Modified PvP weapon damage modifier so players will deal about 20% more weapon damage to each other (note that this change does not impact skill damage)
Added more kill volumes to Dragon’s Nest map. When exiting the map area, characters will be automatically killed
Ehk siis need kellele juba praegu ei meeldi PVP osa DZ-is, siis neil pole enam üldse asja sinna tsooni
See season pass omanikud saavad iga kuu 1-l ja 15-l supply drop-I väljaspool tumedat tsooni.
Ja kui sul on rohkem kui üks karakter tehtud level 30, siis saad mõlemaga neid lahti teha.
Mul on pmst 2 level 30 peal ja kolmas on level 14 et ainult DZ mängida level 14 peal olles.
Pmst esimese karakteriga sain mingi 229GS gear kollase ja mingi 229 AUG saastade talentidega ja siis 268GS tactician vesti.
Teise karakteriga sain ühe alphabridge 268 GS ja teine oli nomad mingine 268GS ja mp7 229 relva.
Esimese karakteriga ei olnud isegi botte ja sain drop-I avatud lihtsalt.
Teise karakteriga oli vist 4-5 level 32 botti kaitsmas.
Need supply drop-id ei kao kuhugi ja võid avada neid 2 nädala jooksul kuni uus tekib.
Kui uus tekib siis vana kaob.
Here are the list of changes to be implemented with the July 28th maintenance.
Fixed a bug where players could initiate 1 Phase Operations in Heroic difficulty by pressing a combination of buttons on their input device.
Rewards from Underground Operation Directives will now also include all gear sets from Updates 1.1 and 1.2 and you have a chance to receive additional loot when completing Operations with 4+ Directives.
Rewards from Underground Sealed Caches will now include all weapon types as well as all Underground and Update 1.3 gear sets.
Named NPCs in the Underground now have increased drop rates across all difficulties and doing multiple phase operations will give you a better chance at higher quality gear.”
nii katki ,et kui välja tulin mängisin 2nädalat ja sain aru ,et asi on lootusetu.
mäng ammu unistallitud möödas mingi 2 kuud ja ei mõtle ka peale panna.
unustatud teema never again ubish1t
Mäletan siven kui algus eitahtnud uskuda mind ja pedereerisid mind, et ole vait see game of the year mäng Keegi eusknud mind tegelt aga see selleks.
Ise loodan siiski siiralt, et watch dogs tuleb korralik ja southpark, see wildlands on minuarust ikka jube puine ja jääb isegi divisionile alla. _________________
mäng oli fun 2 nädalat ei kurda lihtsalt on siiralt kahju ,et sellise massive potentsiaaliga asi rikutakse ära:S
wildlands on jah kahjuks juba maha kantud. watch dog tundub ka selline 5/10 pela olevat 20 euri maks.
Kõige parem on see, et teevad expansione MAA ALLA.. kui nende mängu ilu oli terves hämmastavalt suures New Yorki linnas.. fuck dis. _________________ Minu Youtube - HDTanel
Mulle meeldib see mäng! Ainuke asi mis häirib on see, et DZ vastane nii tugevaks tehti Kuradi rakse on arvuti vastu seal saada. Ise grindin Metroos enamasti.
grindiks ka aga mis point on?
ausalt teel selles mängus kaugele ei jõua...
kuradi haxorid ja exploiterid jooksevad sellise geariga ringi ,et paha... sa ei grindi elus neile järgi.
ja kaua sa seda pve ikka toksid põhirõhk siiski ju pvp osal vähemalt minu jaoks.
Jabur on lugeda ja vaadata seda steam mängijate numbreid. Kahju et uplay's seda pole.
Mis teeb asja veel jaburamaks on see, et mäng koos sp-ga on ikka 60 euro.
Kui see langeks kuskile 40 peale, siis ehk saaks mängijaid juurde ka.
Algse hype-ga sai see mäng kindlasti kuldseid kasumeid. Nüüd lihtsalt suurem osa mänguritest on huvi selle mängu vastu kaotanud.
Eile olin jälle mingis Hiina serveris vist, kuna level 29 olles, ei saanud teist mängurit maha.
Ega mul midagi erilist ka polnud 80K dps, 114K toughness ja 13K skill power level 29 rank 55.
Eestis või mujal maailmas? Meil on uued Ubi mängud tihti kohapeal odavamad, kui uplays, Division on Gamestaris 35€ (varem 45€). _________________ Press A to disagree.
