sant
17.12.2013 18:41:46
Jah see veel odavam Aga samas see on gigabyte mitte asus.
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
| Kommentaarid: 67 loe/lisa |
60 |
kaspar00
17.12.2013 18:43:50
ma siuke kohatu inimene, kellel on iga tootja plaadid veatult töötand selles suhtes ei oska kaasa rääkida kaubamärkide seisukohast
102 |
Evil
Hull
17.12.2013 18:51:46
| Sponge kirjutas: |
äge, kas midagi külma plaanis ka peale kallama hakata ?  |
Radikas käib arvatavasti akna taga ära küll ja usun et 6ghz on tehtav külma veega. Hetkel ei oska öelda kas tahan lämmi või dice-iga jamama hakata.
| kaspar00 kirjutas: |
ma siuke kohatu inimene, kellel on iga tootja plaadid veatult töötand selles suhtes ei oska kaasa rääkida kaubamärkide seisukohast |
Eks ta rohkem tihendis kinni on. Ise olin ka tükk aega gigabyte plaatide peal ja nüüd üle pika aja asus. Vajab harjumist aga mitte midagi hullu pole.
202 |
Genert
17.12.2013 18:59:52
See, et 8+2 VRM on, ei tähenda, et see parem oleks. ;D
The ASRock 990FX Extreme9 looks very nice, especially its VRM which gives the impression of being able to supply the processor even more efficiently than the Asus. Check out the figures here:
At full load, the Voltage Regulator runs about 5 degress cooler (which could be explained by the design, the heatsink or simply where the temperature probe was placed) but it actually consumes slightly more power than the Asus. That is surprising - and a little disappointing for such a pretty board - but it does highlight that more VRM phases does not necessarily mean a more efficient power delivery. This board is overpriced and only has one PCI slot so not for me.
I did consider the Gigabyte GA-970A-UD3 as they too build very good quality motherboards. This model has been around for a while and I get the feeling it won't be too much longer before they stop providing BIOS updates. Also, even though it has an 8+2 phase VRM it performs worse than the Asus (see the link for the Asrock review above). |
_________________ Wannapreneur - Front-End Wizard
http://genert.github.io/ |
sant
17.12.2013 19:14:17
Genert, kui saad viska linki selle gigabyte arvustuse kohta, loeks huviga.
60 |
Evil
Hull
17.12.2013 19:37:31
Seda tasub ka uurida. See jõhker toiteahel Asrockil andis miskipärast kõige madalama prosekloki.
Bulldozer ja vishera omanikele soovitan prose temperatuuri jälgimiseks HWmonitori kasutada, minu jaoks kõige täpsemad temperatuurid. Core Temp näitab mingeid lambinumbreid.
202 |
martin366
17.12.2013 19:42:52
Soovitan 2 plaati.
See mis mul, ehk siis Asus Sabertooth 990FX
või Gigabyte GA-990FXA-UD3
172 |
Erx15
17.12.2013 19:43:25
Loomulikult ei pea Asuse plat olema, võib vabalt ka midagi muud olla, kui on parem. Uurin neid muid plaate ka. Eeldasin, et see Asuse 6+2+2 ahel on samaväärne, mis 8+2. Selles mõttes et ma mingeid haigeid kokke taga ei hakka ajama.
| Kommentaarid: 17 loe/lisa |
16 |
sant
17.12.2013 19:44:15
| Evil kirjutas: |
Bulldozer ja vishera omanikele soovitan prose temperatuuri jälgimiseks HWmonitori kasutada, minu jaoks kõige täpsemad temperatuurid. Core Temp näitab mingeid lambinumbreid. |
Millega sa muidu kellasid oma proset? Biosest või mingi progega?
Nimelt mul endal on msi plate ja selle soft ei tööta üldse mul, ja aod ei toimi korralikult.
60 |
martin366
172 |
Evil
Hull
17.12.2013 19:50:11
| sant kirjutas: |
| Evil kirjutas: |
Nimelt mul endal on msi plate ja selle soft ei tööta üldse mul, ja aod ei toimi korralikult. |
Enamus biosist aga windowsi keskkonnas kasutasin AI suite millega sai lennu pealt suht kõike teha.
