Pailaps
23.10.2015 17:35:46
| alar26t kirjutas: |
Täna hommikult selline probleem, et ping kõikus ühest otsast teise. Tallinnas hostitud mänguserveris läks ping vahepeal 200+.Edaspidine pole probleemi üle vingumine, vaid küsimus, kas antud meetod probleemi kinnitamiseks on õige.
tracert neti.ee
Tracing route to neti.ee [195.50.209.246]
over a maximum of 30 hops:
1 10 ms 99 ms 97 ms dsldevice.lan [192.168.1.254]
2 45 ms 40 ms 27 ms 2-36-50-84.dyn.estpak.ee [84.50.36.2]
3 22 ms 57 ms 54 ms the-bb1-ae-1-0.ee.estpak.ee [213.168.1.42]
4 64 ms 53 ms 54 ms jhv-bb1-xe-7-0-0-0.ee.estpak.ee [195.250.191.97]
5 32 ms 43 ms 60 ms noe-bb1-xe-7-0-0-0.ee.estpak.ee [195.250.191.61]
6 59 ms 53 ms 54 ms kjj-sr9-lag-2.ee.estpak.ee [213.168.1.19]
7 47 ms 54 ms 40 ms kjj-lgw7-gi-0-25.ee.estpak.ee [194.126.96.102]
8 38 ms 41 ms 47 ms neti.ee [195.50.209.246] |
Võtsin traceroute esimese hopi ja kasutasin seda stabiilsuse kontrolliks, kuna see peaks olema kõige lähim punkt minu ja elioni vahel, mis peaks elimineerima muud võimalused, kus probleem on.
Seejärel pingisin 84.50.36.2
ping 84.50.36.2 -t
Pinging 84.50.36.2 with 32 bytes of data:
Reply from 84.50.36.2: bytes=32 time=28ms TTL=63
Reply from 84.50.36.2: bytes=32 time=32ms TTL=63
Reply from 84.50.36.2: bytes=32 time=21ms TTL=63
Reply from 84.50.36.2: bytes=32 time=25ms TTL=63
Reply from 84.50.36.2: bytes=32 time=30ms TTL=63
Reply from 84.50.36.2: bytes=32 time=26ms TTL=63
Reply from 84.50.36.2: bytes=32 time=36ms TTL=63
Reply from 84.50.36.2: bytes=32 time=33ms TTL=63
Reply from 84.50.36.2: bytes=32 time=23ms TTL=63
Reply from 84.50.36.2: bytes=32 time=31ms TTL=63
Reply from 84.50.36.2: bytes=32 time=27ms TTL=63
Reply from 84.50.36.2: bytes=32 time=34ms TTL=63
Reply from 84.50.36.2: bytes=32 time=22ms TTL=63
Reply from 84.50.36.2: bytes=32 time=20ms TTL=63
Reply from 84.50.36.2: bytes=32 time=24ms TTL=63
Reply from 84.50.36.2: bytes=32 time=39ms TTL=63
Reply from 84.50.36.2: bytes=32 time=35ms TTL=63
Reply from 84.50.36.2: bytes=32 time=38ms TTL=63
Reply from 84.50.36.2: bytes=32 time=29ms TTL=63
Reply from 84.50.36.2: bytes=32 time=37ms TTL=63
Reply from 84.50.36.2: bytes=32 time=41ms TTL=63
Reply from 84.50.36.2: bytes=32 time=46ms TTL=63
Reply from 84.50.36.2: bytes=32 time=42ms TTL=63
Ping statistics for 84.50.36.2:
Packets: Sent = 158, Received = 158, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 20ms, Maximum = 46ms, Average = 25ms |
Natukene hiljem kui probleem oli hullemaks läinud
ping 84.50.36.2 -t
Reply from 84.50.36.2: bytes=32 time=45ms TTL=63
Reply from 84.50.36.2: bytes=32 time=43ms TTL=63
Reply from 84.50.36.2: bytes=32 time=48ms TTL=63
Reply from 84.50.36.2: bytes=32 time=44ms TTL=63
Reply from 84.50.36.2: bytes=32 time=47ms TTL=63
Reply from 84.50.36.2: bytes=32 time=40ms TTL=63
Packets: Sent = 47, Received = 47, Lost = 0 (0% loss),
Minimum = 24ms, Maximum = 48ms, Average = 36ms |
Olen varem seda ip-d pinginud kui probleeme ei olnud. Ping jäi 21-24ms vahemikku, peale 2 minutit pingimist.
