| Mitu tolli on sinu peamine igapäevases kasutuses olev monitor? |
| 10-15" |
0% |
[ 3 ] |
| 15-20" |
2% |
[ 7 ] |
| 20-25" |
17% |
[ 56 ] |
| 25-30" |
41% |
[ 132 ] |
| 30-35" |
25% |
[ 83 ] |
| 35" või suurem |
12% |
[ 40 ] |
| hääli kokku : 321 |
20.09.2014 21:11:38
Taas lubatakse siis uut, silmi säästvat, tehnoloogiat. Nii, et on täiesti võimalik, et see ka uue revolutsiooni tekitab ja taas toimub usin vanemate monitoride väljavahetamine.
AOC Wants to Save Your Eyes Using Anti-Blue Light Technology in Monitors
A friendly technology for your eyeballs
Display maker AOC is rolling out a patent-pending technology called "Anti-Blue Light" that's supposed to protect your eyes against the damaging effects of blue light from LED-backlit monitors. Just like overexposure to Ultra-Violet (UV) light waves from the sun can impair your vision, so can shortwave blue light (380-450 nm) from LED-backlit devices, AOC says. The company's Anti-Blue Light technology reduces the intensity and strength of the harmful shortwave blue light by fine tuning the LED backlight.
This method reduces blue light by over 90 percent. Compared to other solutions that use filters or software settings, AOC's ABL technology reduces shortwave blue light without dimming or distorting colors so that the monitor can maintain the true color and clarity of your images.
Is this a real problem? According to AOC, there are studies showing that long-term exposure to blue light can lead to macular degeneration (AMD), a permanent loss of vision in the center of the eye due to damage of the retina. The company references Dr. Carl Kupfer, former Director of the U.S. National Eye Institute, who predicts that "the prevalence of AMD is expected to rise 6.3 million by the year 2030" and that it will become an epidemic.
"We believe that any technology that can help protect our users’ eyes, without forcing them to change their digital lifestyles will be highly welcome," said Steve Young, AOC Marketing Manager. "AOC’s Anti-Blue Light technology leads the industry in protecting consumers against the damaging effects of blue light and providing a safer and healthier workplace."
AOC's solution tweaks the blue light emissions at the source by shifting the wavelength peak of the LED backlight from 450nm to 460nm, moving it out of the range that's considered harmful.
The company plans to implement it's ABL technology into its AOC 76V Series.
http://www.maximumpc.com/aoc_wants_save_your_eyes_using_anti-blue_light_technology_monitors_2014
211 |
KoldK
21.09.2014 11:18:09
| Millal seda tehnoloogiat oodata on? Kui see jääb ainult AOC põhiseks, siis küll nadi.
| Kommentaarid: 47 loe/lisa |
41 |
virx
21.09.2014 11:38:13
Kas just 1:1 tehnoloogia aga Benq XL2420Z puhul on see juba mõnda aega kasutusel.
http://gaming.benq.com/gaming-monitor/xl2420z
Kui monitor(id) mingil põhjusel ei sobi, on alati võimalik kasutada vastavaid prille, mis just selle sinise valguse vastu kaitset pakuvad.
309 |
kaspar737
27.09.2014 14:25:29
| Milliseid 1080p 144Hz monitore Eestis müüakse üldse? HinnaVaatlus leidis kaks tükki, kas ongi seis nii nutune kohe?
| Kommentaarid: 51 loe/lisa |
49 |
angel
27.09.2014 14:38:03
rohem ootaks mõndasid ips/mva vms mitte tn tüüpi kiireid LCD'sid 120+Hz'iga mille reso oleks üle 1080p. Suht nadi on nõnda väike reso
157 |
heretic666
28.09.2014 00:50:46
| angel kirjutas: |
rohem ootaks mõndasid ips/mva vms mitte tn tüüpi kiireid LCD'sid 120+Hz'iga mille reso oleks üle 1080p. Suht nadi on nõnda väike reso  |
Nende reaction time tuleb ilmselt kalts nii või teisiti. Ning kui gamed siis sa ju vaatad molu otse, mitte külje pealt
| Kommentaarid: 73 loe/lisa |
Rand0m
| Kommentaarid: 6 loe/lisa |
karts3
28.09.2014 09:58:56
Üks 2560×1440 monitor ainult, seis on ikka päris nutune
| Kommentaarid: 63 loe/lisa |
62 |
Mustakurmu
28.09.2014 13:32:24
Tere. 21:9 monitore müüakse kusagil normaalse hinnaga?
