LKits
				| Kommentaarid: 13 loe/lisa |
UnknowFunk
02.04.2013 20:17:45
Ruuteriks on valge elioni thompson ja muidu on telefon wifis (seal ei lähe nett ära) ja vahepeal ka sülearvuti wifis (siis kui korra selle errori ette viskab läpakas, siis peab läpakale resa tegema, muidu netis edasi olla ei saa)
 _________________ Mida hiljem saabub kiirabi, seda täpsem on diagnoos. |
				| Kommentaarid: 87 loe/lisa |
spreiii
02.04.2013 23:05:17
Äkki aitaks DNS-i korrasolekus selgusele saada sellisel viisil, et prooviks Google DNS-i?
Example: Changing DNS server settings on Microsoft Windows 7
Go the Control Panel.
Click Network and Internet, then Network and Sharing Center, and click Change adapter settings.
Select the connection for which you want to configure  Google Public DNS. For example:
To change the settings for an Ethernet connection, right-click Local Area Connection, and click Properties.
To change the settings for a wireless connection, right-click Wireless Network Connection, and click Properties.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
Select the Networking tab. Under This connection uses the following items, select Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6) and then click Properties.
Click Advanced and select the DNS tab. If there are any DNS server IP addresses listed there, write them down for future reference, and remove them from this window.
Click OK.
Select Use the following DNS server addresses. If there are any IP addresses listed in the Preferred DNS server or Alternate DNS server, write them down for future reference.
Replace those addresses with the IP addresses of the  Google DNS servers:
For IPv4: 8.8.8.8 and/or 8.8.4.4.
For IPv6: 2001:4860:4860::8888 and/or 2001:4860:4860::8844
				| Kommentaarid: 23 loe/lisa |
				  23 |
UnknowFunk
05.04.2013 15:57:59
spreiii, Hetkel nagu töötaks, pole veel tulnud       (loodan et ära ei sõnu)
E:
Igastahes tuli nüüd tagasi. Pidin ruuterile resa tegema, olid sülearvuti, PC ja telefon ühenduses, tuli kõigil samasugune error ette (va telefonis kus lihtsalt lehti ei laadinud enam ära.)
partyb
05.04.2013 19:50:20
| Kas chrome browserile mustale lingi ribale on võimalik lisada linke  juurde (kalender,drive jne) ? Sooviks, et oleks vähemalt samad lingid nagu seda on google.com versioonil. Hetkel viskab alati default .ee lõpuga lehele ja seal ainul  6 linki....
Märt.
05.04.2013 20:33:01
Ei näe sellist musta riba Chromel?
				| Kommentaarid: 29 loe/lisa |
				  23 |
siinus
06.04.2013 08:25:01
seda vist mõeldud:
aga kroomiga pole seljuhul pistmist.
 _________________ suck less | ANNA MU SAI!
				| Kommentaarid: 67 loe/lisa |
				  60 |
partyb
06.04.2013 08:34:30
	  | siinus kirjutas: |
	  seda vist mõeldud:
aga kroomiga pole seljuhul pistmist. |
Seda jah! Kuidas ei ole? Miks siis sama asi muutub, kui minna google.com lehele?
Hetkel päris mures, et ei saa minna oma kalendrisse 1 klõpsuga
LKits
siinus
				  60 |
M00t
06.04.2013 17:36:34
Maci peal hakkas Chrome mingi hetk ennast ise sulgema, seda eriti siis kui uue tab-i avamise nuppu vajutada. Soovitati asenduseks mingisugust Ironit, mis näeb samasugune välja, aga on kõrgendatud privaatsusega. Huvitaval kombel see ei viska välja.
Tahaks siiski Chrome-i tagasi.
				| Kommentaarid: 72 loe/lisa |
				  68 |
Mnator
06.04.2013 17:51:13
	  | lu1de kirjutas: |
Milleks? Lähtekood neil sama, Ironist on rämpskoodi väljaroogitud.
siinus
06.04.2013 17:54:34
chromium on ka vist macile saadaval. Tasub proovida.
				  60 |
MaxBass
07.04.2013 07:37:49
| Chrome menüü ja järjehoidjad suuremaks läinud. font sama, aga palju tühja ruumi nuppude vahel. Palun abi kuidas tagasi normaalseks muutab saab?
WAV
08.04.2013 04:25:32
	  | MaxBass kirjutas: |
	  | Chrome menüü ja järjehoidjad suuremaks läinud. font sama, aga palju tühja ruumi nuppude vahel. Palun abi kuidas tagasi normaalseks muutab saab? |
See ju igati hea, et näiteks parema hiireklahviga avaneva abimenüü read nüüd suurema reavahega on, enne oligi korduvalt jama, kui kiirelt tegutsedes ikka kursoriga kogemata naaberreale pihta sain ja sellest suhteliselt tüütult jama tekkis. Vähemalt mulle muutus meeldib.
Aga kuidas seda ise ära muuta saaks, seda küll ei oska pakkuda. Kui just ei tee vanema Chrome versiooni tagasipaigaldamist (mis kah selline küsimärgiga ettevõtmine).
				| Kommentaarid: 7 loe/lisa |
RaidoR
08.04.2013 07:19:33
| shortcuti target reale lisa: --disable-new-menu-style
				| Kommentaarid: 52 loe/lisa |
				  50 |
p2ep
				| Kommentaarid: 32 loe/lisa |
				  28 |
MaxBass
09.04.2013 17:58:16
	  | RaidoR kirjutas: |
	  | shortcuti target reale lisa: --disable-new-menu-style |
Suurimad tänud RaidoR! Nüüd norm menüü tagasi jälle.
Mul ka 64bit W7 ja pole sellist probleemi. Vb mingid uuendused puudu või kalavad? nt win, chrome, java, flash uuendused? Või mingid laiendused mis härivad?
p2ep
09.04.2013 18:07:29
	  | MaxBass kirjutas: |
	  | RaidoR kirjutas: |
Mul ka 64bit W7 ja pole sellist probleemi. Vb mingid uuendused puudu või kalavad? nt win, chrome, java, flash uuendused? Või mingid laiendused mis härivad? |
Sai uuesti W7 peale lastud, win uuendused kõik vastu võetud. Laiendusi põle. Ikka sekundite või poole tunni pärast koomas.
				  28 |
aks
09.04.2013 18:32:38
link :: pilt
Kasutan FVD Speed Diali aga thumbide tegemine hakkas villast panema. Teeb lihtsalt mingi häguse käki.
Milles võib viga olla?
				  119 |
LKits
siinus
				  60 |
LKits
its2cold
				  173 |
LKits