EDIT: Elioni sai helistatud. Seal öeldi, et parameetirid OK nende poolt vaadates. Edasi suunati tasulise tehniku poole,kui selline vastus ei meeldinud, millest ma keeldusin. |
https://www.nanog.org/meetings/nanog45/presentations/Sunday/RAS_traceroute_N45.pdf
Loe see enne läbi.
Latentsuse kasv sõltub Sinu toru koormusest. Kui samal ajal midagi üles laed, siis automaatselt kasvab latentsus. Üles laadimis teostatakse samal ajal allalaadimisega. Näiteks veebibrauseris lehe avamisel. Kui paketikadu ei esine on kõik OK.
Seega Sinu ühendus on korras.
| Kommentaarid: 56 loe/lisa |
52 |
alar26t
23.10.2015 18:34:50
| Pailaps kirjutas: |
| alar26t kirjutas: |
tracert neti.ee
ping 84.50.36.2 -t
ping 84.50.36.2 -t
Loe see enne läbi.
Seega Sinu ühendus on korras. |
Asi on selles, et antud hetkel ei toimunud mingit ülesse/alla laadimist minu poolt. Kõik programmid olid minu poolt kinni pandud. Wifi oli välja lülitatud ja minu arvuti oli ainuke asi, mis oli ruuterisse ühendatud. Kõik muu tõmbasin välja. Samuti kontrollisin task managerist, palju mu arvuti trafficut suudab tekitada. Terve testi ajal oli max 1-2 kb/s.Ruuterist ma mingeid upload/download datat ei suutnud leida, seega ei saa kontrollida, kas minu ruuterit kasutatakse võidakse reflection DoS rünnakuteks. Mul on seda sama jama ka varem juhtunud. Iga kord kord öeldi, et kõik on korras, kuigi selle sama kõne ajal ma timeoutin serverist mitmeid kordi (ping 200-1000ms inbound loss 0% outbound 30-40%. See info on kuu aja tagusest sündmusest, mis sarnaneb praegusele.). Miks ma kahtlustan, et mu ruuterit kasutataks DoS on see, et allalaadimine on alati täiesti korras. Upload on see, mis on probleemiks. Seekord tegin 100% kindlaks, et mina ei saa olla see, kes tekitab probleeme.
EDIT:Ruuter on Thomson TG784
| Kommentaarid: 9 loe/lisa |
9 |
Pailaps
23.10.2015 19:10:11
| alar26t kirjutas: |
| Pailaps kirjutas: |
| alar26t kirjutas: |
tracert neti.ee
ping 84.50.36.2 -t
ping 84.50.36.2 -t
Loe see enne läbi.
EDIT:Ruuter on Thomson TG784 |
Su ruuterit rünnakuks on võimatu kasutada. Ligipääs on ainult paarilt hostilt TG784 pihta väljaspoolt. Võid tulemüüri kangemaks konfigureerida käsurea liideselt.
Ühel kliendil avastasin ma kunagi Google Drive probleemi tekitamas.
52 |
KillFrenzy
23.10.2015 20:05:42
Kas Inteno RC7 on mingi probleem? Tehnilise toe ootejärjekord 82minutit
Käisin just tuttavade juures abiks. Hommikul anti elionist inteno ja uus digiboks. Ühendasid järgi, mingi hetk võttis inteno vana käki ssid, parooli, läpakad said wifiga netti. Telekas tööle ei hakanud, helistasid 123, uuendati ilmselt RC7 peale. Polnud ei kaabliga netti, wifiga, ega telekas pilti.
