kriist
20.06.2013 22:54:36
| Scart kirjutas: |
http://forums.cdprojektred.com/threads/255-Full-Combat-Rebalance-2?p=928#post928
One of the most prominent modders of the first Witcher, Andrzej Kwiatkowski (modding scene nickname – Flash), who’s currently working with us as a Gameplay Designer, is finishing his own mod that tweaks the combat and alters some parts of gameplay of The Witcher 2. Here are just a few features that his upcoming mod will include:
- overall purpose of the mod is to increase Geralts responsiveness and mobility
- Geralt can parry attacks while hes walking and running (new animations)
- Geralt reacts faster to keyboard/gamepad buttons
- active block was replaced by active Quen
- during heavy battle Geralt uses pirouettes and focus (new animations)
- difficulty levels were rebalanced
- Geralt does not bump away from opponents swords when his attacks are parried which allows quick continuation of the attack sequence
- opponents explode when particular attacks are used, e.g. Igni causes opponent explosion, just like in The Witcher 2 Enhanced Edition intro
- elixirs have negative influence |
Mainitud mod, nüüd väljas:
http://www.rockpapershotgun.com/2013/06/20/witcher-2-combat-mod/?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+RockPaperShotgun+(Rock%2C+Paper%2C+Shotgun)
93 |
NeroEST
06.11.2013 19:46:01
Wau, mis mäng! Nädalav. sai esimene osa läbi, super mäng oli. Kuid üleminek teisele osale. holy F. Kui veel esimene osa oli välimuselt ja olemiselt täiesti võrreldav tänapäeva mängudega, siis W2 on üle prahi. Uskumatu, mis mäng. Oskaks kõik devid nii hästi mänge teha...
Nii, omal nahal proovitud.
Combat mod on "a MUST use".
See teeb mängu combati nauditavaks, oluliselt realistlikumaks ja paremaks.
Rääkimata witcher 1 save'i üle toomise õiglasest efektist. Itemid on ikka epic itemid ja raha jäetakse 10% mitte 1%.
Polegi elus näinud nii head uuendust mingile mängule. Hea all pean just silmas "true to the roots" teemat. Skyrimmile võib teha modisid palju tahad, kuid kõik nad olid originaalist samm kõrvale.
Selle edasiarenduse puhul pole veel seda kõrvale sammu märganud, pigem just samm sügavamle ja paremuse suunas.
Modi tegijaks ma saan aru witcher 3 lead developer?
Cant wait for the 3rd part nagu.
Tegemist ongi vist parima mänguseeriaga ever.
//mass effect ja knights of the old republic liikusid just top 3's koha võrra allapoole:)
_________________ Winter is coming... |
| Kommentaarid: 38 loe/lisa |
37 |
rastaman
DeTHiCa.
140 |
Gap
16.02.2014 03:03:51
http://store.steampowered.com/app/20920/
Vaatasin et steamis on selle mängu demo saadaval ja mõtlesin et proovin ka siis mis mäng see selline on ... polnud nagu sellest mängust midagi kuulnud ... st kuulnud olin aga mõtlesin et see mingi jura holy shit mis mäng
Igatahes saab ära ostetud selle hinna eest ja pole nii huvitavat ja ägedat mängu tükk aega mänginud ... ma ei kujuta pilti veel milline 3 osa tulla võib graafika on ikka mega ja see kuidas on tehtud mõõgaga võitlemine .... seda ei anna assasin creedi seeriaga võrreldagi
kuigi neid nuppe on nagu niipalju nende igasuguste asjade vastu ja alguses alustasin tutorial-ga siis praegu sain seal kuskil kindluses juba surma kuna üks vend pani mulle nagu paari hoobiga ära... puldiga seda mängu vast ei mängi, aga mängu sees ei saa momendil neid klaviatuuri nuppe muuta siis kas saab seal muuta kui mängu tööle panen ?
| Kommentaarid: 21 loe/lisa |
17 |
trip
16.02.2014 09:58:17
\witcher2\bin\configurator.exe
303 |
marcor1
16.02.2014 11:27:48
Kuidas see witcher2 võrreldes esimesega on? Endal sai millegipärast hoog otsa, mingis alguse sadamalinnas ... seevastu esimene, sai pikkade öödega ja päris kiirelt läbi tehtud.