<Too late!>
Lehys, tavamäng mingi 23euri.. üsna okei. Õnneks tundub, et päris alla pole veel antud ja ikka tegeletakse mängu kallal. _________________ Minu Youtube - HDTanel
Jah päris alla pole antud et kes pidevalt on teemat jälgib see teab mis toimub.
Õnneks avas massive ennast ja otsitakse pidevalt lahendusi et core gameplay korda saaks,kes veel ei tea siis natuke aega tagasi hakati ka kommuuniga tihedamalt suhtlema ja nende ettepanekuid kuulama.
Mille tulemusena loodi elite task force kutsuti casual mangijaid ja hardcore mängijaid ning ka kuulsaid ja vähem kuulsaid juutuubereid rootsi et nad annaks enda nägemuse ja ideid mida muuta mängus,kogu tegevus toimus suletud uste taga mille tulemusena siis paar posti ülesse poole ka video selle kohta.
Ning sellel nädalal peaks avanema ka public test serverid kõikidele kes on mängu soetanud,kus siis hakatakse testima fixe jne jne,mis lõpuks jõuavad mängu (sarnaselt nagu BF4-l oli )
Marcostyle(youtuber) rääkis ka paljudest muudatustest ja andis mõista et väga palju asju on veel tulemas aga nad hetkel NDA all ja väga palju rääkida ei saa.
Võta allkeyshopist ligi 20 euriga saad praegust buildi mängda ja avaneb ka sulle PTS kus testitakse järgmise update builde,senimaani võiks öelda et PTS-sis nüüd mängides päris nauditav.
Praegu steamis 35,99. Ei tea kas on mõtet võtta v mitte. Suhteliselt negatiivne tundub see toon olevat. On kellelgi midagi positiivset ka öelda?
Mulle stoori ja gameplay meeldisid. Mäng jooksis hästi, nägi väga hea välja ja mulle meeldis seda mängida. Multiplayer osa jättis mind külmaks. Kolasin peamiselt maailmas ringi ja mängisin singleplayer mänguna. Minu silmis oleks nt 25€ mäng väärt.
Tasub ikka see mäng mida teadsite ennem on täielikult muutunud PTS keskonnas,põhimängu peaksid uuendused jõudma ehk alles oktoobris või novembris aga elame ja näeme.
no pts mõttetu toksida ju... arvasin ,et ikka mängus ka juba olemas... mida nad uimavad nii kaua
nii kuidas see 1.4 on siis??
redditis kiidetakse väga räigelt massive ....
''I can't play anything else right now... and all I think about when I'm at work is The Division''
''Mine's been calling it "Tom Clancy's The Divorce".
sellised teemad seal lausa kas tõesti lõpuks saadi valmis asi mida me kõik ootasime?
endal on siiamaani olnud lausa kurb ,et see mäng nii pekki läks... meeldis ikka kohutavalt alguses...
kuni said aru kui halb see tegelt on ja muidugi need cheaterid exploiterid...
kuidas praegu on? kas ikka ei teha normaalselt raid rune ja hackerid lasevad darkzones ringi?
tasub tulla tagasi ja hakata oma aega investeerima mängu???
Tasub ikka,teha on nüüd igalpool midagi kui lz oli enne välja surnud siis nüüd jagub ka seal tegevusi kui DZ ei soovita minna,kuigi DZ dropib rohkem looti.
Gearid on ümber disainitud et suhteliselt need mis enne olid metad on muutunud,pole enam sellist OP geari vaid kõik on kasutavad,mõni rohkem,mõni vähem kasulikumaks.
Sisuliselt tuleb hakata uuesti ülesse ehitama.
hackereid pole viimasel ajal isiklkult kohanud,aga eks neid ikka on nagu igas online mängus.
otsin 2 aktiivset liiget juurde...
ise sõbraga võtame asja uuesti käsile aga oleks 2 juurde vaja kellega koos grindida.
kindlasti on kohustuslik mikker ja suhtlemine;)
Uue geari on pidanud iga uuendusega omale ülesse ehitama seda ka viimasega kuigi sai ka vanaga hakkama. PVP on palju võrdsem ja on täiesti võimalik üksida DZ06 farmimine.
kui praegult osta 20 euriga kas siis on expansionid ka seal sees`mis välja tulnud? _________________ In game name:lusikas
See survival tuleb alles healjuhul detsembris.
Kõigepealt lastakse 1.5 välja ja siis pisut aega hiljem alles see survival.
Tänasest ei saa enam seda Survival ka mängida läbi PTS test serverite.
Kuna tahetakse testida dark zone-I ja muud ümbrust, siis pidid selle survival kinni panema, kuna enamus mängisid seda.
