Raha antud
E: Kuna ma olin lammas ja ei fundinud Wasteland 2e kickstarterit, siis võtsin 45USD tieri, sealt saab Wasteland 2e ka kaasa. Väga brjoo lahendus! _________________ Avatar by Flacko
You’ve got to be freaking kidding me!! We just funded in six hours!?!?!
Our heads are still spinning at the incredible response we have had from today's support of our Kickstarter campaign. We had plans to roll out our stretch goals and to write our Kickstarter updates but never in our wildest dreams did we think we would fund this quickly!!! We are joyfully scrambling right now to get a longer update and some stretch goals in front of you as soon as we can. We should have more to say later today.
You are all unbelievably awesome and we could not be happier about receiving your trust in us. For many years we have wanted to get back to making this style of RPG but it appeared that the market was going everywhere but that direction. Almost every article and new game was focused on being an MMO, multi-player or micro-transition based. This wasn’t our style and we couldn’t generate interest in the classical narrative type of RPG that we all grew up making and playing. Thank you for backing our vision once again and we will not let you down. We will continue to communicate and and make sure we solicit input such that the game is hitting all the right notes.
Our goal is to make great RPGs for you all for the rest of our careers.
Originaali peetakse siiani üheks parimaks RPG mänguks läbi aegade, vähemalt story ja unikaalsuse vallas. Vaevalt, et keegi kulmugi kergitas kickstarteri edu üle, kes vähegi originaaliga kursis on.
Ei tea, kas 4 milli saavad kokku? Või rohkem isegi? No sellest tuleb küll üks kõvemad RPG-sid ever + kui loed kõik novellad ka läbi mida mängu kirjutajad lisaks teevad siis peaks mängu story ja maailm nii lahti mõtestatud olema, et vähe pole.
Panin ka õla alla. Hetkel nädal minna ja 3,16 milli koos. Pole paha. mingi 4 milli tuleb siit ilmselt ära küll, ehk ka 4,5. PST on igatahes siiani minu vaieldamatu lemmikmäng. Loodame, et InXile nende projektidega kõik need mängurite kõrgele aetud ootused ka täidab.
4 000 000.- dollarit on olemas! Senise Kickstarteri ajaloo edukaim mängu-projekt. Ning asi pole veel lukus ja kindlasti tuleb palju pappi juurde viimase paari tunniga. Ise pean magama ära kobima, aga igal juhul tubli töö kõigile, kes oma osa panid.
Mõtlen veel viimaseid hetki, kas veidi veel pappi välja käia või mitte. - Samas siiski veidi kahju, et peab vähemalt pool-teist aastat kui mitte kauem ootama.
EDIT:
4,18 miljonit jäi Kickstarteri viimaseks summaks. Võimas. Siia lisanduvad nüüd veel paypali kaudu nii ca. 150-200k ning devide enda isiklikud panused ka vist mingi 200k väärtuses. Ehk mängu eel-arve on siis vähemalt 4,5 miljonit, mis tundub ikka väga kobe summa.
Jäin ise 50$ juurde - ehk digital täispakett. Igasugu betad ja alfad jms tunnustused ei huvitanud - aga kogu digitaalse nänni, eriti novella'd, soundtrack, tahtsin küll saada. Eks kindlasti umbes sama raha eest saab selle mängu läbi GOG'i siis kui ta välja tuleb koos sama mandiga, aga noh - parem ikka devve enne release toetama hakata, et mäng tuleks parem.
Troika ja Black Isle kummardajana, märgin teema ära.
Fallout:NV näitas, et andekus ei kao. _________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop!
Tides of Numenera Beta will be coming to all eligible backers during the week of January 17th and to Steam Early Access on the 26th of January. _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Tulge kõik HV rahvaga jalkat mängima!|
Nii poisid. Aeg teemat värskendada. Vähem kui kuu aega jäänud! Veebruar 28 on release date ja siis saab korralikult käpad külge kogu mängule.
Olen hetkel Beta't vähe näppinud ning mulje on küll 5+.
Mingi 3h mängu ning pole veel ühtegi kaklust isegi olnud peale tutoriali. Ehk STORY't on kamaluga segada. Maailm on põnev, tegelased huvitavad. Main Story ja maailm tundub selline, et isegi lõppu teadmata on tunne nagu siia võiks osasid tegema jäädagi, nagu ka vanade D&D mängude puhul.
Täielik Torment'i tunne on küll. Mitte küll nii morbiidne atmosfäär kui originaalil, kuid maailm ise on võrdväärselt WTF iga nurga alt. Kes ei tea, siis tegevus leiab aset planeedil Maa, +1 miljard aastat tulevikus. Seega proovige ette kujutada.
