CoiL
12.04.2015 13:26:19
Piston 3 kohta natike esimesi muljeid:
- Piston 3 vs Piston 2 (modded w/o filter): P2 bass is more exaggerated and spills into lower mids, P2 mids are more recessed (v-shaped sound), and upper mids/treble sounds harsher and less organic. P2 staging is narrower.
- Piston 3 vs KZ EDSE: KZ has a stronger mid-bass punch where the bass hump is a little more dominant and mids pushed a little more back. Upper mids/treble in KZ is brighter and a little more detailed, though a bit harsher in comparison to P3. P3 soundstage is a little wider/deeper.
- Piston 3 vs VSD3: VSD3 has more sub-bass and faster/stronger mid-bass, slightly pushed back mids (in comparison to P3), brighter upper mids/treble. Soundstage is similar.
- Piston 3 vs E10: E10 has a little more sub-bass, a similar presentation of mids (though P3 is smoother), and a similar tuning of the treble. E10 soundstage is a little narrower and feels more intimate.
- Piston 3 vs KC06A: KC06A has more mid-bass punch, mids/treble are not as smooth - brighter and a bit more detailed (though less organic). Also, KC06A has less depth in soundstage. |
http://www.head-fi.org/products/xiaomi-pistons-3-0-in-ear-headphones/reviews/12868
| Kommentaarid: 95 loe/lisa |
83 |
Petz
13.04.2015 03:12:15
| mihkel7 kirjutas: |
| Petz kirjutas: |
| Kuna plaan on osta kõrvale hea mikrofon |
Kas määratlus "hea" sobib ikka konteksti, kus juttu 100-jüäänisest mikrofonist? Ühesõnaga, milleks seda mikrofoni vaja on? Skaibis juttu puhuda ilmselt kõlbab... |
Otsin ikkagi mängimiseks ja eks ta tundub mulle ka natuke imelik kuid aegajalt suudavad hiinlased pakkuda vägagi häid asju mõistliku hinnaga. |
Mägimiseks? Pilli või mängu mängimiseks?
Aga hiinlaste osas Sul õigus... oskavad asju teha vahel küll. Selle raha eest võib ju katsetada.
Ise leidsin ebayst normaalse hinnaga vanakooli Rode
Aga kisub offtopicuks... Kui mikrofonijuttu pikemaks jätkub, soovitan multimeedia foorumis teema üles võtta!
| Kommentaarid: 81 loe/lisa |
75 |
CoiL
83 |
Klots454
15.04.2015 22:54:52
| Head-fi müügiteemas tasub üldse ringi käia kui millegi vastu huvi on. Saab väga head kraami hea hinnaga.
| Kommentaarid: 40 loe/lisa |
38 |
kala1
26.04.2015 15:11:03
Kust siin kõige parem valik in-ear'e leidub ? nii tartus kohapealt kui epoest
_________________ M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier. |
| Kommentaarid: 52 loe/lisa |
48 |
CoiL
83 |
Peeter
04.05.2015 22:14:54
| Odavaima võimaliku toote otsinguil elus?
| Kommentaarid: 8 loe/lisa |
CoiL
04.05.2015 22:46:59
Ei, lihtsalt hobi korras. Iseenesest mulle piisab juba Piston2 + iBasso DX50 (custom tarkvara ja uuendatud kondekatega) helikvaliteedist. Aga kui võimalus veelgi odavamalt veelgi paremat saada (kui joppab), siis miks mitte? Ja kui ei kõlba, siis mul küllaga inimesi kellele neid kinkida ja rõõmu valmistada Enamjaolt on ikkagi tegu paremate nööpidega kui siinne odav toidupoe kraam (kallimad kui KZ).
83 |
libe
kvaliteetne mees
04.05.2015 22:59:00
selle raha eest, mis selle rämpsu osmisele oled pannud, oleksid juba saanud sellised klapid, mille peale pistonid kohe urni viskaksid
_________________ ☠ |
| Kommentaarid: 82 loe/lisa |
CoiL
04.05.2015 23:23:48
libe, no selleks, et ikka korralikuma IEM`i või isegi CIEM`i summat täis saada peaks ma ikka päris palju neid odav-nööpe ostma
Või mis klappidest räägid, mille pärast Pistonid urni viskaksin ja odav-kraami ostmata jätaksin?
