SilQ
03.06.2015 14:15:06
| caramis kirjutas: |
Devilid pole never ilusad olnud |
Üsna imelik näeb välja jah, samas sellel isendil on 6+8 pinni ehk 300W max.
215 |
Scart
03.06.2015 14:29:34
AMDi prosed on ka maailma kiireimad by far - gigahertsinumbris, mitte jõudluses
101 |
SilQ
03.06.2015 14:32:44
| Scart kirjutas: |
AMDi prosed on ka maailma kiireimad by far - gigahertsinumbris, mitte jõudluses  |
Mille põhjal sa nüüd seda infot ütled? Sul kodus 390X olemas, et saad võrrelda?
215 |
Scart
03.06.2015 14:45:54
| SilQ kirjutas: |
Mille põhjal sa nüüd seda infot ütled? Sul kodus 390X olemas, et saad võrrelda? |
Loogiliselt mõeldes võiks ju ometi tüüpilisest PR-spinnist läbi näha? Täpselt nagu AMDi prosed on maailma kiireimad, mitte ükski Inteli tootepagasis olev prose ei saavuta AMDi toodanguga ligilähedaseltki samu gigahertse aga näed, jõudlus selle kiiruse taga on hoopis teine faktor. See what I did there?
http://www.sweclockers.com/nyhet/20607-amd-radeon-fiji-positioneras-mot-geforce-gtx-980-ti
Nvidia decided to bring forward the launch of the GeForce GTX 980 Ti to make life miserable for AMD and put a spoke in the wheels for the next generation Radeon is hardly a secret. The idea is that from the outset put competitor at a disadvantage and force economically vulnerable AMD once again cut into margins.
Now it looks like that this strategy may be about to succeed. Sources of vBulletin state that AMD will reposition the new flagship Radeon "Fiji" to meet the GeForce GTX 980 Ti in the price range "around $ 600". It is far from what was originally planned.
According partner manufacturers would Radeon "Fiji" contrary marketed as a more reasonable alternative to GeForce GTX Titan X. The new graphics card would offer similar performance at a lower price tag, though not as low as $ 649, that is what the GeForce GTX 980 Ti costs in the current situation .
Additional salt in the wounds come from AMD struggling with low yield, ie the percentage of usable circuits from production, and may be forced to postpone the introduction of the scaled-down versions of the graphics processor Fiji. Although the flagship steals most attention is usually downsized sibling models that account for the vast majority of sales.
The launch of the new Radeon 300 series takes place in connection with game exhibition E3 forward mid-June.
101 |
SilQ
03.06.2015 14:48:35
Scart,
Esiteks sinu pandud lingist ei saa sõnagi aru (pole just usaldust tekitav lehkt kah).
Teiseks näita mulle 2015 aasta linki kus öeldakse, et AMD on maailma kiireim prose.
Kolmandas loe spekulatsiooni artiklit uuesti, mitte pealkirja.
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
215 |
03.06.2015 14:52:22
| SilQ kirjutas: |
| caramis kirjutas: |
Üsna imelik näeb välja jah, samas sellel isendil on 6+8 pinni ehk 300W max. |
390x, pikk pcb. pakun, et 290x refresh.
_________________ - londiste
217 |
jt234
03.06.2015 15:06:42
| SilQ kirjutas: |
| Näita mulle 2015 aasta linki kus öeldakse, et AMD on maailma kiireim prose. |
Sõnastuse küsimus. Kiirust võib mõista kas jõudlusena (tehtud töö maht mingi ajaühiku kohta) või lihtsalt taktsagedusena.
Takti järgi peaks AMD kiireim olema hetkel FX-9590, mille 4,8 GHz-ni ei jõua minu teada stockis ükski Inteli prose.
_________________ Dima oli siin |
| Kommentaarid: 133 loe/lisa |
125 |
SilQ
03.06.2015 15:09:05
| jt234 kirjutas: |
| SilQ kirjutas: |
Takti järgi peaks AMD kiireim olema hetkel FX-9590, mille 4,8 GHz-ni ei jõua minu teada stockis ükski Inteli prose. |
Nõus, aga kus on seal lingil GPU ulme mhz? Mina ei näe. nVidial palju kõrgemad.