_________________ War. War never changes.
Malkavian: [to a stop sign] No, you stop! |
| Kommentaarid: 70 loe/lisa |
angel
16.02.2014 11:36:23
esimene osa on väga väga hea, teine osa on kah väga väga hea. Kuigi mõne kohapealt meeldis kohati 1 osa rohkem. Aga mõne koha pealt jälle 2 osa. Witcher 2 peab kindlasti 2x läbi tegema, vastasel juhul jääb pool mängu kaduma. Ehk siis olenevalt kelle poolele lähed peale võimaluse andmist otsustatakse ära kuidas mäng kujunema hakkab. Ja ei ole selline "epic button muudatus" nagu enamus mängudes vaid sisuliselt mängid suht "teist" mängu.
endal epic raskusastmega viimane linn veel läbi tegemata, tahtmine tuleb teen ära, ei ole eriti raske
157 |
Goon
16.02.2014 19:55:56
| marcor1 kirjutas: |
| Kuidas see witcher2 võrreldes esimesega on? Endal sai millegipärast hoog otsa, mingis alguse sadamalinnas ... seevastu esimene, sai pikkade öödega ja päris kiirelt läbi tehtud. |
Ütleme nii, et kui kunagi teen parimate mängude edetabeli läbiaegade, siis praeguse seisuga witcher 2 on esikoht. Kui saad veel graafika ultra peale panna, siis on väga
ewur
17.02.2014 08:49:30
| ennast pani imestama (kasvõi siinsete kommentaaride põhjal), kui hoopis Skyrim aasta parimaks mänguks selles zanris valiti...
| Kommentaarid: 60 loe/lisa |
60 |
Archangel
17.02.2014 09:09:30
| ewur kirjutas: |
| ennast pani imestama (kasvõi siinsete kommentaaride põhjal), kui hoopis Skyrim aasta parimaks mänguks selles zanris valiti... |
Skyrim on suurema brändi ja firma toode. Meeletult promotud samuti. Muidugi oli ka mäng hea ning just väga lai modimisvõimalus tähendas, et praktiliselt puudusid inimesed, kes mängust midagi huvitavat ja meelepärast ei leidnud.
Witcher 2 on siiski veidi rohkem nišitoode. Bränd pole nii kuulus, tegijafirma pole nii kuulus ning vaevalt, et promogi ligilähedaselt samapalju tehti, kui Skyrimi jaoks.
Kokkuvõttes tähendab see seda, et kui võitja valitakse enamushääletuse alusel, siis võidab alati populaarseim mäng, mitte parim mäng. Populaarsust annab aga väga mitmel moel üles kruvida, isegi kui mäng kesine on.
| Kommentaarid: 25 loe/lisa |
25 |
angel
17.02.2014 10:14:29
skyrim on selline -> "vehi lambist ringi mäng" ja saad hakkama. Witcher'is jäid osad isegi tutorialis hätta kuna niisama, sisutu, nuppu peksmine ei viinud võiduni. Lisaks pidi aeg-ajalt ka ajusid ragistama kui queste oli vaja teha ning questid ei olnud kõik ühesugused fetch questid etteaimatava sisuga.
157 |
thargun
02.05.2014 17:04:46
| Mis moodi siin neid poksimisi tehakse, hetkel olen kohas kus tüüpe tahetakse üles puua ja no mingi 10x olen proovinud, no ei suuda võita, nagu WTF, mäng muidu väga meeldib aga nende debiilsete poksimiste pärast mõtlen uninstall teha, mul on oma ajaga targematki teha kui mingeid nuppe õigel hetkel vajutada
| Kommentaarid: 4 loe/lisa |
Archangel
02.05.2014 17:49:55
| thargun kirjutas: |
| Mis moodi siin neid poksimisi tehakse, hetkel olen kohas kus tüüpe tahetakse üles puua ja no mingi 10x olen proovinud, no ei suuda võita, nagu WTF, mäng muidu väga meeldib aga nende debiilsete poksimiste pärast mõtlen uninstall teha, mul on oma ajaga targematki teha kui mingeid nuppe õigel hetkel vajutada |
No kui õigesti mäletan, siis polnud midagi keerulist. Ekraanil vilgub nupp ning sa vajutad oma klaveril sama nuppu ja Geralt paneb vastasele löögi. Vahest vaja mitu erinevat nuppu järjest vajutada. Nagu tavaline QTE, kasutusel WASD nupud.
