uus teema   vasta Raud »  Protsessorid »  Micronics (w6li) MB & Dual processors märgi kõik teemad loetuks
klOun
klOun
sõnum 13.02.2003 01:22:15 Micronics (w6li) MB & Dual processors vasta tsitaadiga
Teema: VRM (voltage regulator module)
Igastahes probleem säärane, tegemist on ühe Micronics’i dualprose emaplaadiga (w6li), millel on peal kaks Socket8 slotti..
Ühes pesas istus varem juba Pentium 200 Pro.. nii lõpuks õnnestus saada ka teine samasugune olend (Pentium 200 Pro)... pistsin siis pesasse ja hakkasin manuali uurima, kuidas asja enableda või mis iganes tegema peab, et asi tööle hakkaks.
<manualist>
If you are installing a second processor, you do not
need to change any jumpers or BIOS settings. The
system will automatically recognize the new processor.
When installing a second processor, a VRM module
must be installed into header J1. In addition, the
second processor must have the same speed rating
and cache amount as the main processor.
NOTE: If your operating system supports dual processors,
you may need to reconfigure or reinstall your operating
system. Refer to your software documentation for more
information.
</manualist>
Nimelt pöörake tähelepanu teisele lõigule, mis manualist välja toodud on „When installing a second processor, a VRM module
must be installed into header J1.“
Nimelt.. see slot asub teise socket’i üleval.. Seejärel lugesin veidi selle VRM’i kohta:
A voltage regulator module (VRM) is an installable module that senses a computer's microprocessor voltage requirements and ensures that the correct voltage is maintained. If you are changing your computer's microprocessor (for example, changing from a Pentium to a Pentium Pro or a Pentium with MMX), you need to add a voltage regulator module to the existing voltage regulator in the motherboard so that the new voltage requirements can be detected and accommodated.
In the case of the Pentium, the original Pentium has the same voltage requirement for its core or basic operation as for its I/O operation. Both use 2.8 volts. However, the Pentium Pro and the Pentium with MMX have different voltage requirements for core (2.8 volts) and I/O (3.3 volts). Adding a VRM allows it to regulate the voltage for I/O while the original regulator built into the motherboard continues to regulate core voltage.
VRM ise näeb välja midagi sellist:
Lõpuks siis poindi juurde, kas ma vajan eraldi seda VRM’i et samasugust Pentium 200 Pro proset dual asendis tööle saada?
Praeguses olekus näitab linuxis mulle cat /proc/cpuinfo ühte proset... kernelile on SMP külge topitud.. kuid nothing... võimalik, et ka confis on viga. Kuid.. millega seda kõige paremini testida saaks? icon_rolleyes.gif
Lugupidamisega,
Priit Pärna
🥫 Experience is one thing you can't get for nothing.
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 70
XYZ
XYZ
sõnum 13.02.2003 11:20:50 vasta tsitaadiga
Mina saan aru sellest inglise keelsest tekstist nii, et sa tõesti vajad seda lisa VRM moodulit, kuna integreeritu töö muutub.
Morillo
Morillo
sõnum 13.02.2003 11:34:09 vasta tsitaadiga
Üldjuhul jep ka uutele IBM serveritele piad prose lisamiseks juurde ostma VRM jublakahind oli miski 1k.- (võin eksida). Kuid ma ei oska öelda, et on neil firmadel ka mingit vahet, või on kõik VRM jublakad ühe standardi järgi!!??
Kommentaarid: 151 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 141
klOun
klOun
sõnum 13.02.2003 16:36:17 vasta tsitaadiga
hmm... 1000.- see paras kirves hind.. soodsam on uus emme ja prose osta icon_razz.gif
Aga just.. kas seda on vaja või mitte...? ja kas on tegemist universaalse jubinaga icon_confused.gif
klOun
klOun
sõnum 18.02.2003 18:18:45 vasta tsitaadiga
oskab keegi äki öelda, on mingisugune soft, mille saaks näiteks boot diskile lasta.. ja mis detectib mitu proset arvutis on?
