allavett
13.06.2014 22:57:49
Nonii! Uurisin nüüd seda nn uuele mootorile "liikumist". Nagu aru sain, siis seda ei toimu.
Hoopis hetke mootor, mis oli algselt Take on Helicopters oma, on nii palju ümber kompunnitud, et see saab omale nime - Infusion.
Kui keegi teab midagi muud, sheerigu.
E:
Leidsin korraliku allika kah:
http://www.reddit.com/r/dayz/comments/27umee/before_everyone_loses_their_collective_shit_omg/
tsitaat: |
Hicks_206Producer
When DayZ started - we took the source from the existing RV Engine - Over the last many months, extensive clean up, new functionality, and so forth has been created for that engine - while at the same time, vast amounts of it were removed, or rewritten entirely. The changes Dean spoke of entail major leaps forward in that work, with those changes and the many more that will come through out development - we have begun to approach the point in which DayZ's engine is so no longer recognizable as RV, and because of that - and the massive work to come, it is now known by its own name, Infusion.
_________________ Twitch.tv/allavett |
Kommentaarid: 49 loe/lisa |
46 |
ruiks
14.06.2014 15:27:02
Twitterist:
Marek Spanel @maruksp Jun 12
Just to clarify http://disney.com/0v2bhx : Name of the revamped #DayZ engine is #Enfusion and there are 160 people working at @bohemiainteract
WAUZZZ
18.06.2014 16:47:55
Kohe-kohe peaks jõudma update stable'isse, Steam sikutas 762MB nänni.
https://twitter.com/Hicks_206
_________________ Just my stupid and uneducated opinion. |
Kommentaarid: 28 loe/lisa |
28 |
ekupeku
23.06.2014 12:45:38
Rääkige nüüd mulle seda, et kas experimental kadus ära? kuna laadisine experimentali alla ja järgmine päev enam mängida ei saanud kuna ei leidnud servereid kui filtris oli experimental. Võtsin filtri ära ja kohe läidis tavalisi servereid kus olin varem mänginud, kuid mitte experimentalis. Läksin sisse ja kõik experimentalis olnud asjad olid seal?? Aga sai ka AKM ära proovitud
Kommentaarid: 9 loe/lisa |
9 |
Leinö
24.06.2014 15:39:13
0.45 on nüüd stable jah, hetkel peaks uus experimental püsti olema, 0.46.
Kommentaarid: 34 loe/lisa |
33 |
ekupeku
25.06.2014 02:14:24
NE airfield nii halvaks tehtud minu arvates, kohti mida lootida poole vähem.
9 |
-RaiTz-
10.07.2014 22:50:40
Kas serverist väljudes peabki hetkel kogu progress nulli minema? Või oleneb see serverist?
28 |
ufo56
11.07.2014 02:02:55
Ei lähe. Oleneb kas mängid normal või hardcore, pärast tagasi tulles pead valima sama milles mängisid. Aga bugi otsa võisid ka sattuda. Selles mängus on vähemalt 100000 bugi mille läbi sureda.
Lae pildid -> pilt.io |
Kommentaarid: 78 loe/lisa |
67 |
in-sane
11.07.2014 09:40:25
Oleneb Hardcorest või normalist pluss veel olen täheldanud, et üks hostijatest (nimi on keele peal aga ei tule meelde) kasutab ka veel kolmandat hive-i ning varustus kaob ära.
Kommentaarid: 26 loe/lisa |
18 |
-RaiTz-
11.07.2014 13:40:52
Huvitav, et minul kaob olenemata serverist kõik ära. Võtan history alt sama koha kus just olin ja ühendades ütleb "ready default!" Mis viitab vaikimisi mehe laadimisele.
28 |
Leinö
11.07.2014 13:57:29
-RaiTz-, sa ikka tead, et peale väljalogimist ~30sek sul tegelane istub mängus? tsombi või teine tegelane võib sind lebolt seeaeg maha lüüa. Valid ikka korraliku nurgataguse väljalogimise jaoks?
33 |
-RaiTz-
11.07.2014 15:31:59
See, et mind keegi sai maha lüüa pärast välja logimist on suht välistatud. Katsetsin mitmel korral ja iga kord alustasin uue mehega. Eks proovin täna uuesti seda.
28 |
Dj-E
Aeg Maha 2a
11.07.2014 17:13:19
Sai kah siis lõpuks mäng ostetud aga nüüd peale selle teema lugemist on tekkinud väike hirm, et asja õppimine võtab kaua aega Selles mängus olen ikka täiesti amatöör. Mängu süvenemine tahab omajagu aega.
Kommentaarid: 22 loe/lisa |
21 |
Arx07
11.07.2014 17:43:12
Dj-E kirjutas: |
Sai kah siis lõpuks mäng ostetud aga nüüd peale selle teema lugemist on tekkinud väike hirm, et asja õppimine võtab kaua aega Selles mängus olen ikka täiesti amatöör. Mängu süvenemine tahab omajagu aega. |
Ma suht lahja mängur, aga selles mängus midagi keerulist küll ei leia
Minu arust hea variant on map välja printida ja kui mängid siis hea vaadata, kus suunas mis jääb jne
Kommentaarid: 3 loe/lisa |
TauC
11.07.2014 20:47:21
Arx07 kirjutas: |
Dj-E kirjutas: |
Minu arust hea variant on map välja printida ja kui mängid siis hea vaadata, kus suunas mis jääb jne |
Parem variant on kahe monitoriga mängida, kaart kõrval lahti. Vahepeal tuleb ainult mäng alla panna ja kaarti liigutada ning suurendada/vähendada.