Käisin seal resettisin inteno ära, muutsin wifi security wep pealt wpa peale panin uue parooli.
Telekas hakkas tööle, kaabliga tuli nett.
Kustutasin arvutist wifi profiilid ära, tegin uued, ühendab ära. Ruuterisse saab logida, aga netti pole, pingi peale lahendab hosti ära, aga time out.
Samas minu telefon ühendab wifiga ära, ja internet toimib.
134 |
Pailaps
23.10.2015 20:12:05
| KillFrenzy kirjutas: |
Samas minu telefon ühendab wifiga ära, ja internet toimib. |
Tegelikult oleks piisanud juba ennist restardist ruuterile, et seiskunud teenused uuesti taaskäivitada. TV oleks uuendamata tööle hakanud.
Kuidas ruuteris probleeme, kui telefon wifi kaudu ära ühendab ja töötab?
Reaalne on pigem see, et MAC filtering on ruuteris vaikimisi sisse lülitunud või arvutis tulemüür blokeerimas.
Mina MAC filtreerimist vaikimisi konfiguratsiooni pole lisanud. Vaikimisi taastatakse endise seadme SSID ja turva.
Network-Diagnostics all saad kontrollida, kas internet reaalselt töötab. Seal utiliit traceroute, nslookup vms tarbeks.
52 |
KillFrenzy
23.10.2015 20:21:52
Pailaps, homme lähen uurin edasi. Suht kahtlane et mõlemas arvutis nüüd tulemüür midagi hakkas blokkima. Üks on macbook teine win7.
Ja peale reseti võttis inteno ka deafult wifi ssid mingiks hetkeks. Seega võiks ju kõik mac filter seaded ka ära kustuda.
Muidugi tase on see et tehniline tugi, küsis mis digiboks on. Ütlesid uus arris. Vaadake kas arrisel taga võrgupistikus tuled põlevad. Ei põle. Selge digiboks vigane. Minge käige esinduses vahetatakse välja. Anti uus.
Arrisel pole ju võrgupistikus ühtegi ledi
134 |
-parun-
23.10.2015 23:37:54
| Six kirjutas: |
Piitsa pole enam siis kellelegi anda...
| Pailaps kirjutas: |
| Inteno DG301 ELION3.4.0RC7 on saadaval eilsest. Soovitatav algatada upgrade klienditoe abiga. Minu viimane präänik. Lubasin enne lahkumist informeerida. |
Tegin Intenole tikuga reseti ja toimus hoopis tarkvara downgrade
DG301-W7P2U_ELION2.3.11RC1-140422_1519
Pailaps
23.10.2015 23:50:59
| -parun- kirjutas: |
| Six kirjutas: |
| Pailaps kirjutas: |
DG301-W7P2U_ELION2.3.11RC1-140422_1519 |
Ilmselt oli viimane ruuterisse Elioni roboti poolt registreeritud versioon selline. Upgrade saab klienditoe abiga algatada.
52 |
Six
24.10.2015 08:07:31
Kui RC7 oma bugidega välja tuli ning ma lolli peaga oma RC1 upgradesin ning siis palusin elioni klienditoel seda downgradeda tagasi RC1 peale, öeldi, et see pole võimalik ka kõige parema tahtmise juures.
Tuleb välja, et on ikka võimalik küll...
| Pailaps kirjutas: |
| -parun- kirjutas: |
| Six kirjutas: |
| Pailaps kirjutas: |
Ilmselt oli viimane ruuterisse Elioni roboti poolt registreeritud versioon selline. Upgrade saab klienditoe abiga algatada. |
| Kommentaarid: 40 loe/lisa |
39 |
Pailaps
24.10.2015 09:21:21
| Six kirjutas: |
| Pailaps kirjutas: |
| -parun- kirjutas: |
| Six kirjutas: |
| Pailaps kirjutas: |
Võimatu kindlasti mitte. Ei ole samas mõtet vananenud tarkvara versiooni hoida, mis samuti vigu sisaldab.
