Confer
Wiltz
23.04.2002 00:28:00
tb 1.33
kingston ddr@340mhz
3726 cpu
4024 mem
9 :: |
226 |
Nazca
23.04.2002 15:30:00
CPU score: 2806 (AMD Duron 1Ghz)
Memory score: 1817 (256Mb DIMM PC133 PQI)
HDD: N/A (Fujitsu 3.4GB unknown fps)
agent53
23.04.2002 18:25:00
Olen nüüd siis ametlikult benhimise maha jätnud...hea tulemuse saamiseks, benche kasutan ainult siis, kui tulevad näiteks uued driverid.
Ilmselt kui tuleb 3dMark 2002, siis hakkab jama jälle pihta(ull klokkimine, arvuti piinamine, ainult selleks et saada see ilusam punktisumma - mõttetu)
| Kommentaarid: 141 loe/lisa |
112 |
susi
23.04.2002 19:16:00
ajaks kah masina joonele:
cpu 2650
mem 2175
hdd 965
tb 1ghz, 512mb sdram, 30gb hdd
[ Seda sõnumit muutis: susi on 23.04.2002 20:19 ]
210 |
stalcer_x
27.04.2002 18:44:00
Operating System Microsoft Windows 2000
DirectX Version 8.1
Mobo Manufacturer IBM
Mobo Model 6270M6G
AGP Rates (Current/Available) N/A / N/A
CPU Intel Pentium III 736 MHz
FSB 133 MHz
Memory 128 MB
Graphics Chipset 3dfx Voodoo3 2000/3000
Driver Name 3dfx Interactive, Inc. Voodoo Series Driver
Driver Version 5.00.2195.0232
Video Memory 16 MB
CPU Score 1926
Memory Score 1281
HDD Score 274
CPU Tests
Jpeg Decoding 7.4 MPixels/s
Zlib Compression 3.0 MB/s
Zlib Decompression 30.7 MB/s
Text Search 55.1 KRounds/s
Audio Conversion 36.0 KB/s
3D Vector Calculation 23.5 FPS
Memory Tests
Raw Block Read - 3072KB 694.6 MB/s
Raw Block Read - 536KB 693.4 MB/s
Raw Block Read - 384KB 694.6 MB/s
Raw Block Read - 48KB 3184.7 MB/s
Raw Block Read - 6KB 5413.1 MB/s
Raw Block Write - 3072KB 178.0 MB/s
Raw Block Write - 1536KB 177.9 MB/s
Raw Block Write - 384KB 287.3 MB/s
Raw Block Write - 48KB 1861.5 MB/s
Raw Block Write - 6KB 4839.7 MB/s
Raw Block Modify - 3072KB 178.9 MB/s
Raw Block Modify - 536KB 178.5 MB/s
Raw Block Modify - 384KB 278.3 MB/s
Raw Block Modify - 48KB 1854.8 MB/s
Raw Block Modify - 6KB 3097.4 MB/s
Random Access - 24576 (1536KB) items 312.3 MB/s
Random Access - 12288 (768KB) items 312.6 MB/s
Random Access - 6144 (384KB) items 312.3 MB/s
Random Access - 1536 (96KB) items 1477.5 MB/s
Random Access - 768 (48KB) items 1474.5 MB/s
Random Access - 96 (6KB) items 1956.4 MB/s
Video - 1 line 487.5 FPS
Video - 4 lines 469.3 FPS
Video - 16 lines 409.0 FPS
Video - 32 lines 349.3 FPS
Hard Disk Tests
Cached File Write 10.3 MB/s
Uncached File Write 9.9 MB/s
Cached File Read 6.6 MB/s
Uncached File Read 17.7 MB/s
File Copy 1.8 MB/s
Crunch Tests
Jpeg Decoding 4.6 MPixels/s
Raw Block Modify - 3072KB 84.8 MB/s
Blit Test 83.7 FPS
njah...lahjavöitu...ilmselt on puudusex ka agp puudumine...irf
samas see video 32 lines tulemus paneb gf3 gtsile suhu nii mis ludiseb mitte ei saa aru...ja teiste testidega vörreldes tundub et win xp ruulib...
möttetu värk yhesönaga
| Kommentaarid: 28 loe/lisa |
Wiltz
29.04.2002 00:27:00
| mõttetult pikalt panid kirja aga noh oma asi. keegi ei viitsi vaadata lihtsalt neid üxikuid testitulemusi sul:)
9 :: |
226 |
29.04.2002 06:11:00
Nii kehv skoor, mis kõvakaga tegemist?
200 |
me_
29.04.2002 07:00:00
Duron 1ghz@1,21
128mb pc-133 noname RAM
cpu - 3393
ram - 2152
hdd - 289
Pole paha 1k eeguse prose kohta, ega ?