Kuskilt lugesin samas, et kui graafika väga põhja oled pannud, siis võib laggida ning sa ei pruugi jõuda õigel ajal vajutada... aga muidu ei tohiks küll midagi keerulist olla.
25 |
angel
06.05.2014 08:33:27
poksimine on kõige kergem ja lihtsam asi seal mängus, pms vajuta õiget nuppu ja kõik. Aega antakse kah mõõdukalt, et igaüks jõuaks reageerida. Kui sellega hakkama ei saa siis peaks suht moment olema.
157 |
thargun
06.05.2014 15:51:20
| Kusjuures ma ei suutnudki sealt läbi saada, läks uninstall, kusjuures jäi täiesti arusaamatuks milleks seda poksimist üldse oli vaja mängu panna, see ei anna mängule mitte midagi juurde, ainult rikub muidu väga huvitavat mängu, mis seal ikka jääb Witcher 3 ootama, äkki seal ei ole selliseid mõttetuid minigame
DeTHiCa.
06.05.2014 17:35:19
esimeses actis mängule uninstall teha, sest mingi QTE-ga ei saanud hakkama. klahvid on ekraanil paigutatud nii, et isegi ei pea vaatama mis täht seal ilutseb - kui klahv asub vasakul siis järelikult on tegu A klahviga - ei pea isegi mõtlema mida vajutada, refleksiga juba vajutad vasakut klahvi...
aga ära muretse, sellest mängust sa nagunii jagu poleks saanud, kui juba QTE sulle liiga raskeks osutus - mängu lõpupoole päris raskeid bosse vastas.
140 |
thargun
06.05.2014 21:25:16
| Mingid rasked bossud nüüd küll mingi takistus ei oleks, see oleks just huvi tekitanud, selle mängu combat oli tricky aga ei midagi eriliselt über rasket, mulle ei meeldi mängud mida püütakse kunstlikult pikemaks venitada mingite tüütute minigamidega, see mäng oleks väga hea olnud ka ilma nende tobedate pokisimiste ja käe surumisteta.
Goon
06.05.2014 21:28:26
| thargun kirjutas: |
| Mingid rasked bossud nüüd küll mingi takistus ei oleks, see oleks just huvi tekitanud, selle mängu combat oli tricky aga ei midagi eriliselt über rasket, mulle ei meeldi mängud mida püütakse kunstlikult pikemaks venitada mingite tüütute minigamidega, see mäng oleks väga hea olnud ka ilma nende tobedate pokisimiste ja käe surumisteta. |
Aga sa ei pea ju tegema neid side queste. Seda fist fighti vist oli 2 korral ainult. act 1 alguses ja act 2 alguses. Muidu ju täitsa valikuline kas teed neid või mitte
angel
07.05.2014 08:59:02
mnjah... kui inimene ei suuda käsu peale AWSD nuppe vajutada, isegi oodatakse tükk aega ennem kui läbikukkunuks asi loetakse, siis ei ole midagi teha. Witcher 1 (kah supper mäng) omas natuke teises vormis neid kaklusi ning andis võimaluse väga kergesti lisa raha teenida mängus. Ise tegin kõik võitlused kohe ära, väga kerge oli kiiresti tasuta pappi kokku ajada.
