uus teema   vasta Vaidlused »  Võitlustanner »  Millised kõrvaklapid? märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 120, 121, 122 ... 225, 226, 227  järgmine
CoiL
CoiL
sõnum 12.04.2015 13:26:19 vasta tsitaadiga
Piston 3 kohta natike esimesi muljeid:
- Piston 3 vs Piston 2 (modded w/o filter): P2 bass is more exaggerated and spills into lower mids, P2 mids are more recessed (v-shaped sound), and upper mids/treble sounds harsher and less organic. P2 staging is narrower.
- Piston 3 vs KZ EDSE: KZ has a stronger mid-bass punch where the bass hump is a little more dominant and mids pushed a little more back. Upper mids/treble in KZ is brighter and a little more detailed, though a bit harsher in comparison to P3. P3 soundstage is a little wider/deeper.
- Piston 3 vs VSD3: VSD3 has more sub-bass and faster/stronger mid-bass, slightly pushed back mids (in comparison to P3), brighter upper mids/treble. Soundstage is similar.
- Piston 3 vs E10: E10 has a little more sub-bass, a similar presentation of mids (though P3 is smoother), and a similar tuning of the treble. E10 soundstage is a little narrower and feels more intimate.
- Piston 3 vs KC06A: KC06A has more mid-bass punch, mids/treble are not as smooth - brighter and a bit more detailed (though less organic). Also, KC06A has less depth in soundstage.
http://www.head-fi.org/products/xiaomi-pistons-3-0-in-ear-headphones/reviews/12868
Kommentaarid: 95 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 83
Petz
sõnum 13.04.2015 03:12:15 vasta tsitaadiga
mihkel7 kirjutas:
Petz kirjutas:
Kuna plaan on osta kõrvale hea mikrofon
Kas määratlus "hea" sobib ikka konteksti, kus juttu 100-jüäänisest mikrofonist? icon_wink.gif Ühesõnaga, milleks seda mikrofoni vaja on? Skaibis juttu puhuda ilmselt kõlbab...
Otsin ikkagi mängimiseks ja eks ta tundub mulle ka natuke imelik kuid aegajalt suudavad hiinlased pakkuda vägagi häid asju mõistliku hinnaga.
Aga hiinlaste osas Sul õigus... oskavad asju teha vahel küll. Selle raha eest võib ju katsetada.
Aga kisub offtopicuks... Kui mikrofonijuttu pikemaks jätkub, soovitan multimeedia foorumis teema üles võtta!
CoiL
CoiL
sõnum 14.04.2015 23:56:08 vasta tsitaadiga
AKG K7XX hea hinnaga EU siseselt müügil: http://www.head-fi.org/t/762744/akg-k7xx
Ise olen sellelt kasutajalt Fidelio X1 ostnud ning soovitan temaga diili teha thumbs_up.gif
Klots454
sõnum 15.04.2015 22:54:52 vasta tsitaadiga
Head-fi müügiteemas tasub üldse ringi käia kui millegi vastu huvi on. Saab väga head kraami hea hinnaga.
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 38
kala1
kala1
sõnum 26.04.2015 15:11:03 vasta tsitaadiga
Kust siin kõige parem valik in-ear'e leidub ? nii tartus kohapealt kui epoest
M: LG 29wk500-p
The German soldier has impressed the world, however the Italian Bersagliere soldier has impressed the German soldier.
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 45
CoiL
CoiL
sõnum 04.05.2015 10:11:41 vasta tsitaadiga
Kes veel kursis ei ole siis hiina odav-bränd KZ on vahepeal uut head kraami välja lasnud:
KZ ED9, mis mõnede sõnul parema heliga isegi kui uus Piston 3 ja keermega eemaldatavad filter-otsad:
13,64$:
http://www.aliexpress.com/item/2015-New-Arrival-Original-KZ-ED9-3-5mm-in-ear-Earphones-Heavy-Bass-HIFI-DJ-Stereo/32322495771.html?spm=2114.32010308.4.2.OvuCA0
Ja siis kõige uuem üllitis, mis tundub olevat disaini poolest ATH-IM50 koopia ning eemaldatavate kaablitega:
18,90$ :
link
Ise kavatsen ilmselt mõlemad tellida. Kahjuks hiina post on paras loterii. KZ ANV jäigi kohale tulemata aga eks ma avan dispute aliexpressis ja kunagi saab uued vast takkajärgi.