52 |
-parun-
24.10.2015 12:45:18
Sain oma ruuteri tarkvara kenasti uuendatud online abi kaudu, mis ütles kohe, et tarkvara versioon pole uusim ja pakkus upgrade. Nüüd tuli peale see uusim versioon:
DG301-W7P2U_ELION3.4.0RC7-151020_1752
Tähelepanekud:
1. Süsteemilogi ja kerneli logi pole enam kasutajale nähtavad.
2. Uue asjana on ilmunud printer server. Kas töötab ka, pole proovinud
3. Voice tuli ruuteril ei põle, kuigi SIP kontod on registreeritud ja telefonid töötavad
4. Sättisin WiFi-le 40MHz ribalaiuse 11. kanal/upper sideband. Mõne aja pärast jooksis wifi pange. Ühendust ei saanud. Wifi analyzer android telefonis näitas et pangestunud seisundis oli wifi signaalitugevus ca 20dB/m võrra tavalisest nõrgemaks muutunud. Panin tagasi 20 MHz ribalaiuse, rebootisin ja siiani püsib. Sellise nähtuse puhul torkab jälle pähe vandenõuteooria ülekuumenemisest. Elion peab vist veelgi rohkem kasutajaid ahistama, et asi töötaks
5. Statuse all on nähtavaks tehtud IGMP Snooping Table
6. Kadunud on OpenVPN. Kui lähtuda vandenõuteooriast, siis võib see olla eemaldatud ka liigse kuumenemise vältimiseks. VPN teatavasti resursinõudlik teenus.
7. Juurde on tekkinud Parental Control (kindlalt ei mäleta, kas see oli olemas ka eelmises versioonis või mitte).
jkddp
24.10.2015 13:03:59
| woox2k kirjutas: |
| Lisaks tuleb välja, et alati tasub esindusse minna uute asjade nõudega. Elionil mingi kampaania hetkel kõige vanemate digitv omanikega, et uue tähetajalise lepinguga antakse kõik seadmed tasuta kätte. Varem Elionist uut netti küsides ei öelnud nad selle kohta midagi ja käskisid uue ruuteri osta või rentida, igatahes hea teada. |
... et siis kõik seadmed mis?
Mul kiviaegne riistapuu ST716v5 aja algusest taga. palju see kiirusi tänapäeval kannatama peaks?
_________________ Kui vaja joonistada/saagida/hööveldada midagi, võib alati küsida  |
| Kommentaarid: 64 loe/lisa |
62 |
woox2k
24.10.2015 13:08:08
| jkddp kirjutas: |
| ... et siis kõik seadmed mis? |
Kõik seadmed jah, nagu oleks esimene liitumine (ruuter, digibox jne.)
Nüüd on asi mõned päevad üleval olnud ja olgugi, et küsisin seda ka varem, küsin uuesti. Mis targemad arvavad liini parameetritest ja kas oleks tulevikus mõtet Elioni kiusata natuke paremate kiirustega paketi saamisega: https://gist.github.com/anonymous/56a05ee2ad219b43afb2 Ainus number, mis mulle midagi ütleb on "Attainable Rate" aga see näitab vist aiateibaid ja reaalsuses selline ei püsiks? Lisaks miks Attenuation UP on nullis, ruuter paneb segast?
_________________ Mess with the best, die like the rest!
viimati muutis woox2k 24.10.2015 13:14:07, muudetud 2 korda |
| Kommentaarid: 20 loe/lisa |
18 |
KillFrenzy
24.10.2015 13:11:19
jkddp, 2a siduvusega tasuta uued seadmed.
See nädal on paljud tuttavad saanud uue ruuteri ja arrise siduvusega. Kõigil oli kunagi saadud hallid thomsonid. Osad olid ise vahepeal ostnud tg784 et saaks samsungiga nutit vaadata ja said ikka tasuta siduvusega uue inteno ja arrise.