Olen omajagu igasugu ülevaateid uurinud ja no ei ole nagu siiani miskit silma jäänud sellises hinnaklassis mida oleksin nõus välja käima. Küll on mõnel disainiga probleeme ja heli sobilik minu maitsele ja teisel jällegi vastupidi. Aga eks ma ükskord võtan miskid kallimad ka ligi, hetkel ei näe vajadust ja raha läheb ka pigem mujale ning see pisike rahasüst odav-nööpidesse omamoodi huvi/lõbu/hobi. Las "laps" mängib kui "laps" tahab
83 |
Petz
05.05.2015 11:49:10
CoiL, mõtlesin ka uudishimust mõned sellised hiinakad tellida, aga kumb variant eelmainitutest võiks sügavamalt kõrva ulatuda (st minu mõistes mugavamad)? Teine mudel tundub kahtlane selles suhtes... Ja kas need esimesed väga rasked metallikolakad pole? Pildilt tundub nii. 24g - on see normaalne kaal? Ei oska hinnata.
75 |
CoiL
05.05.2015 12:15:25
Ma ise tellisin just pigem need KZ ATE`d kuna ED9 on suht pisikesed ja ei istu toekalt kõrvas, lisaks metallist ja ilmselt raskevõitu kah. EDSE oli samuti liiga peenikese "kerega" ja raske (metall) ning ei püsinud mugavalt kõrvas - põhjus miks EDSE`d ära kinkisin. Mingeid kindlaid gramme ei oska küll öelda kustmaalt raskeks läheb.
Muidu kõrva peaks sügavamalt vast ED9 istuma aga piltide järgi tundub ATE suht ok olema. Aga kõik oleneb täiesti inimese kõrva kujust. Endale istusid HAVI B3 Pro1 suht hästi kõrvas ja sellepärast otsustasin ka pigem ATE kasuks. Heli suhtes on hetkel ATE suht tundmatu maa kuna ainult mõni üksik neid kuulda saanud. Helilava pidavat suure ulatusega olema ja esitus "mahedavõitu", ehk siis ei ole kriiskavaid kõrgeid ning sisinat (EDSE`l on näiteks see SSSsss sisin, eriti vokaalis).
Eks näis kui kätte saan kunagi. Hetkel jõuavad nad alles 7.mail edasimüüjale ja siis hakkavad tulema siiapoole.
83 |
182 |
CoiL
05.05.2015 14:46:13
| Kui ATE osutub jamaks ja Piston 3 ka proovitud saab, siis täitsa võimalik, et proovin ära.
83 |
05.05.2015 15:14:13
ei tea kaua see 50% kupong kehtib, though
182 |
Ramones
05.05.2015 18:12:06
Postikulu $6 - no deal.
| Kommentaarid: 76 loe/lisa |
75 |
heretic666
06.05.2015 13:00:51
Massdropi tulnud Aune T1 MK2 Tube DAC/AMP, lowest price oleks 150 USD, 15 lisa USD eest saad gold lion tube. Kahju ainult et 220V isendeid on aint hõbedasi saadaval, mitte musta värvi isendeid
| Kommentaarid: 73 loe/lisa |
CoiL
06.05.2015 15:10:29
Aune T1 on mõttekas UK`st tellida, saad värvi valida, 6922EH lambi lisaks stock lambile, EU toitekaabli (koos UK adaptriga) ja hind tuleb vaat et väiksemgi kuna tollimaksu ei ole. Ise tellisin UK eBay`st.
Gold Lion lamp on muuseas suht sarnase heliga 6922EH`le. Parem soovitan netist vastavalt kasutajate soovitustele NOS lampe jahtida odavalt. NOS Amperex OG ECC88 saab juba 20-30$ kandis kätte ja parema heliga kui gold lion. MK2 versioonil on lihtsalt non-synchronus USB ühendus (ei ole vist päris async) aga minu arvates ei muuda see midagi kuna endal ei ole mingeid probleeme jitteriga olnud. Suht mõttetu MK2-le raha panna kui MK1 odavam ja veel saadaval.
PS, mul Aune T1-le üle 70 lambi kogunenud ja kui kellelgi vaja enda omale paremat, siis võtke ühendust @ PS, saan oma kollektsioonist miskit mõistliku hinnaga loovutada ja enne proovida anda.
