uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Witcher 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 48, 49, 50, 51  järgmine
kriist
kriist
sõnum 20.06.2013 22:54:36 vasta tsitaadiga
Scart kirjutas:
http://forums.cdprojektred.com/threads/255-Full-Combat-Rebalance-2?p=928#post928
One of the most prominent modders of the first Witcher, Andrzej Kwiatkowski (modding scene nickname – Flash), who’s currently working with us as a Gameplay Designer, is finishing his own mod that tweaks the combat and alters some parts of gameplay of The Witcher 2. Here are just a few features that his upcoming mod will include:
- overall purpose of the mod is to increase Geralts responsiveness and mobility
- Geralt can parry attacks while hes walking and running (new animations)
- Geralt reacts faster to keyboard/gamepad buttons
- active block was replaced by active Quen
- during heavy battle Geralt uses pirouettes and focus (new animations)
- difficulty levels were rebalanced
- Geralt does not bump away from opponents swords when his attacks are parried which allows quick continuation of the attack sequence
- opponents explode when particular attacks are used, e.g. Igni causes opponent explosion, just like in The Witcher 2 Enhanced Edition intro
- elixirs have negative influence
Mainitud mod, nüüd väljas:
http://www.rockpapershotgun.com/2013/06/20/witcher-2-combat-mod/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+RockPaperShotgun+(Rock%2C+Paper%2C+Shotgun)
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 93
NeroEST
NeroEST
sõnum 06.11.2013 19:46:01 vasta tsitaadiga
Wau, mis mäng! Nädalav. sai esimene osa läbi, super mäng oli. Kuid üleminek teisele osale. holy F. Kui veel esimene osa oli välimuselt ja olemiselt täiesti võrreldav tänapäeva mängudega, siis W2 on üle prahi. Uskumatu, mis mäng. Oskaks kõik devid nii hästi mänge teha...
Nii, omal nahal proovitud.
Combat mod on "a MUST use".
See teeb mängu combati nauditavaks, oluliselt realistlikumaks ja paremaks.
Rääkimata witcher 1 save'i üle toomise õiglasest efektist. Itemid on ikka epic itemid ja raha jäetakse 10% mitte 1%.
Polegi elus näinud nii head uuendust mingile mängule. Hea all pean just silmas "true to the roots" teemat. Skyrimmile võib teha modisid palju tahad, kuid kõik nad olid originaalist samm kõrvale.
Selle edasiarenduse puhul pole veel seda kõrvale sammu märganud, pigem just samm sügavamle ja paremuse suunas.
Modi tegijaks ma saan aru witcher 3 lead developer?
Cant wait for the 3rd part nagu.
Tegemist ongi vist parima mänguseeriaga ever.
//mass effect ja knights of the old republic liikusid just top 3's koha võrra allapoole:)
Winter is coming...
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 37
rastaman
rastaman
sõnum 06.11.2013 20:24:20 vasta tsitaadiga
2x läbi teinud, et mõlemad stoorid ära näha ja teeks veelgi, hea ajaviide.
http://www.enbdev.com/mod_witcher2_v0189.htm
DeTHiCa.
DeTHiCa.
sõnum 09.11.2013 16:24:17 vasta tsitaadiga
kuidas CDprojekt RED peaaegu pankrotti läks:
http://www.eurogamer.net/articles/2013-11-06-seeing-red-the-story-of-cd-projekt
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 136
Gap
Gap
sõnum 16.02.2014 03:03:51 vasta tsitaadiga
http://store.steampowered.com/app/20920/
Vaatasin et steamis on selle mängu demo saadaval ja mõtlesin et proovin ka siis mis mäng see selline on ... polnud nagu sellest mängust midagi kuulnud icon_redface.gif ... st kuulnud olin aga mõtlesin et see mingi jura icon_biggrin.gif holy shit mis mäng icon_eek.gif
Igatahes saab ära ostetud selle hinna eest ja pole nii huvitavat ja ägedat mängu tükk aega mänginud ... ma ei kujuta pilti veel milline 3 osa tulla võib icon_razz.gif graafika on ikka mega ja see kuidas on tehtud mõõgaga võitlemine icon_eek.gif .... seda ei anna assasin creedi seeriaga võrreldagi icon_biggrin.gif
kuigi neid nuppe on nagu niipalju nende igasuguste asjade vastu ja alguses alustasin tutorial-ga siis praegu sain seal kuskil kindluses juba surma kuna üks vend pani mulle nagu paari hoobiga ära... puldiga seda mängu vast ei mängi, aga mängu sees ei saa momendil neid klaviatuuri nuppe muuta siis kas saab seal muuta kui mängu tööle panen ?
trip
trip
sõnum 16.02.2014 09:58:17 vasta tsitaadiga
marcor1
marcor1
sõnum 16.02.2014 11:27:48 vasta tsitaadiga
Kuidas see witcher2 võrreldes esimesega on? Endal sai millegipärast hoog otsa, mingis alguse sadamalinnas ... seevastu esimene, sai pikkade öödega ja päris kiirelt läbi tehtud.
