beastbeats
15.07.2016 13:39:11
Neid "nööpe" keegi tagasi ei taha kuid aastaid tagasi kasutas Lufthansa kõrvapealseid klappe ja need korjati lennu lõpus tagasi.
M: Shimano XT kiirkinnitused (uued)- 2tk/15€ |
284 |
15.07.2016 13:42:41
| beastbeats kirjutas: |
| Neid "nööpe" keegi tagasi ei taha kuid aastaid tagasi kasutas Lufthansa kõrvapealseid klappe ja need korjati lennu lõpus tagasi. |
Need korjati, erandina, tõesti tagasi...
196 |
infect
15.07.2016 14:32:54
Enda lendudel see tagasikorjamine oli pigem prügi kokku korjamise eesmärgil. Lennu alguses oli istmel kohe olemas kilekoti sees värsked klapid igal lennul.
| Kommentaarid: 25 loe/lisa |
25 |
CoiL
15.07.2016 15:10:49
Ei oska heli kohta kommenteerida, aga üks uuem odava otsa DAP - Benjie K9
Penonaudio: http://penonaudio.com/BENJIE-K9
Aliexpress: http://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20160715040216&SearchText=Benjie+K9
Description
K9 is a HI-FI level digital music player especially for music fanciers.With smart size,light weight,fashion outlook,it can be brought conveniently when you are at home,on business,on travel or in anywhere.It can support all popular lossless audio formats,support up to 24Bit/192Khz master level high definition sampling rate,also support DSD format.To meet the bigger capacity of lossless audio.
TF/Micro SD card using at the same time,then you don’t need to worry about the storage capacity.With HD OLED screen,letters on window can be clearly found even in the sunshine.player,your real friend,no matter you are at home,on business or on the way.
Support High Resolution Lossless Music Files
Lossless format PCM: APE,FLAC,WAV,AIFF,ALAC,WMA(up to 24bit/192khz)
Lossy Format PCM: MP3,OGG,ACC
Benjie k9 support Mp3,FM loud speaker function
Support Large-capacity Memory Cards
Support 64GB SD card at the same time.Can store more than 5000 of lossless songs;over 50000 MP3 songs.Let you no longer worry about the capacity shortage problem!
Compact Size
It weighs only 78g with dimension of only 7.5x3.1x0.9cm.Making you no longer carry the brick like player,this player is convenient for you to carry around when staying at home,traveling,shopping!
58 hours of Continuous Playback
Playback time up to 58 hours,which is enough for a day outside.Charging time is less than two hours(quick charge),the computer or mobile phone charger is available,which is safe and efficient.
Function introduction
MP3 player function with built-in speaker,support MP3,WMA and all lossless music fomats
Support FM radio
Support Voice recording,recording format: MP3,WAV,ACT
Support e-book reading,picture
Support folder switch function
Lyrics synchronized display
24 languages optional
Specification
Model: BENJIE K9
Solution: ATJ 2127
Screen: 1.8”OLED color screen
Case: Zinc alloy
Size: 94*38*9mm,net weight: 79.2g
Capacity: built-in 8GB flash memory,32GB external storage
Playing time: 20 hours by earphone
Charging time: 2 hours
Battery capacity: 3.7V/400mAh |
Plaanis endal kingituseks tellida. Eks annan tagasisidet kuidas kärab selle ~22€ eest.
| Kommentaarid: 95 loe/lisa |
83 |
mihkel7
15.07.2016 15:15:16
Ootan huviga Su tagasisidet.
| Kommentaarid: 53 loe/lisa |
50 |
libe
kvaliteetne mees
15.07.2016 16:54:08
| salatoimik kirjutas: |
| Mida see ühekordne kasutamine tähendab? Paned pistikusse saad kasutada ning kui pistikust välja tõmbad, lähevad katki? |
ühekordsed sellesmõttes, et mingid seened ja muud kõrvanakkused nööpidega edasi ei kanduks järgmisele kuulajale.
klappe ei desinfitseerita, seega odavam on suur hange klappidele teha ja sent tüki eest maksta, kui mõne kliendiga hakata kõrvapõletiku pärast kohut käima
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
jaank
15.07.2016 21:31:10
| Kallimatel istmetel on vahest ikka Bose jne asju ka, need võetakse eranditult tagasi.
