uus teema   vasta Raud »  Kõvad kettad »  KÕVAKETTAD (HDD) - Statistika, Võrdlus, Testid, Soovitused, Info märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 119, 120, 121 ... 172, 173, 174  järgmine
kaabakas
kaabakas
sõnum 01.04.2014 21:08:07 vasta tsitaadiga
Aprill:)
pois11
sõnum 04.04.2014 22:28:13 vasta tsitaadiga
Kas keegi võiks lühidalt eesti keeles ära seletada mis vahe on ATA / SATA / RAID valikul. Emaplaadi biosil on need valikud saadaval ja hetkel on ATA.
sõnum 04.04.2014 22:33:08 vasta tsitaadiga
pois11
sõnum 04.04.2014 22:58:19 vasta tsitaadiga
no aga kui mul on üks SSD ketas masinas mis ma siis panema pean?
sõnum 04.04.2014 23:35:09 vasta tsitaadiga
Sata ja ahci mode
Sul win juba installitud?
Kui jah, siis guugelda ennem win7 ja ahci mode kui selle paned biosis
Ehk keegi seletab kui vaja, sest mul hakkab internet otsa saama väljamaal icon_biggrin.gif
DVDRW
DVDRW
sõnum 05.04.2014 06:46:29 vasta tsitaadiga
Üks bit tuli ära muuta kuskil registris enne achi panekut.
sõnum 07.04.2014 19:05:12 vasta tsitaadiga
Seagate-lt tänane uudis:
Seagate has today announced what they're claiming is the "world's fastest 6TB HDD", known imaginatively as the Seagate Enterprise Capacity 3.5 HDD v4. The fast speeds can be mostly put down to an operating speed of 7,200 RPM, which makes the hard drive 25% faster than competing solutions.
The Enterprise Capacity 2.5 HDD v4 boasts either 12 Gb/s SAS connectivity, or standard SATA 6 Gb/s, depending on the model you opt for, delivering a sustained transfer rate of up to 226 MB/s. Seagate also claims the drive offers the "highest density storage per square foot in the industry", as it fits into a standard 3.5" bay.
As the drive is designed for enterprise scenarios such as cloud data centers, it's built for reliability. The drive's data sheet lists a mean time between failure of 1.4 million hours (around 160 years), and has been engineered for constant workloads, or 550 TB of transfers per year.
http://www.techspot.com/news/56286-seagate-announces-worlds-fastest-6-tb-hard-drive.html
SurfData
SurfData
sõnum 08.04.2014 11:40:00 vasta tsitaadiga
tahanteada kirjutas:
zimson
zimson
sõnum 08.04.2014 12:35:51 vasta tsitaadiga
WD Green 2TB ketas, HD Tune free smarti ega muud infot ei näita samas kui tasuline versioon näitab. Oskab keegi öelda, milles asi võib olla? Lihtsalt liiga uus ja suur ketas tasuta versiooni jaoks?
Juriidiliselt on kõik korrektne!
Kommentaarid: 43 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 42
SurfData
SurfData
sõnum 11.04.2014 16:14:45 vasta tsitaadiga
Enter Price seeria oma siis ST6000NM0024, reaalne suurus 5588,9GB
sõnum 11.04.2014 16:19:42 vasta tsitaadiga
- londiste
SurfData
SurfData
sõnum 11.04.2014 16:31:46 vasta tsitaadiga
londiste kirjutas:
Eip, nagu öeldud, siis 6TB ehk reaalselt kasutatav 5588,9GB
sõnum 11.04.2014 16:57:40 vasta tsitaadiga
eeldad tibibaite?
- londiste
Chidori
Chidori
sõnum 11.04.2014 17:17:21 vasta tsitaadiga
SurfData kirjutas:
IEC kohaselt on reaalselt kasutatav andmeteks 5588,9 GiB
Windowsis failide "size" peaks olema IEC kohaselt Gibibyte-des ja "size on disk" Gigabyte-des. Või vähemalt olen mina niimoodi sellest aru saanud.
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 99
sõnum 11.04.2014 17:25:50 vasta tsitaadiga
eks ma meelega nokin. 6tb (terabaiti) ehk siis 5588.9gib (gibibaiti).
oi kuidas mulle põhimõtteliselt see binary prefixite ümbermängimine ei meeldi, aga kui me si ja binary eesliiteid samas lauses võrdleme, siis võiks ikkagi enam-vähem normaalselt tähistada.
