olavsu1
külaline
04.09.2014 21:42:42
| Sain oma vahtkummist otsikud kätte. Pioneer se-cl28 küljes päris hääd, originaal kummiotsikutest tunduvalt paremad. LG QuadBeat2 klappidele ei sobi mitte, heli muutus tugevalt teistsuguseks. teravaid palju, bassi netu.
flake
04.09.2014 22:10:59
CoiL, räägi mulle superlux hd681 modidest. kust mingit stuffi saada ja mida teha? sain enda omad täna kätte
_________________ ..||.. |
| Kommentaarid: 63 loe/lisa |
60 |
CoiL
05.09.2014 00:37:36
| CoiL kirjutas: |
| CoiL kirjutas: |
Jäin vist "natuke" hiljaks vastamisega Aga parem hilja kui mitte kunagi. Rockgrotto foorumist ja mujalt kokku kogutud inf, äkki tuleb kellelegi veel kasuks:
___________________________________________________________________________
---<([|||/// HD-681 Filter mod \\\|||])>---
Filter components:
Resistors:
use wirewound, Metal film, carbon whatever you like or feel will be better.
Not of any importance really in this application as long as the wattage is
ABOVE 0.25W (which most resistors are)
capacitor 1uF:
Multicomp MCRR50105Z5UM00050 = Farnell order code 121-6447
or:
Multicomp MCRR50105X7RK00050 = Farnell order code 121-6443 (used by me)
or:
AVX SR305C105KTR = Farnell order code 110-0398
or:
AVX SA305E10MARTB = Farnell order code 110-0420
Inductor (choke coil):
EPCOS B82144A2474J = Farnell order code 517-070 (used by me)
or:
EPCOS B82145A1474J000 = Farnell order code 164-4331
or any other small coil, inductor, choke with 470uH and a resistance of
equal or lower than 2.5 Ohms.
Only the resistor values are to be altered.
You can vary the resistor value
of R3 and R4 (now 39 Ohms) between 27 (to little damping of high freq) to
120 Ohms (a bit too much damping of high freq.). You can put a 100 Ohms
potentiometer in it's place and fiddle with the settings for instance.
If the resistor value of R3/R4 is between 25 and 50 Ohms use 56 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 50 and 75 Ohms use 47 Ohm resistors for R1/R2
If the resistor value of R3/R4 is between 75 and 150 Ohms use 39 Ohm resistors for R1/R2
The capacitor and inductor need not to be changed as these are the frequency
determining parts of the filter.
Resistor R3/R4 determines the Q factor of the
filter AND amount (dB) of filtering at the filter frequency.
The center frequency is around 7.2kHz.
L1,C1,R1,L2,C2,R2 are for compensating
the impedance peak which is caused by the filter network L3,L4,R3,R4,C3,C4.
You can leave L1,C1,R1,L2,C2,R2 out IF you want if you are ONLY going
to use these cans on a low Z output amp (around 10 Ohms).
In all other circumstances (output impedance between say .. 20 Ohms and 600
Ohms or unknown) this part (L1,C1,R1,L2,C2,R2) of the filter network is ESSENTIAL
in obtaining the right amount of damping.
maximum highs, sibilance gone HD681 character remains (first filter):
R1=R2=56 Ohm
R3=R4=39 Ohm
slightly less treble but still close to original HD681 character:
R1=R2=56 Ohm
R3=R4=47 Ohm
less treble but still brighter then Sennheiser signature in general (second filter):
R1=R2=39 Ohm
R3=R4=56 Ohm
About equal to Sennheiser signature in general bass more prominent:
R1=R2=39 Ohm
R3=R4=82 Ohm
Capacitors:
Some say polyprop sounds better (in this picture).
Some will say mica or
silver-mica is better, yet not available in these values.
Multitlayer ceramics
(X7R is preferred over Z5U) are small and can be used inside the headphone without
taking up too much space. There are also smaller sized polypropyline avaiable.
The voltage (which determines the size) is not of importance.
For external filters
the sky is the limit (money wise) and can be constructed to your audio religion.
Q: For the orginal HD681 filter from the very first page, say I want to attenuate
the ~7.25 kHz frequency 3db rather than 6db? I replace the resistor in parallel
part of the filter with one of lower value correct? What value would I use?
