14.08.2014 14:18:26
Kuidas konto sulgemine antud teemaga praegu haakub?
| enterprice kirjutas: |
| Täpselt sama tegi facebook, ilma ühegi hoiatuse või selgituseta. |
Ja üldiselt sind ju hoiatati ja küsiti luba - kui tahad installida, siis pead Messengerile konkreetsed õigused andma. Kui ei sobi, siis saad alati Cancel või Back nuppu vajutada? Mingit omavolilist õiguste eskaleerimist pole ju olnud
562 |
LKits
| Kommentaarid: 13 loe/lisa |
sakinaga
14.08.2014 14:38:29
Google Hangouts:
Version 2.1.317 can access:
Identity
find accounts on the device
add or remove accounts
Contacts / Calendar
read your contacts
modify your contacts
Location
approximate location (network-based)
precise location (GPS and network-based)
SMS
read your text messages (SMS or MMS)
receive text messages (SMS)
send SMS messages
edit your text messages (SMS or MMS)
receive text messages (MMS)
Phone
directly call phone numbers
Photos / Media / Files
modify or delete the contents of your USB storage
test access to protected storage
Camera / Microphone
take pictures and videos
record audio
Wi-Fi connection information
view Wi-Fi connections
Device ID & call information
read phone status and identity
Other
receive data from Internet
read instant messages
Exchanges messages and receives sync notifications from Google servers.
full network access
control vibration
run at startup
use accounts on the device
view network connections
control Near-Field Communication
read Google service configuration
prevent device from sleeping
change your audio settings
pair with Bluetooth devices
change network connectivity
send sticky broadcast
Ehk siis miks nutta Facebooki messengeri üle aga jätta teised tähelepanuta?
| Kommentaarid: 160 loe/lisa |
152 |
SurfData
14.08.2014 14:52:16
| maatriks kirjutas: |
Google Hangouts:
Identity
Contacts / Calendar
read your contacts
Location
SMS
send SMS messages
Phone
Camera / Microphone
record audio
Other
full network access
control vibration
run at startup
Ehk siis miks nutta Facebooki messengeri üle aga jätta teised tähelepanuta? |
seetõttu ongi mul veel google talk peal, see hangouts tahtis liiga palju õiguseid
| Kommentaarid: 84 loe/lisa |
74 |
14.08.2014 14:58:01
Nexus 5 sunnitakse sind Hangoutsi kasutama - tavalist SMS-i saatmise võimalust enam pole. Samas kõik kiidavad puhast Androidi
562 |
nexus4
14.08.2014 15:11:43
| hangouts ongi puhas android, kui see ei sobi võid kasutada ka mõnda muud. wireless & networks -> more -> default SMS app
| Kommentaarid: 29 loe/lisa |
26 |
SurfData
14.08.2014 15:17:16
| Betamax kirjutas: |
Nexus 5 sunnitakse sind Hangoutsi kasutama - tavalist SMS-i saatmise võimalust enam pole. Samas kõik kiidavad puhast Androidi  |
Mul telefoniks üle 3 aasta vana luts HTC sensation. Kõik on ametlik ja puhas Android nii nagu originaalis oli. Uuemate telefonidega võib jah jama tekkida, samas kunagi pean telefoni välja vahetama. Mulle endale samuti ei meeldi kui suvaline app tahab suvalisi õiguseid saada ja teha kõike millal ise tahab Sinu teadmata. See on sama kui kutsud sõbrad endale korraks külla, aga peale seda nad käivad siis kui ise tahavad, isegi kui Sind kodus pole. Siin paistab olevat inimesi kellele selline asi meeldib. Mulle selline asi ei meeldi ja arvan et uue telefoniga saab üks esimesi asju olema appide piiramine. 3 aastat tagasi olukord veel nii hull ei olnud. Appide uuendamisel vaatasin mis õiguseid juurde taheti ja kui liiga palju, siis jäi uuendamata. Mida aeg edasi, seda pikemaks see list kasvas
74 |
14.08.2014 15:24:32
| nexus4 kirjutas: |
| hangouts ongi puhas android, kui see ei sobi võid kasutada ka mõnda muud. wireless & networks -> more -> default SMS app |
Nexus 5 ei ole seda SMSi valikut.