Tegemist väga hää mänguga, dark difficulty isegi on täiesti mängitav ja tasakaalus
157 |
thargun
07.05.2014 15:58:12
Nojah eks ma vaata, hetkel ei viitsi, sest ootan ühe teise mängu launchi aga eks ma võtan ta uuesti ette, tõenäoliselt keerasin graafika liiga põhja, kuigi mängides küll tunda ei andud ja googeldades tundus et ma ei ole ainuke, kipub läägima nende vajutustega kui graafika liiga põhjas.
Ja sellegi poolest arvan et see poksimine on selle mängu suurim
Kuidagi okas on hinges, et see mäng on siiani mängimata (polnud arvutit selle jaoks, nüüd on), ma peale RPG midagi muud ei vaata isegi
rastaman
07.05.2014 18:00:57
haha, seriously ? eriti naeruväärne asi mille üle kurta.
DeTHiCa.
19.06.2014 22:33:02
| witcher 2 steamis praegu 3.99€ ....hind nii madal, et peab lausa ostma, kes veel ostnud pole.
140 |
freetime1
19.06.2014 22:54:40
| Ostsin ka just ära, väga hea hind ikka.
Archangel
23.06.2014 09:18:07
| DeTHiCa. kirjutas: |
| witcher 2 steamis praegu 3.99€ ....hind nii madal, et peab lausa ostma, kes veel ostnud pole. |
GOG's veel odavam hetkel. Mitu korda summer sale's läbi käinud juba, kuid flash dealid kestavad vaid paar tundi, seega peab kiirustama. 3.99$ on väga odav hind selle mängu eest + boonusena suur kogus igasugu digitaalset nänni nagu GOG'is ikka.
http://www.gog.com/game/the_witcher_2
25 |
NightStriker
03.08.2014 01:27:42
ACt 1 lõpus jooksis mäng stabiilselt kokku. Vaatasin netis ringi, soovitati salvestusi vähemaks võtta. Võtsin, aga tulemust ei olnud. Täpselt samas kohas kokkujooks korduvalt.
Valideerisin steamis failid ära= 14 vigast faili. Praegu sikutab 9,7 GB Oleks tore, kui see probleemi lahendab.
Esimene kord jäi mäng kuudeks seisma, sest kogu see joo seda jooki/nuusuta seda lille teema võttis silme eest kirjuks. Esimest korda seda tüüpi mängu kallal. Seekord jõudsin esimese acti lõppu ja vahevideo ajal niimodi kooma joosta ei olnud mängust kena.
Edit: pastab, et nüüd jookseb jälle normaalselt.
_________________ Allverelaev sukeldub määramata ajaks... |
| Kommentaarid: 65 loe/lisa |
63 |
05.08.2014 07:45:10
Ka 2 osa failid läksid vahepeal lolliks, samas pigem häirisid mõned kohad, mis olid oluliselt raskemaks tehtud üldise vooga võrreldes.
Jääb loota, et W3 tuleb suurema vabadusega ringi liikuda.
201 |
angel
05.08.2014 08:38:14
3x läbi tehtud, endal karbi versiooniga "lolliks" minemist ei täheldanud... loodetavasti 3 osa tuleb samasse suppi nagu 2 osa oli + mõngingad lisad/parandused.
157 |
06.08.2014 07:39:25
Mul steami oma.
Ega nad palju muutma ei pea jah...ehk ronimist võiks rohkem olla ja selle kontroll kiirem.
Samas kuna sellist jookse ja mõttetult jälita teemat polnud, siis oli mäng oluliselt nauditavam. AC vanemates seeriates said ikka üsna tihti "failed" kontrolli lolliks minemise tõttu, nüüd on see korda tehtud ja jooksed nagu AHV, aga ilmselt nägid nad väga tugevalt vaeva.
201 |
angel
06.08.2014 08:13:33
redelitelt ei saanud poole pealt maha, kergematest takistustest ei suutnud üle minna, fov oli liiga kitsas, taimestiku vaatekaugus keerati piixu viimaste pätsidega, üks quest oli minuteada kah natuke katki (iga kord kui läbi tegin oli see quest failed, see oli see "mürgitaja" otsimise quest, kuidagi ei õnnestunud seda nõnda teha nagu vaja). Aga muidu hää teos
157 |
06.08.2014 08:18:30
| Täis open world puhul ilmselt oleks saanud seal minna palju asju metsa ja ka ei konkureeri otseselt kiirema AC seeriaga. Tollele tehti ka ju miski HD remake.