AOC Q2963PM jättis hea mulje, aga ei müüda kusagil 300€ kandis... on mingeid sarnase hinnaga veel? Välismaalt saaks koos saatekuludega koos 260€-ga... Eestis 330€+
| Kommentaarid: 34 loe/lisa |
29 |
Rand0m
28.09.2014 13:50:22
Jutt oli 144hz monitoridest
karts3
28.09.2014 16:09:13
| Jep.
62 |
angel
28.09.2014 17:19:16
| heretic666 kirjutas: |
| angel kirjutas: |
Nende reaction time tuleb ilmselt kalts nii või teisiti. Ning kui gamed siis sa ju vaatad molu otse, mitte külje pealt  |
Kui kord juba pikemat aega, aastaid, mva paneeli kasutanud siis enam selle TN saasta peale tagasi minna ei taha. Tööl kah mingi ips/mva tüüpi paneel kasutatud. Ei pea nagu postil seisma kartmast, et vale nurga alt vaadates värvid muutuvad. + TN paneeli värvi eristus on suht
157 |
heretic666
28.09.2014 17:41:17
| angel kirjutas: |
| angel kirjutas: |
Kui kord juba pikemat aega, aastaid, mva paneeli kasutanud siis enam selle TN saasta peale tagasi minna ei taha. Tööl kah mingi ips/mva tüüpi paneel kasutatud. Ei pea nagu postil seisma kartmast, et vale nurga alt vaadates värvid muutuvad. + TN paneeli värvi eristus on suht  |
No ma kaks aastat kasutanud e-IPS paneeliga monitore ja nüüd lisandus 10 bit TN paneel, e-IPS ja 10bit TN on mul kõrvuti kogu aeg igapäevases kasutuses ja minu arust sarnased toonid neil mõlemal (peab väga puuriva pilguga otsima hakkama kui neid erinevusi tahad leida).
erko
28.09.2014 18:00:01
| angel kirjutas: |
| angel kirjutas: |
No ma kaks aastat kasutanud e-IPS paneeliga monitore ja nüüd lisandus 10 bit TN paneel, e-IPS ja 10bit TN on mul kõrvuti kogu aeg igapäevases kasutuses ja minu arust sarnased toonid neil mõlemal (peab väga puuriva pilguga otsima hakkama kui neid erinevusi tahad leida). |
Milline see 10 bitise TN paneeliga monitor oleks? On selline asi tõesti reaalselt olemas?
| Kommentaarid: 26 loe/lisa |
26 |
von Wu
28.09.2014 18:01:18
E-IPS on säästu IPS, sellest on märgatavalt paremaid olemas.
_________________ Müüa igasugu asju
Müüa 4TB SSD
Müüa 55" OLED teler |
| Kommentaarid: 910 loe/lisa |
684 |
28.09.2014 19:32:10
10-bit tn paneele ei tohiks olemas olla.
kui, siis 8-bit+fcr
_________________ - londiste
217 |
28.09.2014 20:21:31
IPS ja VA paneelide puhul kehtib sama... võtmesõnaks on tootjapoolne kulude kokkuhoid.
Enamesinev 6bit paneel +FRC; 8bit paneel +FRC
131 |
heretic666
28.09.2014 20:26:34
| erko kirjutas: |
| angel kirjutas: |
| angel kirjutas: |
Milline see 10 bitise TN paneeliga monitor oleks? On selline asi tõesti reaalselt olemas? |
Vabandused, endapoolne näpukas. Pidasin silmas 8bit TN paneel.
Won wu, ma täitsa usun et säästu IPSidest on veel paremaid paneele. Aga nende vahe 'tavasilma jaoks' vaevalt nii drastiline on kui 6 bit TN vs e-IPS. Kindlasti leidub ka värvikriitikuid kelle jaoks algavad hea pildiga monitorid NEC PA271W seeriast või muust taolisest.
28.09.2014 20:47:31
Paneel võib küll toetada, kuid enne paneeli peab olema täielik jada, mis kõik peavad toetama 10bit värvispektrit
rakendus operatsioonisüsteem graafikadraiver graafikakaart DisplayPort kaabel 10bit ekraan
Ilma ülaltoodud jadata ei esita see paneel mingitmoodi väljareklaamitud värviedastuse võimekust.