Peeter
sõnum 04.05.2015 22:14:54 vasta tsitaadiga
Odavaima võimaliku toote otsinguil elus?
CoiL
CoiL
sõnum 04.05.2015 22:46:59 vasta tsitaadiga
Ei, lihtsalt hobi korras. Iseenesest mulle piisab juba Piston2 + iBasso DX50 (custom tarkvara ja uuendatud kondekatega) helikvaliteedist. Aga kui võimalus veelgi odavamalt veelgi paremat saada (kui joppab), siis miks mitte? icon_smile.gif Ja kui ei kõlba, siis mul küllaga inimesi kellele neid kinkida ja rõõmu valmistada icon_wink.gif Enamjaolt on ikkagi tegu paremate nööpidega kui siinne odav toidupoe kraam (kallimad kui KZ).
libe
kvaliteetne mees
libe
sõnum 04.05.2015 22:59:00 vasta tsitaadiga
selle raha eest, mis selle rämpsu osmisele oled pannud, oleksid juba saanud sellised klapid, mille peale pistonid kohe urni viskaksid
CoiL
CoiL
sõnum 04.05.2015 23:23:48 vasta tsitaadiga
libe, no selleks, et ikka korralikuma IEM`i või isegi CIEM`i summat täis saada peaks ma ikka päris palju neid odav-nööpe ostma icon_biggrin.gif
Või mis klappidest räägid, mille pärast Pistonid urni viskaksin ja odav-kraami ostmata jätaksin? icon_smile.gif
Olen omajagu igasugu ülevaateid uurinud ja no ei ole nagu siiani miskit silma jäänud sellises hinnaklassis mida oleksin nõus välja käima. Küll on mõnel disainiga probleeme ja heli sobilik minu maitsele ja teisel jällegi vastupidi. Aga eks ma ükskord võtan miskid kallimad ka ligi, hetkel ei näe vajadust ja raha läheb ka pigem mujale ning see pisike rahasüst odav-nööpidesse omamoodi huvi/lõbu/hobi. Las "laps" mängib kui "laps" tahab icon_biggrin.gif beer_yum.gif
Petz
sõnum 05.05.2015 11:49:10 vasta tsitaadiga
CoiL, mõtlesin ka uudishimust mõned sellised hiinakad tellida, aga kumb variant eelmainitutest võiks sügavamalt kõrva ulatuda (st minu mõistes mugavamad)? Teine mudel tundub kahtlane selles suhtes... Ja kas need esimesed väga rasked metallikolakad pole? Pildilt tundub nii. icon_smile.gif 24g - on see normaalne kaal? Ei oska hinnata.
CoiL
CoiL
sõnum 05.05.2015 12:15:25 vasta tsitaadiga
Ma ise tellisin just pigem need KZ ATE`d kuna ED9 on suht pisikesed ja ei istu toekalt kõrvas, lisaks metallist ja ilmselt raskevõitu kah. EDSE oli samuti liiga peenikese "kerega" ja raske (metall) ning ei püsinud mugavalt kõrvas - põhjus miks EDSE`d ära kinkisin. Mingeid kindlaid gramme ei oska küll öelda kustmaalt raskeks läheb.
Muidu kõrva peaks sügavamalt vast ED9 istuma aga piltide järgi tundub ATE suht ok olema. Aga kõik oleneb täiesti inimese kõrva kujust. Endale istusid HAVI B3 Pro1 suht hästi kõrvas ja sellepärast otsustasin ka pigem ATE kasuks. Heli suhtes on hetkel ATE suht tundmatu maa kuna ainult mõni üksik neid kuulda saanud. Helilava pidavat suure ulatusega olema ja esitus "mahedavõitu", ehk siis ei ole kriiskavaid kõrgeid ning sisinat (EDSE`l on näiteks see SSSsss sisin, eriti vokaalis).