134 |
harakas
24.10.2015 13:24:12
| -parun- kirjutas: |
Tähelepanekud:
4. Sättisin WiFi-le 40MHz ribalaiuse 11. kanal/upper sideband. Mõne aja pärast jooksis wifi pange. Ühendust ei saanud. Wifi analyzer android telefonis näitas et pangestunud seisundis oli wifi signaalitugevus ca 20dB/m võrra tavalisest nõrgemaks muutunud. Panin tagasi 20 MHz ribalaiuse, rebootisin ja siiani püsib. Sellise nähtuse puhul torkab jälle pähe vandenõuteooria ülekuumenemisest. Elion peab vist veelgi rohkem kasutajaid ahistama, et asi töötaks  |
Mul VOICE põleb
Mul pakub ribalaiuseks 20MHz ja 20/40MHz. 40MHz eraldi ei paku. Valisin 20/40MHz, sel juhul näitab wifi kiiruseks 150Mbps, 20MHz korral 65Mbps. Kanali valik automaatne, wifi toimib korralikult
jkddp
24.10.2015 14:06:12
woox2k, KillFrenzy, kas kahe digiboxilisel kliendid saavad 2 seadet?
62 |
KillFrenzy
24.10.2015 14:50:54
jkddp, seda peaks elionist küsima. Aga kahtlen. Oma viga et oled teise digiboxi ostnud
134 |
-parun-
24.10.2015 18:40:21
| harakas kirjutas: |
| -parun- kirjutas: |
Tähelepanekud:
Mul VOICE põleb
Mul pakub ribalaiuseks 20MHz ja 20/40MHz. 40MHz eraldi ei paku. Valisin 20/40MHz, sel juhul näitab wifi kiiruseks 150Mbps, 20MHz korral 65Mbps. Kanali valik automaatne, wifi toimib korralikult |
Mul ei hakanud voice põlema ka pärast mitmendat uut reseti. Aga las ta olla. Rohkem ei viitsi enam sellega mängida. Võibolla pärast järgmist tarkvarauuendust hakkab...DECT ka ei põle aga see vist ei peagi?
harakas, kas Sul on ikka see uus versioon, mis alles eile välja tuli?
riaak
24.10.2015 18:41:19
Kuidas saada 780WL Inteno wifit pikendama? Soov digiboks 780WL külge pista.
_________________ ¯\_(ツ)_/¯ |
105 |
Pailaps
24.10.2015 18:44:57
| -parun- kirjutas: |
| harakas kirjutas: |
| -parun- kirjutas: |
Tähelepanekud:
Mul VOICE põleb
harakas, kas Sul on ikka see uus versioon, mis alles eile välja tuli? |
Ei põle, kui Sul DECT toru järgi pole.
20/40 MHz võiks valitud olla. Automaatika ise otsustab. Mis puudutab Voice LED mittepõlemisse, siis teenuse kasutust see ei häiri. Konfipõhja ruuterisse kirjutades võis LED osa välja jääda.
Mis puudutab pangestumis 40 Mhz juures, siis võib häda olla riistvaraline.
52 |
harakas
24.10.2015 21:39:37
| -parun- kirjutas: |
| harakas kirjutas: |
| -parun- kirjutas: |
Tähelepanekud:
Mul VOICE põleb
Uus ikka, muidu poleks kommenteerinud. Kusjuures sain selle uue vaevata peale, Elioni toe abi ei vajanud. Siin on korduvalt kommenteeritud, et minu Intenol puuduvad probleemid, kuna see on üsna algul ostetud, hilisemad pidavat probleemsemad olema.