Tänud,
chemic
kaalikas
kaalikas
sõnum 18.02.2003 18:19:50 vasta tsitaadiga
Mul vedeleb kodus kaks PentiumPro emaplaati koos prosedega, võin margi järgi vaadata (igastahes samasugused moodulid on plaadil küljes)
moonrabbit
sõnum 18.02.2003 18:30:14 vasta tsitaadiga
klOun kirjutas:
chemic
mäletan, et minu dual-PIII emaplaadiga, millel oli üks CPU küljes, teatas Knoppix linux kohe bootimise alguses midagi, stiilis a la
mingi samalaadse infi peaks ka Sisoft Sandra andma...
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
klOun
klOun
sõnum 18.02.2003 19:53:06 vasta tsitaadiga
kaalikas kirjutas:
Olexin ülimalt tänulik, kui sult vastuse saaks!
sisoftSandra kohta niipalju, et seda vist naljalt linuxile ei leia ?
wicked
wicked
sõnum 18.02.2003 20:33:31 vasta tsitaadiga
Linux Platform:
Linux 32-bit Platform
Linux 32-bit x86 (Intel Compatible) Platform
Linux 64-bit Platform
Linux 64-bit AA64 (AMD) Platform
Linux 64-bit IA64 (Intel) Platform
Miscellaneous (Linux Platform)
http://www.sisoftware.co.uk/?dir=&location=compatibility&a=&lang=en
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 63
kaalikas
kaalikas
sõnum 19.02.2003 12:11:45 vasta tsitaadiga
klOun kirjutas:
kaalikas kirjutas:
suur13
suur13
sõnum 19.02.2003 16:16:08 vasta tsitaadiga
kaalikas kirjutas:
AT, või ATX ?
Kommentaarid: 189 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 176
kaalikas
kaalikas
sõnum 19.02.2003 17:05:44 vasta tsitaadiga
suur13 kirjutas:
AT, või ATX ?
Mingid Digitali oma standardi plaadid (standardset toite pistikut plaadil pole)
klOun
klOun
sõnum 20.02.2004 12:33:19 vasta tsitaadiga
thumbs_up.gif oleks siiski teemast huvitatud. Praegu istub emmel üks prose lihtsalt leigelt ja tööd ei tee icon_sad.gif
Radiaator
sõnum 20.02.2004 15:22:45 vasta tsitaadiga
Teise protsessori lisamisel tuleb lisada ka VRM. See on plaatidel erinev. Google otsingus saad rohkem infi.
klOun
klOun
sõnum 20.02.2004 17:37:51 vasta tsitaadiga
seda ma tean, et tuleb lisada.. aga ma ei kujuta ette, kust ma selle meie banaanivabariigist leida võiks? :S
dyyp
dyyp
sõnum 24.02.2004 23:26:03 vasta tsitaadiga
ma siin olin just ühe compaqi serveri upgradega samas hädas(p3 1ghz)sai kah teine prose leitud aga VRM jäi kahe silma vahele.tundub et selliste asjade leidmiseks on enamvähem ainus mõistlik variant(hinnad+saadavus) ebay.com
klOun
klOun
sõnum 25.02.2004 01:53:00 vasta tsitaadiga
vähem närvesööv variant minu puhul oleks vist mingi p3 emme ja prose serverisse osta, mis trumpab jõudluses selle pro prose üle.. aga retro stiil on ka lahe icon_lol.gif
j00nasna
sõnum 24.10.2011 19:31:00 vrm moodul vasta tsitaadiga
Kas said omale VRM mooduli või oled ikka huvitatud ?
Küsige igasugu asju mida vaja läheb, eeldusel et teil on kuskil mõned vanad prosed vedelemas !
Toiteplokid, lülitid, releed, mõnd radikat vaja, takisteid dioode, led-e juhet mida iganes.
Toimub ainult vahetus !!
