WOT foorumis on lausa jube lugeda selle sama teema all, et uuendus tuli, sisse ei saa kuni ca 10.30-eni.
Peale seda siis 10 tükki kisavad jumala vihaselt, et miks sisse ei saa..
1 kirjutab, et lugege uuenduse lehelt, kuni kelal 10.30-eni sisse ei saa ja siis tulevad jälle kümme uut matsi kes samat asja küsivad..
Nagu seal kirjutati, *Reading is not a requirement for Internet Games* .
tundub, et tegu korralike heeliumidega, kelle ajud ei registreeri ära antud infot enne kui karjutakse
Loe ka mida kirjutatakse
My advice about this offer is:
DO NOT BUY IT.
Two reasons for that really. First and the most obvious one is that according to people from Russian server who actually bought it as well as some supertesters, the tank is shit. It’s uncomfortable to drive and completely hopeless without limited MM against tier 10′s. Good luck flanking anyone in a German sniper. It’s definitely not a tank for beginners.
DO NOT BUY IT.
seda ma lugesingi et ei tasu osta. Milles kysimus on?
keegi teab m6nda lehekylge vms kus oleks nimekiri tankidest näiteks aastaarvu järgi ? vanematest uuemateni n2iteks. _________________ life is a bitch with 12inch strapon
Mina olen praegu Klannikaaslane k2rks ka. Ega muudmoodi see tööle ei hakka kui peab iga kord sisse jääma idlema, kuni inimesi juurde tuleb. Muidu igaüks vaatab, et oi, kanal ju tühi, mis ma siin ikka olen, ja läheb edasi.
Kellelgi veel BSODe loobib ca iga kahe tunni tagant?
Enne viimast uuendust polnud probleeme. _________________ YAGA müügiputka - SNAP pildipank
M: 3D Touch V3.2 15€
- smart modified autoaim, that can track a target behind obstacles and highlight its contour. Also, it doesn't aim at the center of the vehicle, but at (preprogrammed) vulnerable spots. Oh, and it also calculates the speed of the target and aims in front of it to compensate (pre-aim)
- automatic fire extinguisher/repair, a script that triggers the repair/extinguish automatically as soon as it happens
- removes any aim circle jerking (contrary to he official version, there is no jerk even when you get rammed)
- counterarty hack that puts a red dot on the spot enemy arty just fired from
- sixth sense mod that replaces the perk (if you don't have it), it shows you not only you are targetted but also who's targetting you
- artymode for tanks and TDs, snipermode for arty (with the artymode you can fire HE shells accross the map with a regular tank)
- tracerhack (visible and color tracers)
- a mod showing on minimap where trees fell or buildings got destroyed ("ideal for field commanders")
- a mod that removes ALL vegetation and "binoculars" in sniper mode
- laser pointer mod
- a free camera mod
- enemy reload timer
- white wrecks
- fire burst mode
- extended zoom in sniper mode
Kusjuures tegin analoogse mängu... Ace tanker jne. DMG ja spot oli natuke suurem, lasin ka kulda ja jäin 7000'ga veel plussi, seega selle tanki võib isegi alles jätta...
dunno esimene replay mida mby julgeks avalikult näidata, pole midagi erilist aga wn8 näitas 8500 punni
http://wotreplays.eu/site/1454356#report _________________ life is a bitch with 12inch strapon
http://wotreplays.eu/site/145611
Mäng ise oli jumala taaline ringi derpimine, mitte miedagi erilis, kohati isegi halb. _________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
Kus on loogika, et stabiilselt peksab Tier 1ga mängides ainult Tier 2 serverisse. Ulme juba
Oleks siis vastasvõiskonnas ka kasvõi 1 tier 1 masin, kuid kus sa sellega
No ja kui õnnestub Cruiser IVga oma tier klassis lammutada, siis saab ka selliseid häid tulemusi. Enamus jääb siiski 4-6 killi sisse, sest keegi noppib küljelt ära viimase kriipsu.
Miskine reportimis nupp võimalus ka on ingames? Kuradima närvidele käivad need TK mehed juba. Lendad tüübile appi, võitled sisuliselt tema ellujäämise nimel ja siis tänutäheks tõmbab mulle sisse, et ta elu päästsin.
Või rammitakse posjalt ära ja kui ei ole nõus minema, siis kukutakse laskma, kuniks eest ära tulen _________________ YAGA müügiputka - SNAP pildipank
brokenarm, haige süsteem! Mis minu kõnnike masin peaks tier 2 masinatele tegema? Suvaliselt võta miskine masin ja nad kõik teevad damage per sek ära. Nii kui nähakse on sisuliselt pidu läbi.
Ja nüüd ühe tunnine bänn ka mängust. Taas üks p**der kohe alguses pani paugu kirja, lasin talle vastu. Jäi passima sinna ja ma sõitsin edasi. Pani uue laksu mulle ja ma panin vastu ja kuttu ta oligi.
Haiged tüübid ikka _________________ YAGA müügiputka - SNAP pildipank
A milleks sul vaja vastu lasta? Reporti tüüpi ja mäng paneb talle ise bänni
Olgem ausad, ma ei teadnudki, et niimoodi bänni saab ja et ajuhiiglased enda lõbuks teistel mängu peeti keeravad.
Palju neid reporte koguneda võib miski aja jooksul, et bänni saaks?
Viimati mängisin seda kolm aastat tagasi. Pole väga kursis nende uute muudatustega. _________________ YAGA müügiputka - SNAP pildipank
No teatamiste värk oli juba algusaegadest sees, aga karistusi karmistati vist paar uuendust tagasi. Aga siniseks (teamkiller) minemise teema oli vist juba paar aastat tagasi.
Arvu kohta ei tea, kuid kui ikka päeva jooksul sinu kohta mitmes mängus teatatakse, siis hakkab asi automaatselt tööle. Pealegi, see kes sind tulistab, saab trahvi ja sina saad "valuraha"