Ja see Hangouts käib läbi Google'i serverite, ehk siis on paha! Miks keegi sellest ei räägi?
562 |
LKits
14.08.2014 15:36:19
Ei saa jätta mainimata, et põhimõtteliselt Android on ju Google oma, mis tähendab, et su sõnumid jms on nagunii neile "analüüsimiseks" kättesaadavad.
Mina isiklikult Google-t ei kardagi, sest too ei ole kordagi takistanud andmete kätte saamist ja nende kustutamist - vastupidiselt FB-le.
Google toetab mõnusalt palju export formaate/lahendusi nii, et sealt andmete kätte saamine on lausa nauding.
| Betamax kirjutas: |
| nexus4 kirjutas: |
Ja see Hangouts käib läbi Google'i serverite, ehk siis on paha! Miks keegi sellest ei räägi? |
sakinaga
152 |
Dijital
| Kommentaarid: 41 loe/lisa |
enterprice
14.08.2014 16:24:57
Minu vastus oli konto kustutamise kohta. Lisafailide allalaadimine on samas ka messengeri alla kasutajalt küsimata olemas, et ma ei imestaks kui sma loogika toimuks ka softi vallas.
| Betamax kirjutas: |
Ja üldiselt sind ju hoiatati ja küsiti luba - kui tahad installida, siis pead Messengerile konkreetsed õigused andma. Kui ei sobi, siis saad alati Cancel või Back nuppu vajutada? Mingit omavolilist õiguste eskaleerimist pole ju olnud  |
98 |
softis
14.08.2014 16:47:29
Kuulge, vandenõuteoreetikud. Pool sellest jamast on seotud sellega, et Androidil tuleb alguses kohe need õigused küsida.
Kas siis oleks teil süda rahul kui iOSi moodi küsitaks neid alles vastava funktsiooni kasutamisel? Kolistage Google'i uksetaga siis.
| Kommentaarid: 21 loe/lisa |
21 |
LKits
enterprice
14.08.2014 17:02:46
Ma natuke imetlen seda vandenõu teoreetiku väljendit. Tegelikult on veel palju ilusaid sõnu mida kannataks kasutada : foob, fooiumütsiga mehike, seemnesööja jne. Kui leidub keegi kes julgeb suure juhi ja õpetaja ilmeksmatuses kahelda siis käivad sellised väljendid ju tänapäeval hästi. Vene ajal olid natuke erinevad väljendid. Sisu on sama. Reaalne kogemus õpetab, teoretiseerida polegi palju vaja. Kui varas varastab ühes kohas või poliitik valetab ühe ilmakorra ajal siis piisab lihtsast tervest talupojamõistusest mõistmaks, et teda ülearu usaldada tunduks kohatu ja ka teise ilmakorra ajal imet ilmselt loota pole.
| softis kirjutas: |
Kas siis oleks teil süda rahul kui iOSi moodi küsitaks neid alles vastava funktsiooni kasutamisel? Kolistage Google'i uksetaga siis. |
98 |
14.08.2014 17:35:37
| Ma natuke imetlen seda vandenõu teoreetiku väljendit. Tegelikult on veel palju ilusaid sõnu mida kannataks kasutada : foob, fooiumütsiga mehike, seemnesööja jne. Kui leidub keegi kes julgeb suure juhi ja õpetaja ilmeksmatuses kahelda siis käivad sellised väljendid ju tänapäeval hästi. Vene ajal olid natuke erinevad väljendid. Sisu on sama. Reaalne kogemus õpetab, teoretiseerida polegi palju vaja. Kui varas varastab ühes kohas või poliitik valetab ühe ilmakorra ajal siis piisab lihtsast tervest talupojamõistusest mõistmaks, et teda ülearu usaldada tunduks kohatu ja ka teise ilmakorra ajal imet ilmselt loota pole. |
Uus põlvkond kasvab peale kellel pole midagi varjata. Kelle jaoks on normaalne, et lisaks akendele paistavad ka seinad läbi, uks on "heatahtlikule majaomanikule" ka valla. Kardinaid ei kasutata - mida mul ikka varjata!