| Kommentaarid: 63 loe/lisa |
57 |
Markos
15.07.2016 21:53:52
| Tänapäeval on nii suur valik nende special gamer klappide seas et ei tea mida võtta mida jätta icon_lol.gif igasugused |
Sain just kätte Razer Krakenid. Mis ma öelda oskan, väga väga bassy, keskmised ja kõrged mudased. Soundstage on ahtake, kõik surutakse pähe keskele kokku. Õhku ja hingamist ei ole. Võibolla on see mänguklappide puhul taotluslik, ei tea, pole mängur. Samas, filmide ja mängude jaoks võibolla selline lähenemine isegi sobib, melomaanil pole nende klappidega igastahes mitte midagi teha. Surve peale on võibolla natukene liiga tugev, samas padjad on pehmed ja tunduvad mugavad. Pikemat kuulamissessiooni ei ole teinud, sestap ei tea, mis tunne on 4 tunni pärast. Heliisolatsioon on nagu mingitel avatud klappidel, samas seest välja ei leki. Tegin ebaausa võrdluse, kuulasin vaheldumisi Denon D600 ja Krakeneid ... tulemus oli ettearvatav, ei ole võimalik võrrelda võrreldamatuid asju.
| Kommentaarid: 14 loe/lisa |
12 |
NATAS999
17.07.2016 20:57:52
sony MDR-EX650AP ostsin omale. mingine 5-6 erisuurusega lutut kaasas, mulle sobivad need, mis kohe peal olid. küllalt mugavalt istuvad kõrvas ja niisama lihtsalt välja ei kuku. mikkriga süsteem täitsa toimib, vajutad nuppu, paneb spotify käima, vajutad veel, paneb kinni, kõne võtab vastu ja paneb ära, mis on suht mugav. heli on täitsa okei. alguses tundus, et bassi on justkui vähe võrreldes koss the plugidega, aga väga kiirelt harjus ümber sellega ja tegelikult on madal ots väga korralik, ei usu, et väga palju patemaks seda saakski. muu sageduskarakteristik tundub ka okei olema, vähemalt midagi kuskilt kriipima ei jää.
plussid:
+püsivad kõrvas
+nupuga mikker
+heli
miinused:
-hind
-L-otsikuga pistik
| Kommentaarid: 41 loe/lisa |
39 |
CoiL
18.07.2016 11:07:20
-L-otsikuga pistik on miinus? Isiklikult pean seda just plussiks. Sirged otsikud kipuvad pesasid "lõhkuma" ja taskus kandes äärmiselt ebamugav
83 |
NATAS999
18.07.2016 12:27:27
| CoiL, L-otsik on taskus ebamugav ja kipub lagunema. telefoni taskusse paned ja taskust ära võtad, siis L-otsikut kruti nagu loll, et juhe kuskile ette tilbendama ei jääks, taskust välja võttes kipub vastu taskut otsikut murdma ja igale poole taha kinni jääma. tavalise otsikuga torkad lihtsalt taskusse püstipidi ja rahu majas. ja kui kasutad näiteks kas arvuti või ressi või välise helikaardi küljes, siis L-otsik jääb väga värdjalt paindesse, mida tavalise otsikuga ei juhtu kunagi. endal on just L-otsikud iga viimne kui üks lõpuks saba andnud, tavalistest mitte ükski.
39 |
markedmen
18.07.2016 12:30:51
| Ilmselgelt on see täiesti individuaalne ning ilma põhjaliku selgituseta mõttetu miinuse alla panna. Minu jaoks on samuti L-otsik pigem pluss
| Kommentaarid: 7 loe/lisa |
NATAS999
18.07.2016 12:36:18
markedmen, maitse asi vb tõesti, aga nii palju kui kokku olen nendega puutund, mitte ainult kõrvaklapid, siis ainus erand, kus tõesti L-otsik õigustatud on, on instrumendi kaablid ja ka siis vaid teatud juhtudel. minu teha oleks, siis L-otsiku leiutaja oleks tuleriidal lõpetand.