-parun-
24.10.2015 22:04:43
| Pailaps kirjutas: |
Mis puudutab pangestumis 40 Mhz juures, siis võib häda olla riistvaraline. |
Tegin veel ühe restardi, mille algatasin online abist. Pärast seda sai voice-ga korda. Wifi on default settingutega püsinud. Nii kui määran 20/40, siis pangestub ruttu. Proovisin vähendada wifi võimsust 50% peale, see midagi paremaks ei muutnud. Jätan nüüd 20 MHz peale ja eks siis näeb.
riaak
25.10.2015 11:21:57
| riaak kirjutas: |
| Kuidas saada 780WL Inteno wifit pikendama? Soov digiboks 780WL külge pista. |
Tegin Intenos uue Wifi võrgu WEP võtmega (780 ei toeta enamat).
780 seadistasin WEP võtme ning wifi kanali Intenoga samaks ning enablesin äsja loodud Inteno võrgu WDS. Selle peale aga ei saanud kummagi Inteno võrguga ühendust, 780 kaudu ka internet ei toiminud. WDS jälle välja lülitades võrk mõne aja pärast taastus.
105 |
25.10.2015 18:50:37
| harakas kirjutas: |
| -parun- kirjutas: |
| harakas kirjutas: |
| -parun- kirjutas: |
Tähelepanekud:
Mul VOICE põleb
Uus ikka, muidu poleks kommenteerinud. Kusjuures sain selle uue vaevata peale, Elioni toe abi ei vajanud. Siin on korduvalt kommenteeritud, et minu Intenol puuduvad probleemid, kuna see on üsna algul ostetud, hilisemad pidavat probleemsemad olema. |
Misasja. Vastupidi ikka. Enda ruuter ka esimestel päevadel ostetud.
131 |
KillFrenzy
25.10.2015 19:36:15
Uuendasin ka naabrimehe käest laenatud intenol firmware, midagi läks alguses nahka. Nupust reset ja üles ruuter enam ei tulnud, tuled peal põlesid aga ära ei ühendanud. Peale voolu eemaldamist tegi ise veel mitu restarti ja hakkas tööle.
Vaatab kuidas selle wifi ennast üleval peab, päevas mitu korda kukub link 300 pealt 1-2 peale ja signaali tugevus läheb nõrgaks. Sama eelmise tarkvaraga elioni rendikas nädalajooksul sellist nalja kordagi ei teinud. Riistvaraline erinevus?
134 |
-parun-
25.10.2015 20:36:46
| jägaja kirjutas: |
| harakas kirjutas: |
| -parun- kirjutas: |
| harakas kirjutas: |
| -parun- kirjutas: |
Tähelepanekud:
Mul VOICE põleb
Misasja. Vastupidi ikka. Enda ruuter ka esimestel päevadel ostetud. |
Esimese Inteno sain kohe esimesel päeval kui need ametlikult müügile ilmusid. Sellel suri nädala jooksul ära üks ethernet port. Vahetati välja. Teine töötas, kuid aegajalt esinesid teada tuntud probleemid. Üleminekul VDSL-ilt optika peale tegi tehnik ettepaneku ka ruuter välja vahetada. Olin nõus lootes et läheb paremaks. Sain selle uuema versiooni, millel pots pesa enam ei ole. Tegelikult midagi ei muutunud, samad probleemid jätkusid.
harakas
28.10.2015 12:10:32
| Jälle üks mure TG784-ga. Kui see oli mul koduvõrgus Inteno järel, sain sinna 192.168.1.254/login.lp vabalt sisse. Nüüd tõin selle kooli võrku, et oma klassis levi parandada. Kooli võrgus Inteno+switch kust kaabel tuleb Thomsonisse, aga enam ruuterisse sisse ei saa, ei telneti ega brauseri kaudu. Kõik muu toimib, saan internetti jagada nii wifi kui ka kaabli kaudu. Tundub, et TG784 sai uue IP-aadressi, võrgus on seade nimelt aadressiga 192.168.0.134, aga ka selle aadressiga ei saa ruuterile ligi. Ei saa isegi siis, kui ruuteri võrgust lahti ühendan ja kaabliga arvuti külge jätan. Ainuke võimalus sisse saada, on teha reset, aga nii kui uuesti võrku ühendan, enam ei saa.
