| erick kirjutas: |
Loodetevasti AMD ülevaatajatele cherry picked näidiseid ei saada, aga kindel ei või olla. Kas keegi tänapäeval oma prosed ja muu kraami poest ka toob, või teevad kõik ülevaated "tasuta" saadud tehnikaga? |
Kahtlen, et midagi cherrypicked üldse on. Cherrypicking on suuresti käsitöö ja see maksab palju rohkem kui kalleim 550€ vms mudel. Näiteks siliconlottery.com lehel on näha mida cherrypicking lisab Inteli hindadele. Vaevalt AMD-ga teistmoodi oleks. Mis puutub reviewereid, siis paraku jah tavaliselt nad saavad oma isendid tootja/edasimüüja käest. Väga harva, kui nad testi mõttes lähevad ja ostavad retailist (tavaliselt on see ka selgelt välja toodud siis ülevaates). Nt on neil sellised alusetäied prosesi (tunnistan, et teeb kadedaks küll ):
| Kommentaarid: 92 loe/lisa |
pots4t4j4
401 |
18.02.2017 22:06:25
13 erinevat proset, wtf
1700X vist vaid nupu vajutusega saab 100 daala kallimaks teha....ei mõista
18.02.2017 22:09:01
Eestis siis umbes taoline ilmselt
R7 1800X: 569.99 €
R7 1700X: 459.99 €
R7 1700: 379.99 €
18.02.2017 22:10:18
X versioonil on mingi präänik ikka olemas, vaevalt see jahuti on 60 daala eest....krt seda teab
sooty
18.02.2017 22:11:27
| Kui, siis ainult otse laost. Mingit ehku peale vahemehelt tellimist, ammugi preorderit, küll tegema ei hakka.
12 |
18.02.2017 22:11:47
ah kurat, nüüd lugesin edasi, seal pealkirjas antud hinnad vist ilma käibekata... Krt üldse kirjutada ilma käibemaksuta hindasi sedasi...
Siis pakuks endiselt
R7 1800X: 669.99 €
R7 1700X: 559.95 €
R7 1700: 449.95 €
SilQ
18.02.2017 22:12:38
| jeesus188 kirjutas: |
X versioonil on mingi präänik ikka olemas, vaevalt see jahuti on 60 daala eest....krt seda teab  |
X versioonil on, cooler + XFR tehnoloogia. See ilmselt 60$ väärt.
215 |
18.02.2017 22:13:37
ma selle maha maganud...mis see on?
SilQ
18.02.2017 22:16:17
| jeesus188, erick ütles eelmisel lehel: "XFR toob meile per-core automaatse overlockingu. Väidetavalt siis Ryzen on võimeline ise aru saama, millised tema tuumadest on head kellujad, ja andma igal tuumale just talle optimaalse pinge, et igast tuumast eraldiseisvalt maksimaalne sagedus välja võluda. Nõrgemad tuumad siis jäävad madalamatele sagedustele ja paremad tuumad lükatakse nii üles kui võimalik."
215 |
18.02.2017 22:17:55
ma selle maha maganud...mis see on?  |
Too late. Kui sa nii kaua kivi all oled maganud, siis maga edasi. Sellest on siin mitu kuud juba juttu olnud
| salatoimik kirjutas: |
R7 1800X: 669.99 €
R7 1700X: 559.95 €
R7 1700: 449.95 € |
Jep see on äärmiselt kummaline. Tavaliselt on 99% juhtudel EU hinnad ALATI koos maksudega juba kirjas. Samas, kui USA hind on 499, siis ma ei usu elu sees, et ka EU hind tuleb 499. Parimal juhul tuleb EU hind 550-570 tippmudeli eest. Arvestades Eesti väiksust on ka täiesti usutavad hinnad mis sa oled välja toonud. Samas - ma ei kaeble. Isegi 670€ on tippmudeli eest väga hea hind arvestades Inteli röövellikke hindasid. Pannes asjad perspektiivi on see umbes samas klassis hind mida küsitakse tipp GPU eest a'la GTX 1080 ja arvatavasti tuleb ka Vega sinna hinnaklassi.