202 |
sant
17.12.2013 19:55:17
| Evil kirjutas: |
| sant kirjutas: |
| Evil kirjutas: |
Enamus biosist aga windowsi keskkonnas kasutasin AI suite millega sai lennu pealt suht kõike teha.  |
Mis asi see AI suite on
60 |
Evil
Hull
17.12.2013 20:10:26
| sant kirjutas: |
| Evil kirjutas: |
| sant kirjutas: |
| Evil kirjutas: |
Mis asi see AI suite on  |
Google aitab. Aga panin veidi puusse, täpsemalt asuse enda progega tegu. Asus TurboV Evo-ga saad voldiga ja klokiga mängida.
202 |
Genert
Siidiuss
17.12.2013 23:41:01
Ise mõtlen ka amd 8350 oma kasti sisse torgata. Ei tea kas ta 8320 st parem just on. Aga 4 GHz algkiirus kõlab justkui paremini. Kuigi jah 8320 pannakse ka kerge vaevaga 4 GHz peal käia. Ei teagi kumb see parem valik oleks.
Siiani olen ka gigabyte plaate kasutanud. Aga suur kiusatus on vahelduseks proovida ka seda Asus Socket AM3+ /M5A99FX PRO R2.0 plaati . Kuigi Gigabyte GA-990FXA-UD3 paistab ka vägagi magus suutäis olema. Siiski mille poolest see Asuse PRO parem valik oleks? Kvaliteet parem? kellasid vilesid rohkem?
caramis
17.12.2013 23:46:54
| ASUSe plaadil on digiVRM, väidetavalt kõvasti parem. samuti on ökorežiim parem sellel. väidetavalt
| Kommentaarid: 174 loe/lisa |
151 |
sant
17.12.2013 23:55:23
| Siidiuss kirjutas: |
Siiani olen ka gigabyte plaate kasutanud. Aga suur kiusatus on vahelduseks proovida ka seda Asus Socket AM3+ /M5A99FX PRO R2.0 plaati . Kuigi Gigabyte GA-990FXA-UD3 paistab ka vägagi magus suutäis olema. Siiski mille poolest see Asuse PRO parem valik oleks? Kvaliteet parem? kellasid vilesid rohkem? |
8320 on best bang Kui kellad siis pole eriti vahet 8350-ga, 8320 ja korralik cooler
4,5-5 GHz vahemikku läheb iga 8320 Kui volti ei anna siis ei lähe kah.
60 |
Siidiuss
18.12.2013 00:26:10
| Karta on, et tuleb siis asuse PRO võtta. See paistab ka palju auhindu võitnud olevat. Järgmiseks tahaks küsida mis videokaarti oleks mõistlikum sinna paigutada. Kas asus amd radeon r9 270x või gtx 760?
Erx15
16 |
Chidori
18.12.2013 01:20:01
| Kas asus amd radeon r9 270x või gtx 760? |
GTX760 on suhtkoht samal pulgal mis r9 280x
99 |
martin366
172 |
SilQ
18.12.2013 08:56:37
| Chidori kirjutas: |
GTX760 on suhtkoht samal pulgal mis r9 280x |
On ikka või? Mis ajast?
215 |
Chidori
18.12.2013 11:11:42
SilQ, no päris mitte, aga parem kui 270...Ma vaatasin BF3 järgi
99 |
One
18.12.2013 11:51:15
| 9% keskmiselt on see 760 kiirem kui 270X, 280X ikka omajagu sellest kiirem
728 |
Evil
Hull
18.12.2013 18:33:08
Dual core bulldozer:
Klokk
Aeg on jätkuvalt mõttetu, XP-d kasutama kui tahaks parimat aega.
202 |
Siidiuss
sant
21.12.2013 00:54:30
prose kiirendamist ka ilmselt eriti ei talu
Talub ikka, võtab parem jahuti, see valitu sul nats lahja. Vali midagi 30-40 euri vahel.