A: Parallel filter (the one in series with the driver) between 27 and 33 Ohm
series
filter (on the input of the filter) R = 68 Ohm
HD-662 mod (-3dB bandwidth 3.4 kHz - 11 kHz,
-7.5dB @ 6.3kHz):
r1 = r3 = 47 Ohm
c1 = C3 = 1.33nF (1uF // 330nF)
L1 = L3 = 470uH
____________________________________________________________________________
HD-662F filter (CoiL):
r1 = r2 = 47 Ohm
r3 = r4 = 51 (56 Ohm if cymbals and guitars feel too bright)
C1 = C2 = C3 = C4 = 1.33nF (1uF // 330nF)
L1 = L2 = L3 = L4 = 470uH |
Mk3 filter pidavat bassi vähendama võrreldes mk2 filtriga. Peale mk2 filtrit on minu arvates bassi just parajalt, siis kui vaja ülimadalaid kuulda on olemas mitte ei tõmba "hinge kinni". Mk3 filter on suunitletud rohkem neutraalse "audiofiili" heli suunas. Kes soovib siiski mõnusat madalat bassi alles jätta, sellele soovitaks siiski mk2 filtrit. |
| olavsu1 kirjutas: |
CoiL'i jutu täienduseks niipalju, et selle filtri peaks igaüks ise arvutama oma isikliku audiogrammi järgi.
Paar Stirlitz'i pilti tuntud raamatust, jutt on siis "b" skeemist. ahel C3, R3 jäta välja.
Ta ei ole midagi muud, kui amplituudikorrektor. Tema kisub allapoole selle sagedusevahemiku, mille jaoks ta on arvutatud.
soovitud sagedusvahemik vaata oma audogrammi pealt.
http://diyaudioheaven.wordpress.com/schematics/headphone/ ...keri allapoole, seal HD-681 kohta palju teste ja infi.
Komponendid tellisin oomipoest. Samas ma vaatan, et sa pesitsed ka Tartus, võin nädalavahetusel uurida mis jubinaid mul alles on. Mälu järgi sai viimati juurde tellitud kuna H-Fi foorumis tegin ühele tellimusena puidust korpusega filtri aga pean üle kontrollima kas jäi piisavalt juppe alles. Selline sai muidu:
| Kommentaarid: 95 loe/lisa |
83 |
flake
05.09.2014 08:33:38
Tänud, uurin nädalavahetuse jooksul Kui tüli ei tee, võid vaadata.
Viitsid, postita selle karbikese sisust ka pilti, tahaks näha mis karul kõhus on
60 |
CoiL
83 |
flake
05.09.2014 13:17:52
okei.. panen kõrva taha. Skeemi saan sealt rockgrottost jah?
60 |
pacho
08.09.2014 19:51:47
| pacho kirjutas: |
Tellisin sellised jubinad.
Lihtsalt proovimiseks. Keegi peab ju esimese julge sammu tegema. Oleks teinud võrdluse Comply'ga. Tulid kohale. Nüüd ei leia klappe üles. |
Need ei kõlba kuskile.
Ainult kehvast vahust junnid. Pole võimalik korralikult klappide külge panna. Lisaks tekitasid kõrvakanalis ebameeldiva tunde. Nagu kergelt abrasiivsed oleksid. Kõrvakanalisse sisestades peab väga etevaatlik olema, et klappide ava ei sulgeks.
Akustiliselt on Comply T-seeriaga samal tasemel. Comply'd pakuvad karvavõrra kirkamat heli.
Comply'de ainuke viga on hind. Pistonid, Quadbeat 2-d, MH1C-d, jne maksavad vahemikus 20-25 eurot. Minu kogemuse kohaselt parandavad korralikud otsikud sääraste klappide heli märkmisväärselt. Kahjuks maksavad need klappide hinna ja alternatiivi pole siiani leidnud.
Kellele huvi pakub, siis võrdlesin otsikuid QB2 klappidega.
| Kommentaarid: 25 loe/lisa |
25 |
olavsu1
külaline
08.09.2014 23:36:11
Sattusin Konsumis siin palju kiidetud Vivanco SB klappidele. Bass lööb maha... Täpselt kehtib see jutt mida kirjutatakse SIIN valikus kaheksanda loo kohta.
8. – Mark Keali’i Ho’omalu – „He Mele No Lilo“ – kuulake tähelepanelikult kohta, kus lastekoori lämmatab võimas bass.
Tõepoolest lauljad ei kosta välja. Minu arvates vajavad need eeltoodud amplituudikorrektorit liigse tümaka alla tõmbamiseks.
