anubis
19.11.2016 15:14:41
3840 x 2160 x 60 Hz x 30 bit (RGB/YCbCr 4:4:4 = 3x bits kanali kohta) ~ 14.9 Gb/s
HDMI 2.0 riba - 14.4 Gb/s (faktiliselt on ~18Gb/s aga overhead sööb 3.6Gb/s ära sellest)
DP 1.2 riba - 17.28Gb/s
HDMI 2.0 ei saagi seda näidata, füüsiliselt.
edit: http://www.tweaktown.com/news/55012/amd-reaffirms-hdr-abilities-hdmi-2-limitation/index.html
I reached out to AMD for clarification, with Antal Tungler - the Senior Manager of Global Technology Marketing, who said t hat this was a limitation of HDMI bandwidth. Tungler said "we have no issues whatsoever doing 4:4:4 10b/c HDR 4K60Hz over Displayport, as it's offering more bandwidth". Tungler added: "4:4:4 10b/c @4K60Hz is not possible through HDMI, but possible and we do support over Displayport. Now, over HDMI we do 4:2:2 12b 4K60Hz which Dolby Vision TVs accept, and we do 4:4:4 8b 4K60Hz, which TVs also can accept as an input. So we support all modes TVs accept. In fact you can switch between these modes in our Settings".
283 |
19.11.2016 15:24:36
| Jep. Samas kui selline asi eksisteeriks ka 1440p puhul näiteks, siis oleks see bug driverites.
| Kommentaarid: 92 loe/lisa |
silk45
23.11.2016 12:20:23
Kellel rx480 on, mis teil kaardi temp on loadis. Ja kas kasutate custom fan curve?
Mul XFX rs rx480 4gb, millel loadis temp max 71 kraadi, aga fanid siis 100% juures,
tahaks vaiksemaks saada, seega tõstaks max tempi kõrgemale ja modiks natuke fan curve´i, et
pöördeid allapoolse saada.
| Kommentaarid: 16 loe/lisa |
16 |
anubis
23.11.2016 12:33:14
| Võta volti 25mv kaupa maha, esiteks.
283 |
olafsand
23.11.2016 22:01:14
silk45, mul sapphire rx480. Full loadis 75c, aga vendid siis 50%. Proovin ka seda anubis pakutud varianti
| Kommentaarid: 62 loe/lisa |
59 |
masmre
24.11.2016 09:32:36
| kas 470 peaks ka volti vähemaks keerama?
| Kommentaarid: 82 loe/lisa |
76 |
anubis
24.11.2016 10:55:59
| Kui stabiilsust ei mõjuta siis peenhäälestusega saab voolutarbest ja soojaeraldusest hea tüki maha.
283 |
Gap
| Kommentaarid: 21 loe/lisa |
17 |
uldreg
24.11.2016 15:47:38
Ons mõtet siis endale jõuludeks RX 480 võtta või ikka oodata see vega ära?
| Kommentaarid: 18 loe/lisa |
18 |
WäntWõll
make.believe
24.11.2016 16:22:59
| uldreg kirjutas: |
Ons mõtet siis endale jõuludeks RX 480 võtta või ikka oodata see vega ära?  |
Keegi ei tea mis kaart reaalselt tuleb ja sul on juba küsimusi, loe ikka enne uudis läbi
300 |
HunabKu
33 |
PPC
24.11.2016 19:06:38
| uldreg kirjutas: |
Ma ootaks 490. Sapphire 480 4gb 224,8 eur eest 1a.eest oli norm budget valik, kui nuud enam ei ole neid muugis. 8gb isendid on m6tetu ja kallid.
| Kommentaarid: 47 loe/lisa |
46 |
anubis
24.11.2016 19:16:32
| Neweggis on RX480 alla $170..
283 |
24.11.2016 19:23:30
täpsemalt 160/220 euri 4/8gb versioonid ;D
182 |
-kasutaja-
24.11.2016 19:33:37
Eestis RX 480 4GB 230€ 8GB 290€
| Kommentaarid: 32 loe/lisa |
31 |
anubis
283 |
PPC
24.11.2016 21:19:41
see powercolor ei ole hea valik... aga siin veel x1 fan
rmc,
Kust selle hinnaga muuakse? Ja palju maksab transport Eestisse?
46 |
Killhoven
OC`er
24.11.2016 21:22:44
[ot]Paljud vist ei tea hiljti alandati 1060 mõlema versiooni hindasid kah.