Eks näis kui kätte saan kunagi. Hetkel jõuavad nad alles 7.mail edasimüüjale ja siis hakkavad tulema siiapoole.
sõnum 05.05.2015 14:24:43 vasta tsitaadiga
CoiL, vb. vesi sinu veskile: http://www.gizchina.com/2015/05/05/get-a-pair-of-huawei-honor-earphones-for-just-8/
"Get a pair of Huawei Honor earphones for just $8"
CoiL
CoiL
sõnum 05.05.2015 14:46:13 vasta tsitaadiga
Kui ATE osutub jamaks ja Piston 3 ka proovitud saab, siis täitsa võimalik, et proovin ära.
sõnum 05.05.2015 15:14:13 vasta tsitaadiga
Ramones
Ramones
sõnum 05.05.2015 18:12:06 vasta tsitaadiga
rmc kirjutas:
Postikulu $6 - no deal.
heretic666
heretic666
sõnum 06.05.2015 13:00:51 vasta tsitaadiga
Massdropi tulnud Aune T1 MK2 Tube DAC/AMP, lowest price oleks 150 USD, 15 lisa USD eest saad gold lion tube. Kahju ainult et 220V isendeid on aint hõbedasi saadaval, mitte musta värvi isendeid icon_sad.gif
CoiL
CoiL
sõnum 06.05.2015 15:10:29 vasta tsitaadiga
Aune T1 on mõttekas UK`st tellida, saad värvi valida, 6922EH lambi lisaks stock lambile, EU toitekaabli (koos UK adaptriga) ja hind tuleb vaat et väiksemgi kuna tollimaksu ei ole. Ise tellisin UK eBay`st.
Gold Lion lamp on muuseas suht sarnase heliga 6922EH`le. Parem soovitan netist vastavalt kasutajate soovitustele NOS lampe jahtida odavalt. NOS Amperex OG ECC88 saab juba 20-30$ kandis kätte ja parema heliga kui gold lion. MK2 versioonil on lihtsalt non-synchronus USB ühendus (ei ole vist päris async) aga minu arvates ei muuda see midagi kuna endal ei ole mingeid probleeme jitteriga olnud. Suht mõttetu MK2-le raha panna kui MK1 odavam ja veel saadaval.
PS, mul Aune T1-le üle 70 lambi kogunenud ja kui kellelgi vaja enda omale paremat, siis võtke ühendust @ PS, saan oma kollektsioonist miskit mõistliku hinnaga loovutada ja enne proovida anda.
olavsu1
külaline
sõnum 06.05.2015 19:13:12 vasta tsitaadiga
ja ikka pole seda õiget leidnud?
heretic666
heretic666
sõnum 06.05.2015 20:32:22 vasta tsitaadiga
Tube rolling on vist suht hobi, ühe muusikastiili jaoks paned 1 kindla tube ja teise jaoks mingi muu.
Markos
sõnum 07.05.2015 10:30:21 vasta tsitaadiga
Tekkis just tooteidee, "Tube flute", ehk siis lambiflööt. Paned oma 70 lampi kenasti ritta ja siis digitaalse selectoriga valid sobiva lambi. Sobib kasutamiseks ka jõulukaunistuseks aknalaual. Eritellimusel on võimalik valmistada ka kolmnurga, kuuse ja ristkülikukujulisi.
CoiL
CoiL
sõnum 08.05.2015 23:51:08 vasta tsitaadiga
olavsu1 kirjutas:
Muidugi olen - `65 Siemens E88CC goldpin grey shield. Aga jah, vastavalt muusikastiilile ja ka klappidele on väga häid lampe erinevaid.
Olen nad kõik üliodavalt saanud ja teagupärast NOS lampide hinnad aina tõusevad ja mul omajagu üpris haruldasi ja väärtuslikke lampe selles kollektsioonis.
Muidugi see eelmainitud Siemens on nö. "puhas kuld" lambimaailmas ja hind võtab suht köhima aga ise sain joppamisi 5tk miski 36€ eest icon_biggrin.gif
Markos kirjutas:
Nii lihtne see vist kahjuks ei ole kuna iga lamp vajab siis nö. püsivat eelsoojendust, et neid A/B võrrelda. RG foorumis üks tegelane tegi minuteada A/B/X lambi selectori aga lihtne see ei olnud. Aga kui see oli sarkasm, siis lõpetame selle lambi teema siin. Eelnevalt juba kinnitust saanud, et see teema kisub siin mõttetuks vaidluseks. Muidu väike näide, et isegi hifiman EF1000 lipulaev kasutab 6x 6922 lampe, mis on sama tüüpi kui Aune T1`l (mitte, et see Aune T1 väärtust/helikvaliteeti tõstaks).
Edit:
Unustasin öelda, et KZ ED9 ja GR said ka ära tellitud ja ANV jõudis täna imekombel kohale (läks 34 tööpäeva aega). Muljetan mingi aeg hiljem aga esmamulje on hea, võiks öelda, et parem isegi kui EDSE ja ei ole SSSsss sisinat vokaalis. Üldiselt tegu hästi balansis ja neutraalse heliga nööpidega. Muuseas, korpus käib neil lihtsasti lahti ja saab keerata asendi vastavalt kõrva iseärasusele üle kõrva kandmiseks.