War. War never changes.
Malkavian: [to a stop sign] No, you stop!
Kommentaarid: 70 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 64
angel
angel
sõnum 16.02.2014 11:36:23 vasta tsitaadiga
esimene osa on väga väga hea, teine osa on kah väga väga hea. Kuigi mõne kohapealt meeldis kohati 1 osa rohkem. Aga mõne koha pealt jälle 2 osa. Witcher 2 peab kindlasti 2x läbi tegema, vastasel juhul jääb pool mängu kaduma. Ehk siis olenevalt kelle poolele lähed peale võimaluse andmist otsustatakse ära kuidas mäng kujunema hakkab. Ja ei ole selline "epic button muudatus" nagu enamus mängudes vaid sisuliselt mängid suht "teist" mängu.
endal epic raskusastmega viimane linn veel läbi tegemata, tahtmine tuleb teen ära, ei ole eriti raske icon_smile.gif
Goon
Goon
sõnum 16.02.2014 19:55:56 vasta tsitaadiga
marcor1 kirjutas:
Ütleme nii, et kui kunagi teen parimate mängude edetabeli läbiaegade, siis praeguse seisuga witcher 2 on esikoht. Kui saad veel graafika ultra peale panna, siis on väga thumbs_up.gif
ewur
ewur
sõnum 17.02.2014 08:49:30 vasta tsitaadiga
ennast pani imestama (kasvõi siinsete kommentaaride põhjal), kui hoopis Skyrim aasta parimaks mänguks selles zanris valiti...
Archangel
Archangel
sõnum 17.02.2014 09:09:30 vasta tsitaadiga
ewur kirjutas:
Skyrim on suurema brändi ja firma toode. Meeletult promotud samuti. Muidugi oli ka mäng hea ning just väga lai modimisvõimalus tähendas, et praktiliselt puudusid inimesed, kes mängust midagi huvitavat ja meelepärast ei leidnud.
Witcher 2 on siiski veidi rohkem nišitoode. Bränd pole nii kuulus, tegijafirma pole nii kuulus ning vaevalt, et promogi ligilähedaselt samapalju tehti, kui Skyrimi jaoks.
Kokkuvõttes tähendab see seda, et kui võitja valitakse enamushääletuse alusel, siis võidab alati populaarseim mäng, mitte parim mäng. Populaarsust annab aga väga mitmel moel üles kruvida, isegi kui mäng kesine on.
angel
angel
sõnum 17.02.2014 10:14:29 vasta tsitaadiga
skyrim on selline -> "vehi lambist ringi mäng" ja saad hakkama. Witcher'is jäid osad isegi tutorialis hätta kuna niisama, sisutu, nuppu peksmine ei viinud võiduni. Lisaks pidi aeg-ajalt ka ajusid ragistama kui queste oli vaja teha ning questid ei olnud kõik ühesugused fetch questid etteaimatava sisuga.
thargun
sõnum 02.05.2014 17:04:46 vasta tsitaadiga
Mis moodi siin neid poksimisi tehakse, hetkel olen kohas kus tüüpe tahetakse üles puua ja no mingi 10x olen proovinud, no ei suuda võita, nagu WTF, mäng muidu väga meeldib aga nende debiilsete poksimiste pärast mõtlen uninstall teha, mul on oma ajaga targematki teha kui mingeid nuppe õigel hetkel vajutada
Archangel
Archangel
sõnum 02.05.2014 17:49:55 vasta tsitaadiga
thargun kirjutas:
No kui õigesti mäletan, siis polnud midagi keerulist. Ekraanil vilgub nupp ning sa vajutad oma klaveril sama nuppu ja Geralt paneb vastasele löögi. Vahest vaja mitu erinevat nuppu järjest vajutada. Nagu tavaline QTE, kasutusel WASD nupud.