215 |
Scart
101 |
03.06.2015 17:27:37
mis sest pr-i jutust ülistada või maha teha. business as usual. oleks väga imelik kui amd vp oma tooteid taevani ei kiidaks.
217 |
03.06.2015 17:59:14
| Tomorrow kirjutas: |
Mis puutub Fury X vs 980Ti jõudlusesse, siis 290X hetke jõudluse defitsiit 980Ti-le on 27-29% sõltuvalt resost. FX kehvem ju ei tule, kui 290X, seega vahe ilmselt väheneb aga millise protsendini on iseasi.
Vaadates puhtalt arvutusüksuste põhjal:
290X: 2816
FX: 4096
On viimasel umbes 31% rohkem arvutusüksusi. Kas see just 31% kiiremaks muudab, kui 290X on iseasi, kuna toored draiverid, HBM ja ilmselt tõstetud jõudlus per üksus (GCN 1.3) on teadmata suurused hetkel mis võivad jõudlust veelgi tõsta. |
Wcctechi arvutus on muidugi parem, kuna nad arvestavad ka kellasid mitte ainult arvutusüksusi. Seega jah ma ei näe siin midagi võimatut selles, et FX võib tulla kiireim sGPU kaart. Küsimus ongi selles kas dariverid on piisavalt head, et mängudes see jõudlus maksma panna.
| Kommentaarid: 92 loe/lisa |
Scart
03.06.2015 18:10:50
| Rootslased väidetavalt lekitasid hinnad ning 290X respin koos kaheksa giga DDR5 VRAMiga maksab ~500 euri. Sealt edasi siis ainult Fiji.
101 |
SilQ
03.06.2015 18:43:22
Scart, Kust sa neid lehti leiad?
Rootsi leht on küll täielik BS.
Saksa omas ei viitsi isegi vaadata, et aru saada kas üldse tasub uskuda.
215 |
caramis
03.06.2015 18:48:50
| Scart kirjutas: |
| Rootslased väidetavalt lekitasid hinnad ning 290X respin koos kaheksa giga DDR5 VRAMiga maksab ~500 euri. Sealt edasi siis ainult Fiji. |
mida välismaal kirjutatakse, Scart-poiss usub. ütle, et siga lendab ja- oi raisk, lendabki
| Kommentaarid: 174 loe/lisa |
151 |
Braien
03.06.2015 18:58:46
Sounds legit, because from ".se"
90 |
Scart
03.06.2015 19:25:26
| SilQ kirjutas: |
Saksa omas ei viitsi isegi vaadata, et aru saada kas üldse tasub uskuda. |
Terve kuradi nett on seda inffi täis, vaata hoolikamalt - http://wccftech.com/amd-radeon-300-series-pricing-leaked-expensive-200-series/
Muidugi nimetada Sweclockeri lehte tundmatuks on päris kurb. Tegu on jätkuvalt ühe parima infolekitajaga, eriti just 300-seeria puhul.
101 |
SilQ
03.06.2015 19:32:15
| Scart kirjutas: |
| SilQ kirjutas: |
Muidugi nimetada Sweclockeri lehte tundmatuks on päris kurb. Tegu on jätkuvalt ühe parima infolekitajaga, eriti just 300-seeria puhul. |
Kurb? Loe mõnda muud artiklit. Päris masendav jutt, koolipoisid vist teevad seda.
215 |
Kristoferr
| Kommentaarid: 269 loe/lisa |
220 |
Scart
03.06.2015 20:23:39
| SilQ kirjutas: |
Kurb? Loe mõnda muud artiklit. Päris masendav jutt, koolipoisid vist teevad seda. |
Sweclockersit? Kui sa ei märganud, siis kogu inglisekeelne tekst sealt saidilt on läbi Google-i tõlkija lastud
101 |
One
03.06.2015 22:32:37
NDA hoiab kuni lõpuni. Mitte nagu intelil et 2a varem juba kõik väljas ja prosed klokkuvad nagu noored jumalad.
Ainult, et õigel launchil ostab väino poest selle noore jumala ja asi klokkub nagu etkar savusaar.