[ Seda sõnumit muutis: me_ on 29.04.2002 08:01 ]
| Kommentaarid: 64 loe/lisa |
62 |
siilur
17.05.2002 11:43:00
CPU -1948
Memory-1436
HDD -543
Win ME
PIII@733MHz
Abit Siluro T400
320MB SDRAM(133MHz)
Quantum Fireball lct15 15GB 4400rpm
| Kommentaarid: 9 loe/lisa |
9 |
palle
17.05.2002 12:22:00
Tundub et viimase ehk kõige aeglasema masina auhinnaline koht on alles vaba siis pretendeeriks sellele:
Test: Mark2002
CPU 1012
Memory 748
HDD 203
Masin ise:
Intel Celeron 433
RAM 128MB
Inegreeritud video 8MB, AGP 32MB
HDD Fujitsu 4GB
WinMe
Kuidas siis on, kas kindel viimane koht on tagatud ja milline masin auhinnaks tuleb - piisaks ka P4-st või ka Athlonist koos 21 tollise Nec Trinitron-monitoriga. Duron ja Celeron ei huvita...
[ Seda sõnumit muutis: palle on 17.05.2002 13:23 ]
lammas
17.05.2002 12:48:00
PcMark2002
CPU 474
Memory N/A
HDD N/A
Masin ise on
Microsoft Windows 98
Processor:AMD K6-2 @ 401 MHz
Graphics Card:RAGE IIC PCI (English)
Total Physical Memory: 128 MB
HDD 10GB WD
Irw. Aga mis jama on?
| Kommentaarid: 113 loe/lisa |
102 |
palle
17.05.2002 20:33:00
Hr. Lammas
Palju Sul videomälu on. Mul ei tahtnud ATI 4MB-ga ka samu teste teha.
Proovi 2001-ga.
andrez3d
17.05.2002 20:51:00
Minu tulemused on järgmised
Cpu 2477 Duron 650@965
Memory 2306 PQI 128mb
Hdd 526 Fujitsu 10gb
| Kommentaarid: 97 loe/lisa |
91 |
Superglue
18.05.2002 08:16:00
CPU=3329 Celeron 1.20
MEM=1691 128 MB PC133 Kingston + 256MB PC133 PQI
HDD=847 IBM Deskstar 60GXP 60GB 7200rpm
[ Seda sõnumit muutis: Superglue on 21.06.2002 12:11 ]
| Kommentaarid: 62 loe/lisa |
58 |
lammas
18.05.2002 10:49:00
17.05.2002 21:33 palle kirjutas:
Hr. Lammas
Proovi 2001-ga.
2MB on Tegelt on see arvuti vaid netis surfamiseks. Päris kodus ikka väheke vingem relv
102 |
VeixES
| Kommentaarid: 34 loe/lisa |
33 |
JL
20.05.2002 21:08:00
prose - 2202 duron 750@840
mälu - 2623 256 DDR Kingston cl2
hdd - 1000 - ilus number Fujitsu 40 GB
[ Seda sõnumit muutis: JL on 20.05.2002 22:09 ]
| Kommentaarid: 20 loe/lisa |
17 |
jyrgen
20.06.2002 23:07:00
CPU Score 6319 P4 1.6A@2.56A
Memory Score 5768 noname DDR266@DDR320
HDD Score 2472 IBM Deskstar 60GXP 60GB
20 |
Earl
20.06.2002 23:43:00
21.06.2002 00:07 jyrgen kirjutas:
Mis valemiga sa selle HDD skoori said? Seni pole siin kellelgi üle 1000 näinud.
Minu tulemused:
CPU - 4176 (XP 1600+)
Mälu - 3013 (2x256 DDR PC2100 Kingston @CL2)
HDD - 833 (Maxtor 80 GB, DiamondMax+ UIDE133 7200rpm) NTFS
WinXP Pro
[ Seda sõnumit muutis: Earl on 21.06.2002 05:09 ]
| Kommentaarid: 35 loe/lisa |
reimers66
21.06.2002 00:13:00
Minu tulemused:
CPU - 3670 (TB 1ghz@1.38ghz)
Mälu - 2560 (1x128 PQI PC-133@CL2+4way)
HDD - 510 (Maxtor 20 GB,DiamondMax+ UIDE133 7200rpm
see god deem HDD kiirus on küll väike kuid Sisandra 2k2 saan 26100pointsa niiet...
| Kommentaarid: 65 loe/lisa |
60 |
reimers66
21.06.2002 00:14:00
see sul pigem vist 472 või miss?
60 |
jyrgen
21.06.2002 00:21:00
21.06.2002 00:43 Earl kirjutas:
Kuule huvitav jah, aga vist mõtlesin "valemi" välja Nimelt ta defaultina teeb kettatesti loogilisele C: kettale. Minul on sellel partitsioonil ainult boot- ja swap-failid. Muidu absoluutselt tühi ja fragmenteerumata kettaosa. Vist seepärast. Tegin nüüd süsteemikettaga, mis füüsiliselt järgneb sellele C:-le, ja mis seal salata, tulemus langes räigelt - 595. Seega ei saa seda PCMarki kasutada ketaste kui selliste võrdluseks (a la IBM vs Seagate), küll aga näitab ta kindlasti konkreetse loogilise ketta performance'it olemasoleva failide hulga, fragmentatsiooni, füüsilise paigutuse jm näitajate juures.
Teisel katsel saadud tulemused on siin. Huvitav on see, et ka teised margid langesid pisut, kui ketast vahetasin.
20 |
reimers66
21.06.2002 00:30:00
| to jyrgen: selge siis ma juba hakkasin mõtlema et sul mingi imeketas!
60 |
jyrgen
21.06.2002 00:33:00
Uus rekord imekettaga:
20 |