146 |
prtv
14.08.2014 17:48:50
| Betamax kirjutas: |
Puhta Androidi saad AOSP'st ise kompilleerides omale (saad eraldi Messaging äpi sealt sõnumite jaoks Hangoutsi asemel), Nexus 5 tehasekonfiguratsioonis on nö Google nägemus Androidist oma teenustega.
| Kommentaarid: 82 loe/lisa |
73 |
sakinaga
14.08.2014 18:00:13
| Mark0 kirjutas: |
| ]Uus põlvkond kasvab peale kellel pole midagi varjata. Kelle jaoks on normaalne, et lisaks akendele paistavad ka seinad läbi, uks on "heatahtlikule majaomanikule" ka valla. Kardinaid ei kasutata - mida mul ikka varjata! |
Väga asjatundmatu üldistus, pigem hoolivad noored justnimelt tunduvalt rohkem oma privaatsusest, ei jagata Facebooki kõike, kasutatakse snapchati (või alternatiive) jne.
Tundub pigem sellise muru oli rohelisem, taevas sinisem ning noorus on hukas jutuna.
152 |
enterprice
14.08.2014 18:08:46
Lihtsalt noored on altimad massimeedias ja koolis jagatavale ajupesule ja usuvad sinisilmselt enam samas kui vanem generatsioon kogemustest lähtuvalt enim riske hindab. Paljugi mis võib juhtuda ja liigne võim valedes kätes ei tööta alati soovitud suunas. Vaata või Venemaal või Tallinna Linnavalitsuses toimuvat.
Selline noorte vanade erinevus on on olnud ju läbi aastasadade ja ei tohiks kellelegi uudiseks olla
| Mark0 kirjutas: |
Tundub pigem sellise muru oli rohelisem, taevas sinisem ning noorus on hukas jutuna. |
98 |
14.08.2014 18:09:59
| Mark0 kirjutas: |
pigem hoolivad noored justnimelt tunduvalt rohkem oma privaatsusest, ei jagata Facebooki kõike, kasutatakse snapchati (või alternatiive) jne. |
Väga asjatundmatu üldistus.
See on kogu aeg nii olnud.
viimati muutis Dirty Harry 14.08.2014 18:19:03, muudetud 1 kord |
146 |
14.08.2014 18:17:11
| gan3b kirjutas: |
| Betamax kirjutas: |
Puhta Androidi saad AOSP'st ise kompilleerides omale (saad eraldi Messaging äpi sealt sõnumite jaoks Hangoutsi asemel), Nexus 5 tehasekonfiguratsioonis on nö Google nägemus Androidist oma teenustega. |
Kompi-what?
562 |
sakinaga
14.08.2014 18:22:47
| Mark0 kirjutas: |
| Mark0 kirjutas: |
Väga asjatundmatu üldistus. |
Eks sa uuri, miks Facebook muretseb, et nad noorema demograafiani ei jõua.
152 |
enterprice
14.08.2014 18:43:33
Kuna noored, ei taha, et õpetajad ja vanemad nende tegemistel silma peal hoiaks. Seetõttu on osa seltskonnast kolinud mujale.
| Mark0 kirjutas: |
| Mark0 kirjutas: |
Eks sa uuri, miks Facebook muretseb, et nad noorema demograafiani ei jõua. |
98 |
sakinaga
14.08.2014 21:03:32
| Mark0 kirjutas: |
| Mark0 kirjutas: |
Ehk siis hoolitakse oma privaatsusest? m.o.t.t.
152 |
enterprice
14.08.2014 21:22:22
Mitte oma privaatsusest üldiselt vaid ainult teatud seltskonna eest jälgede peitmist - mitte et kedagi huvitaks kas valitsus, nsa, google või muu suur vend nende tegemistest huvitub või mis nende dataga tegelikult tehakse. Pilveteenuseid usaldatakse tihti pimesi, kuna kõik ju usaldavad.
| Mark0 kirjutas: |
| Mark0 kirjutas: |
Ehk siis hoolitakse oma privaatsusest? m.o.t.t. |
98 |
