LKits
| Kommentaarid: 13 loe/lisa |
UnknowFunk
02.04.2013 21:17:45
Ruuteriks on valge elioni thompson ja muidu on telefon wifis (seal ei lähe nett ära) ja vahepeal ka sülearvuti wifis (siis kui korra selle errori ette viskab läpakas, siis peab läpakale resa tegema, muidu netis edasi olla ei saa)
_________________ Mida hiljem saabub kiirabi, seda täpsem on diagnoos. |
| Kommentaarid: 94 loe/lisa |
84 |
spreiii
03.04.2013 00:05:17
Äkki aitaks DNS-i korrasolekus selgusele saada sellisel viisil, et prooviks Google DNS-i?
Example: Changing DNS server settings on Microsoft Windows 7
Go the Control Panel.
Click Network and Internet, then Network and Sharing Center, and click Change adapter settings.
Select the connection for which you want to configure Google Public DNS. For example:
To change the settings for an Ethernet connection, right-click Local Area Connection, and click Properties.
To change the settings for a wireless connection, right-click Wireless Network Connection, and click Properties.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Select the Networking tab. Under This connection uses the following items, select Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6) and then click Properties.
Click Advanced and select the DNS tab. If there are any DNS server IP addresses listed there, write them down for future reference, and remove them from this window.
Click OK.
Select Use the following DNS server addresses. If there are any IP addresses listed in the Preferred DNS server or Alternate DNS server, write them down for future reference.
Replace those addresses with the IP addresses of the Google DNS servers:
For IPv4: 8.8.8.8 and/or 8.8.4.4.
For IPv6: 2001:4860:4860::8888 and/or 2001:4860:4860::8844
| Kommentaarid: 23 loe/lisa |
23 |
UnknowFunk
05.04.2013 16:57:59
spreiii, Hetkel nagu töötaks, pole veel tulnud (loodan et ära ei sõnu)
E:
Igastahes tuli nüüd tagasi. Pidin ruuterile resa tegema, olid sülearvuti, PC ja telefon ühenduses, tuli kõigil samasugune error ette (va telefonis kus lihtsalt lehti ei laadinud enam ära.)
84 |
partyb
05.04.2013 20:50:20
| Kas chrome browserile mustale lingi ribale on võimalik lisada linke juurde (kalender,drive jne) ? Sooviks, et oleks vähemalt samad lingid nagu seda on google.com versioonil. Hetkel viskab alati default .ee lõpuga lehele ja seal ainul 6 linki....
Märt.
05.04.2013 21:33:01
Ei näe sellist musta riba Chromel?
| Kommentaarid: 29 loe/lisa |
23 |
siinus
06.04.2013 09:25:01
seda vist mõeldud:
aga kroomiga pole seljuhul pistmist.
_________________ suck less | no slop grenade
| Kommentaarid: 70 loe/lisa |
63 |
partyb
06.04.2013 09:34:30
| siinus kirjutas: |
seda vist mõeldud:
aga kroomiga pole seljuhul pistmist. |
Seda jah! Kuidas ei ole? Miks siis sama asi muutub, kui minna google.com lehele?
Hetkel päris mures, et ei saa minna oma kalendrisse 1 klõpsuga
LKits
siinus
63 |
M00t
06.04.2013 18:36:34
Maci peal hakkas Chrome mingi hetk ennast ise sulgema, seda eriti siis kui uue tab-i avamise nuppu vajutada. Soovitati asenduseks mingisugust Ironit, mis näeb samasugune välja, aga on kõrgendatud privaatsusega. Huvitaval kombel see ei viska välja.
Tahaks siiski Chrome-i tagasi.
| Kommentaarid: 77 loe/lisa |
73 |
Mnator
06.04.2013 18:51:13
| lu1de kirjutas: |
Milleks? Lähtekood neil sama, Ironist on rämpskoodi väljaroogitud.
siinus
06.04.2013 18:54:34
chromium on ka vist macile saadaval. Tasub proovida.
63 |
MaxBass
07.04.2013 08:37:49
| Chrome menüü ja järjehoidjad suuremaks läinud. font sama, aga palju tühja ruumi nuppude vahel. Palun abi kuidas tagasi normaalseks muutab saab?
WAV
08.04.2013 05:25:32
| MaxBass kirjutas: |
| Chrome menüü ja järjehoidjad suuremaks läinud. font sama, aga palju tühja ruumi nuppude vahel. Palun abi kuidas tagasi normaalseks muutab saab? |
See ju igati hea, et näiteks parema hiireklahviga avaneva abimenüü read nüüd suurema reavahega on, enne oligi korduvalt jama, kui kiirelt tegutsedes ikka kursoriga kogemata naaberreale pihta sain ja sellest suhteliselt tüütult jama tekkis. Vähemalt mulle muutus meeldib.