Charly
28.10.2015 12:33:54
Mõtlesin, et lähen võtan ka prooviks rendi-Inteno, aga see osutus rängaks veaks, tuleb vana hea TG 585 v7 tagasi ühendada.
Alustame sellest vanast tuntud wifi katkemise teemast, lisaks ei saa wifi-võimekusega printer enam Inteno pakutava võrguga üldse kokku, leviala korteris on kahanenud pisemaks, kui korter ise, ja läppar ei saa ka enam muidu wifisse, kui peab wifi läpakas välja-sisse lülitama.
Midagi on kindlasti veel ette tulnud, mis vähem häiriv...ah jaa, laste Wii konsool ei tunne ka enam wifi-võrku ära, kuigi sai täpselt sama konfiga tehtud, kui TG 585 v7 peal oli.
_________________ I'm just 2 people short of a threesome.Help! |
A.S.
28.10.2015 12:53:44
| harakas kirjutas: |
| ...aga ka selle aadressiga ei saa ruuterile ligi. |
Kas vana hea http://10.0.0.138/ enam ei toimi?
| Kommentaarid: 34 loe/lisa |
34 |
harakas
28.10.2015 18:41:46
| A.S. kirjutas: |
| harakas kirjutas: |
Kas vana hea http://10.0.0.138/ enam ei toimi? |
Tänud!
Pole varem vaja läinud, homme proovin
Edit:
Ei saa ka sellega, ikka sama vastus "See veebileht pole saadaval"
viimati muutis harakas 29.10.2015 10:08:07, muudetud 1 kord |
Wordmc9
28.10.2015 19:43:39
küsimus kas on kellelgi sama jama, et kui online mängu mängid siis ruuter kooleb ära Thomson TG789vn ?
krt endal nagu rusika reegel, nii kui online läheb on kellad
| Kommentaarid: 346 loe/lisa |
287 |
Pailaps
28.10.2015 20:43:29
| Wordmc9 kirjutas: |
krt endal nagu rusika reegel, nii kui online läheb on kellad  |
Tee pordisuunamised käsitsi. Rusikareegel on, et upnp reeglid suretavad thomsoni välja.
52 |
libe
kvaliteetne mees
28.10.2015 21:02:40
| Pailaps kirjutas: |
| Wordmc9 kirjutas: |
Tee pordisuunamised käsitsi. Rusikareegel on, et upnp reeglid suretavad thomsoni välja. |
kummaline lugu
tg784 ja ei ole juba aastaid koolenud
upnp ja jutud enabletud
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
sooty
29.10.2015 12:17:42
Ma uudishimust pärast siin Inteno tarkvarauuenduse kohta lugemist panin kodus enda (mitte Intenole) ruuterile OpenVPN serveri püsti.
Mis seal keerulist oli või mida ta Elioni ruuteriga tegi, et see võimalus ära võeti? Mingi kuumenemine?
| Kommentaarid: 12 loe/lisa |
12 |
Pailaps
29.10.2015 12:34:34
| sooty kirjutas: |
Mis seal keerulist oli või mida ta Elioni ruuteriga tegi, et see võimalus ära võeti? Mingi kuumenemine? |
Ei. Kasutamiseliidese seadistamise raskuse tase ületas ootusi klientidele.
52 |
-parun-
29.10.2015 14:12:52
| Pailaps kirjutas: |
| sooty kirjutas: |
Ei. Kasutamiseliidese seadistamise raskuse tase ületas ootusi klientidele. |
Tegelikult võiks Elion Inteno seadistamise juhendi teha ja selle kuhugi netti riputada. See ei tohiks suurfirmal tükki küljest võtta ja siis poleks ka vaja klientide saamatusega ennast välja vabandada. Kasutajate arv peaks olema piisav, et võiks selle ette võtta
sooty
29.10.2015 14:28:39
| ot: |
Ma seadistasin enda ruuteril openvpn SSH kaudu juhendil näpuga järge ajades, sest veebi kaudu oli liiga keeruline ja kirju |
12 |
| Kommentaarid: 172 loe/lisa |
161 |
Vidget
30.10.2015 13:05:54
Tavakasutajad ei hakka helistama Synology toele vaid otsivad tuttava patsiga poisi, kes paari õltsi eest asja korda seab. Elioni aga helistataks ja nõuaks, kuigi Elion pakub vaid iternetti ja muu peaks olema juba kasutaja enda kapsaaed.
