IffikaS
15.09.2015 15:01:58
HDMI -> VGA probleem [Starman StarBOX] |
Tere,
Kuna enam telekat kodus pole, aga siiski sooviks aegajalt midagi vaadata, siis oli mõte ühendada Starmani STARbox (INTEK HD-C63CX) enda vana projektoriga.
Sai hangitud jebaist siis converter HDMI to VGA: LINK
The latest version of the VGA to HDMI convertor allowing you to connect PS3, PS4, XBOX One, XBOX 360, Sky HD, Apple TV, Tivo and other HDMI devices to a VGA monitor, projector or other display. Output definition of 720P and 1080P are supported.
1080P HDMI to VGA SVGA RGB Video and Audio. Brand new with 1 year warranty. The built in chipset seperates the HDMI signal and converts the Video for use on the VGA output port and the aux audio output port. Perfect for use with older monitors and televisions.
* IMPORTANT* Your monitor/TV/projector MUST be capable of displaying the resolution/refresh rate from your HDMI input device. If your display is not compatible with the resolution/refresh rate through its VGA port then it will not be able to display any picture. Check your user manual for compatible VGA input resolutions before purchasing.
This adapter will not functional in reverse, it will not convert VGA to HDMI.
Latest version with integrated audio output
Intergrated chipset, no software required, plug and play technology
Convert HDMI to VGA
Durable ABS Construction
Precision fit connectors protect ports and ensure a reliable connection
HDMI version 1.3 compliant and HDCP compliant
Compatible with all versions of HDMI up to 720p and 1080p
Input resolution accepted: 480i/480p/576i/576p/720p/1080i/1080p
Max resolution is 1920 x 1200 at 60hz
No external power supply required
Very light weight at just 61gms
Koostekvaliteet alla igasugust arvestust, audio pesa lagunes kohe ära, see sai tagasi joodetud.
Aga nüüd probleemi sisu juurde:
Ühendasin ära, lülitasin digiboxi sisse ja sundisin välja andma 480p pildi. Selle peale tuli projektori ekraanile digiboxi HUD ja kõlaritesse ilusti heli ka.
Aga mida ei ole, ei ole pilti, ainult HUDi näen ja saan kõike näppida, aga pilti ei tule.
Ma tean, et saan kasutada ka AV väljundit, aga enese hairimiseks, mõtlesin uurida, et kuidas on võimalik, et HUD töötab läbi konverteri, aga pilti ei tule?
Googeldasin, aga võib olla oskamatult, sest ei leidnud midagi sarnast.
Oskab keegi äkki kommenteerida?
Tänades,
Ivar
| Kommentaarid: 160 loe/lisa |
150 |
TT
15.09.2015 15:26:22
link :: HDCP
Koopiakaitse?
Edit: Kirjade järgi peaks koopiakaitse läbi laskma. Ei oska asist lahendust seega pakkuda.
AV väljundi puhul Component(mitte Composite) peaks andma päris hea tulemuse pildile.
_________________ Things ThaT You own end up Owning you! |
276 |
Villemk2
15.09.2015 15:26:39
Olen paari taolist katsetanud ja nendest pole ükski pilti näidanud.
Samas powered adapterid töötavad.
121 |
jnt
15.09.2015 15:54:06
Villemk2, küsijal on hud ees ju. Seega adapter ise toimib tehniliselt.
108 |
Villemk2
15.09.2015 16:08:56
| Kõrgemat reso proovida ehk?
121 |
ihvike
15.09.2015 16:17:44
| Väga tõenäoliselt HDCP probleem, väidetagu seal andmetes mida tahes. Ise ka arvutimonitoriga sellist kammi näinud, aitas monitori on/off, aga sellest muidugi antud juhul ei pruugi tolku olla.
| Kommentaarid: 12 loe/lisa |
12 |
IffikaS
15.09.2015 18:55:35
Väga huvitav.
Resolutsiooni muutmine ei aita. Õhtul proovin arvuti HDMIst pildi projektorisse suunata ja vaadata kas töötab.
Aga ma ei saa aru, kuidas on ikkagi võimalik, et ma HUDi näen. Arusaamatu.