Kommentaarid: 328 loe/lisa |
272 |
Dj-E
Aeg Maha 2a
11.07.2014 20:54:40
TauC kirjutas: |
Arx07 kirjutas: |
Dj-E kirjutas: |
Parem variant on kahe monitoriga mängida, kaart kõrval lahti. Vahepeal tuleb ainult mäng alla panna ja kaarti liigutada ning suurendada/vähendada.  |
Õnneks mul ongi kaks monitori. Peaks proovima.
21 |
dohc-48v12
Aeg maha 1p
11.07.2014 21:36:28
kasutasin algul sellejaoks läpakat, val ka teist monitori, ja suht õigustas ära. Algul kah spawnid ei tea kuhu ja ajasid linna juures oleva linna sildi juures näpuga järge, siis otsustasin et teen algul ühe poole kaardist endale selgeks, ja õnnestus, ning sealt edasi ka, mõned kohad on veel nii et kohe ei pauguta lahti kus oled aga üldiselt tuvastan suht minuti jooksul kus ole. Lihtsalt kooberdanud suht palju metsades siis tean ka sealseid kujundust kus mida on.
Üks nipp ka et pilved liiguvad idast läände ning ka varjude asukoha järgi sai selgeks teha kummal pool lõuna põhja suund. Viimast ei saand usaldada hommiku vara ja hilja õhtul .
Aga see linna sildi juures seismine meenutab ühte korda kus sõitsime piraajadega autodega ning järsku seisab kodanik alt tab-is sildi alla ja arvatavasti otsis kus on, Muidugi sõideti tast üle ja tehti ka gearist puhtaks. Seda muidugi modis
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
Kommentaarid: 112 loe/lisa |
6 :: |
85 |
tatslinkov
11.07.2014 22:00:21
Alguses tasuks proovida ilma abivahendeid kasutamata mängida, jätkub avastamisrõõmu kauemaks.
Kommentaarid: 2 loe/lisa |
Leinö
11.07.2014 22:41:45
päike on suht koht koguaeg edelas, seega see on üks indikaator.
33 |
-RaiTz-
12.07.2014 01:07:02
Kukkusin ja murdsin jala ja uskumatu kui pikalt pidin roomama, et leida särk millest lahas teha. Õnneks omasin kirvest ja sain ise pulki raiuda, muidu oleks lootusetu olnud. Roomates ei toimu liikumine just meeldivas tempos. Ei soovita kellelegi
28 |
Dj-E
Aeg Maha 2a
12.07.2014 06:58:55
Eile krt mitu tundi kolasin ringi ja siis lõpuks nägin ühte teist mängijat kah. Aga see millegipärast vajus mo kõrval kokku ja suri ära. Sain hetkeks mõned asjad tema käest aga siis ründasid 2 zombit ja neid labidaga maha lüüa oli võimatu kuna nende rünnakud tegid mulle viga isegi siis kui füüsiline kontakt puudus ja minu rünnakud ei teinud neile mingit viga. Ju mängu bug vms. Zombisi on ikka väga vähe ja teisi mängijaid ei näe eriti üldse. Maybe olen kusagil jams serveris... Dont know.
_________________ Eesti suurim Ubisofti fänn!!! |
21 |
Arx07
12.07.2014 09:57:48
Dj-E kirjutas: |
Eile krt mitu tundi kolasin ringi ja siis lõpuks nägin ühte teist mängijat kah. Aga see millegipärast vajus mo kõrval kokku ja suri ära. Sain hetkeks mõned asjad tema käest aga siis ründasid 2 zombit ja neid labidaga maha lüüa oli võimatu kuna nende rünnakud tegid mulle viga isegi siis kui füüsiline kontakt puudus ja minu rünnakud ei teinud neile mingit viga. Ju mängu bug vms. Zombisi on ikka väga vähe ja teisi mängijaid ei näe eriti üldse. Maybe olen kusagil jams serveris... Dont know. |
Zombisid tuleb lüüa pähe, soovitatavalt selja tagant... kui juba sind märganud on siis minu arust mõttekam eest ära joosta, kui just pole tulirelva millega ilma probleemita maha lasta(tavalise püstoliga lase või jalga ja surnud). Inimesi kohtab strateegiliselt paremates kohtades rohkem, näiteks 2 lennuvälja. Aga üldiselt inimesed on tunduvalt ohtlikumad kui zombid
-RaiTz-
12.07.2014 10:25:10
Labidaga on mõttetu vehkida, sellega on nii ebamäärane tabamine. Kui kirvest pole löön pigem käteka, siis saad ta nokki lüüa ja maas edasi taguda. Vehkisin ka kunagi mingi sõnnikuhargiga, aga lõpetasin ikka kätega.
28 |
Diesel157
12.07.2014 10:33:38
Tasub kamp kokku ajada ja nii mängida, üksi võidki nädal aega ringi joosta ja mitte kedagi näha. Lisaks mida rohkem vendi kaasas on seda parem security samas tõmbab ka rohkem tähelepanu.
Kommentaarid: 155 loe/lisa |
140 |
-RaiTz-
12.07.2014 11:17:02
Kuidas see chat mängus toimib. Kas klaviatuuriga on koguaeg global chat või saab kuidagi ainult lähedal asuvate inimestega ka rääkida?
28 |