83 |
olavsu1
külaline
06.05.2015 19:13:12
ja ikka pole seda õiget leidnud?
heretic666
06.05.2015 20:32:22
| Tube rolling on vist suht hobi, ühe muusikastiili jaoks paned 1 kindla tube ja teise jaoks mingi muu.
Markos
07.05.2015 10:30:21
| Tekkis just tooteidee, "Tube flute", ehk siis lambiflööt. Paned oma 70 lampi kenasti ritta ja siis digitaalse selectoriga valid sobiva lambi. Sobib kasutamiseks ka jõulukaunistuseks aknalaual. Eritellimusel on võimalik valmistada ka kolmnurga, kuuse ja ristkülikukujulisi.
| Kommentaarid: 14 loe/lisa |
12 |
CoiL
08.05.2015 23:51:08
| olavsu1 kirjutas: |
ja ikka pole seda õiget leidnud? |
Muidugi olen - `65 Siemens E88CC goldpin grey shield. Aga jah, vastavalt muusikastiilile ja ka klappidele on väga häid lampe erinevaid.
Olen nad kõik üliodavalt saanud ja teagupärast NOS lampide hinnad aina tõusevad ja mul omajagu üpris haruldasi ja väärtuslikke lampe selles kollektsioonis.
Muidugi see eelmainitud Siemens on nö. "puhas kuld" lambimaailmas ja hind võtab suht köhima aga ise sain joppamisi 5tk miski 36€ eest
| Markos kirjutas: |
| Tekkis just tooteidee, "Tube flute", ehk siis lambiflööt. Paned oma 70 lampi kenasti ritta ja siis digitaalse selectoriga valid sobiva lambi. Sobib kasutamiseks ka jõulukaunistuseks aknalaual. Eritellimusel on võimalik valmistada ka kolmnurga, kuuse ja ristkülikukujulisi. |
Nii lihtne see vist kahjuks ei ole kuna iga lamp vajab siis nö. püsivat eelsoojendust, et neid A/B võrrelda. RG foorumis üks tegelane tegi minuteada A/B/X lambi selectori aga lihtne see ei olnud. Aga kui see oli sarkasm, siis lõpetame selle lambi teema siin. Eelnevalt juba kinnitust saanud, et see teema kisub siin mõttetuks vaidluseks. Muidu väike näide, et isegi hifiman EF1000 lipulaev kasutab 6x 6922 lampe, mis on sama tüüpi kui Aune T1`l (mitte, et see Aune T1 väärtust/helikvaliteeti tõstaks).
Edit:
Unustasin öelda, et KZ ED9 ja GR said ka ära tellitud ja ANV jõudis täna imekombel kohale (läks 34 tööpäeva aega). Muljetan mingi aeg hiljem aga esmamulje on hea, võiks öelda, et parem isegi kui EDSE ja ei ole SSSsss sisinat vokaalis. Üldiselt tegu hästi balansis ja neutraalse heliga nööpidega. Muuseas, korpus käib neil lihtsasti lahti ja saab keerata asendi vastavalt kõrva iseärasusele üle kõrva kandmiseks.
Edit2:
Natuke siis KZ ANV kohta muljeid. Nagu ennist öeldud sai on tegu hästi balansis ja neutraalse heliga nööpidega. Kõrgete sagedusala on väga hea ning mikro-detailid tulevad hästi esile. Bass on ka "tihke" ja täpne ning olemas kui vaja. Helilava on keskmisest suurem kuid tundub tiba kitsam kui EDSE`l. Instrumentide/helide eraldatus väga hea. Nende nööpide leivanumber on tegelikult trummi jms. löökinstrumentide puhtus, täpsus ja nö. tihedus. Vaatamata eelmainitud headele omadustele on minu subjektiivne arvamus, et miinuseks on kesksageduste madala otsa ja vb. isegi mid-bass`i liigne neutraalsus. Kuulates kontrabassi, saksofoni ja meesvokaali, siis jääb nö. soojusest ja dünaamikast tiba puudu, et tekiks loomuliku reaalse pilli/vokaali heli. Ühesõnaga head nööbid neile, kes otsivad taga väga neutraalset ja analüütilist heli aga isiklikult meeldivad ikkagi Piston 2 ja modifitseeritud R35 rohkem oma soojema kõlaga ning kübe loomutruuma kesksagedustega, olenemata sellest, et bassi on vb. tibake liiast. Lihtsalt P2/R35 haarab muusikaga kaasa aga ANV kuulates seda tunnet ei teki. On küll väga hea detailne puhas heli aga no ei kõla piisavalt naturaalselt.