Archangel, kujutada pole siin midagi ette, 600 miljoni aasta pärast pole taimede jaoks piisavalt CO2 seega jääb lihtsalt üks kivitükk, kus ei ela suurt midagi.
Nõrk kujutlusvõime seega. Selle probleemi vaat, et lahendaks praeguse tehnoloogigaga ära. Mis sa arvad mida tehnoloogiad miljonid aastad tulevikus teevad?
Archangel, vaevalt tehnoloogia päikselt tulevat 10% tugevamat kiirgust kinni püüab ja füüsikaseadusi kardinaalselt muudab.
fantaseerida võib, aga mõelda et siin vot miljardi aasta pärast elu lill on ja mungad mädsikut teevad pole sügavat mõtet.
samas noh, saientoloogide piibel pidavat päris äge olema, et miljon miljardit aastat tagasi tuli mingi tüüp nimega john smith kaugelt kosmosest ja hakkas siin kartulit kasvatama just because... niiet jahm, las ta siis olla.
Meil siin täna arvatakse, et 50 aasta jooksul leiutame AI ,mis siis ühel või teisel moel toob meie arengutasemesse sellise hüppe sisse, et edasi spekuleerida pole pointi.
Surematuse ja sünteetiliste ajude ning kosmoserännaku/kolonisatsiooni probleemid võivad kõik järgmise 100a jooksul lahenduda. Isegi kui need järgmise 1000 aasta jooksul lahenduvad tundub rääkimine Maast nii kauges tulevikus väga ebaoluline. _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Aeron, mis siis selle järgneva 50 aasta jooksul juhtuma peaks hakkama, et kohe nii vägevad aid ja värgid tulema hakkavad? siiani ei suudeta luua ilma kriitiliste bugideta äppe ja itilahendusi kõige triviaalsemate probleemide lahendamiseks ja nüüd järsku keegi väidab, et on nii kõva mees, et ehitab aju valmis. soovitan maa peale tagasi tulla. mis meie arengutasemesse puutub, siis iga järgneva põlvkonnaga muutub inimkond üha lollimaks ja saamatumaks. 100 aasta jooksul ei lahendu siin midagi mis koloniseerimisse puutub.
Reaalselt võiks 26 päeva pärast, see mäng välja tulla ja siis hakkavadki "mungad mädsikut tegema". _________________ War. War never changes.
NATAS999, särav rumalus.
1. me pole kogu oma möödunud jalooga ka nii palju arenenud, kui möödnud 50 aastaga
2. ofc ei ole garantiid, et midagi juhtub, ma lihtsalt ütlen, et enamik tarku mehi on seisukohal, et 50 aasta jooksul me suudame toota esimese thisintellekti ja on paar varianti, mis edasi juhtub:
a. intellekt on apaatne meie murede suhtes ja ei mõista meie ellujäämise ja elu mõttekuse ängi ning arvab, et kõik on pohhui, temast pole meile mingit kasu/ohtu
b. intellekt pärib ka meie hirmud ja tahab ellu jääda ning näeb meis oma suurimat ohtu ja kuna ta on meist võimekuselt lugematult üle, siis ilmselt kavaldab meid üle ja inimkond bioloogilise rassina kas hävitatakse või tehakse patareiderks ringi nagu matrixis vms
c. meil õnnestub mingi sõbralik intellekt luua, kes oma uskumatu võimekusega lahendab väga suure osa meile täna täiesti küündimatutest probleemidest.
Eks reaalsuses kõik nii must-valge pole ja vb tuleb mitu intellekti ja vb on kõik mõjutatad ja võtavad eri pooled ja igaast asju võib juhtuda, aga bottom line on see,et kogu see jutt abitusest ja stagnatsioonist on uskumatult vale. Soovitan rohkem teadust lugeda... _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Aeron, soovitan vähem hollivuudi tarbida. mitte mingit intellekti ei tule sul siin ei 50 ega 100 aasta pärast. niikaua, kuni eksisteerivad loogikavastase ülesehitusega programmid/äpid/kasutajaliidesed ja neis peituvad tõsisemad bugid, niikaua pole lootustki isegi mitte amööbi tasemel tehisintellektist undki näha. need discovery science ufoloogidest arvamusliidrid muidugi nii ei arva, aga see ei muuda eelpool öeldud tõsiasja.
Igapäevastel apidel ei ole sellega mitte mingit pistmist. Selleks, et AI saaks tekkida, ei pea end-user kogemusest või infact üdse kuskil mujal IT maailmas mitte midagi muutuma... on vaja lihtslt teha piisavalt hästi õppiv ja ennast arendav programm ning ta ise ehitab ennast edasi.
