Raha antud
E: Kuna ma olin lammas ja ei fundinud Wasteland 2e kickstarterit, siis võtsin 45USD tieri, sealt saab Wasteland 2e ka kaasa. Väga brjoo lahendus! _________________ Avatar by Flacko
You’ve got to be freaking kidding me!! We just funded in six hours!?!?!
Our heads are still spinning at the incredible response we have had from today's support of our Kickstarter campaign. We had plans to roll out our stretch goals and to write our Kickstarter updates but never in our wildest dreams did we think we would fund this quickly!!! We are joyfully scrambling right now to get a longer update and some stretch goals in front of you as soon as we can. We should have more to say later today.
You are all unbelievably awesome and we could not be happier about receiving your trust in us. For many years we have wanted to get back to making this style of RPG but it appeared that the market was going everywhere but that direction. Almost every article and new game was focused on being an MMO, multi-player or micro-transition based. This wasn’t our style and we couldn’t generate interest in the classical narrative type of RPG that we all grew up making and playing. Thank you for backing our vision once again and we will not let you down. We will continue to communicate and and make sure we solicit input such that the game is hitting all the right notes.
Our goal is to make great RPGs for you all for the rest of our careers.
Originaali peetakse siiani üheks parimaks RPG mänguks läbi aegade, vähemalt story ja unikaalsuse vallas. Vaevalt, et keegi kulmugi kergitas kickstarteri edu üle, kes vähegi originaaliga kursis on.
Ei tea, kas 4 milli saavad kokku? Või rohkem isegi? No sellest tuleb küll üks kõvemad RPG-sid ever + kui loed kõik novellad ka läbi mida mängu kirjutajad lisaks teevad siis peaks mängu story ja maailm nii lahti mõtestatud olema, et vähe pole.
Panin ka õla alla. Hetkel nädal minna ja 3,16 milli koos. Pole paha. mingi 4 milli tuleb siit ilmselt ära küll, ehk ka 4,5. PST on igatahes siiani minu vaieldamatu lemmikmäng. Loodame, et InXile nende projektidega kõik need mängurite kõrgele aetud ootused ka täidab.
4 000 000.- dollarit on olemas! Senise Kickstarteri ajaloo edukaim mängu-projekt. Ning asi pole veel lukus ja kindlasti tuleb palju pappi juurde viimase paari tunniga. Ise pean magama ära kobima, aga igal juhul tubli töö kõigile, kes oma osa panid.
Mõtlen veel viimaseid hetki, kas veidi veel pappi välja käia või mitte. - Samas siiski veidi kahju, et peab vähemalt pool-teist aastat kui mitte kauem ootama.
EDIT:
4,18 miljonit jäi Kickstarteri viimaseks summaks. Võimas. Siia lisanduvad nüüd veel paypali kaudu nii ca. 150-200k ning devide enda isiklikud panused ka vist mingi 200k väärtuses. Ehk mängu eel-arve on siis vähemalt 4,5 miljonit, mis tundub ikka väga kobe summa.
Jäin ise 50$ juurde - ehk digital täispakett. Igasugu betad ja alfad jms tunnustused ei huvitanud - aga kogu digitaalse nänni, eriti novella'd, soundtrack, tahtsin küll saada. Eks kindlasti umbes sama raha eest saab selle mängu läbi GOG'i siis kui ta välja tuleb koos sama mandiga, aga noh - parem ikka devve enne release toetama hakata, et mäng tuleks parem.
Troika ja Black Isle kummardajana, märgin teema ära.
Fallout:NV näitas, et andekus ei kao. _________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop!
