Jaan
123 |
labidas
17.02.2017 16:53:00
"The single threaded (single core) performance of this Ryzen unit shows 1888 points. That is precisely on par with Core i7 6850K single core performance and that I did not expect (thus that is very positive). We know that the Intel Core i7-6850K clocks in at 6/12 (cores/threads) 3.6 GHz / 3.8 GHz (base clock / turbo clock). So compared 1:1 that is really fricken close on the per core performance. The Ryzen muli-threaded performance shows 12544 points, which is faster then a Core i7-6850K who reaches 10872 points in our own testing. "
http://www.guru3d.com/news-story/6-core-ryzen-5-1600x-benchmarks-shows-50-faster-then-core-i5-7600k.html
33 |
17.02.2017 19:53:19
| Kommentaarid: 229 loe/lisa |
194 |
sooty
17.02.2017 21:09:27
| Etz kirjutas: |
mälu, m.2 ja RX480 OC ootavad mobo & 1600X ryzenit
| Kommentaarid: 12 loe/lisa |
12 |
Optimist
17.02.2017 22:01:25
http://www.bitsandchips.it/52-english-news/8058-xfr-and-its-anchestors
Now let's talk of Ryzen. We can suppose that it has all these features. XFR is not too much far from Bristol Ridge's shadow p-states. The only difference is that XFR should go in 25MHz increments, and not be bound to p-states and thus it doesn't have any upper limits. The SMU calculates the VFTs and if the current power drawn is under the TDP limit, the temperature is under the limit and the needed Vcore is under the current calculated Vmax, the frequency increase is acknowledged. If any of these conditions are not met, the frequency is decreased until they are met. The temperature can probably be measured in multiple spots and the maximum is used. This can limit the single core boost to safe levels, in which the TDP limit is not met, but the core is too hot. Better cooler will help to raise the actual frequency at which this happens.
From these information, we could guess that XFR is a powerful automatic clocking technology, that will render hard to do better with traditional overclock. Just raise TDP and temperature limits, put a good cooler and let Ryzen clock itself higher. The only other knobs, beside TDP and temperature limits, that we foresee are Vmax offset, to allow higher Vcore and guard band relaxing on the statistics collected to calculate the VFTs. But those knobs are at your own risk. We don't know what things will be configurable by the users, but XFR seems an interesting tool to squeeze the maximum from the hardware.
Kui väidetav Ryzen5 1600X CPU-Z single core@1888 tulemus oli XFR'i+hea jahutusega lastud, siis see üksik tuum võis päris karmil taktil lipata.
| Kommentaarid: 10 loe/lisa |
eix666
17.02.2017 23:03:22
| Optimist kirjutas: |
Kui väidetav Ryzen5 1600X CPU-Z single core@1888 tulemus oli XFR'i+hea jahutusega lastud, siis see üksik tuum võis päris karmil taktil lipata. |
Multithread number oli samamoodi võrreldav Inteli vastavate prosedega, niiet päris nii polnud, et üksik tuum sai hullu takti aga kõik 6 tiksusid vaikselt ja rahulikult finišisse. Samas eks see XFR paras küsimärk ole. Lisaks veel see, et selliseid lekkinud numbreid tasub alati paraja koguse naatriumkloriidiga manustada.
| Kommentaarid: 39 loe/lisa |
39 |
18.02.2017 07:09:17
i5 6600K teeb stock 1757.
see lambi number, sest taustal asju käimas. AMD osas siit nüüd midagi head loeks kui hind tuleb soodne.
Ehk saadki 240.- asja 160-ga.
200 |
SilQ
18.02.2017 08:48:35
Magic, Arvestades, et tegu on mitte tipp seeria CPU'ga siis ma küll ühtegi halba sõna ei ütleks. Nendel 1800X ma ei usu, et single score üle 7700K läheb, aga loota võib.
Def 7700K score on 2770.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
| Kommentaarid: 244 loe/lisa |
210 |
Diesel157
18.02.2017 10:24:30
| Tegelikult miinimum mis neil vaja on haswelli kanti core perf ja vastav hind. Edasi saavad nad asja tuunida nagu intel teeb, ikka nõksu paremuse poole jne.
| Kommentaarid: 157 loe/lisa |
142 |
trip
18.02.2017 11:43:09
| SilQ kirjutas: |
Def 7700K score on 2770. |
2300
http://valid.x86.fr/bench/1
kust see 2700 number tuli
oc ilmselt
303 |
SilQ
18.02.2017 11:59:54
trip, Googeldasin kiirelt ja sain esimese vaste, ei tundu väga OC.