Nii, kui ma ühendan digiboxi arvuti ekraani taha, siis sama jama.
Arvutil HDMI väljundit polegi, nii et ei saa testida. Aga huvitav probleem igal juhul.
Lahendus on ilmselt ikkagi AV kasutada ja kogu muusika.
Aitäh
Ivar
150 |
TT
15.09.2015 18:56:37
HUD ei käi vast HDCP alla(koopiakaitse puudub).
276 |
IffikaS
15.09.2015 19:02:19
| TT kirjutas: |
| HUD ei käi vast HDCP alla(koopiakaitse puudub). |
Mnjah, tundub et nii see ilmselt vast ongi.
Keegi puusalt oskab kirjutada, mis kaabel mulle sinna AV'sse sobib.
Ivar
150 |
725 |
TT
15.09.2015 19:54:24
| IffikaS kirjutas: |
| TT kirjutas: |
Ivar |
Projektori ja digiboksi mudel? Nende järgi saab parima lahenduse vaadata.
Digiboksi leidsin, ühes juhendis kirjutab, et optional variandina on kaasas component kaabel. Selline kaabel peaks ülemineku ja projektori vahele minema https://en.wikipedia.org/wiki/Component_video.
276 |
725 |
IffikaS
16.09.2015 00:43:21
| laurx kirjutas: |
| starboxi scart on natuke eriline. suvalise sama pin layoudiga asjaga ei saa. rävalast tuleb seda kaablit küsida aga maksab 10€. |
Äkki oskad öelda ka seda kui pikk see kaabel on?
PIN layout on muidu selline: http://pinoutsguide.com/Multimedia/intek_AV_pinout.shtml
Ivar
150 |
725 |
abman
22.12.2016 17:21:47
StarBox scart ainult RCA telerile |
Siin nagu teadjaid selle StarBox scartist!
Teleril ainult 3RCA pesa, seega ainult COMPOSITE signaali sisend olemas.
Kas sellest piisab või vaja ka ülejäänud signaale, RGB jne ehk scart sisendiga telerit?
Boksi HADMI-s on juba LCD teler.
Tuli mõte, et paneks scart taha teise toa vana teleka
ja juhiks boksi mingi sarnase IR-repeateri kaudu.
725 |
abman
22.12.2016 19:08:53
| laurx kirjutas: |
| probleemiks võib saada PAL / NFSC |
Ja-ah! Nii ongi, ei tabanud kohe ära, ainult RGB kaudu saaks pildi ette ilma PAL-ita!
Kui juba mingi muundi muretseda siis Wireless ja et IR käiks kah selle kaudu.
Meil selliseid vidinaid ei müüda, ainult Aliexpres-ist tellimisega.
22.12.2016 19:55:12
ma olen neid ühendanud, kui telekas on üks / teine, hakkab "viskama". aitab kui telekast ringi lülitada või starbox mõne teise ekraani külge panna ja lülitada. . rca tekitamiseks kasutatavad scart ema-ema ja scart rca on tavalised "oomipoe" jullad. kuskilt "älist" neid tellima ei pea.
725 |
abman
23.12.2016 14:38:44
| laurx kirjutas: |
| ma olen neid ühendanud, kui telekas on üks / teine, hakkab "viskama". aitab kui telekast ringi lülitada või starbox mõne teise ekraani külge panna ja lülitada. . rca tekitamiseks kasutatavad scart ema-ema ja scart rca on tavalised "oomipoe" jullad. kuskilt "älist" neid tellima ei pea. |
Scart ema-ema vajalike signaalide kokkutinutamine pole mingi probleem, Serigost ostsin emaseid juba nädal tagasi.
Kahjuks Scart 64 oli otsas. Pühade ajal aega nikerdada.
Aga Aliexpressi mainisin selliste vidinate pärast.
Tegelikult ju kui juttu COMPOSITEST siis peaks ta vunkama, on ju digifotokatelgi see väljund ja menüüs valik PAL/NTSC, mida olen kasutanud.
Paistab, et on võimalik se idee realiseerida ka selle vana romuga.
Tänud info eest!