128 |
Pailaps
30.10.2015 13:20:37
| Vidget kirjutas: |
Tavakasutajad ei hakka helistama Synology toele vaid otsivad tuttava patsiga poisi, kes paari õltsi eest asja korda seab. Elioni aga helistataks ja nõuaks, kuigi Elion pakub vaid iternetti ja muu peaks olema juba kasutaja enda kapsaaed. |
Aitäh! Paraku nii oli see tõesti.
52 |
sooty
30.10.2015 13:26:13
| Kas enam telefonis raha eest nõu ei annagi?
12 |
dentartu
30.10.2015 14:03:29
| sooty kirjutas: |
| Kas enam telefonis raha eest nõu ei annagi? |
Ikka pakkuvad 10eur est.
| Kommentaarid: 11 loe/lisa |
9 |
30.10.2015 16:25:21
"Tavakasutajaid" ei huvita VPN kah, seega ei hakka nad ka kuhugi helistama.
DSM-i tõin eeskujuks kui näite, kuidas GUI saab lihtsaks ajada.
Endal ei kulunud üle paari minuti, et VPN tööle sealtkaudu ajada.
Endale selline probleemide lihtsalt menüüst eemaldamine väga ei meeldi.
+ lisaks ma ei saa aru, kellele need kernel/system log nüüd ette jäid et neid ka enam ei kuvata?
161 |
Six
30.10.2015 16:59:46
Mida vähem tead, seda parem.
Muidu hakkad veel küsimusi esitama.
| bladerunner kirjutas: |
+ lisaks ma ei saa aru, kellele need kernel/system log nüüd ette jäid et neid ka enam ei kuvata?  |
39 |
30.10.2015 18:09:06
| Six kirjutas: |
Kuvatakse ju?
Pigem huvitab mind hoopis kellele see Guest Wifi ja Config Backup ette jäid...
196 |
loox
30.10.2015 20:23:56
| Etz kirjutas: |
| Six kirjutas: |
Kuvatakse ju?
Pigem huvitab mind hoopis kellele see Guest Wifi ja Config Backup ette jäid...  |
Mõtlesin just esindusse küsima minna, et kas Inteno veel mingi soodustuse alla käib, aga kuna kõik kasulikud featuurid on maha nuditud, jääb see tegemata.
Kas uusNuti (vana menüüga) ilma IGMP proxy-ta, s.t. vana ruuteriga, üldse toimib? Huvitaks ainult uuemad HD kanalid, muu stuff on niikuinii juhuse asi.
30.10.2015 21:03:39
| loox kirjutas: |
Kas uusNuti (vana menüüga) ilma IGMP proxy-ta, s.t. vana ruuteriga, üldse toimib? Huvitaks ainult uuemad HD kanalid, muu stuff on niikuinii juhuse asi. |
Peaks nagu ikka toimima...
196 |
| Kommentaarid: 92 loe/lisa |
30.10.2015 21:34:39
| Tomorrow kirjutas: |
| Etz, Config Backup eemaldatud või? Confi ei saagi enam varundada ega taastada? |
Ei, menüüs pole enam seda kohtagi...
196 |
The_Boss
30.10.2015 21:39:12
Sattusin telekomi /abi lehele ja uurisin seal ringi. Vaatasin siis viimase 72h võrguliikluse graafikut ja märkasin, et iga öö kell 2:00 on liiklus nullis. Millest see tuleneb?
284 |