Lasin neisse sündist Alte Kameradenit. Vivancodega on kuulda, et stuudio on basstrummi sämplite tegemisel kajanud. Suure trummi heli kumiseb.
ATH-M50 klappidega pole sama sündi taga ei kaja ega kuminat.
CoiL
09.09.2014 18:40:32
Sain täna lõpuks T-Peos Popular`id kätte. Jätan hetkel nö. sisse mängima aga mõned esmamuljed:
* kõrvas istuvad tiba mugavamalt kui Pistonid oma väiksema korpuse tõttu
* kaabel (lapik) on kohmakam aga samas ei lähe nii kergelt sõlme
* näevad "odavamad" välja (sinine versioon) kui Pistonid. Mustad võivad isegi üsna soliidsed olla.
* esmasel kuulamisel tunduvad bassisemad, vähem õhulise heliga, natuke väiksema heliruumiga ja mitte nii selgete kõrgete/kesksagedustega kui Pistonid
Eks näis, mis sissemängimine neile teeb, kui üldse midagi. Samas tunduvad 22€ eest head klapid.
83 |
erik111
09.09.2014 18:48:31
| Ise tahan ka nüüd SuperLuxist ära tellida sealt pillipoest.Kindlam.
157 |
pacho
09.09.2014 19:16:06
Ma hakkasin 5 paari €20-30 eurose klapi kohta võrdlevat ülevaadet kirjutama. Sai need sissemängitud. Kuulasin veidike ja enam ei viitsi. Klapid on oma hinna kohta ok. Ainuke viga on need viimased 15-20% protsenti, mis teevad tavalisest klapist tippklassi. Minu jaoks on see viimane protsent tähtsam, kui eelnev 80.
Elu on lihtsalt liiga lühike.
25 |
CoiL
09.09.2014 19:46:16
pacho, kui tahad võin T-Peos Popular 32Ohm ja Piston V2.1 16Ohm klapid ka sulle ülevaate jaoks saata kui soovid? Aga siis jääb elu veel lühemaks Lihtsalt pakun juhul kui kavatsed lõpuni ülevaate teha.
83 |
pacho
09.09.2014 19:57:29
Ikka ei viitsi. Lihtalt minu jaoks ei oma mingisugust tähtsust. Tähtis on olla võimalikult lähedal perfektisoonile. W4, UE900, ER4S ja SE535 on seda. Selgus, et sellest allapoole ei paku mulle enam IEM'd huvi.
Ma veel paar päeva üritan uuesti alustada. Kui ikka motivatsiooni pole, siis on mõned paarid klappe jälle üle.
25 |
CoiL
09.09.2014 20:06:30
pacho, selliste klappidega võrreldes muidugi motti pole ...aga ülevaade oleks hea eelkõige neile kel sellist pappi ei ole välja käia ja soovivad odavalt paremat heli saada.
Ega otseselt sellest ülevaatest miskit kasu ei olekski kuna netis ülevaateid ja infi meeletus koguses aga hea oleks ühte sellist kodumaist budget-IEM ülevaadet lugeda
edit: ahjaa, kui sul Piston V2.1 üle jääb, siis sooviks osta, mul pereliige avaldas soovi aga ei ole veel uut tellimust sisse andnud.
83 |
olavsu1
külaline
09.09.2014 20:13:56
Sain vivanco'dest endajaoks normaalse heli kätte. Lõikasin kõige suurematelt otsikutelt lõdviku osa ära nii, et jäi ainult toru järgi. Nende torude peale tõmbasin augurauaga löödud svammitükikesed ja voilah.
Tulemus siis:
Straussi võib kuulama jäädagi.
pacho
09.09.2014 20:17:32
CoiL, see ei tähenda, et nendel odavatel klappidel poleks häid aspekte.
Näiteks QB2 bassi kvaliteet on midagi mida peab ise kuulama. Kiirus, täpsus ja "impact" (vabandust, ei leia eestikeelset sõna) on muljetavaldavad.
25 |
CoiL
09.09.2014 20:35:45
| pacho, ega sul Havi B3 Pro1 juhuslikult olemas ole? Mõtlen ja mõtlen aga ei raatsi raha välja käia peale pistonite kuulmist. Samas ega see 55€ kah ära tapa aga teaks kas edasiminek on märgatav või ei, sest Pistonite heli meeldib väga koos DX50-ga.