39 |
CoiL
18.07.2016 13:21:44
| NATAS999 kirjutas: |
| CoiL, L-otsik on taskus ebamugav ja kipub lagunema. telefoni taskusse paned ja taskust ära võtad, siis L-otsikut kruti nagu loll, et juhe kuskile ette tilbendama ei jääks, taskust välja võttes kipub vastu taskut otsikut murdma ja igale poole taha kinni jääma. tavalise otsikuga torkad lihtsalt taskusse püstipidi ja rahu majas. ja kui kasutad näiteks kas arvuti või ressi või välise helikaardi küljes, siis L-otsik jääb väga värdjalt paindesse, mida tavalise otsikuga ei juhtu kunagi. endal on just L-otsikud iga viimne kui üks lõpuks saba andnud, tavalistest mitte ükski. |
Nojah, sul siis ristivastupidi kogemus minu kogemusele Eks see ole väga individuaalne ja sõltub mis mängijaga, millises taskus jne. kasutada.
Mul oleks toolile istudes esimese asjana püstine/sirge pistik plõksti puru taskus
Aga on ka kuldne kesktee, mis ka mulle kõige paremini istub - ~30-45' otsik
83 |
NATAS999
18.07.2016 13:52:40
CoiL, fakt on see, et kui on ikka head klapid, siis otsiku kuju deal breaker ei ole. eks aeg näitab, kust otsast need klapid lagunevad, kui lagunevad . mugavad ja hea saund on määrav siiski. kahjuks pole korralikust allikast nendega veel kuulanud, siiani piirdunud nexus 5 ja spotify "normal" kvaliteediga.
39 |
CoiL
21.07.2016 19:58:07
Keegi Lasmex L-85 klappe ei taha proovida? https://www.massdrop.com/buy/lasmex-l-85-headphones
Omamoodi nagu Fidelio X1/X2 koopiaga disain (väga kenad minu arvates) ja tundub, et pidavat hea heliga ka olema.
PS, sain LZ A2S üleeile kätte ning olen neil lasnud nö. sisse mängida (ilma kuulamiseta). Otse-karbist-välja-kuulates vau-efekti ei tekkinud aga kesksagedused olid küll head ja naturaalsed. Varsti hakkan kuulama ja edastan rohkem muljeid.
83 |
pots4t4j4
21.07.2016 20:09:46
| Massdropiga maksad ju shipping + tolli ja käibekaga haigeks ennast muidu telliks sealt tihtipeale midagi.
401 |
CoiL
83 |
infect
26.07.2016 17:00:26
| CoiL kirjutas: |
Kasvõi miski odav väline DAC/amp - neid terve nett täis. Näiteks Zorloo ZuperDAC ja HifimeDIY Sabre. Lisaks tasuks ka uurida modifikatsioonide ja erinevate patjade mõju kohta DIYaudioheaven lehelt: http://www.mediafire.com/download/av6k1rhkv5lwol6/Superlux_HD681_EVO.pdf
Kõige lihtsam ja odavam "mod" parendamaks sinu HD681 EVO heli on lihtsalt teatud patjade kasutamine (loe pdf`st kust osta ja millised). |
Ostsin uued padjad. Sealt samast, mida kõige rohkem soovitati.
Ütleks nii, et kui klapp on 30 euri väärt ja 15 eurised padjad juurde osta, siis see 15 euri ei anna mitte midagi juurde. Vanad "uued" padjad on ka pdf kohaselt enam-vähem okeid. Veel vanem versioon nendest oli halb.
15 euri ja suts juurde osta korralik helikaart AMP-iga ja on märgatavam vahe. (Hetkel läpakas, ei saa oma kasutada)
Ehk kui kellelgi on tulevikus ka plaan upgradeda, siis pigem paiguta oma raha helikaarti/AMP-i.