Kuskilt lugesin samas, et kui graafika väga põhja oled pannud, siis võib laggida ning sa ei pruugi jõuda õigel ajal vajutada... aga muidu ei tohiks küll midagi keerulist olla.
angel
angel
sõnum 06.05.2014 08:33:27 vasta tsitaadiga
poksimine on kõige kergem ja lihtsam asi seal mängus, pms vajuta õiget nuppu ja kõik. Aega antakse kah mõõdukalt, et igaüks jõuaks reageerida. Kui sellega hakkama ei saa siis peaks suht doh.gif moment olema.
thargun
sõnum 06.05.2014 15:51:20 vasta tsitaadiga
Kusjuures ma ei suutnudki sealt läbi saada, läks uninstall, kusjuures jäi täiesti arusaamatuks milleks seda poksimist üldse oli vaja mängu panna, see ei anna mängule mitte midagi juurde, ainult rikub muidu väga huvitavat mängu, mis seal ikka jääb Witcher 3 ootama, äkki seal ei ole selliseid mõttetuid minigame
DeTHiCa.
DeTHiCa.
sõnum 06.05.2014 17:35:19 vasta tsitaadiga
esimeses actis mängule uninstall teha, sest mingi QTE-ga ei saanud hakkama. klahvid on ekraanil paigutatud nii, et isegi ei pea vaatama mis täht seal ilutseb - kui klahv asub vasakul siis järelikult on tegu A klahviga - ei pea isegi mõtlema mida vajutada, refleksiga juba vajutad vasakut klahvi...
aga ära muretse, sellest mängust sa nagunii jagu poleks saanud, kui juba QTE sulle liiga raskeks osutus - mängu lõpupoole päris raskeid bosse vastas.
thargun
sõnum 06.05.2014 21:25:16 vasta tsitaadiga
Mingid rasked bossud nüüd küll mingi takistus ei oleks, see oleks just huvi tekitanud, selle mängu combat oli tricky aga ei midagi eriliselt über rasket, mulle ei meeldi mängud mida püütakse kunstlikult pikemaks venitada mingite tüütute minigamidega, see mäng oleks väga hea olnud ka ilma nende tobedate pokisimiste ja käe surumisteta.
Goon
Goon
sõnum 06.05.2014 21:28:26 vasta tsitaadiga
thargun kirjutas:
Aga sa ei pea ju tegema neid side queste. Seda fist fighti vist oli 2 korral ainult. act 1 alguses ja act 2 alguses. Muidu ju täitsa valikuline kas teed neid või mitte
angel
angel
sõnum 07.05.2014 08:59:02 vasta tsitaadiga
mnjah... kui inimene ei suuda käsu peale AWSD nuppe vajutada, isegi oodatakse tükk aega ennem kui läbikukkunuks asi loetakse, siis ei ole midagi teha. icon_lol.gif Witcher 1 (kah supper mäng) omas natuke teises vormis neid kaklusi ning andis võimaluse väga kergesti lisa raha teenida mängus. Ise tegin kõik võitlused kohe ära, väga kerge oli kiiresti tasuta pappi kokku ajada.
Tegemist väga hää mänguga, dark difficulty isegi on täiesti mängitav ja tasakaalus thumbs_up.gif
thargun
sõnum 07.05.2014 15:58:12 vasta tsitaadiga
Nojah eks ma vaata, hetkel ei viitsi, sest ootan ühe teise mängu launchi aga eks ma võtan ta uuesti ette, tõenäoliselt keerasin graafika liiga põhja, kuigi mängides küll tunda ei andud ja googeldades tundus et ma ei ole ainuke, kipub läägima nende vajutustega kui graafika liiga põhjas.
Ja sellegi poolest arvan et see poksimine on selle mängu suurim thumbs_down.gif
Kuidagi okas on hinges, et see mäng on siiani mängimata (polnud arvutit selle jaoks, nüüd on), ma peale RPG midagi muud ei vaata isegi
rastaman
rastaman
sõnum 07.05.2014 18:00:57 vasta tsitaadiga
haha, seriously ? icon_lol.gif eriti naeruväärne asi mille üle kurta.
DeTHiCa.
DeTHiCa.
sõnum 19.06.2014 22:33:02 vasta tsitaadiga
witcher 2 steamis praegu 3.99€ ....hind nii madal, et peab lausa ostma, kes veel ostnud pole.
freetime1
freetime1
sõnum 19.06.2014 22:54:40 vasta tsitaadiga
Ostsin ka just ära, väga hea hind ikka.
Archangel
Archangel
sõnum 23.06.2014 09:18:07 vasta tsitaadiga
DeTHiCa. kirjutas:
GOG's veel odavam hetkel. Mitu korda summer sale's läbi käinud juba, kuid flash dealid kestavad vaid paar tundi, seega peab kiirustama. 3.99$ on väga odav hind selle mängu eest + boonusena suur kogus igasugu digitaalset nänni nagu GOG'is ikka.
http://www.gog.com/game/the_witcher_2
uus teema   vasta Tarkvara »  Arvutimängude foorum »  The Witcher 2 mine lehele eelmine  1, 2, 3 ... 48, 49, 50, 51  järgmine