83 |
W!ngs
09.05.2015 11:52:36
Käisin just oma Piston 3'l järgi. Esimesed hiinakad ja esmamulje on super arvestades oma hinda. Kuna ma ei oska kõige paremini heli kirjeldada, siis lühidalt, et heli on puhas ja mõnusalt tasakaalus erinevalt praegustest Sennheiseritest, kus bass kipub üle peksma ning mille võrra kipub muid helisid varju jätma. Ehituskvaliteet ja disain oma samuti kiiduväärt. Ideaalselt sobivad kõrva, summutab totaalselt ümbritsevad helid. Helinupud koos mikriga on tore lisa arvestades seda kuidas mulle meeldib lugusid vahetada helivolüümi nuppudega, enam ei pea telefoni taskus näppima.
Odavalt sain ka, ehk 20 eurot ja ~paarkümmend senti. Kui kedagi huvitab, siis ostsin siit: http://www.aliexpress.com/item/IN-STOCK-Newest-Original-Xiaomi-Piston-3-0-3-5mm-Xiaomi-Standard-Edition-Piston/32311652643.html Kiiduväärt, sõbralik müüja. Pildid on identsed sellega, mis kohale jõudis. Osad said juba paari nädala oma kõrvaklapid kätte, minul läks natuke alla kuu.
| Kommentaarid: 23 loe/lisa |
23 |
CoiL
09.05.2015 12:35:00
| W!ngs, ibuygou`st saab kiiremini ja vist isegi odavamalt.
83 |
krist2an
09.05.2015 16:15:54
| W!ngs kirjutas: |
Odavalt sain ka, ehk 20 eurot ja ~paarkümmend senti. Kui kedagi huvitab, siis ostsin siit: http://www.aliexpress.com/item/IN-STOCK-Newest-Original-Xiaomi-Piston-3-0-3-5mm-Xiaomi-Standard-Edition-Piston/32311652643.html Kiiduväärt, sõbralik müüja. Pildid on identsed sellega, mis kohale jõudis. Osad said juba paari nädala oma kõrvaklapid kätte, minul läks natuke alla kuu. |
Huhh.... siin teemas tõelised heligurmaanid koos, kuidas sa julged üldse 20€ maksvate klappidega kiidelda? Alla 100€ maksvad klapid on kõik kräpp ju. Sest et esiteks, maksavad vaid 20€, teiseks need on pärit Aasiast ja kolmandaks neil pole tuntud firmamärki peal. Eriline idioot on CoiL kes oleks võinud ammu korralikud Sennheiserid või Beyerid osta selle raha eest, mis ta Hiina jurakate alla on pannud.
Sarkasm. Lihtsalt seda teemat lugedes jääb täpselt selline mulje tänu mõnedele kasutajatele. Tegelikult on tore kuulda, et Piston 3 ka lippu kõrgel hoiab, peab varsti ka ära tellima.
| Kommentaarid: 42 loe/lisa |
41 |
libe
kvaliteetne mees
09.05.2015 16:44:41
| krist2an kirjutas: |
| Sarkasm. Lihtsalt seda teemat lugedes jääb täpselt selline mulje tänu mõnedele kasutajatele. Tegelikult on tore kuulda, et Piston 3 ka lippu kõrgel hoiab, peab varsti ka ära tellima. |
see, kui internetis rohkete inimeste poolt kiidetakse mingeid odavaid klappe, ei tähenda kindlasti seda, et tegu on hea heliga klappidega, see tõestab vaid seda, et inimesed, kes nood ostnud on, on rahul - hoopis iseasi on, mis nende võrdlusmoment on
20€ on paljude jaoks väga kallid klapid ja nondele tõenäoliselt on helikvaliteet midagi ennekuulmatut
oli ka mul aegu, kus tugev bass oli ainus argument ja mida rohkem seda parem - isegi kui oli umbne kumisev bass
nööpide puhul ma ei eeldagi mingit suuremat kvaliteeti, kuid siiani proovitud klappidel on kõigil heli võrdlemisi kehv, enamasti puhas pask
Smuul
09.05.2015 17:31:55
Varem olin minagi selline mitte eriti helikvaliteedist huvitatud, pigem bassi tagaajav. Selleks olid mul 3-4 aastat Sony XB500 klapid. Väga mõnus soe, mitte kõrvukriipiv heli, isegi kõige kõrgemate helitugevuste juures (kunagi sai kuulatud päris valjult, pärast tinnituse tekkimist tõmbasin kõvasti tagasi ). Paljud aktiivsemad Head-Fi tegelased kiitsid ja soovitasid. Siiani kasutan aegajalt, kui tantsumuusikast rohkem seda fiilingut tahan .