Natuke otsisin profikasutuse monitore
5000+ rohelist http://www.flandersscientific.com/index/cm240.php
131 |
angel
28.09.2014 21:33:07
Ei ole värvikriitik aga kui kahte paneeli kõrvuti vaadata -> IPS/MVA vs TN siis toonide vahe on märgatav. Lisaks TN'i vaatenurk, viimati kui kasutasin, on ikka väga masendav. Võimalik, et TN paneelid on paremaks läinud (pole ammu kasutanud) aga vähealt mõned aastad tagasi oli neil väga suur probleem erinevate musta/halli varjundite kuvamisega.
157 |
29.09.2014 17:08:50
keegi odavamat (~€100'ish) 22"+ monitori oskab soovitada? FullHD vast võiks olla.
Kasutusvaldkond, igapäevategevused ja kontoritöö.
182 |
rycyve
01.10.2014 06:35:18
| rmc kirjutas: |
Kasutusvaldkond, igapäevategevused ja kontoritöö. |
AOC mudel täitsa olemas 21.5 toili(õhuke ,voolusäästlik pluss tugev ips-ah paneel) kui just flicker free silmanägemist ei mõjuta.Aga muidu selle raha eest(ca.100€) saaks siit foorumist kasutatud ultra sharp delli teatud mudeli millel selline jamps puudub ja garantii on täitsa ok.
_________________ CH341A EEPROM Flash BIOS teenus. |
83 |
01.10.2014 12:00:07
rycyve, 2312h'st räägid vast?
182 |
kaspar737
01.10.2014 15:33:21
| Keegi mängimiseks, netis surfamiseks, üldiseks kasutamiseks oskab monitori soovitada? Kindlasti 1080p ja kuni 125€.
49 |
Kirsa
01.10.2014 20:15:54
| rmc kirjutas: |
https://www.hinnavaatlus.ee/products/Arvutikomponendid/Monitorid/354088/
Benq GW2265M on 106 euri. Tegemist on päris 8 bitise VA paneeliga monitoriga, mis veel pealekaba virvendamisvaba.
Paremat diili on raske leida.
| Kommentaarid: 77 loe/lisa |
71 |
W!ngs
| Kommentaarid: 23 loe/lisa |
23 |
Rand0m
01.10.2014 23:51:04
BenQ oma flicker-free, muud suurt vahet ei tohiks olla.
Ise oman VG248QE'd ja olen väga rahul.
vysnap007
02.10.2014 03:08:49
| Oleks vaja mõnda monitori, mis oleks mängimiseks hea ja maksab kuni 200€ (häda korral ka natuke rohkem). IPS.
Timoha
03.10.2014 12:23:37
Tere. Tekkis soov oma monitore (3tk) kalibreerida ja vaadata kas on siis suur vahe või mitte. On kellelgi võimalik laenata (väikse tasu eest) korraks kalibraatori?
Monitore mida plaanin kalibreerida on HP 24 L2445w + 2xDell 24" UltraSharp U2412M.
P.S. sain 10€ eest Fotoluksist.
| Kommentaarid: 42 loe/lisa |
40 |
B6
05.10.2014 00:39:38
vaatan seda TN ja IPS monitoride vaidlust TN koledaks kahjuks ja ei saa aru millest käib jutt
omale ostsin BenQ XL2411Z ja pojale Dell U2414H
no ei ole minu benqil mingit toonide muutumist vaatenurka muutes.
ehk on see dell siis sihuke käkk, et pildi eelist välja ei tule
159 |
05.10.2014 00:41:12
no sa pime või midagi on delliga mäda
B6
05.10.2014 01:20:49
ma ikka kaldun arvama, et siin räägitakse odavatest monitoridest või ajaloost
159 |
KoldK
05.10.2014 10:42:17
| vysnap007 kirjutas: |
| Oleks vaja mõnda monitori, mis oleks mängimiseks hea ja maksab kuni 200€ (häda korral ka natuke rohkem). IPS. |
Midagi sellist ehk: http://www.1a.ee/arvutitehnika/led_monitorid/lg_24mb35pmb
Kui pivot funktsioon oluline pole, siis saab odavamalt ka veel.
41 |
vahvel77
| Kommentaarid: 10 loe/lisa |
9 |
09.10.2014 23:38:00
pls = ips for all intents and purposes.
endal on üks pls-paneeliga monitor laual, ei oska nagu kurta. u2312hm odav ips võrdlust välja ei kannata (u2713hm on parema paneeliga, nii et sellega väiksem vend ka võrdlust välja ei kannata).
tftcentrali ülevaated on üldjuhul usaldusväärsed:
http://www.tftcentral.co.uk/reviews/asus_pb278q.htm
http://www.tftcentral.co.uk/reviews/dell_u2713hm.htm
pb278q peaks oma omaduste poolest olema pigem u2713h võistleja.