Aga kuidas seda ise ära muuta saaks, seda küll ei oska pakkuda. Kui just ei tee vanema Chrome versiooni tagasipaigaldamist (mis kah selline küsimärgiga ettevõtmine).
| Kommentaarid: 7 loe/lisa |
RaidoR
08.04.2013 08:19:33
| shortcuti target reale lisa: --disable-new-menu-style
| Kommentaarid: 52 loe/lisa |
50 |
p2ep
| Kommentaarid: 32 loe/lisa |
28 |
MaxBass
09.04.2013 18:58:16
| RaidoR kirjutas: |
| shortcuti target reale lisa: --disable-new-menu-style |
Suurimad tänud RaidoR! Nüüd norm menüü tagasi jälle.
Mul ka 64bit W7 ja pole sellist probleemi. Vb mingid uuendused puudu või kalavad? nt win, chrome, java, flash uuendused? Või mingid laiendused mis härivad?
p2ep
09.04.2013 19:07:29
| MaxBass kirjutas: |
| RaidoR kirjutas: |
Mul ka 64bit W7 ja pole sellist probleemi. Vb mingid uuendused puudu või kalavad? nt win, chrome, java, flash uuendused? Või mingid laiendused mis härivad? |
Sai uuesti W7 peale lastud, win uuendused kõik vastu võetud. Laiendusi põle. Ikka sekundite või poole tunni pärast koomas.
28 |
aks
09.04.2013 19:32:38
link :: pilt
Kasutan FVD Speed Diali aga thumbide tegemine hakkas villast panema. Teeb lihtsalt mingi häguse käki.
Milles võib viga olla?
_________________ Pakkuda
VÕIMENDI ICEPOWER 1200AS2 koos korpusega - 2 X 700W - 440€
HECO AMBIENT 22 F SEINAKÕLARID - 300€ / 2tk |
120 |
LKits
siinus
63 |
LKits
its2cold
174 |
LKits
12.04.2013 12:08:39
Manage multiple users on Chrome: http://support.google.com/chrome/bin/answer.py?hl=en&answer=2364824
The ability to add multiple users to Chrome is intended to provide a quick and simple way to set up personalized copies of Chrome for people who are already sharing Chrome on the same computer today. It isn’t intended to secure your data against other people using your computer. To truly protect your data from being seen by others, please use the built-in user accounts in your operating system of choice. |
LKits
13.04.2013 13:49:29
Kui sul on seal arvuti kallal nii kõvad "häkkerid", kes op-süsteemi kasutaja parooli saavad ühtegi parooli teadmata vahetatud, siis ega seal tõesti muud varianti ei jää. (Mitte et brauseri profiili kopeerimiseks üldse mingit parooli teada oleks vaja, kui arvutile on füüsiline ligipääs olemas...)
Brauserilt suuremat turvalisust oodata kui op-süsteemilt pole eriti mõtet.
Ega äriklassi läpakatele naljapärast TPM kiipe ja ketta krüpteerimise võimalust riistvara tasemel ei pakuta.
Shadow25
15.04.2013 12:40:48
Kuidas te mitmesaja sakiga/lehega GC-s toime tulete? Ühtegi normaalset lisa ei leia, mis teeks GC kasutamise sellises olukorras kasutatavaks. FF-is mul hetkel üle 600 saki lahti.
15.04.2013 13:07:57
| Shadow25 kirjutas: |
Kuidas te mitmesaja sakiga/lehega GC-s toime tulete? Ühtegi normaalset lisa ei leia, mis teeks GC kasutamise sellises olukorras kasutatavaks. FF-is mul hetkel üle 600 saki lahti.  |
Sellepärast ma Chrome'i ei kasutagi muuks kui vahel harva veebilehe töö ja välimuse kontrolliks selles brauseris. Ei ole seni ühtegi omadust tal leidnud, mis mulle Firefoxist rohkem meeldiks.
Mingi uurimistöö tegemiseks see sakimajandus ikka sakib kohutavalt
Eks ta vähenõudlikele kasutajatele sobib paremini kui mulle ja sulle. 600 sakki mul just lausa pole korraga käes olnud, aga üle 200 küll...
fallout3
15.04.2013 13:28:57
| UnknowFunk kirjutas: |
Chrome viskab koguaeg selliseid http://puu.sh/2sAAD Erroreid, pead mingi 3-xxx korda refeshima, siis läheb tööle jälle, üli ketta ajab... Oskab keegi aidata  |
| spreiii kirjutas: |
Click OK.