Nüüd juba Sennheiser HD598 omanik. Algul olin nii pettunud, kehvad kõrvad, harjunud EDM ja muu säärase plämaga. Kuid pika peale harjusid kõrvad sirgemajoonelise heliga ära ja ei taha üldse muud kasutada. Väga hea "soundstage"(avatud klapid kah, loogiline ). Filmides ja kehva "mastering'iga" lugudes võib aint see kõrgem 15khz kanti vilin välja tulla, olgu need lood iTunesist, filmid päris oma BluRayl või tõmmatud, aegajalt ikka kuulda seda(oleneb vast ka DAC-ist või mis iganes asjast tuleb). Muidu väga terav ja täpne heli. Väga mugavad, peale 5-10 mintsa unustab need üldse ära, et peas on.
Sai ka Shure SE215 in earid ostetud, äärmiselt mugavad, head "memory" kaablid ja vahetatavad kah. Tavaliselt telefonis keeran natuke kõrgeid helisid ülespoole, et keskmised kõrvu ei lõhuks liialt, pole vb lihtsalt harjunud sellise keskmise heliala tugevusega. Pole küll nii head kui mõned armatuurid, kuid dünaamiliste kohta pole üldse paha.
Heli arvutist tuleb Focusrite Scarlett 2i2'st, kõvasti parem heli kui see, mis onboardist tuleb. Ja kaasaskantav on Samsung Galaxy Note 3 ilma lisadeta.
libe
kvaliteetne mees
18.05.2015 23:04:13
ostsin siis creative soundblaster ZxR'i ära lõpuks
toidab klappe ikka hoopis mõnusamalt
too lugu kõlab hoopis bassirohkemalt, samas bass on väga sume mõnus, sulnis
loost muidu lugu ei pea, rütm pole just minu jaoks, kuid kõla on küll mõnus
CoiL
21.05.2015 09:54:41
Lihtsalt infoks ,et KZ ATE saab Head-fi foorumis suht head tagasisidet ja pidavat ED9-ga "samal tasemel" olema aga teistsuguse helisignatuuriga. Piston3-ga võrreldes pidavat kesksagedused paremad olema, vokaalile hästi sobima ja vähem V-kujulise helisignatuuriga. Üks seal kiidab ka võrreldes IE80-ga, pidavat üpris sarnase heliga olema (kahjuks võrdlus läpaka helikaardiga). Avara helipildiga. Kaalult pidavat ka head kerged olema.
Enda omad ei ole veel kohale jõudnud, et kiidulaulu kinnitada/ümber lükata aga ilmus ka müüki läbipaistev-must: http://www.aliexpress.com/store/product/KZ-ATE-Copper-Driver-Ear-Hook-HiFi-In-Ear-Earphone-Sport-Headphones-For-Running-With-Foam/1358152_32337313320.html
viimati muutis CoiL 21.05.2015 17:30:05, muudetud 1 kord |
83 |
dex
21.05.2015 10:21:56
Võtsin omale töö juurde ka need palju kiidetud mänguriklapid Kingston HyperX Cloud stereo variandid. Peab tunnistama, et on tõesti head asjad. Veits liiga edevad näevad välja töö jaoks, aga lync/skype koosolekuid pidada, telefoniga rääkida ja spotifyd kuulata on päris mõnus. Enne olid mingid odavad ligitechi junnid ja peale vahetust rääkisid teised koosoleku osapooled ka, et sind on täna kuidagi maruhästi kuulda, taustamüra pole jne.