210 |
trip
303 |
SilQ
18.02.2017 12:18:55
trip, Selge, see pisiasi jäi kahesilma vahele , vaatasin ainult pilti, seal oli @ 4.2.
Aga anyway, loodan et 1800X singel core tuleks sama jõudlusega.
Tegelikult, see test on natuke naljakas, lasin for fun kodu masinal ka selle testi, selle tabeli järgi saan profiili masinaga 4590 non K käest ka põske. Kuigi muudes benchmarkidest on pea poole kiirem.
210 |
sooty
18.02.2017 13:06:17
Crosshair VI Hero Unboxing and First Look
Kas keegi veel Taiwanis ka toodab? Sellel tagumisel poolel selgelt kirjas 'made in china'
12 |
18.02.2017 14:37:54
Loodan täiega, et AMD kaardile tagasi tuleb... kui nad oma GPU'd oma CPU'dega veel eriti hästi koos toimima saaksid, siis oleks megahea...
VB. pole läbi käinud veel:
www.digitaltrends.com/computing/ryzen-leaked-slides/ "Technical slides reveal new truths about Ryzen's power management "
182 |
pots4t4j4
18.02.2017 15:29:14
| Täpp.
401 |
erick
18.02.2017 16:02:39
| rmc kirjutas: |
www.digitaltrends.com/computing/ryzen-leaked-slides/ "Technical slides reveal new truths about Ryzen's power management " |
Kui ma nüüd seda õigesti lugesin, siis XFR toob meile per-core automaatse overlockingu? Väidetavalt siis Ryzen on võimeline ise aru saama, millised tema tuumadest on head kellujad, ja andma igal tuumale just talle optimaalse pinge, et igast tuumast eraldiseisvalt maksimaalne sagedus välja võluda. Nõrgemad tuumad siis jäävad madalamatele sagedustele ja paremad tuumad lükatakse nii üles kui võimalik. Vot see on küll üsna huvitav!
Räniloterii saab samuti uue tähenduse - parimad chipid siis need, millel maksimaalne arv tuumasid ennast ise võimalikult kõrgele klokivad.
96 |
18.02.2017 16:29:48
erick, mhm, sain sellest ise samuti nii aru... igatahes tundub see kõik väga huvitav. Tahaks ainult teada, kas see AUTO OC on piisavalt täpne, et asendada käsitsi-OC'd või jääb täppis-OC siiski lae saavutamisel domineerima..
182 |
pots4t4j4
18.02.2017 18:09:49
| Ma ei saa aru miks seda XFR niiväga vaja on? Kes tahab kellab manuaalselt ja kes ei taha see ei kella ja ongi kõik? XFR pole ju boost.
401 |
DeTHiCa.
18.02.2017 18:14:40
| automaat oc paneb voldi üldiselt veidi kõrgemale et garanteerida stabiilsus. käsitsi kruttides saab alati parema tulemuse, prose kah jahedam kui volt madalam.
136 |
Auron
18.02.2017 18:18:02
| erick kirjutas: |
| Räniloterii saab samuti uue tähenduse - parimad chipid siis need, millel maksimaalne arv tuumasid ennast ise võimalikult kõrgele klokivad. |
Lõhnab handpicked black editionite järele kui tõsi.
131 |
SilQ
18.02.2017 18:19:25
| pots4t4j4 kirjutas: |
| Ma ei saa aru miks seda XFR niiväga vaja on? Kes tahab kellab manuaalselt ja kes ei taha see ei kella ja ongi kõik? XFR pole ju boost. |
See on pigem sellisele inimesele kes arvutitest, clokkimisest ja biosist siblimisest midagi ei tea, aga samas tahaks võimalikult palju pauku. Siis ma ei pane üldse pahaks kui ta selle eest rohkem raha välja käib.
210 |
sooty
18.02.2017 18:39:38
| Auron kirjutas: |
| erick kirjutas: |
Lõhnab handpicked black editionite järele kui tõsi. |
Loodetevasti AMD ülevaatajatele cherry picked näidiseid ei saada, aga kindel ei või olla. Kas keegi tänapäeval oma prosed ja muu kraami poest ka toob, või teevad kõik ülevaated "tasuta" saadud tehnikaga?
12 |
Metsjeesus
18.02.2017 19:01:15
| Magic kirjutas: |
Ehk saadki 240.- asja 160-ga. |
Eks ta nii ole. Vahetasin oma 4a 1700punkti peal tiksunud 2500k välja, mis sisuliselt 70 euro prose. AMD puhul see xfr võiks justkui asja päästa, paljud oleksid nõus nö muretu OC eest grammi lisa maksma. Mõnel juhul on ju ikka väga isane Performance tõus.
Vaatame.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