25 |
libe
kvaliteetne mees
26.07.2016 18:20:03
| infect kirjutas: |
| CoiL kirjutas: |
Ehk kui kellelgi on tulevikus ka plaan upgradeda, siis pigem paiguta oma raha helikaarti/AMP-i. |
ma paigutaks raha klappidesse
30€ on ikka paras prügi
siin nende nööpidega võib ehk jopata, kuid need superluxid ei ole liha ega kala
isegi siin teemas põhipromootor soovitab neid "modides" kasutada. Selleks peab aga ostja olema mingi tehnikahuviline ja jootejaama ja oskusi omama
kui füüri napib, siis peab koguma ja tõsiselt uurima ja valima, kui veidi rohkem ülejääki, siis tasub kindla peale minna
muidugi tasub endale selgeks teha avatud ja kinnise klapi heli iseärasused, et oma eelistustega puhtalt hinna järgi rappa ei jookseks
tänapäeval on arvutiemaplaatidelgi korralikud helikaardid koos võimendiga, ühel isegi oli creative ZxR otse emaplaadil
AMPi on siiski vaja klappidel üle 32Ohm, eriti kui vaja mussi valjemalt kuulata, muidu pole kuni 80Ohm vajagi
infect
26.07.2016 18:52:12
| Superlux EVO-d on vägagi korralikud klapid oma hinna eest. Ja keskmine kasutaja ei vaja enamat.
25 |
Levelxer
26.07.2016 18:56:38
Kaks korda pidanud garantiioskonda tülitama HD 681 EVO lagunemise pärast, ent heli ise on väga hea.
Seega tänud pillipood.ee suunas
114 |
hendrik32
26.07.2016 19:04:16
| On vahepeal EVO'de kõrvale midagi uut ka tekkinud, mis madala hinna juures on võrdväärsed/paremed kui EVO?
| Kommentaarid: 16 loe/lisa |
12 |
libe
kvaliteetne mees
26.07.2016 20:08:30
| infect kirjutas: |
| Superlux EVO-d on vägagi korralikud klapid oma hinna eest. Ja keskmine kasutaja ei vaja enamat. |
kui nüüd kõlarisüsteemide hinnaga võrrelda, siis 100-200€ ei ole klapisüsteemi jaoks palju ja see 200€ ei ole ka 600€ teeniva inimese jaoks just summa, mida koguda ei jaksa - kõik sõltub sellest, kas heli soovitakse kuulata või mitte
tuleks mainida veel, et head heli kannatab vaid nooruses nautida, sest hiljem on kõrvad anyway peetis, kuigi head klapid kõlavad igavesti hästi
eks see ole prioriteetide küsimus
isiklikult autot ei oma ja sealt tulenevad kulud on vaba raha
klappe kasutan küll harva, kuid kui kasutan, siis unustan ennast
infect
26.07.2016 20:29:46
| 100-200€ on palju kõrvaklappide jaoks. Eriti su 600 eurose palgaga inimesele
25 |
libe
kvaliteetne mees
26.07.2016 21:09:00
| infect kirjutas: |
| 100-200€ on palju kõrvaklappide jaoks. Eriti su 600 eurose palgaga inimesele |
nu koguda või järelmaksu saab ka kahe aasta peale võtta
nagu ütlesin, prioriteedid ja kui ikka raha napib, siis aeg tasuvam töökoht otsida - hetkel pakutakse ikka hulka paremaid kohti ka väheharitud inimesele, kel käed otsas
viimane on kasuks hoolimata prioriteetidest
olavsu1
külaline
26.07.2016 22:02:48
| libe kirjutas: |
| infect kirjutas: |
viimane on kasuks hoolimata prioriteetidest  |
Tahaks näha neid tööpakkumisi kuhu ilma baka ja B katita ligi saab?
mis 100+n kõrvaklappidesse puutub siis...
https://pood.elion.ee/productInfo/381/korvaklapid-audio-technica-ath-m50x-(must)/ATH-M50X
5€ kuus ei ole miski eriline summa. mida kokkuhoitud ei saa.
Markos
26.07.2016 23:38:20
| Headesse klappidesse tasub raha paigutada küll. Tegemist on ju kestvuskaubaga, tihti sa neid ikka ostad, 10a jooksul korra ehk, kui just mingi poweruser ei ole ja mehaaniliselt ära ei lõhu. Samas on kallima otsa klappidel paljud tükid asendatavad ka. Odavad klapid lähevad mehaaniliselt suhteliselt kergelt katki, niiet kokkuvõttes ei ole üldse kindel, mis päeva lõpuks odavam tuleb, kas kohe korralik või iga aasta uued odavad. Mul on klapimajandusele kulunud aastate jooksul ligi 1000 euri, sisaldab siis ühte komplekti high-end klappe, dac'i, võimu, paari korralikke raadioklappe telekavaatamiseks ja mobiilsed bt klapid. Praktika näitab, et kõige enam kasutan just wireless ja bt klappe, high-endi haruharva.