Panen märgi maha, et mul esines ka sarnast probleemi, kus aeg-ajalt Chrome (ainuke brauser mida kasutan) ei leidnud koduses wifi võrgus enam lehti üles, kuigi torrent ja IM programmid töötasid ilusti edasi. Õnneks oli mul levialas 2 kasutatavat ja erineva liitumisega Elioni ühendust, ja siis lihtsalt vahetasin neid vastavalt vajadusele. Peale Google DNSi peale üle kolimist seda probleemi enam täheldanud ei ole.
Kas siin ei või probleem olla pigem Elioni poolne?
| Kommentaarid: 27 loe/lisa |
26 |
15.04.2013 13:36:05
pakun, et elioni poolne. mul on elioni ühenduse küljes dnsiga võrdlemisi tihti probleeme.
_________________ - londiste
217 |
fallout3
15.04.2013 13:43:47
| See on küll natuke teemaväline, aga kas kellelgi on kogemust ka probleemi lahendamisega? Kui ma klienditeenindusse helistan ja ütlen, et meil on majas 2 ühendusega üsna tihti DNS probleemid, siis kas nad oskavad sellega ka ise edasi tegeleda, või on standardvastuseks see, et tehke seadmetele restart jne?
26 |
mTim
15.04.2013 14:33:05
miks sul 600 sakki lahti peab olema?
_________________ Lexuse summutist tuleb vaid lilleõisi ja ükssarvepeeru - HV foorum
M: E36 varuosad |
| Kommentaarid: 47 loe/lisa |
42 |
15.04.2013 18:07:17
| mTim kirjutas: |
miks sul 600 sakki lahti peab olema? |
Teeb ehk mingit uurimistööd? Otsib infot millegi kohta erinevatest allikatest. Võib-olla mitme teema kohta korraga. Ma küll kujutan ette sellist olukorda.
fallout3
15.04.2013 18:17:59
Ma arvan, et sellise uurimustöö jaoks oleks mõistlik juba mingeid muid andmete haldamise süsteeme kasutada kui brauseri multi-tabbing
Ma saan aru, et aegajalt tuleb 50-100 tabi lahti suures hoos linkidel klikkides. Võibolla kellelgi ka 200. Aga juba siis on nende haldamine ju selline pornograafia ka firefoxi puhul, et vabatahtlikult ma küll sellise asjaga tegelemist ette ei kujutaks.
26 |
15.04.2013 19:38:03
Jep, mul sama probleem.
313 |
Shadow25
15.04.2013 22:16:32
Põhimõtteliselt ongi nii nagu Dogbert mainis - vaja midagi uurida, kohe hunnik lehti lahti. Vahel leian huvitava artikli, aga kohe ei viitsi seda lugeda ja jääb jälle lahti. Aja jooksul koguneb neid päris palju. Pidevalt vaadata, mida kinni annab panna, on palju raskem, kui jättagi lahti. Aga nii umbes 2-3 korda aastas teen suurpuhastust ja pooled lehed lähevad kinni. Mul on aastaid olnud tõsiselt raske alla 150 saki lahti hoida. Vana arvutiga käis pidevalt närvidele, et 150 lehte umbes sai kiirelt lahti ja arvuti muutus uimaseks ja pidi siis pidevalt vaatama, mida jälle kinni annab panna. Uue arvutiga seda probleemi pole - probleem on siis, kui FF mälukasutus 3 giga peale tõuseb ja jookseb kokku. Vana arvutiga ma ka ei kujutanud 600 lehte ette, aga nüüd, kus võimalus olemas, tuli see kergelt. Võimalus lehed nö kaustadesse FF-is panna teeb lehtede haldamise palju lihtsamaks - meelelahutus oma kaustas, üks töö teises kaustas, kolmas töö kolmandas kaustas jne. Mul neid kauste praegu neli.
fallout3
15.04.2013 22:21:55
Kasutad siis ühesõnaga bookmarkide asemel lihtsalt lahtiseid tabe? Kevadine suurpuhastus ja kaustadesse jagamine jne iseloomustab täpselt tavalise kasutaja bookmarkide nimekirja. Aga no kui arvuti vastu peab ja neist ilma jääda ei karda siis miks mitte
26 |
Tiim
15.04.2013 22:24:56
on ikka huvitavaid inimesi ma vaatan...siin teemas raudselt lahatud aga ei viitsi otsida..kas bookmarkide jaoks ka mingi lisa on chromel?