_________________ Foorumis on ühe lolli kohta kümme tarka, nii et jõud on enam-vähem võrdsed.™
viimati muutis Killhoven 24.11.2016 21:25:14, muudetud 1 kord |
| Kommentaarid: 405 loe/lisa |
349 |
24.11.2016 21:24:25
PPC, juttu oli sellestsamast neweggist
182 |
silk45
24.11.2016 21:25:40
| silk45 kirjutas: |
pöördeid allapoolse saada. |
Vaatasin enne valesti, mul ka loadis tglt 70 kraadi juures fan ca 65-70%, GPU usage oli 100%,
kuid juba pisike undervolt 18mV muutis kaarti vaiksemaks.
16 |
KrikU
25.11.2016 14:37:50
Dual Polaris 10 oleks küll oodatud Siiani ju RX4xx põlvkonna 2 GPU-ga kaart puudu!
119 |
rycyve
25.11.2016 17:15:27
| Killhoven kirjutas: |
| [ot]Paljud vist ei tea hiljti alandati 1060 mõlema versiooni hindasid kah. |
Näen ikka samasid hindasid
| Kommentaarid: 98 loe/lisa |
81 |
liiv
26.11.2016 05:52:50
| PPC kirjutas: |
rmc,
Kust selle hinnaga muuakse? Ja palju maksab transport Eestisse? |
Need välismaised "hinnavaatlused" on niisma silmale ilusad vaadata. Reeglina saadetakse Saksamaale või Austriasse, teised UK või iirimaa, EU riikides saavad vahel Holland ja Poola ka. Ülejäänud riigid võtku raulikult. Toon näite mingi brändi euroopa esindajaga suheldes.
mina: tahan hulgi tellimust teha, tehke normaalne hind
esindaja: mis on teie tellimus?
mina: panen pre-orderisse seda mudelit 100tk
esindaja: kas see on nali? meil selle ..... keti see pood... võtab selles linnas.... 500tk.
mina: berliinis elab koos eeslinnadega üle 3,5 miljoni inimese, nad võivad võtta ühte poodi selle koguse. Meil elab terves riigis vaevu pool sellest.
esindaja: teate, ärge segage meid, minge kuskile edasimüüjate juurde, nad tegelevad teiega
Näide kaks.
Kunagi tahtsin ühte litsenseeritud teatud filmide levitamise õigust osta aga kõik Eesti õigused (Eesti on 2 regioon, kogu EU on 2 regioon maailma businesi mõistes) olid antud mingile vene firmale Peterburis. Venemaa ja kogu SRÜ on regioon 5. Venkud ostsid litsentsid ja kogu Balikum anti niisama kauba peale (sest me oleme prügi muu maailma mõistes ja meid saab tabavkana kaasa). Kui ma suhtlesin peterburi esindajaga, et ehk saaks Eesti keelse tõlkega seda kraami osta, ise võtame tõlke kulu enda kanda siis küsiti palju ostad seda DVD. Ma ütlesin 1000 (ma poleks isegi 500 maha müünud tegelikult). Kohe öeldi, et ainuüksi Piiteris müüme me seda niisamagi 30 000. Milleks meile paberimäärimist. Tõmmake mingisse meie filiaali ja ajage seal asju.
Seepärast polegi paljudel filmidel tõlget. Need kelle käes on õigused, neid ei huvita. Pigem segab. Nad peavad rohkem pabereid täitma.
Umbes sama on arvutimaalmas.
| anubis kirjutas: |
| Neweggis on RX480 alla $170.. |
Newegg on hiinlaste tehtud firma Californiasse. Turg mõeldud USA, Canada, China ja Austraalia jaoks. Euroopast on saanud jala uksevahele UK, Iiri, Holland ja Poola. Ma olen neid koguaeg jälginud ja veel suvel iirimaad ja Poolat ei olnud.
Mina saan muide seal tellimisega aidata. Seal on haruldast kraami mis kunagi meie marketingi ei jõua, mul on postiaadressid olemas kuhu tellida aga ooteaeg on siis ka pea 2 kuud. Näiteks ütlevad:
IMPORTANT INFORMATION:
APO/FPO packages may take to 2-6 weeks for delivery. Please contact us between 6-8 weeks after the ship date if you have not received your order.
Need kes katsetavad, võiks RMA infot jagada. Mina pole Neweggi maha matnud aga mul läheb saksamaaga pea juba halliks.
| Kommentaarid: 627 loe/lisa |
9 :: |
6 :: |
517 |
26.11.2016 09:09:08
| ot: |
| liiv kirjutas: |
Näide kaks.
Seepärast polegi paljudel filmidel tõlget. Need kelle käes on õigused, neid ei huvita. Pigem segab. Nad peavad rohkem pabereid täitma. |
| ot: |
Aga vabatahtlikke, kes subtiitreid teevad ja neid tasuta jagavad peedistavad autorikaitse kolmetähelised mõnuga |
26.11.2016 13:35:49
liiv, mis hinnad Poola tellides on Neweggis? Samad nagu USA omad? ;D
182 |