201 |
angel
06.08.2014 08:28:23
ei ole eriti huvitatud open world gameplayst mis on täis fetsh queste ja sisutut grindimist... loodetavasti 3 osa tuleb sama "open world" kui 2 osa oli + rohkem sisu ja suuremad alad.
157 |
Archangel
06.08.2014 08:39:10
| angel kirjutas: |
| ei ole eriti huvitatud open world gameplayst mis on täis fetsh queste ja sisutut grindimist... loodetavasti 3 osa tuleb sama "open world" kui 2 osa oli + rohkem sisu ja suuremad alad. |
Noh, mõni arvab, et Witcher 3 maa-ala on suurem kui Skyrim.
http://www.vg247.com/2014/06/23/witcher-3-wild-hunt-map-pc-ps4-xbox-makes-skyrim-look-small/
Selles suhtes kardan, et tegemist tuleb täiesti open world mänguga. Siiski loodan, et nad suudavad piisavalt kvaliteetset sisu ka sinna toota, sest erinevalt Elder Scroll seeriast ei ole Witcher seeria päris open rpg. Ehk ei saa olla päris see kes tahad ja teha mida tahad. Üldine story ja character development on siiski suhtkoht piiratud. Seega tahes tahtmata on mõned tegevused ja questide ideed välistatud.
Aga eks näis.
25 |
angel
06.08.2014 08:49:38
Witcher 1 ja 2 olid kah päris pirakad kui kogu see käidav ala ühte panna. Ala ei olnud ainult tervikus ligipääsetav.
157 |
marcor1
12.08.2014 00:12:41
W1 näitas, et sisu teeb mängu. Suht koridoris jooksmine aga 5+ mäng oli.
Kvaliteet RPG suudab luua illusiooni, et "oled see, kes tahad ja teed mis tahad" - kuigi tegelikult käid mööda tegijate ettekirjutatud rada ja lõpp on üks, või siis erineb kosmeetiliselt (erinevad lõpustseenid ja videod).
Dave20
18.08.2014 23:52:29
Olen mängus suht alguses, seal kus vaja lasta teised väravast sisse, aga ise peab päris mitme mehega ennem võitlema. Ei saa kuidagi seda kohta läbi. Kas seal mingi nipp kuidas nendest kõigist jagu saada?
Edit: Lõpuks sain jagu.
| Kommentaarid: 26 loe/lisa |
25 |
angel
19.08.2014 01:10:41
õpid võitlema, kaitse, rünnak, eemale põikamine etc
väga asjalik võitlus süsteem, isegi kõige raskema (dark) raskusastmega on täiesti toimiv ja tehtav.
157 |
Dave20
19.08.2014 21:25:21
Kas võitlus käib ainult hiirega või on klaviatuuril ka mingid nupud millega rünnata jne?
Muidu mäng ise päris hea, aga vaja veel selgeks saada mida selle kraamiga teha mis üles korjab ja kuidas seda kasutada
25 |
Rand0m
20.08.2014 00:00:23
| Klava pealt saad sign'e kasutada (alguses on mõõgad päris nõrgad, ignii tuleb kasuks ntks), samuti saad vajadusel pomme ja daggereid visata, aga selle jaoks peab hiirega sihtima (endale tundus see võimalus üpris mõttetuna). Kaitse jaoks on olemaks dodge'mine ja blokeerimine/riposte'mine/arrow redirection, mida saad samuti vaid klavalt kasutada
| Kommentaarid: 6 loe/lisa |
Dave20
21.08.2014 20:19:55
| Kas see kui vanglast põgeneb on suht mängualgus veel?
25 |
NightStriker
21.08.2014 20:21:48
| Dave20 kirjutas: |
| Kas see kui vanglast põgeneb on suht mängualgus veel? |
Vangla jääb esimese protsendi sisse sajast.