83 |
pacho
09.09.2014 21:04:39
Ei ole
Ma ühest teisest foorumis lugesin nende kohta. Ma üldiselt hoian "AMAZING", "INCREDIBLE" ja "UNBELIEVABLE" kirjadega kraamist eemale. Nii kaua kuni keegi usaldusväärsem infot edastab.
25 |
CoiL
09.09.2014 21:33:19
niipalju kui lugenud nende kohta erinevatest foorumitest ja ostukommentaaridest, siis peaksid head olema aga egas niikuinii enne aimu ei saa kui ära osta ja ise reaalselt proovida
Järgmine kuu vist lähevad loosi kui just muud silmapiirile ei ilmu.
83 |
argentum7
10.09.2014 16:38:58
| pacho kirjutas: |
Ma veel paar päeva üritan uuesti alustada. Kui ikka motivatsiooni pole, siis on mõned paarid klappe jälle üle. |
Täpselt samad tunded. Olen omanud Earsonics SM3, Shure Se535, Sony Sony MDR-EX1000 Ja Westone 4 -ja. Kõige universaalsem nendest on Westone, Sony oli ehk isegi pisut parema heliga aga tolle IEM'i hädaks on omapärane disain, mis igapäevaseks ning mobiilseks kasutuseks väga hea variant ei ole. Westoned on vastu pidanud pea 3 ja pool aastat, pistiku pidin siiski ära vahetama aga see häda on vist kõigil IEM'del ühine aktiivse kasutuse juures.
97 |
pacho
10.09.2014 21:14:20
| argentum7 kirjutas: |
| Westoned on vastu pidanud pea 3 ja pool aastat, pistiku pidin siiski ära vahetama aga see häda on vist kõigil IEM'del ühine aktiivse kasutuse juures. |
Kaablid kipuvad kõigil katki minema. Eestis oli probleem temperatuurikõikumiste tõttu rohkem märgatav Sellepärast üritangi soetada vahetatavate kaablitega mudeleid. Ka mul on Westone igapäevases kasutuses. 4R mudel. Suure tõenäosusega jääb ka viimaseks universaalseks IEM-ks. Ei usu, et mõistliku raha eest on võimalik teha märgatavalt paremaid klappe. Selliseid, mis raha kulutamis õigustaksid.
Järgmine samm on custom'id.
25 |
kosmonaut0
10.09.2014 23:00:45
Otsin koduseks kasutamiseks kõrvaklappe, mis üle kõrva käiksid ja ega muud ei teegi nendega kui mängin mänge ja kuulan muusikat. Muusika loomist ja töötlust ei toimu. Mikrofoni olemasolu pole otseselt oluline, sobib nii ilma kui mikriga. Heli poolest tahaks sügavust ja puhtust... Raha pole palju välja käia, võiks jääda ~50€ kanti vast?(kui saab midagi enam-vähem selle eest)... Ma ise ei tea audiost ja klappidest midagi, seega ei tea mida vaadata nende juures täpselt ja mida hinnata ja võrrelda ja mille järgi valida.. Loodan targemate peale
| Kommentaarid: 7 loe/lisa |
lkraav
11.09.2014 00:38:03
Need AKG K551-d http://www.euronics.ee/t/53384/korvaklapid/hifi-korvaklapid-k551-akg-murasummutus/k551wht olid Frankfurti Saturn elektroonikaketi kaubamajas müügil €79.99 / paar. Terve vankritäis karpe oli. Euronics €279, Amazon $299. Rebisime siis kolleegiga mõlemad 1 paari endale ajaviiteks. Võib-olla keegi satub veel sinnakanti või leiutab kaughanke mooduseid, siis tundub mõistlik diil olevat.
_________________ TELEFON PROFIILIS :: HV-NewFavFilter - GreaseMonkey HV lemmikute filter! Kui meeldib, pane positiivne märksõnaga "HV-NewFavFilter". |
| Kommentaarid: 138 loe/lisa |
129 |
CoiL
83 |
Ariel, MM
11.09.2014 11:03:44
Mul on vanemad pruunid Uptownid, millel on juhtmes liugur ning klappidel pole kirja "Music Seal", ning uuemad mustad, millel see probleemne helitugevuse liugur eemaldatud. Ma pole audiofiil ja võib-olla oli asi meeleolus, ilmas või milleski muus, aga uuel versioonil tundus heli kuidagi vähem... särav? Kuidagi umbsem tunne oli. Mingit tõsist võrdlust pole teinud, aga joonlaud ütleb, et klapipadjad on uutel umbes 1.5 cm väiksemad.