60 |
caramis
21.12.2013 02:05:52
| sant kirjutas: |
Talub ikka, võtab parem jahuti, see valitu sul nats lahja. Vali midagi 30-40 euri vahel. |
tegelikult tahaks teada, kuidas 212EVO AMD kaheksatuumsega hakkama saab. oskab keegi seletada..? ja nüüd EVO ja X vahe samuti
151 |
aht0
21.12.2013 03:58:43
stock kiirustel jahutab ära.Multithreadiga mängudes (BF3/4) temp 55-62 kraadi (minu masinas), seda siis ühe ventilaatoriga õhku sisse surudes, 212 toetab kahte ventilaatorit, kahega proovinud pole. Klokkida ka pole proovinud (ei eruta märgatav energiakulu tõus ). Muul ajal, ilma eriliselt koormamata, kõigub prose temp nii 30-38C ringis
| Kommentaarid: 82 loe/lisa |
71 |
martin366
21.12.2013 04:40:28
| caramis kirjutas: |
| sant kirjutas: |
tegelikult tahaks teada, kuidas 212EVO AMD kaheksatuumsega hakkama saab. oskab keegi seletada..? ja nüüd EVO ja X vahe samuti |
Mul sai väga hästi @ 4.5ghz 1.4V FX8320, ainuüksi CPU jahutist ei piisa, kastis peab korralik õhuvool ka olema.
212 Evo ja X vahe on suht olematu tegelikkuses, kui kasutada sama ventikat
172 |
xpander
21.12.2013 05:27:15
| martin366 kirjutas: |
212 Evo ja X vahe on suht olematu tegelikkuses, kui kasutada sama ventikat  |
kindel et 1.4 peal aint? ..väga hea isend siis
mul 1.4 peal @4.4Ghz prime95 (linuxi version) tehes pani 4 tuuma pillid kotti
1.435V aga toimib edukalt
_________________ Linux Gaming Videos: Xpander69 |
| Kommentaarid: 18 loe/lisa |
16 |
martin366
21.12.2013 05:35:03
| xpander kirjutas: |
1.435V aga toimib edukalt |
Veits üle keskmise isend. 1.5V @ 5ghz teeb kah Palju loeb emaplaadist
172 |
Siidiuss
kaspar00
102 |
Siidiuss
21.12.2013 18:58:54
| Ma nüüd ka ei usu eriti. Huvitav kuidas cpu boss nii mööda paneb.
Evil
Hull
22.12.2013 16:43:17
Mingi cinebenchi tulemus:
Kõrgele pingele ei reageeri hästi, samuti on temperatuurid imelikud. Tellisin swiftech apogee XT-le amd kinnituse.
Hetkel on prosel EK Supreme LT Amd nickel plokk. Eks siis näeb kui palju parem Swiftech Apogee XT amd-ga on.
202 |
Siidiuss
22.12.2013 17:32:58
| Selline küsimus,et kas 8350 toetab kingston hyperx blue 2x4gb mälusid ja mis sagedustel need tööle hakkaks asuse pro plaadil kui hakkavad? Ja kas 8320 on mingeid erinevusi mälude toetamise osas võrreldes 8350 prosega?
kaspar00
22.12.2013 17:53:34
mobost sõltub rohkem seoses mäludega kui prosest. 8320 ja 8350 vahel mingit erinevust pole sel teemal.
blu - 8GB Kit* (2x4GB) - DDR3 1600MHz CL9 Intel XMP DIMM
Part Number: KHX1600C9D3B1K2/8GX
Specs: DDR3, 1600MHz, CL9, 1.65V, Unbuffered, Spec Sheet PDF
Profile 1: 1600MHz, 9-9-9, 1.65V
Profile 2: 1333MHz, 9-9-9, 1.5V
aga ei tundu nagu eriti atraktiivne mälu kui isegi 1600MHz peal juba 1.65V tahetakse
https://www.hinnavaatlus.ee/products/Arvutikomponendid/Mälud/408637/
see pigem ehk nt, 1866MHz, 1.5V, ja peaks asuse plaadiga D.O.C.P valides täitsa toimiva 1866mhz profiili andma.
102 |
Siidiuss
22.12.2013 17:55:05
Ega ta just atraktiivne mälu ei ole jah. Aga töötab siis see kingstoni 1600mz mälu ikka nende prosedega? Asi selles et need mälud lihtsalt olemas, uued karbi sees.
viimati muutis Siidiuss 22.12.2013 17:57:32, muudetud 1 kord |
kaspar00
22.12.2013 17:56:16
kindlsti töötab, 1333mhz peal 99,95% muude kiiruste jaoks võib aga ei pruugi olla vaja manuaalselt seadete paikasättimist.