üldiselt hinnatakse seda kui bang-for-buck monitori.
217 |
heretic666
09.10.2014 23:40:56
| 144hz TN gaminguks ja IPS kõrvale fotopoe jaoks.
09.10.2014 23:44:08
jep, ja vähemalt gtx980 sli ka kui juba ostmiseks läheb. tri- või quad-sli oleks parem.
/s
217 |
vahvel77
10.10.2014 09:35:37
heretic666, Enam ma seda fps niivõrd taga ei aja. Ennem oli mul Dell ALienware 120 hz, kuid mõtlesin et kolin üle kvaliteetsema pildi ja 1440p peale....60 fps on piisavalt
Lootsin et keegi oskab selle delli mudeli kohta midagi öelda, et kas see cross-hatching on tõesti niivõrd probleemne selle monitori puhul?
_________________ Müüa Nikkonile Sigma 70-200mm f/2.8 EX DG HSM II Macro + kere. |
9 |
heretic666
vahvel77
10.10.2014 10:51:01
krt natuke kaua oodata jah. Homme annan enda praeguse monitori juba ära ja lähen Tallinna selle delliga tutvuma.
9 |
KoldK
10.10.2014 12:57:03
vahvel77, Dell U2713HM on korralik asi, alt ei saa sellega vähemalt minna.
Ise olin selle taga küll ühe päeva, aga mulje jäi väga hea ja pilt oli .
Samas kui aega on, siis ootaks kindlasti U2715H ära.
viimati muutis KoldK 10.10.2014 12:59:45, muudetud 2 korda |
41 |
bitCON
10.10.2014 13:02:02
| vahvel77 kirjutas: |
Lootsin et keegi oskab selle delli mudeli kohta midagi öelda, et kas see cross-hatching on tõesti niivõrd probleemne selle monitori puhul? |
Omasin seda delli, ülisitt (cross-hatching ja bleed ka ebareaalne), viisin poodi tagasi pärast 2 päeva kasutamist
IMO täiesti mõttetu praegu neid 1440p monitore osta, hind pole üldse langenud aastaid juba ja 3440*1440/4K on pmst sama hinnaga saadaval juba/kohe.
IPS MONITOR - U3477PQU *AVAILABLE IN OCTOBER*
http://www.aoc-europe.com/no_cache/en/monitors.html?showUid=362
10.10.2014 13:18:29
bitCON, naljakas reso sel AOC monitoril.. lisaks, et AOC kvaliteet on paranenud? Vanasti oli nende hüüdnimi /\OC, ehk LOS (line of sight) ja pilt oli jube...
kui mängida jne., siis ootaks selle u2715h ära, paberil näeb ülihea välja.. näikse, kas kõlbab ka äkilisema-nõudliku tegevuse jaoks..
KoldK, mida tegid selle ühe päeva selle taga?
182 |
karts3
62 |
10.10.2014 17:32:20
| bitCON kirjutas: |
| 3440*1440/4K on pmst sama hinnaga saadaval juba/kohe. |
<500€? kus?
217 |
bitCON
10.10.2014 17:35:44
| londiste kirjutas: |
| bitCON kirjutas: |
<500€? kus? |
alla 500 euriseid 4K-sid on olemas küll juba.
Aga kui juba 500 eurine monitor osta siis vaevalt, et 100-200 euri veel lisaks ära tapab
heretic666
10.10.2014 21:05:46
Oleneb eesmärgist, gamingus see pixel density suhtes on 1440p just see sweet spot. 4K gaming on endiselt powerpointi slaidiesitlus, ulmelised Quad SLI'd välja jättes.
bitCON
10.10.2014 21:48:04
Oleneb eesmärgist, gamingus see pixel density suhtes on 1440p just see sweet spot. 4K gaming on endiselt powerpointi slaidiesitlus, ulmelised Quad SLI'd välja jättes. |
Eks jah, õnneks G-Sync ja FreeSync parandavad asja. Saab ka 1 r9 290x peal mänge mängida 4K resoga.
Kas G-Synciga on 30(35) FPS sama smooth nagu 60-gagi?
vahvel77
10.10.2014 22:14:53
Tagasi 1440p monitoride juurde .
Mis te soovitaksite hetkel olemasolevatest valikutest? Tn paneeli ei soovi.
9 |