63 |
Dave20
21.08.2014 21:05:48
| radist87 kirjutas: |
| Dave20 kirjutas: |
Vangla jääb esimese protsendi sisse sajast. |
Tundub, et väga pikk mäng tuleb siis
25 |
Prozer
17.05.2015 12:23:39
Witcher 2 anomaalia AMD videoga |
Kas ka teil on R9 280 videokaardiga esinenud koledaid, nn pikselisi varjuefekte? Varjudelt on justkui optimeerimise eesmärgil pikslid osaliselt välja nopitud, mis teeb üldpildi suht koledaks. Grafikasettingud on muidu põhjas v.a. "übersampling":
_________________ Sidevõrkude ja tehnilise infra arendus. |
| Kommentaarid: 69 loe/lisa |
68 |
labidas
17.05.2015 12:55:28
ma olen selliseid varje pea igas mängus näinud... pole kunagi mõelnud, et see mingi bug on.
| Kommentaarid: 34 loe/lisa |
34 |
AlvinL
26.06.2021 21:20:50
Kaevan. Pole varem puttunud Witcher 2/3 (kunagi mängisin oma juustu arvuti peal Witcher 1 läbi ja vilksamisi olen TW3 saanud "nuusutada"). Tegin Witcher 2 EE läbi, sain kommiraha eest GOG-s. Fantastiline story, tegelased, dialoog, huumor. Mõningad tüütud bugid siin-seal. Tegin 2 playthrough'd Dark peal. Esimene kord Iorvethiga, teine Rochega. See on äge, et ühe jooksuga ei näe kogu storyt ja story ei ole "good vs evil". Väga sünge tooniga mäng sellegipoolest. Nüüd tuleb veel TW3 (lõpuks faking ometi) läbi teha. See ka GOG-s koolilõuna raha eest saada.
_________________ Võimatu on teha midagi lollikindlaks, sest lollid on haruldaselt leidlikud. |
| Kommentaarid: 18 loe/lisa |
17 |
Dreamlover
26.06.2021 21:24:54
AlvinL, Jep witcher 3 on hea. kahjuks võtsin selle ette enne, kui w2, seega tagasi minek oli raske ette võtta-
aga see hea mäng on hea vaid kõige raskemal astmel.
_________________ ARVUTID
3G1,5/3G2,5/5G1,5/5G2,5 KAABEL
HDD kettad |
| Kommentaarid: 1902 loe/lisa |
1326 |
Muhekas
02.08.2021 23:37:11
| Kuna W3 olemas siis otsustasin ka W2 osta... siis ütles tuttav, et võta esimene ka ära. Kolasin siis netis ringi ja leidsingi võtme odavalt. Ostsin siis suure hurraaaga ära ja hetk hiljem selgus, et see GoG-i võti ja hakka jälle mingit uut platformi tõmbama ja omama, täielik pain in ass
| Kommentaarid: 20 loe/lisa |
17 |
kuccu
02.08.2021 23:47:25
Ohsa pisike lilleke, las ma teen sulle pai, muidu nutad veel silmad peast ära....
Mul ainult gog tiksubki, kõik platvormid ühes koos, hea mugav.
Muhekas
03.08.2021 00:32:37
| kuccu kirjutas: |
Mul ainult gog tiksubki, kõik platvormid ühes koos, hea mugav. |
Aitäh pai eest, meel palju rõõmsam kohe
Mul on arvutiga yhendatud headset ja dialoogi heli ei kuule on kuulda ainult muusikat taustaks :/ nii palju netist leidsin, et heli tuleb win. seadetes stereoks muuta ja siis pidavat ok olema a mis moodi ma oma hyperx heli seal win seadetes stereoks saan muuta?
17 |
ewur
05.08.2021 15:44:48
See peaks ju nii basic olema? No kindlasti oled lahenduse juba leidnud, aga igaks juhuks - Control Panel ja sealt Sound osa. Ja Sound osast leiad juba ise selle seadme, millega kuulad ja selle seadetest panedki stereoks...
60 |