_________________ mida sa vahid mu allkirja, AHV raisk |
| Kommentaarid: 49 loe/lisa |
43 |
mTim
15.04.2013 22:30:58
pidin mitu korda Shadow25 teksti lugema, et uskuma jääda. Ei kujutaks ettegi, et jätan browseri lahti, kui arvuti juurest lahkun...
Või üldse kui midagi muud teen peale weebitamise...
M: E36 varuosad |
42 |
Shadow25
15.04.2013 23:49:45
| mTim kirjutas: |
Või üldse kui midagi muud teen peale weebitamise... |
Mis selles imelikku, et mul veebilehitseja päev otsa lahti, kui ka arvuti käib? Kui ma kuni paariks tunniks arvuti juurest ära astun, panen arvuti lukku, ei näe mõtet veebilehitsejat sellepärast kinni panna või ennast kõikjalt välja logida jne. Ööseks panen arvuti magama, taas jätan veebilehitseja ja kõik muud programmid lahti, hommikul hea poolepealt jätkata. See asjade kinni ja käima panemine hoopis mõttetu vaev ju, kui just puuduvad ressursid seda ei sunni.
| fallout3 kirjutas: |
Kasutad siis ühesõnaga bookmarkide asemel lihtsalt lahtiseid tabe? Kevadine suurpuhastus ja kaustadesse jagamine jne iseloomustab täpselt tavalise kasutaja bookmarkide nimekirja. Aga no kui arvuti vastu peab ja neist ilma jääda ei karda siis miks mitte  |
Ei saa nüüd öelda, et nad päris järjehoidjaid asendavad. Järjehoidjad nõuavad suuremat tööd - pead hakkama mõtlema, kas väärib järjehoidjasse lisamist, kui väärib, siis pead lisama, tihti sellises olukorras vaja nime muuta ja hiljem tülikam kustutama hakata. Mul järjehoidjates ka väike hunnik lehti ja sinna panen teistsuguse väärtusega lehti - näiteks mingi õpetus või tööriist, mida praegu küll vaja ei lähe, aga võib hiljem iga kell korduvalt vaja minna. Muidu aga lahti hoian neid, mis ma tahan, et oleks nagunii pidevalt lahti ja need, mis ootavad üks kuni mõnu kord suuremat tähelepanu ja saaks siis jäädavalt kinni panna - näiteks seoses mingi juba mainitud uurimistööga/projektiga.
Ilma jäämise hirmu pole. FF salvestab ise alati lahti olnud lehed ühte faili, kust annab ka vajadusel taastada ja lisakaitsena on mul FF-is ka Session Manager.
Aga GC-ga ongi see jama, et tahan või ei, puudulik sakimajandus teeb temale täielikult üle mineku võimatuks. Selles osas FF-ile konkurents puudub. Olen tegelikult juba aastaid imestanud, et miks GC-s sakimajandust paremaks ei teha. Võiks ju. Olen küll kunagi mõndasid lisasid proovinud, aga ükski ei paku FF-i mugavust. Nii siis nüüd küsingi, et mida teie kasutate ja mida oskate välja pakkuda? Isegi, kui GC-d pidevalt ei kasuta, oleks kena, kui saaks temas kah üle 30-ne saki lahti teha ja normaalselt kasutada.
mTim
42 |
ufo56
16.04.2013 00:01:01
No palju sul rammi peab olema ? Chromega on 30 tabi juba 5gb umbes.
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
Shadow25
16.04.2013 00:35:41
Eks ma ise ka natuke imestan selle 600 üle, aga nii ütleb Session Manager. Hetkel täpsemalt 608. Viimasel ajal kõigub 570-620 kandis. Peakski varsti ühe suurpuhastuse ette võtma.