In 2013, there was a survey by V. C. Muller and N. Bostrom that asked around hundreds of AI experts what are chances of achieving Human-Level AI and when. Results:
Median optimistic year (10% likelihood): 2022
Median realistic year (50% likelihood): 2040
Median pessimistic year (90% likelihood): 2075
Sellest hetkest alates ongi intelligence explosion käes pmt. Siis ei tea mis juhtub. _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
viimati muutis Aeron 02.02.2017 17:10:07, muudetud 1 kord
Kuidas AI muudab meie elu juba praegu. Põhimõtteliselt suudab AI juba praegu täpselt leida, mida tuleb teha valmisvõiduks. https://motherboard.vice.com/en_us/article/how-our-likes-helped-trump-win Ohtlik ei ole mitte AI ise vaid see mida AI suudab piisavalt ebaeetiliste inimeste heaks korda saada.
No me ei tea, mida AIst oodata ju.
Meil ei ole põhjust arvata, et suudame kontrollida mehhanismi, mis on meist intellektuaalselt kaugemal ees, kui meie oleme putukatest.
Pigem on küsimus selles, et kas AI on meie möödapääsmatu hukk ja inimrassi loogiline jätkuvus mehhaanilisel kujul.
See kõik taandub küsimusele, kas eksistents on parem kui mitteeksistents?
Kas täiesti ratsionaalne masin suudab seda selle valiku teha. Kui suudab ja see vastus on , et jah on küll parem, siis oleme meie tema nr1 vastane kohe automaatselt.
Kui jõuab järeldusele, et ei ole, siis ei tea mis saab. Vb tal pole motivatsiooni mitte midagi teha, aga vb tal on nii savi, et aitab kõiki kes küsivad, sest tulemustest on ükskõik, sest inimkond on ebahuvitav ja ebaoluline teema samal määral kui tema enda olemasolu, mis on talle täeisti ükskõik, sest eksitents ei ole parem, kui mitteeksistents.
Ei tea mis juhtub, aga tundub, et lõviosa valdakonnas tegevaid inimesi arvavad, et see juhtub järgmise 100 aasta jooksul kindlasti.
Samas, me arvasime igast asju kui esimesed arvutid toodeti progressi osas (sh Marsi koloniseerimine etc), aga näedsa siis. Sellegi poolest, rääkida mingitest miljonitest aastatest tundub absurdne.
https://intelligence.org/2013/05/15/when-will-ai-be-created/ _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Aeron, tunnustatud teoreetikute viga on see, et nad kipuvad oma võimeid üle hindama ja probleeme alahindama. kui põlve otsas nikerdajad suudavad halvata ja maha võtta elukutseliste proffessionaalide poolt ehitatud süsteeme, siis fakt on see, et midagi sellist, nagu sa kirjeldad, ei saa juhtuda veel nii pea. intellekt suudaks ddos rünnaku lihtsalt niisama kukele saata ja rahu majas. millegi pärast pole keegi kaugelti sellist süsteemi suutnud luua. soovitan tõesti vähem oma ajusi pesta lasta mingitel omateada kõvadel tegijatel, keda tunnustavad paljud teised samasugused omateada kõvad tegijad. fakt on see, et arvutid ja tarkvara on kõik rangelt "kui... siis..." loogikale üles ehitatud ja selliselt ei ole võimalik ise mõtlevat, olukordi analüüsivat ja probleeme lahendavat süsteemi luua.
sukelduja, sinu toodud "artikkel" räägib ümmargust juttu ajupesumasinast, ehk massimeediast, mitte tehisintellektist. andmed kogutakse andmebaasi, laotakse exceli tabelisse, visatakse kasutajatele reklaame vastavalt, kogutakse jälle andmeid, võrreldakse, visatakse vastavalt jälle teisi andmeid jne jne. see ei ole mitte tehisintellekt, vaid andmebaasi töötlemine algorütmide järgi, mida analüütikud ja psühholoogid koostöös välja töötavad loogikaga, kui teeb seda, näita seda. if then loogika.
viimati muutis NATAS999 02.02.2017 17:58:11, muudetud 1 kord
Närvivõrkudest oled midagi kuulnud? Fuzzy logicust? Pole sugugi ainult If...then.. Ilmaasjata jaurad Aeroni kallal.
korrutamisest ja jagamisest oled midagi kuulnud? pole sugugi ainult liitmine ja lahutamine.
soovitan teil vaadata youtubest numberphile ja computerphile kanaleid, saate ehk targemaks.
Kui haridust pole, siis ei aita ka youtube. Ja mida pole, seda pole. Muidu sa teaksid, et pole olemas mingit lahutamist, vaid on tegemist on vastandarvuga liitmisega, nagu pole ka olemas eraldi tehet nagu jagamine. See vajab ikka head õnne, et kohe nii kõvasti ämbrisse astuda. Soovitan Knuthi lugeda, äkki saad targemaks.