Chidori, windows peaks nii ketta kui failide suurust binary prefixidega näitama. ajaloolistel põhjustel. size on disk on koos overheadiga (blokid, sektorid etc pudi).
- londiste
toivos
toivos
sõnum 16.04.2014 09:27:52 vasta tsitaadiga
Mis juhtub kettaga kui on piisavalt kaua kolksunud? Poola andmetaastusse toodud kettast pilte saab näha siin:
http://img835.imageshack.us/img835/5028/w1ff.png
http://img836.imageshack.us/img836/5092/1sup.png
http://img834.imageshack.us/img834/1909/fbfs.png
Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt.
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 66
UrmoZ
UrmoZ
sõnum 16.04.2014 10:42:19 vasta tsitaadiga
Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Kommentaarid: 225 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 205
SurfData
SurfData
sõnum 16.04.2014 11:44:46 vasta tsitaadiga
UrmoZ kirjutas:
tegemist on vist 80 MB, jah MB mitte GB kettaga? Seega miski kümme aastakest ikka kolksus icon_biggrin.gif
wicked
wicked
sõnum 16.04.2014 11:49:55 vasta tsitaadiga
toivos, midagi kätte ka saadi?
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 63
toivos
toivos
sõnum 16.04.2014 12:29:33 vasta tsitaadiga
wicked kirjutas:
sõnum 30.04.2014 21:56:32 vasta tsitaadiga
The Register "sahistab": icon_cool.gif
6TB - big? Pah! Seagate plans to pull out 8TB and 10TB MONSTERS
We got all excited about Seagate's latest 6TB drive but, really, we haven't seen anything yet. It has been revealed that the spinning dusk company is anticipating 8TB and 10TB drives later this year.
This info came out in the company's third quarter results earnings call, where chairman, president and CEO Steve Luczo was talking about price erosion with nearline storage, high-capacity 3.5-inch drives:
Edasi juba lingil:
http://www.theregister.co.uk/2014/04/30/seagate_drive_capacity_increase_on_way/
SurfData
SurfData
sõnum 02.05.2014 11:22:31 vasta tsitaadiga
Edasi juba lingil:
spezwend
sõnum 12.05.2014 22:23:58 vasta tsitaadiga
Overall, there is not a correlation between operating temperature and failure rates.
As long as you run drives well within their allowed range of operating temperatures, keeping them cooler doesn’t matter.
http://blog.backblaze.com/2014/05/12/hard-drive-temperature-does-it-matter/
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 63
miq1988
miq1988
sõnum 13.05.2014 06:37:56 vasta tsitaadiga
Teises teemas ei saanud vastust. Küsime siis siin ka.
SSD saab esimest korda käiku võetud. Samsung Evo 840 250GB
Selle järgi oleks normaalne kõik teha ?
http://www.computing.net/howtos/show/solid-state-drive-ssd-tweaks-for-windows-7/552.html
I don't need anger management. I need people to stop pissing me off !
sõnum 13.05.2014 08:10:28 vasta tsitaadiga
miq1988, Punkt 6 Pagefile olemasolu ja suurus sõltub rohkem RAM kogusest, kui SSD olemasolust. Kui sa kasutad mingeid väga vanu programme või mänge mis võivad eeldada pagefile olemasolu, siis on kasulik seada kindel suurus. 16GB+ RAM korral on juba mõttekas üldiselt kinni keerata pagefile.
Punkt 9 on soovitatav ainult siis, kui arvuti jookseb UPS tagant või on SSD-le sisseehitatud kaitsemehhanism ootamatu voolukadumise korral puhvri nullimiseks. Või veelparem mõlemad. Jään vastuse võlgu, kas EVO-l see on, aga ma usun, et pole.
Punkt 11 on suht mõttetu.
EDIT: Loe ka seda: http://blogs.msdn.com/b/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx
uus teema   vasta Raud »  Kõvad kettad »  KÕVAKETTAD (HDD) - Statistika, Võrdlus, Testid, Soovitused, Info mine lehele eelmine  1, 2, 3 ... 119, 120, 121 ... 172, 173, 174  järgmine