Ühesõnaga seniks kuni mingit ametlikku ülevaadet pole ei tea mingid rootsi moslemid ega muud multikultid miskit.
Tuleb jama siis tuleb, vähemalt on proovitud miskit uut, nm nagunii sama ahi.
728 |
sooty
03.06.2015 22:50:43
On läbi käinud? Scarti möla ei viitsi filtrida
| Kommentaarid: 12 loe/lisa |
12 |
caramis
151 |
Scart
04.06.2015 11:13:08
See on ju juba kuid teada, et kõik alla Fiji on rebranded 2xx seeria.
101 |
caramis
04.06.2015 11:15:51
| Scart kirjutas: |
See on ju juba kuid teada, et kõik alla Fiji on rebranded 2xx seeria. |
ja mis selle Fiji tuumaga siis on? Fury? ainult? wat. arvasin senimaani, et sain AMD tulevasest lineupist aru, a hu*
151 |
04.06.2015 11:36:34
caramis, fury jah on fiji, kõik alla selle on rebrand + tuunitud vana.
182 |
caramis
04.06.2015 11:39:57
| rmc kirjutas: |
| caramis, fury jah on fiji, kõik alla selle on rebrand + tuunitud vana. |
johhaidii. olin nii kaua hyped mingi kaardi pärast, mida ma never ei oma nojah siis
151 |
NATAS999
04.06.2015 12:10:15
| caramis, ei noo aga esimene ainuõige reference jahutussüsteemiga teerajaja videokaartidele ja nüüd siis ei ostagi? ise veel nii haipisid seda, et parim asi enne viilutatud leiba. olen sinus pettunud.
| Kommentaarid: 41 loe/lisa |
39 |
anubis
04.06.2015 12:51:42
R-300 teema see siin siiski... mille referencejahutus on jätkuvalt hetkeandmetel AIO vesi.
See, mida tootjad rebrand kiipide jahutuseks tahavad kasutada on ka nende endi teema, omast kogemusest võin öelda, et R-200 on veeall hoopis teine kiip (ma ei räägi OCst), kuna AMD referencejahuti oli alamõõduline (ja seda sellepärast, et nad enne launchi keerasid volti-takti juurde, et perfi vs GTX780 parandada - läbinämmutatud teema).
283 |
caramis
151 |
SilQ
04.06.2015 13:46:54
| caramis kirjutas: |
| Scart kirjutas: |
ja mis selle Fiji tuumaga siis on? Fury? ainult? wat. arvasin senimaani, et sain AMD tulevasest lineupist aru, a hu* |
Sellest on ju juttu olnud küll ja küll, et 300 seeria lastakse täiega üle. Vahepeal oli juttu, et üldse ei lase 300 seeriat välja. Kogu aur läheb 400 peale kust tulevad kõik uued kivid, midagi ei rebrandita. 300 seeria ongi selline vahe katsetus uute mälude peal.
215 |
caramis
04.06.2015 16:26:07
| SilQ kirjutas: |
| caramis kirjutas: |
| Scart kirjutas: |
Sellest on ju juttu olnud küll ja küll, et 300 seeria lastakse täiega üle. Vahepeal oli juttu, et üldse ei lase 300 seeriat välja. Kogu aur läheb 400 peale kust tulevad kõik uued kivid, midagi ei rebrandita. 300 seeria ongi selline vahe katsetus uute mälude peal. |
et siis nagu uus, aga tegelt ei ole ka
151 |
SilQ
04.06.2015 16:31:23
| caramis kirjutas: |
| SilQ kirjutas: |
| caramis kirjutas: |
| Scart kirjutas: |
et siis nagu uus, aga tegelt ei ole ka |
Sama nagu 7xxx seerialt mindi üle 200'jale. Tipp saab edasi arenduse aga ülejäänud sama, 290X'st saab 380X jne. Et need kellel kaevurite käest odavalt 290X ja 280X kaardid ostetud, nendel ei tasu enne 400 seeriat midagi vahetada.
215 |
04.06.2015 16:32:45
SilQ, praeguse seisuga paistab, et 290x-st saab 390x.