12 |
libe
kvaliteetne mees
26.07.2016 23:57:53
ma kasutan ka high endi haruharva, kuna pea eranditult jään ma peale pähepanekut päevalõpuni muusikat kuulama
pelgan seda nõiavärki
samas mugavus ja heli on sellised, mille eest tunnen väärt raha maksnud
kokku olen ka circa 1200€ investeerinud, viimased klapid võtsid lõviosa - see kulutus siis alates 2008, poleks vanu klappe ära lõhkunud, oleks kulutus pisut alla poole
26.07.2016 23:59:40
Aga millised üldse oleksid head Bluetooth klapid?
196 |
Markos
27.07.2016 00:50:51
| Sõltub, milliseid sa eelistad, in-eare, on-eare, over eare ja palju oled nõus maksma. Mingid Sennheiseri MM X500'd on head, aga maksavad nagu pommilennuk. Paarisaja euro eest saab viisakad in-earid ka. Ma tegin pulli ja ostsin Alist 10 eurised Awei in-earid ja ei suuda ära imestada, kuivõrd bang4buck tootega tegemist on. Praegust igapäevases kasutuses. Laen üle kahe päeva.
12 |
27.07.2016 09:06:07
No ma muidu neid Sennheisereid muidu piilusingi...
Ise eelistan ülidselt Overeare ja mingi kuni 500€ oleks täitsa okei, kallimatel ei näe enam isiklikku kõrvakuulmist arvestades mõtet.
196 |
Markos
27.07.2016 09:58:58
No, kui rahakott võimaldab, siis 500X või 550X (noise cancelling) võiksid olla täitsa teema. Hea seegi, et vajadusel saab ka juhtmega kasutada, st ei pea muretsema, kui aku saab tühjaks. Mul filmiklappidega RS-160, on alatasa see jant, et kunagi ei tea, palju akut järel on ja no tühjaks saab ta ju ikka kõige põnevama koha peal alati Mitte, et toiteadapteriga koos edasi vaadata ei saaks, aga paraku on see nii ebamugavas kohas, et lihtsam on juhtmega klappide peale üle minna.
12 |
27.07.2016 13:16:49
Markos, no sinihammas olekski just teema (RS160 seda pole), sest enamus seadmetel on see tänapäeval built-in.
Seda juhtme asja vaatasin kah, kõikidel seadmetel BT liidest siiski endal pole, siis viskaks lihtsalt juhtme sappa ja mure lahendatud.
Oleks sellised suht universaalsed kodu kasutuse klapid...
High-Endikad on mul anyway endal eraldi olemas ja reisimiseks ka mingid Sennheiseri juhtmega in-earid.
Nagu selgus, siis 500X on EOL, ainult 550X on tootmises...
196 |
Markos
27.07.2016 16:35:14
| Jah, ma tõin selle lihsalt näiteks, milleks juhtmega ühendamise võimalus hea on, ehk, kui aku peaks ootamatult tühjenema.
12 |
strohher
27.07.2016 18:20:11
Kui kuni 50 rublaseid bluetooth over-eare klappe telekast filmide vaatamiseks otsida, siis sobivad ka suvalised alist tellitud? Telekas on LG UF8607
Ma ei ole absoluutselt kursis selle asjaga, aga kiunuv naabrimutt hakkab üle viskama lihtsalt
_________________ Tunguusia tundraahv |
30 |
27.07.2016 19:15:27
| strohher kirjutas: |
Ma ei ole absoluutselt kursis selle asjaga, aga kiunuv naabrimutt hakkab üle viskama lihtsalt  |
Tehniliselt sobivad ka suvalised, iseasi mis su kõrvad asjast arvavad ja kui pikaealised nad on.
| Markos kirjutas: |
| Jah, ma tõin selle lihsalt näiteks, milleks juhtmega ühendamise võimalus hea on, ehk, kui aku peaks ootamatult tühjenema. |
No ~250€ eest tundub seal klappe olema enam kui küll, 550X on kerge overkill kuna "Active Noise Cancellation" mulle erilist huvi ei paku, ega mul kodus nii mürarohke nüüd kah ei ole.