Sa ei saanud ilmselgelt sellest artiklist ööd ega mütsi aru.
sukelduja, ei ole olemas mingeid vastandarve, samamoodi nagu pole olemas negatiivset temperatuuri.
see sinu artikkel ei puutu absoluutselt asjasse.
Jää parem oma youtuberite juurde, see on kõigile parem!
arvutid teevad operatsioone binaar arvudega, on olemas 0 ja 1, väikseima väärtusega bait saab olla 00000000 ja suurima väärtusega bait 11111111, ei ole olemas baiti -00001000
tõsiselt soovitan sul ennast harida natukene nendes asjades, enne kui lahmima hakkad. niikaua, kuni pole kõige elementaarsematestki põhitõdedest vähimatki aimu, ei tasu hakata sõna võtma tehisintellekti teemadel ja veel vähem selleni jõudmiseks kuluvat aega üritada ennustama hakata.
Kuidas te mängufoorumis loodusseadustega ja matemaatikaga seotud filosoofilise vaidluseni jõudsite?
Tõenäoliselt saadakse aru, mida silmas pead. Ülesehitus on tehtud esimest järku loogika peale, kus "kui.., siis.." on üks võimalik tehe. Tehteid on veel.
Numberphile soovitan nii palju vaadata, et kerge aimdus tekiks, millest on juttu ja siis tõsisematest allikatest lugeda täpsemalt. NP on ebatäpne.
Nii, aga kunagi ammu sai mängitud Tormentit, mis oli üpriski võõrastav kogemus, story poolest on see ilmselt üks parimaid mänge, mida olen saanud mängida. Arvestades tänapäeva story kvaliteedi kahanemist mängudes, siis olen skeptiline, aga kindlasti juba mängu nimi kutsub [Raibe peab muidugi semestri sees releasima ja siis tekivad dilemmad, kumb on olulisem, kas Torment või lõputöö ]
Mul on magistrikraad arvutiteaduses. Sa oled nii kinni oma pisikeses von Neumanni arhitektuuri kuurinurgas. Usu mind, see ei ole kogu maailm. Peale selle esineb veel mitut sorti arvuteid. Analoogarvutid, kvantarvutid, närvivõrgud, dna-arvutid, kunagi püüti isegi arvutit ehitada, mis oleks loodud Prologis väljendatud ülesannete jaoks. Osasid lahendusi saab emuleerida tavaarhitektuuri peal mingi mõistliku ajalise ja mälu keerukusega, mõningaid mitte. Meie aju ei tööta ka nullide ja ühtede peal ja meie DNA ei ole kodeeritud binaarselt. Tavaarvutid võivad olla väga võimsad, kuid teatud ülesannete jaoks need ei sobi ja ei hakka ka kunagi sobima olgu neil niipalju mälu ja protsessoreid kui tahes. Kui sa end väga kõva käena tunned, siis võta milleeniumiprobleemid ette https://en.wikipedia.org/wiki/Millennium_Prize_Problems ja proovi, kas sa saad üldse aru, milles nende olemus on. Või kui midagi lihtsamat tahad, siis loe natuke kuidas näiteks Pii-d arvutatakse ja milline matemaatika selle taga on. Selles mõttes, et sa saad aru kuidas selline arvutusmeetod saadud on. Numberphiles on tore, 80-tunnist ülikoolikursust pole tegelikult võimalik 5-minutisse suruda.
NATAS999, sul võiks olla siis midagi harivat lugeda anda või näidata peale oma "ekspertarvamuse", muidu on maru raske sind tõsiselt võtta.
Keegi pole väitnud ju, et AI tuleb "x86 arhitektuurile" või et selle leiutavad selle ala tipud, mitte "boris" "kuskil kuuris".
Natuke liiga argressiivne oled selle kohta, kui vähe argumente sa välja tood peale selle, et 1 ja 0-ga ei saa midagi teha + kõik see seosetu hala everyday compute vastu. Hektel kõlad nagu mingi eriti hullunud vandenõu teoreetik, kes oma asja hüsteeriliselt ajab. Samas, neil enamasti on mingi seoste jada kuskil olemas... _________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
tahate öelda, et pangandussüsteeme toodavad borisid paldiskist? ma räägin teile, et kui juba sellised süsteemid koos ei suuda püsida, siis ei tasu unistada siin mingisugusest tehisintellektist, mis kõik maailma probleemid ära lahendab meie eest lähema sajandi jooksul. x86 ei puutu siin absoluutselt asjasse enam.
jätkuvalt soovitan silma peal hoida sellel, mis päris maailmas toimub ja vähem ulmet ja hollivuudi lasta endale ajusi loputama.