217 |
SilQ
04.06.2015 16:37:50
| londiste kirjutas: |
| SilQ, praeguse seisuga paistab, et 290x-st saab 390x. |
Mälude uuendus ju ikka on? Kivi optimeerimine jne. Muu jääb samaks jah.
215 |
caramis
04.06.2015 17:00:30
| SilQ kirjutas: |
Mälude uuendus ju ikka on? Kivi optimeerimine jne. Muu jääb samaks jah. |
kui see "refresh" järelturu hindu mõjutab, siis tuleb R9 290 non-x crossfire poole liikuma hakata, raisk ma näen asju teisipidi, sorri
151 |
04.06.2015 17:11:40
SilQ, 8gb mälu on igal pool 390x külge kirjutatud, nii et seda vast jah.
loodetavasti gcn 1.2 uuendused ka (samad mis tongal) - mälusiini compression, parem tessellation, efficiency update ja mingi tõsine decode/multimeedia engine update vms.
caramis, järelturu hindu kuhu? 290d liiguvad (nii palju kui neid enam liigub) 180-200€. sealt allapoole ei saa väga liikuda.
217 |
04.06.2015 17:21:51
caramis, sa sellest saad aru, et 7XXX seeria läks edasi 2XX seeriaks? see ei ole midagi uut.
182 |
caramis
04.06.2015 17:56:37
| rmc kirjutas: |
| caramis, sa sellest saad aru, et 7XXX seeria läks edasi 2XX seeriaks? see ei ole midagi uut. |
7970=280X, mitte 290(x). R9 290 on juba uue arhidektuuriga ja see toetab ka DX12 oluliselt paremini kui 7900-seeria.
| caramis, järelturu hindu kuhu? 290d liiguvad (nii palju kui neid enam liigub) 180-200€. sealt allapoole ei saa väga liikuda. |
kunagi maksis GTX580 ka järelturul 150€
151 |
04.06.2015 18:29:30
mhmh, ainult, et hbm kaardid tulevad täiesti uue seeriana välja.. st. fury
182 |
Killhoven
OC`er
| Kommentaarid: 410 loe/lisa |
352 |
anubis
05.06.2015 11:00:16
GPUd mis väljatöötatud enne DX12 speccide lukustamist ei toeta kõiki DX12 funktisoone? Say it isnt so...
283 |
05.06.2015 11:01:44
see on non-issue, samamoodi nagu oli (üle)eelmine põlvkond nvidia 11.1 või 11.2 või misiganes asja puuduv toetus non-issue.
selleks ajaks kui uue dx kõrgema otsa featured mängudes asjakohased on, on uus põlvkond juba kindlasti väljas.
217 |
Teiv
05.06.2015 11:38:45
londiste, see on kahe otsaga asi.
See võib minna samamoodi nagu enne, aga võib ka juhtuda nii: kuna Nvidial on suur turuosa, siis ma leian et piisab 2-5 AAA mängust, mille puhul otsustatakse et me toetame neid feature'eid Nvidia puhul. Lihtsalt enamikel inimestel on nvidia kaart ja mängitakse selle peale.
Aga ma loodan et sul on õigus.
_________________ Black Edition |
69 |
05.06.2015 12:03:16
naljakas, et 7790 muust 7xxx seeriast uuemat asja toetab...
igatahes... hea, et "vana seeria" 12_0'gi toetab, samas tahaks teada kui keeruline oleks 12_1 toetama saada..
182 |
Teiv
69 |
Vael
05.06.2015 16:42:01
| Palju see dx12_1 jõudlust\silmailu juurde annab üldse? Või käib lihtsalt võidujooks, kes saab karbile rohkem silte kleepida?
| Kommentaarid: 17 loe/lisa |
16 |
Draco
05.06.2015 16:46:25
| Vael kirjutas: |
| Palju see dx12_1 jõudlust\silmailu juurde annab üldse? Või käib lihtsalt võidujooks, kes saab karbile rohkem silte kleepida? |
Pigem viimane. DX12 pole veel väljasgi, rääkimata mootoritest mis seda kasutab.
_________________ Purgatory Judgement |
12 |
Scart
101 |
tomm2n
| Kommentaarid: 159 loe/lisa |
149 |