Klapid on mul ikka pigem selleks, et mitte ise teisi häirida...
196 |
Markos
27.07.2016 20:42:57
Vaata siis http://www.soundshop.ee/?id=1832&toode=Sennheiser%20PXC%20360%20BT seal ale ja puha. On klass madalamad, kui 550 aga võiks kärada küll.
| ui kuni 50 rublaseid bluetooth over-eare klappe telekast filmide vaatamiseks otsida, siis sobivad ka suvalised alist tellitud? Telekas on LG UF8607 |
Teleka bt'sse võiks reserveeringuga suhtuda, alati ei pruugi toimida, st ei ühenda seadmega ära. Alist ehk Bluedio T3 tasuks proovimist.
12 |
27.07.2016 21:08:56
Vaatab, hetkel sai ValiHeli`ga suheldud 500X teemadel..
196 |
CoiL
83 |
strohher
30 |
NATAS999
39 |
Markos
28.07.2016 14:58:30
| Olen seda ka varem siia postitanud juhtmeta-fännidele aga miks ka mitte selline asjandus osta ja kombineerida odavama kuid hea heliga klappidega? |
Mulle näib, et out of box lahendusena eeldab see konkreetset tüüpi klappe, ehk selliseid, milllel on ÜKS eemaldatav juhe. Mul pole ühtegi paari selliseid klappe, high-endidel läheb kummagi can'i sisse eraldi monopistikuga juhe. Sinna peaks siis ülemineku aretama ja kõige lühem juhe, mis mul on, ca meeter pikk, oleks siis rullis taskus või ümber kaela Ok, juhtmeid saab ise teha nii pikki, kui vaja, see pole kindlasti probleem, kuid kompaktsus kaob. Ma olen mingeid klipp/bt vastuvõtjaid ka näinud ca 15 euri eest, mis mõeldudki juhtmega klappidele.
12 |
02.08.2016 22:21:25
| Etz kirjutas: |
Vaatab, hetkel sai ValiHeli`ga suheldud 500X teemadel..  |
Läheb ilmselt hoopis PCX 550 loosi, 500X ja 550X saadavus on igalpool 0, eks need ole juba 4 aastat vana mudelid kah...
196 |
CoiL
03.08.2016 22:25:37
Varsti tulekul sellised nööbid:
Ja lisaks saadetakse mulle ühe kasutaja poolt niisama tasuta Magaosi BK50.
Eks annan tagasisidet kui käes.
83 |
Markokene
05.08.2016 01:06:29
| Ehk keegi oskab öelda kust võiks saada kummist otsi nööpidele?
| Kommentaarid: 6 loe/lisa |
Athunik
05.08.2016 10:57:15
| Markokene, kui kannatad oodata, siis Aliexpress või eBay. Siin Eestis ma nagu ei teaks ühtegi poodi, kus oleks suur valik kummilutte.
vinski
05.08.2016 11:21:20
Milliseid klappe te jooksmiseks kasutate, mis püsivad hästi kõrvas?
Varem olid Sennheiseri mx680 aga need on kolimise käigus kaotsi läinud.
lkraav
05.08.2016 12:14:43
Kas Xiaomi Pistoneid saab kuskilt Tallinna teada kohast päevasiseselt ka osta, teab keegi?
_________________ TELEFON PROFIILIS :: HV-NewFavFilter - GreaseMonkey HV lemmikute filter! Kui meeldib, pane positiivne märksõnaga "HV-NewFavFilter". |
| Kommentaarid: 138 loe/lisa |
129 |
Revilo
05.08.2016 12:47:56
| Kas kellelegi HyperX Cloud II omanikest tundub ka, et heli kvaliteet läbi USB on kehvem kui otse? 7.1 3d heli emulatsioon peal või mitte, mulle tundub, et see "internal soundcard" kõrvaklappidel teeb heli kehvemaks.
