uus teema   vasta Tarkvara »  Arvutimängude foorum »  Starbound märgi kõik teemad loetuks
mine lehele 1, 2  järgmine
Midigi
Midigi
sõnum 26.11.2013 11:54:42 Starbound vasta tsitaadiga
STARBOUND
    Ametlik leht: Starbound
    Ametlik Foorum: Foorum
    Mängu väljalaskeaeg: Jul 22, 2016
    Hind: 13,99€
    Kirjeldus:
    Starbound begins with you fleeing your homeworld in a space shuttle, just as it’s destroyed by an unknown enemy. With nothing to guide it, the escape pod shoots into space without direction, becoming hopelessly lost in a sea of stars. As luck would have it, the space shuttle touches down on a habitable planet and an adventure begins that will take you hurtling across the universe. Starbound contains both quests and story driven missions, buried inside its vast sandbox universe. Planets in Starbound are entirely procedurally generated and filled to the brim with unique content. We went into the planet generation with one simple goal: no two planets should be the same. By procedurally generating even the smallest details,
    we’re doing just that. Not only is the terrain of the planet procedurally generated, but the weather, the gravity, the difficulty level, the plant life, the behaviour and appearance of alien creatures, and much more all contain random or procedurally generated elements.
Link
viimati muutis Midigi 25.10.2016 22:04:37, muudetud 5 korda
Timberg
ööKARU
Timberg
sõnum 26.11.2013 12:42:59 vasta tsitaadiga
4 packi keegi tahab võtta? 11,25 doltsi näkku.
allavett
allavett
sõnum 26.11.2013 16:45:04 vasta tsitaadiga
Tahad ettemaksuna või pärast ostu kandib?
Twitch.tv/allavett
Kommentaarid: 49 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 46
Timberg
ööKARU
Timberg
sõnum 26.11.2013 18:10:29 vasta tsitaadiga
Ettemaksuga thumbs_up.gif Saadan pangainfo kui puuduvad 2 inimest olemas.
Siis ostan ära.
allavett
allavett
sõnum 26.11.2013 19:46:56 vasta tsitaadiga
Twitch.tv/allavett
muff
muff
sõnum 26.11.2013 19:48:55 vasta tsitaadiga
Ot kas siin on Terraria tegija ka mängus?
Timberg
ööKARU
Timberg
sõnum 26.11.2013 20:01:36 vasta tsitaadiga
muff kirjutas:
Tiy
Finn Brice was the main Sprite Artist for Terraria until around April 2011. He currently lives in London, UK and is working on his new game project Starbound. He is no longer affiliated with Re-logic.
Mercury
sõnum 26.11.2013 23:24:16 vasta tsitaadiga
Kas annab linuxi native serverit hostida?
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 60
Midigi
Midigi
sõnum 03.12.2013 11:32:42 vasta tsitaadiga
Mercury kirjutas:
''I'm developing in Linux. I use Linux pretty much exclusively. If the game didn't run in Linux I would have a difficult time. So everything works in Linux, natively.''
http://community.playstarbound.com/index.php?threads/linux-server-support-at-release.24013/
Homme beta!!!!!
Link
viimati muutis Midigi 03.12.2013 21:15:20, muudetud 1 kord
Redikate
Redikate
sõnum 04.12.2013 19:42:57 vasta tsitaadiga
Täna kell 20 peaks siis võtmed saama...
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Resistance
sõnum 04.12.2013 20:00:34 vasta tsitaadiga
Edit: otsas
viimati muutis Resistance 04.12.2013 23:48:21, muudetud 1 kord
Midigi
Midigi
sõnum 04.12.2013 20:54:16 vasta tsitaadiga
Steami võti käes ja aktiveeritud, nüüd ootan milla steam järgi jõuab! icon_smile.gif
http://www.twitch.tv/chucklefishlive
Anymomentnow!
Väljas!!!!!
Timberg
ööKARU
Timberg
sõnum 04.12.2013 22:33:48 vasta tsitaadiga
Saatsin võtmed ära. Kui kellelgi mingi jama, siis ps.
