Ametlik leht: Starbound Ametlik Foorum: Foorum Mängu väljalaskeaeg: Jul 22, 2016
Hind: 13,99€ Kirjeldus:
Starbound begins with you fleeing your homeworld in a space shuttle, just as it’s destroyed by an unknown enemy. With nothing to guide it, the escape pod shoots into space without direction, becoming hopelessly lost in a sea of stars. As luck would have it, the space shuttle touches down on a habitable planet and an adventure begins that will take you hurtling across the universe. Starbound contains both quests and story driven missions, buried inside its vast sandbox universe. Planets in Starbound are entirely procedurally generated and filled to the brim with unique content. We went into the planet generation with one simple goal: no two planets should be the same. By procedurally generating even the smallest details,
we’re doing just that. Not only is the terrain of the planet procedurally generated, but the weather, the gravity, the difficulty level, the plant life, the behaviour and appearance of alien creatures, and much more all contain random or procedurally generated elements.
Tiy
Finn Brice was the main Sprite Artist for Terraria until around April 2011. He currently lives in London, UK and is working on his new game project Starbound. He is no longer affiliated with Re-logic.
''I'm developing in Linux. I use Linux pretty much exclusively. If the game didn't run in Linux I would have a difficult time. So everything works in Linux, natively.''
Meh...
Võibolla sai hiljuti liiga palju Terrariat mängitud ning ei viitsi enam seda stiili mängu, aga mingit WOW effekti pole kahjuks. _________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
Panen serveri maha aadressil: merkuri.me (mis peaks 24/7 töötama kuni ei crashi..)
Kuna StarBound on nii uus, siis puudub igasugune konfiguratsioon serverile, nii et oleks hea kui spawn esimestel päevadel maha ei rikuta.
Server restardib ka vahel? Mingi jube lääg on :/ _________________ Twitch.tv/allavett
Olen probleemist teadlik, töötan selle kallal.
e. Kõik on nüüdseks korras.
viimati muutis Mercury 10.12.2013 01:37:38, muudetud 4 korda
Praegu paistab server täitsa töötavat. Mänguga ühinedes algul oli mingit sorti lag aga see kadus ära mingi aja vältel. Annan siis kerge ülevaate oma kogemusest kah.
E: kerge lagg on tagasi
E2: tõmbasin kogemuse osa õigesti tagide vahele.
Endal muidu juba Diamond pickaxe käes, ning üritan viimast gold seti itemit kokku ajada, et siis steeliks ära upgradeda. Kõige raskem osa on siiani olnud välja nuputamine, kuidas mida järgmisena saab, lõpuks võtsin wiki appi ning õnneks/kahjuks on seal veel suhteliselt vähe informatsiooni itemite ja nende saamise kohta, enda vajaliku info sain muidugi kätte.
Mäng on suht ellujäämise peale üles ehitatud ning algus tundub suhteliselt raske, aga küll see tunne muidugi ajapikku kaob. Ise surin mingi 6-7x enne kui korralikke asjade kallale tegutsema sain(ja noh järgmiste planeetide peal on veel hullem). Surres kaotab praegu ainult pixleid(money) ja seda siis mingi portsjon olemas olevast. Planeetide vaheline liikumine on suht mõistlik ja hetkel kaugeim hüpe, mis ma teinud on 200 fueli eest umbes, ei ole just midagi ületamatut kokku ajada. Olen leidnud ka 2 muusika instrumenti, millega saab siis mängus sees palasid mängida(muidugi tuleb eelnevalt need vist valmis teha).
Üldiselt on mäng siiski suhteliselt fun ja leidub päris huvitavaid kilde. Tundub küll suht minecrafti ja terraria pealt maha võetud olevat aga õnneks on asju, mida neis ei olnud ja säilitab mängitavuse seni kuni eelmistes update-e juurde ei tule või kuni kõik asjad käes ja üldine point mängul saavutatud.
viimati muutis Windscam 08.12.2013 14:11:10, muudetud 1 kord
Ma ei julge eelmist postitust tervelt lugeda, tundub kuidagi spoilereid täis
Püüan ise mängida võimalikult palju nii, et wikit ja teisi asju ei kasuta. Ise avastan. Hetkel olen veel esimese planeedil. Mänginud kokku vist mingi 7h.
Nädalavahetusel sai edasi arendatud serverit. Serveri "lääg" peaks nüüdseks ära parandatud olema, olid neti probleemid kus paketid läksid kaduma. Kui vahest viskab läggi, siis ei tasu ära unustada mis algstaadiumis mäng alles on.
Server teeb iga 5 hommiku ajal taaskäivituse ja laseb starbound uuendada kui vaja.
Arendatud välja ka leht kus saab näha mitu mängijat on parajasti serveris, vestluse ajalugu ja üleüldine serveri jõudlus.
Mercury, väga hea! Eile õhtul sai sõbraga mängitud ja läägiga probleeme ei olnud.
Sai isegi väike monument püsti aetud esimese spawni juurde _________________ Twitch.tv/allavett
Okei. Viimane ehk tänane uuendus oli mahukam ja lasi mängijate kasutajad kui ka serveri maailma ära resettida (This update will probably require a character reset (I’m sorry! Beta ))
Lisaks lõhkus see mu mängijate arvu ja vestluse ajalugu ära
ma hetkel kolan enda põhikasutajaga LV 4 planetite peal ringi durasteel armoriga. Kui keegi liituda tahab et seltskonnaga mängida siis võtke ühendust mumble/ts/skype oleks ka tore samal ajal
Kas keegi oleks huvitatud koos 4-packi ostmisest? Saaks kokku siis 31€, ehk 7,75 € igaühele. Mul on koos sõpradega praegu 3 soovijat olemas, niiet 1 läheks veel vaja. Kes tahab head mängu odavalt?