Edit2:
Natuke siis KZ ANV kohta muljeid. Nagu ennist öeldud sai on tegu hästi balansis ja neutraalse heliga nööpidega. Kõrgete sagedusala on väga hea ning mikro-detailid tulevad hästi esile. Bass on ka "tihke" ja täpne ning olemas kui vaja. Helilava on keskmisest suurem kuid tundub tiba kitsam kui EDSE`l. Instrumentide/helide eraldatus väga hea. Nende nööpide leivanumber on tegelikult trummi jms. löökinstrumentide puhtus, täpsus ja nö. tihedus. Vaatamata eelmainitud headele omadustele on minu subjektiivne arvamus, et miinuseks on kesksageduste madala otsa ja vb. isegi mid-bass`i liigne neutraalsus. Kuulates kontrabassi, saksofoni ja meesvokaali, siis jääb nö. soojusest ja dünaamikast tiba puudu, et tekiks loomuliku reaalse pilli/vokaali heli. Ühesõnaga head nööbid neile, kes otsivad taga väga neutraalset ja analüütilist heli aga isiklikult meeldivad ikkagi Piston 2 ja modifitseeritud R35 rohkem oma soojema kõlaga ning kübe loomutruuma kesksagedustega, olenemata sellest, et bassi on vb. tibake liiast. Lihtsalt P2/R35 haarab muusikaga kaasa aga ANV kuulates seda tunnet ei teki. On küll väga hea detailne puhas heli aga no ei kõla piisavalt naturaalselt.
W!ngs
W!ngs
sõnum 09.05.2015 11:52:36 vasta tsitaadiga
Käisin just oma Piston 3'l järgi. Esimesed hiinakad ja esmamulje on super arvestades oma hinda. Kuna ma ei oska kõige paremini heli kirjeldada, siis lühidalt, et heli on puhas ja mõnusalt tasakaalus erinevalt praegustest Sennheiseritest, kus bass kipub üle peksma ning mille võrra kipub muid helisid varju jätma. Ehituskvaliteet ja disain oma samuti kiiduväärt. Ideaalselt sobivad kõrva, summutab totaalselt ümbritsevad helid. Helinupud koos mikriga on tore lisa arvestades seda kuidas mulle meeldib lugusid vahetada helivolüümi nuppudega, enam ei pea telefoni taskus näppima.
Odavalt sain ka, ehk 20 eurot ja ~paarkümmend senti. Kui kedagi huvitab, siis ostsin siit: http://www.aliexpress.com/item/IN-STOCK-Newest-Original-Xiaomi-Piston-3-0-3-5mm-Xiaomi-Standard-Edition-Piston/32311652643.html Kiiduväärt, sõbralik müüja. Pildid on identsed sellega, mis kohale jõudis. Osad said juba paari nädala oma kõrvaklapid kätte, minul läks natuke alla kuu.
CoiL
CoiL
sõnum 09.05.2015 12:35:00 vasta tsitaadiga
W!ngs, ibuygou`st saab kiiremini ja vist isegi odavamalt.
krist2an
krist2an
sõnum 09.05.2015 16:15:54 vasta tsitaadiga
W!ngs kirjutas:
Huhh.... siin teemas tõelised heligurmaanid koos, kuidas sa julged üldse 20€ maksvate klappidega kiidelda? Alla 100€ maksvad klapid on kõik kräpp ju. Sest et esiteks, maksavad vaid 20€, teiseks need on pärit Aasiast ja kolmandaks neil pole tuntud firmamärki peal. Eriline idioot on CoiL kes oleks võinud ammu korralikud Sennheiserid või Beyerid osta selle raha eest, mis ta Hiina jurakate alla on pannud.
Sarkasm. Lihtsalt seda teemat lugedes jääb täpselt selline mulje tänu mõnedele kasutajatele. Tegelikult on tore kuulda, et Piston 3 ka lippu kõrgel hoiab, peab varsti ka ära tellima.
uus teema   vasta Vaidlused »  Võitlustanner »  Millised kõrvaklapid? mine lehele eelmine  1, 2, 3 ... 120, 121, 122 ... 225, 226, 227  järgmine