Mercury
sõnum 04.12.2013 23:34:43 vasta tsitaadiga
Timberg kirjutas:
Üllatuseks mäng kaalub 3GB.
Redikate
Redikate
sõnum 05.12.2013 01:01:14 vasta tsitaadiga
Meh...
Võibolla sai hiljuti liiga palju Terrariat mängitud ning ei viitsi enam seda stiili mängu, aga mingit WOW effekti pole kahjuks.
http://nodejs.org/
cubedude
cubedude
sõnum 05.12.2013 13:28:10 vasta tsitaadiga
Panen ka märgi maha
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 87
Mercury
sõnum 05.12.2013 21:06:56 vasta tsitaadiga
Panen serveri maha aadressil: merkuri.me (mis peaks 24/7 töötama kuni ei crashi..)
Kuna StarBound on nii uus, siis puudub igasugune konfiguratsioon serverile, nii et oleks hea kui spawn esimestel päevadel maha ei rikuta.
cubedude
cubedude
sõnum 05.12.2013 22:37:40 vasta tsitaadiga
Redikate
Redikate
sõnum 06.12.2013 17:42:31 vasta tsitaadiga
cubedude kirjutas:
Mul on üks üle 4 packist.
E: Kasutaja cubedude sai jaole.
http://nodejs.org/
Timberg
ööKARU
Timberg
sõnum 06.12.2013 18:54:53 vasta tsitaadiga
Eile jõudsin põgusalt määngida.
Esmamuljed. Hinda väärt.
Hea: liikumine sujuv
mäng piisavalt kasutajasõbraliku ja mugava liidesega
mägitavus "mõnus"
jõhkralt hea soundtrack
Halb: beta (1 crash)
tegelasi tuleb käsitsi failides möllamisega kustutada
Tahaks kangesti mõne sõbraga seda mitmikmängus lasta, kui aega rohkem. Samas enne paari nädalat seda aega vist ei tule.
Igatahes, kui 2d mängud meeldivad, siis soovitan. Kui ei meeldi 2d mängud, siis ei soovita icon_smile.gif
allavett
allavett
sõnum 07.12.2013 15:51:33 vasta tsitaadiga
Mercury kirjutas:
Server restardib ka vahel? Mingi jube lääg on :/
Twitch.tv/allavett
Mercury
sõnum 07.12.2013 16:36:43 vasta tsitaadiga
allavett kirjutas:
Mercury kirjutas:
Olen probleemist teadlik, töötan selle kallal.
e. Kõik on nüüdseks korras.
viimati muutis Mercury 10.12.2013 01:37:38, muudetud 4 korda
allavett
allavett
sõnum 07.12.2013 17:00:19 vasta tsitaadiga
Twitch.tv/allavett
Windscam
Windscam
sõnum 07.12.2013 23:09:19 vasta tsitaadiga
Praegu paistab server täitsa töötavat. Mänguga ühinedes algul oli mingit sorti lag aga see kadus ära mingi aja vältel. Annan siis kerge ülevaate oma kogemusest kah.
E: kerge lagg on tagasi
E2: tõmbasin kogemuse osa õigesti tagide vahele.
Üldiselt on mäng siiski suhteliselt fun ja leidub päris huvitavaid kilde. Tundub küll suht minecrafti ja terraria pealt maha võetud olevat aga õnneks on asju, mida neis ei olnud ja säilitab mängitavuse seni kuni eelmistes update-e juurde ei tule või kuni kõik asjad käes ja üldine point mängul saavutatud.
viimati muutis Windscam 08.12.2013 14:11:10, muudetud 1 kord
Timberg
ööKARU
Timberg
sõnum 08.12.2013 11:42:58 vasta tsitaadiga
Ma ei julge eelmist postitust tervelt lugeda, tundub kuidagi spoilereid täis icon_razz.gif
Püüan ise mängida võimalikult palju nii, et wikit ja teisi asju ei kasuta. Ise avastan. Hetkel olen veel esimese planeedil. Mänginud kokku vist mingi 7h.
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Starbound mine lehele 1, 2  järgmine