viimati muutis Tomorrow 18.02.2017 22:23:18, muudetud 1 kord |
18.02.2017 22:24:50
| Tomorrow kirjutas: |
Too late. Kui sa nii kaua kivi all oled maganud, siis maga edasi. Sellest on siin mitu kuud juba juttu olnud  |
No ega ma plaanigi osta, ootan vaid head asja, et inteli tavaari hind alaneb. Ma oma masina peal plaanin veel paar 3 aastat istuda
Samas saad shita isendi, siis tagastad ja võtad uue 14p jooksul?
pots4t4j4
401 |
anubis
18.02.2017 22:38:02
Ma ootan neid 32c/64t kive.
283 |
18.02.2017 22:56:23
Üks asi paneb siiski veidi muretsema. Kõikidel lekkinud testidel on Turbo, XFR - misiganes, olnud kinni keeratud. Kas ES-id ei peaks just olema selle jaoks, et selliseid asju testida ja buge parandada mis võivad esineda?
Kui see on kogu aeg kinni keeratud, siis kui hästi see tegelikult toimib?
Üks teooria mis ma kuulnud olen on see, et soft ei suuda Turbot korralikult lugeda ja seega eeldab, et see on kinni keeratud. Tulemused justkui viitavad, et see tegelikult toimib ja prose ikka boostib 3.6 peal 4.0 peale.
Või siis veel üks variant, et XFR per core OC on nii uus nähtus, et soft ei suuda sellest aru saada.
pots4t4j4
18.02.2017 23:00:54
| anubis kirjutas: |
Millal need tulevad?
401 |
olc
18.02.2017 23:09:18
| anubis kirjutas: |
Sellega saab kõiki Doome korraga mängida?
130 |
sooty
18.02.2017 23:17:15
Või siis veel üks variant, et XFR per core OC on nii uus nähtus, et soft ei suuda sellest aru saada. |
AFAIK on need lekitatud testid kõik madalama otsa MOBO peal ja seal ei tohiks XFR üldse töötada. Ainult CPU enda boost. X prose või mitte.
AMD võiks kõigi nende lekete peale oma PR plaani muuta ja NDA katkestada ja miks google >.< peale ühtegi emoticoni ei anna... tahaks siia panna...
viimati muutis sooty 18.02.2017 23:19:30, muudetud 1 kord |
12 |
18.02.2017 23:18:52
Et siis veel parem kui näidatakse?
See viib sõjani
sooty
18.02.2017 23:20:00
| ... no AFAIK. Vähemasti need 1600/1500 omad pidavat väga madala otsa pealt olema.
12 |
18.02.2017 23:31:39
| sooty kirjutas: |
AMD võiks kõigi nende lekete peale oma PR plaani muuta ja NDA katkestada ja miks google >.< peale ühtegi emoticoni ei anna... tahaks siia panna... |
Jah, aga XFR on emaplaadist sõltumatu selle põhjal mis ma näinud olen. Ainult manuaalset OC ei saa teha odava otsa plaatidel. Samas ma olen näinud ka teste X370 peal.
sooty
18.02.2017 23:40:56
| Hmm, see on uudis. Kas XFR/mobo seose kohta on mingi link anda? Võiksin siis odavama otsaga 1700x võtta ja win?
12 |
koiott
18.02.2017 23:44:16
| sooty, Eks sõltub jah, mida tahta. Kui see XFR üksikuid tuumi boostib, siis mängudes parem. Kui tahad max multicore perfi, siis vast kallis plate ja 1700/1700X ja manual OC. Aga praegu tuleb infot nii palju ja midagi väga kindlat on raske öelda, peab natuke veel ootama.
136 |
sooty
18.02.2017 23:54:54
Nojah, tegelikkuses muid asju ka vaja vaadata. Madalamal otsal paistab SATA portidega väga kitsas olevat. Mul on vaja vähemalt seitset. Võiksin ka laienduseks eraldi kaardi võtta, ilmselt oleks sääst täitsa olemas. Kastil akent ei ole, aga jääks ikkagi hinge kraapima.
12 |
sama123
| Kommentaarid: 23 loe/lisa |
22 |