_________________ Süümi, juumi, makkami ja kui tüüle nakkami... |
| Kommentaarid: 97 loe/lisa |
86 |
krist2an
21.05.2015 14:50:42
Tellisin ka ära, 9€ eest võib ju proovida
41 |
heikis
21.05.2015 17:14:42
tellisin ka ühe mikriga paari. kas nende odavate hiinakate puhul on juhtmesse integreeritud mikker pigem miinus- rohkem jootekohti, õrnam juhe?
| Kommentaarid: 338 loe/lisa |
290 |
CoiL
21.05.2015 17:27:52
Mikrit ei kasuta ja minu jaoks pigem miinuseks. Endale sai hõbedane variant ilma mikrita tellitud, siis veel ei olnud musta läbipaistvat saada.
Muuseas, võtsin siin oma pekki läinud Piston2 juhtmed lahti ning kõik kinnituskohad, mikri ja ka elementide juures on nö. press-klambritega mitte joodetud
Vähemalt niipalju kui silm näeb ei tuvasta küll jootekohti. Ilmselt seetõttu tõmbasingi ühe kanali kogemata tagant ära. Imepeenikesed juhtmed kah seest
83 |
olavsu1
külaline
21.05.2015 18:39:08
soonte otsad peaks ikka tinatatud olema. muidu ei anna pressklambrit nii hästi juhtmeotsa kinnivaltsida, et see sinna jääks.
Rand0m
21.05.2015 19:05:44
Tellisin ka ära, 9€ eest võib ju proovida  |
Double that!
Loodan, et kvaliteedilt ja vastupidavuselt küündivad vähemalt Piston v2-de tasemele.
| Kommentaarid: 6 loe/lisa |
CoiL
21.05.2015 21:54:19
Mainin lisaks, et seniste kommentaaride põhjal soovitatakse ATE puhul suurema avaga ja mitte-vaht otsikuid kasutada, muidu pidavat kõrged tiba "tahaplaanile" jääma ja nö."flat" kõlama. Muuseas kes muretseb, et nozzle pikkus jääb lühikeseks, siis ATE puhul ei tohiks seniste kasutajate piltide põhjal küll probleemi olla.
KZ ANV on näiteks liiga lühikese toruga, isegi minu pisemat sorti kõrvadele aga lahenduseks pikemad otsikud või double/triple-flange otsikud.
Aga kes soovib neid odav-nööpe veel proovida, siis ärge kindlasti välistage ED9`t, see saab hetkel kõige rohkem kiidulaulu ja peetakse siiani parimaks KZ nööbiks. ATE`l pidavat lihtsalt teistsugune helisignatuur olema. Ise tellisin mõlemad. Eks annan ka omalt poolt tagasisidet.
| olavsu1 kirjutas: |
soonte otsad peaks ikka tinatatud olema. muidu ei anna pressklambrit nii hästi juhtmeotsa kinnivaltsida, et see sinna jääks. |
Ilmselt küll. Ei saa enam kontrollida ka kuna viskasin kaabli ära (mikrist ülespoole olevad osad).
83 |
markedmen
21.05.2015 23:04:59
Tellisin ka mõlemad ära. Pistoneid pole kunagi proovida saanud, jään huviga ootama, kuidas nad võrreldes JVC HA-FXD80-ga on
| Kommentaarid: 7 loe/lisa |
22.05.2015 13:42:42
mida te €9'ga tellite? ~25 usd hind ju
182 |
s6dalane
22.05.2015 13:58:23
| Oskab keegi soovitusi anda, milliseid klappe osta 30-50 € eelarvega? Võiksid olla mikrofoniga, samas, kui on midagi tunduvalt paremat ilma mikrofonita, siis pakub ka huvi. Täpsustavad tingimused oleksid veel, et kõrvapealsed ja juhtmega (3.5 mm).
| Kommentaarid: 15 loe/lisa |
15 |
heikis
22.05.2015 14:06:29
| rmc kirjutas: |
mida te €9'ga tellite? ~25 usd hind ju  |
Ostukorvi lisatuna saad discounti
290 |
CoiL
27.05.2015 18:18:24
Sain ED9 kätte ja kinnitan, et tegu hea helikvaliteediga. Hetkel minu jaoks parim KZ nööp. Tellisin siit ja tuli üsna kiiresti kohale, tiba üle kahe nädala: http://www.aliexpress.com/item/2015-New-Arrival-Original-KZ-ED9-3-5mm-in-ear-Earphones-Heavy-Bass-HIFI-DJ-Stereo/32322495771.html
Heli suhtes paremad kui Piston2 ja EDSE ning vahetatavate otsikutega saab vastavalt maitsele ka sättida
Endale meeldib hetkel selline filtri variant kõige rohkem: kuldse filtri svammid mattide filtrite põhjas võre vastu.
