klOun
13.02.2003 01:22:15
Micronics (w6li) MB & Dual processors |
Teema: VRM (voltage regulator module)
Igastahes probleem säärane, tegemist on ühe Micronicsi dualprose emaplaadiga (w6li), millel on peal kaks Socket8 slotti..
Ühes pesas istus varem juba Pentium 200 Pro.. nii lõpuks õnnestus saada ka teine samasugune olend (Pentium 200 Pro)... pistsin siis pesasse ja hakkasin manuali uurima, kuidas asja enableda või mis iganes tegema peab, et asi tööle hakkaks.
<manualist>
If you are installing a second processor, you do not
need to change any jumpers or BIOS settings. The
system will automatically recognize the new processor.
When installing a second processor, a VRM module
must be installed into header J1. In addition, the
second processor must have the same speed rating
and cache amount as the main processor.
NOTE: If your operating system supports dual processors,
you may need to reconfigure or reinstall your operating
system. Refer to your software documentation for more
information.
</manualist>
Nimelt pöörake tähelepanu teisele lõigule, mis manualist välja toodud on When installing a second processor, a VRM module
must be installed into header J1. Nimelt.. see slot asub teise socketi üleval.. Seejärel lugesin veidi selle VRMi kohta:
A voltage regulator module (VRM) is an installable module that senses a computer's microprocessor voltage requirements and ensures that the correct voltage is maintained. If you are changing your computer's microprocessor (for example, changing from a Pentium to a Pentium Pro or a Pentium with MMX), you need to add a voltage regulator module to the existing voltage regulator in the motherboard so that the new voltage requirements can be detected and accommodated.
In the case of the Pentium, the original Pentium has the same voltage requirement for its core or basic operation as for its I/O operation. Both use 2.8 volts. However, the Pentium Pro and the Pentium with MMX have different voltage requirements for core (2.8 volts) and I/O (3.3 volts). Adding a VRM allows it to regulate the voltage for I/O while the original regulator built into the motherboard continues to regulate core voltage.
VRM ise näeb välja midagi sellist:
Lõpuks siis poindi juurde, kas ma vajan eraldi seda VRMi et samasugust Pentium 200 Pro proset dual asendis tööle saada?
Praeguses olekus näitab linuxis mulle cat /proc/cpuinfo ühte proset... kernelile on SMP külge topitud.. kuid nothing... võimalik, et ka confis on viga. Kuid.. millega seda kõige paremini testida saaks?
Lugupidamisega,
Priit Pärna
_________________ 🥫 Experience is one thing you can't get for nothing. |
Kommentaarid: 77 loe/lisa |
XYZ
13.02.2003 11:20:50
Mina saan aru sellest inglise keelsest tekstist nii, et sa tõesti vajad seda lisa VRM moodulit, kuna integreeritu töö muutub.
Kommentaarid: 81 loe/lisa |
12 :: |
56 |
Morillo
13.02.2003 11:34:09
Üldjuhul jep ka uutele IBM serveritele piad prose lisamiseks juurde ostma VRM jublakahind oli miski 1k.- (võin eksida). Kuid ma ei oska öelda, et on neil firmadel ka mingit vahet, või on kõik VRM jublakad ühe standardi järgi!!??
Kommentaarid: 151 loe/lisa |
141 |
klOun
13.02.2003 16:36:17
hmm... 1000.- see paras kirves hind.. soodsam on uus emme ja prose osta
Aga just.. kas seda on vaja või mitte...? ja kas on tegemist universaalse jubinaga
klOun
18.02.2003 18:18:45
oskab keegi äki öelda, on mingisugune soft, mille saaks näiteks boot diskile lasta.. ja mis detectib mitu proset arvutis on?
Tänud,
chemic
kaalikas
18.02.2003 18:19:50
Mul vedeleb kodus kaks PentiumPro emaplaati koos prosedega, võin margi järgi vaadata (igastahes samasugused moodulid on plaadil küljes)
moonrabbit
18.02.2003 18:30:14
klOun kirjutas: |
chemic |
mäletan, et minu dual-PIII emaplaadiga, millel oli üks CPU küljes, teatas Knoppix linux kohe bootimise alguses midagi, stiilis a la
"error, only one CPU detected!"
mingi samalaadse infi peaks ka Sisoft Sandra andma...
Kommentaarid: 30 loe/lisa |
29 |
klOun
18.02.2003 19:53:06
kaalikas kirjutas: |
Mul vedeleb kodus kaks PentiumPro emaplaati koos prosedega, võin margi järgi vaadata (igastahes samasugused moodulid on plaadil küljes) |
Olexin ülimalt tänulik, kui sult vastuse saaks!
sisoftSandra kohta niipalju, et seda vist naljalt linuxile ei leia ?
wicked
Kommentaarid: 68 loe/lisa |
63 |
kaalikas
19.02.2003 12:11:45
klOun kirjutas: |
Need on kahjuks Digitali emad, neist vist kasu pole
suur13
19.02.2003 16:16:08
AT, või ATX ?
Kommentaarid: 189 loe/lisa |
176 |
kaalikas
19.02.2003 17:05:44
suur13 kirjutas: |
AT, või ATX ? |
Mingid Digitali oma standardi plaadid (standardset toite pistikut plaadil pole)
klOun
20.02.2004 12:33:19
oleks siiski teemast huvitatud. Praegu istub emmel üks prose lihtsalt leigelt ja tööd ei tee
Radiaator
20.02.2004 15:22:45
Teise protsessori lisamisel tuleb lisada ka VRM. See on plaatidel erinev. Google otsingus saad rohkem infi.
klOun
20.02.2004 17:37:51
seda ma tean, et tuleb lisada.. aga ma ei kujuta ette, kust ma selle meie banaanivabariigist leida võiks? :S
dyyp
24.02.2004 23:26:03
ma siin olin just ühe compaqi serveri upgradega samas hädas(p3 1ghz)sai kah teine prose leitud aga VRM jäi kahe silma vahele.tundub et selliste asjade leidmiseks on enamvähem ainus mõistlik variant(hinnad+saadavus) ebay.com
Kommentaarid: 21 loe/lisa |
20 |
klOun
25.02.2004 01:53:00
vähem närvesööv variant minu puhul oleks vist mingi p3 emme ja prose serverisse osta, mis trumpab jõudluses selle pro prose üle.. aga retro stiil on ka lahe
j00nasna
24.10.2011 19:31:00
vrm moodul |
Kas said omale VRM mooduli või oled ikka huvitatud ?
_________________ Küsige igasugu asju mida vaja läheb, eeldusel et teil on kuskil mõned vanad prosed vedelemas !
Toiteplokid, lülitid, releed, mõnd radikat vaja, takisteid dioode, led-e juhet mida iganes.
Toimub ainult vahetus !! |
Kommentaarid: 1 loe/lisa |