Õige leiab lihtsalt üles. Lehed saab nö kaustadesse panna. Valides esimese kausta on üleval sakkidena vaid need lehed, mis on selles valitud kaustas, valides teise kausta, on taas üleval selle teise kausta lehed. Valid FF-i sees. Saab nii näiteks meelelahutuse ja töö lahus hoida. Lisaks kui hakata valima kauste, niisama trükkima hakates otsib kohe kõikidest kaustadest sobivat lehte. Lisaks FF-is ei suru sakid nii kitsaks, et poleks näha, mis seal lahti on - GC-s on see väga suur probleem. Ja üleval paremal nurgas veel üks nooleke, millele vajutades avaneb valitud kaustas olevate lehtede nimekiri. Kui vähegi mäletad, kus kaustas avatud leht on, pole selle leidmine raske. Küll aga tuleb tunnistada, et ma ei mäletagi kõiki lehti, mis mul praegu lahti on.
ufo56, noh, hetkel on mul 16 GB kokku, sellest 2 on ramdiskile eraldatud. Praegune mälukasutus on 9,31 GB (Sisaldab siis 2 giga ramdiskile), on olnud ka üle 12 GB.
fallout3
16.04.2013 07:10:38
Ei saa nüüd öelda, et nad päris järjehoidjaid asendavad. Järjehoidjad nõuavad suuremat tööd - pead hakkama mõtlema, kas väärib järjehoidjasse lisamist, kui väärib, siis pead lisama, tihti sellises olukorras vaja nime muuta ja hiljem tülikam kustutama hakata. Muidu aga lahti hoian neid, mis ma tahan, et oleks nagunii pidevalt lahti ja need, mis ootavad üks kuni mõnu kord suuremat tähelepanu ja saaks siis jäädavalt kinni panna - näiteks seoses mingi juba mainitud uurimistööga/projektiga. |
Ei taha küll mingit vaidlust tekitada, aga kommentaarina pean ikka jääma arvamuse juurde, et kui sa seda sakimajandust ainult 2-3 korda aastas üle puhastad, siis ei ole ju mingit sisulist põhjust miks sa ei saaks neid täpselt sellisel kujul järjehoidjatesse lisada ja selle "õige" järjehoidjate kogumi veel omakorda seal eraldi kaustas hoida. Ainuke vähegi tõsisem argument ehk võiks olla see, et järjehoidjatest kustutamine võtab paar klahvivajutust rohkem kui lihtsalt tabi kinnipanemine.
| Ilma jäämise hirmu pole. FF salvestab ise alati lahti olnud lehed ühte faili, kust annab ka vajadusel taastada ja lisakaitsena on mul FF-is ka Session Manager. |
Kui see session manager oma asjad kuhugi pilve ka laeb, siis pole tõesti hirmu. Ainult kohalikus arvutis hoidmine on ikka natuke kahtlane.
Pole firefoxi ammu kasutanud, aga Chrome puhul see üle kõigi seadmete lahtiolevate lehtede sünkroonimine on küll väga mugav kui töö juures mõned asjad lahti jäävad ja kodus neile vaja ligi saada või vastupidi.
| ufo56 kirjutas: |
| No palju sul rammi peab olema ? Chromega on 30 tabi juba 5gb umbes. |
Kuidas sa niipalju tulemuseks saad? Mul alati küll 30 tabi lahti ei ole, aga ilma mingite adblockide ja flashblockideta ja üsna kaua lahti olnud Chrome tavaliselt oluliselt üle 1GB mälu ei kasuta. Tegin praegu lisaks olemasolevale uues aknas lahti ka täpselt 30 järjehoidjaga kausta kõik lehed ja nüüd sain tulemuseks veidike alla 2GB.
26 |
WAV
16.04.2013 10:03:01
Kui on 600 lehte avatud ja need aasta otsa sedasi ripakil, siis minu arvates kaob asja mõte juba seetõttu, et aasta pärast on enamuse nende lehtede sisu juba lootuselt aegunud või muutunud. Näiteks uudised. Või mingi veebipoe tooteleht, mille saadavuse ja hinna number muutub iga mõne tunni tagant... Seega lehe kallale asudes pead ikkagi refresh tegema, ehk siis sisuliselt samahea nagu järjehoidjast leht uuesti avada.
Iseküsimus muidugi vahetu tööarvuti hoidmine aasta otsa nii et kordagi pole vaja restarti teha (igakuised Win updated!?) ega esine mingeid pikemaid voolukadumisi.
16.04.2013 10:06:13
WAV, nii brauserid ise kui session manager oskavad ju lahtiolevad asjad ilusasti üle restartide alles hoida.
aga ma olen ka üsna veendunult seal laagris, mis teeb 600 lahtise tabi peale
217 |
ufo56
16.04.2013 16:48:22
Ma ei tea tõesti. Pole ise ka aru saanud. Julm memory leak on kuskil chromes. Päevas korra peab kinni panema muidu võtab lõpuks 4+gb. Pluginaid väga midagi pole, gmaili notifier, lastpass.
67 |
Märt.
16.04.2013 17:54:44
FF-is samamoodi.
23 |