Edit:
| Mida rohkem nendega kuulan, siis üha rohkem saan aru kuidas Piston2 "halastas" tibakenegi kehvema masterdusega salvestustele. ED9 on väga "paljastav" selles suhtes ja heli resolutsioon on üsna hämmastav sellise odava nööbi kohta. Väga hea helide/instrumentide eraldatus ja puhas selge detailne helipilt. Heliruumi avarus ka tunduvalt parem kui Piston2`l. |
Tulid samasuguses mustas karbis nagu siin (võtsin ilma mikrita): http://www.head-fi.org/t/698148/knowledge-zenith-kz-impressions-thread/3945#post_11628240
11,5€ eest soovitan kindlasti Minu jaoks uus IEM säästu-kunn.
Edit2:
Üks värske lühiülevaade ka KZ ATE ja KZ ED9 kohta: http://www.head-fi.org/t/698148/knowledge-zenith-kz-impressions-thread/4020#post_11638199
Võrdluses ka IM50, VSD3, KC06A, Pistons 2 ja EDSE.
Edit3:
Sain KZ ATE kah kätte ja mis siin ikka öelda kui et KZ paugutab häid nööpe "nagu seeni peale vihma"
ATE`d megakerged, pika nozzle`ga ja istuvad väga mugavalt kõrvas, kaabel hea ja kaalud üle kõrva kandmiseks väga hästi paigas.
Heli puhas, õhuline ja detailne, suur heliruum. Ütleks et tegu üsna hästi balansis ja neutraalse heliga aga mitte nö. külma-kõlalised. Mikro-detailide suhtes on ED9 parem aga ilmselt tänu sellele, et ATE kõrged on kergelt "pehmendatud" ja väga nauditav kuulata - pikemal kuulamisel ei teki ilmselt mingisugust nö. kuulmis-väsimust.
Soovitan mõlemaid, ATE ja ED9 proovida! Piston2 on minu jaoks igatahes "surnud" kraam.
83 |
heretic666
CoiL
27.05.2015 21:35:43
Ainult x86?
83 |
libe
kvaliteetne mees
pots4t4j4
27.05.2015 23:30:24
Juhtusin apple earpodse proovima, ja ei ütleks, et nad väga halvasti kõlasid üllatavalt kuulatavad isegi
401 |
CoiL
28.05.2015 23:33:45
Kes siinsetest ATE tellisid, siis soovitan nö. grill-mod teha. Ja kui bassi/trummi "mütsust" väheks jääb, siis torude kaelal asuvad pisikesed õhuaugud kinni panna:
See oli lihtsalt katsetus. Õiged katted tulevad puidust ja teise võrega siis kui mmcx otsad ja asenduskaablid kätte saan.
83 |
libe
kvaliteetne mees
28.05.2015 23:48:36
tellisin jah, mingid 2 paari, paistab, kuidas nad praeguste solidega võrreldavad on
182 |
CoiL
29.05.2015 09:54:57
Discount lõppes ära minuteada. Tuleb ilmselt tiba oodata ja saab jälle discounti. Endal ka plaanis läbipaistvad mustad 2tk tellida ja nood ka ära modida.
Muuseas, ED9 on praegu megaodavalt müügil (~5.7€): link
83 |
Tshaika
29.05.2015 13:14:54
Omasin Sony XB700-t, bassi bängis nii et lõi nohuse nina puhtaks.
aastaid hiljem nüüd on mul jälle siin kõvad nohuhood ja bassi vajadus tekkis. Mida hetkel minusugust bassiarmastajatele pakutakse umbes 100-140 euri eest? sonyl mingi uus seeria XB välja tuld, ei ole usku nendesse, kogemusi? soovitusi?
| Kommentaarid: 28 loe/lisa |
28 |