102 |
Dave20
23.12.2013 23:59:29
| Selline mure, et mängides crisys3-e läheb cpu temp 65c ja Ai suites tuleb teade, et prose temp liiga kõrge ja see "65" muutub punaseks. Mängus aga langeb fps nii, et pole enam mängitav ja kui see natuke aega nii olnud, siis cpu temp langeb ka väga kiirelt 55 peale, kuigi cpu ventika kiirus koguaeg põhjas. Kas cpu ise regullib ennast madalale võimsusele, et kaitse nagu mingi? Muidu ei saaks ju temp nii järsku alla minna. Ja saan aru, et mängus läheb fps selle pärast nii madalaks, et cpu kuumeneb üle natukeseks ajaks?
| Kommentaarid: 26 loe/lisa |
25 |
marxveix
24.12.2013 00:01:50
| Dave20 kirjutas: |
| Selline mure, et mängides crisys3-e läheb cpu temp 65c ja Ai suites tuleb teade, et prose temp liiga kõrge ja see "65" muutub punaseks. Mängus aga langeb fps nii, et pole enam mängitav ja kui see aeg nii olnud, siis cpu temp langeb ka väga kiirelt 55 peale, kuigi cpu ventika kiirus koguaeg põhjas. Kas cpu ise regullib ennast madalale võimsusele, et kaitse nagu mingi? Muidu ei saaks ju temp nii järsku alla minna. Ja saan aru, et mängus läheb fps selle pärast nii madalaks, et cpu kuumeneb üle natukeseks ajaks? |
Ikka regullib. Pane parem jahutus koos parema pastaga. Lisavent korpusesse ka paha ei tee.
| Kommentaarid: 310 loe/lisa |
270 |
Dave20
24.12.2013 00:30:47
Jälgisin nüüd, cpu-Z oli lahti ja kui temp 65 läks, siis prose kiirus langes 1400MHz peale, kuni temp 56 peale jälle langes. Kas seda piirmäära biosis muuta ei saa? Mõtlen, et paneks ülekuumenemis tempi 70 peale.
Ps. kui juba teemaks, siis milline siit tuleks valida, mis suudaks selle prose ära rahuldada? : http://arvutitark.ee/est/TOOTEKATALOOG/ARVUTIKOMPONENDID-Jahutid//?t=Cooler%20Master
Alla 40eu peaks jääma...
25 |
kaspar00
24.12.2013 00:43:23
vaata pasta alustuseks üle ikka.. vabalt võib olla seda seal nt 2x rohkem kui vaja ja sellepärast 10c soojem kui norm
102 |
Teiv
24.12.2013 01:00:37
Dave20, Asuse AMD emaplaatidel on CPU seadete all HPC mode vmt, see välja, siis throttling kaob.
65 kraadi ei ole ka midagi hullu kohe üldse mitte.
_________________ Black Edition |
69 |
Dave20
24.12.2013 01:31:26
| Teiv kirjutas: |
65 kraadi ei ole ka midagi hullu kohe üldse mitte. |
Siis ei oleks 65 hullu jah, kui ta crashi ei paneks ja poolt kiirust alla ei tõmbaks, aga norm kui saab seda muuta Kohe proovin järgi
25 |
Siidiuss
24.12.2013 01:33:16
| Mina ei tea mis teha oma kingstoni 1600mz intel xmp cl9 mäludega. Kõlbavad need siis asus ja amd protsessorile või peaks neid inteli omanikele pakkuma. Ja endale mingi 14900 mälu 1866mz ostma või pole asjal erilist jumet? Vaatan siin päris paljudel profiilis kingstoni 1600 mz mälud ja huvitav kuidas toimivad ja mis sagedustel?
Dave20
24.12.2013 01:37:43
Siidiuss: Mul mälud 1600 toimivad.
Teiv: HPC mode juba oli disabled, panin enabled või ei peaks enabled panema? Mingi võimalus peaks ju olema selle temperatuuri piiri tõsta kus kiiruse alla automaatselt tõmbab?
25 |
Teiv
24.12.2013 01:45:31
Dave20, tähendab jah enabled peal pidi vist olema, sorri, ei mäletanud täpselt.
Mis piiri muutmisse puutub, siis pead otsima, ei tea küll.
69 |
Dave20
24.12.2013 01:47:32
| Teiv kirjutas: |
Mis piiri muutmisse puutub, siis pead otsima, ei tea küll. |
Aga see throttling tähendabki, et võtab selle piirangu maha?
25 |
