uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Lucid Virtu MVP / GPU+iGPU märgi kõik teemad loetuks
johhu12
johhu12
sõnum 15.03.2012 16:16:49 Lucid Virtu MVP / GPU+iGPU vasta tsitaadiga
1.HyperFormance™ : A new technology which combines integrated and discrete graphics for uncompromised performance and improves gaming frame rates 30-70%. Special highlight here is that HyperFormance is also supported with both ATI™ and NVIDIA® graphics cards.
Allikas:http://www.vortez.net/news_story/asrock_introduces_amd_mb_supporting_lucid_virtu_universal_mvp_technology.html
Virtues MVP is a new technology from Lucid will be available for most cards based on Intel Z77. To do this requires a license in the BIOS makes me think the old boards based on Intel P67 / Z68 will not get a BIOS update to support it. Novelty for MVP Virtue is the option that can work both HyperFormance i-Mode and in d-mode, reducing the GPU work by determining that the frames to be rendered or not. It is much to discuss on this issue and we will do after we test this technology in more detail, until then we only say that promises significant improvement in gaming experiences.
Allikas: http://translate.google.com/translate?sl=ro&tl=en&u=http%3A%2F%2Flab501.ro%2Fplaci-de-baza%2Fasus-maximus-v-gene-preview
Link
Paistab, et lõpuks on ka kasu integreeritud videokaardist high-end masinatel. thumbs_up.gif
Prayer
Prayer
sõnum 05.12.2012 00:03:12 vasta tsitaadiga
Huvitav teema aga miskipärast vaikus majas... kas keegi ei ole proovinudki?
Kommentaarid: 232 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 201
Lehys
Lehys
sõnum 05.12.2012 06:46:54 vasta tsitaadiga
Ennastki hakkas selline asi huvitama,3dmark skoor tõusis küll ilusti ,ise asi kas mängudes ka märgatavalt tõuseb.
noxton
noxton
sõnum 05.12.2012 08:01:49 vasta tsitaadiga
vsync 120 thumbs_up.gif 60 asemel
Kommentaarid: 186 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 169
sõnum 09.01.2013 21:51:12 vasta tsitaadiga
Keegi on proovinud Virtut?
Mobo: Gigabyte G1.Sniper M3 (rev. 1.0) Z77
CPU: Intel® Core™ i5-2500K Processor (6M Cache, up to 3.70 GHz)
RAM: 4x4GB G.Skill RipjawsX DDR3-1600 = 2x F3-12800CL9D-8GBXL
GPU: ASUS GTX 560 DirectCU II OC 1GB
ja täna just proovisin onboard graafikat... kui ainult onboardiga teha, siis töötas kõik suurepäraselt.. bf3 sai proovitud, vanade settingutega, ehk lagis, ent vedas välja jne. tahtsin seda testida..
Igatahes, kõik oli fine & dandy, siis tahtsin panna Virtu peale, et emaplaadi tagant kaableid laiali vedada (monitor dvi ja telekas hdmi), ning panna läbi Virtu vajadusel D-GPU (560gtx) tööle.. ehk siis, ideest sain aru nii, et emaplaadi tagant paned pildinäitamiskastidele juhtmed taha ja läbi emaplaadi käib kõik signaal... kui koormus tekib, siis kasutatakse läbi emaplaadi väljundite gpu võimsust... senikaua aint igpu'd...
panin siis virtu peale, töötab, ok, lõbus, proovin mängu.. bf3 battlelogi ette paned, siis viskab aero maha ja brauseri üleval nurgas nupud kaovad ära + tekib mingisugune must kast sinna.. bf3 exe crashib toorelt kui käima panna. gta iv mitte ei jooksnud veel sujuvamalt (jookseb tavaliselt sujuvalt), vaid tõksus rõvedalt. proovisin selle hyperv peale panna ka virtu optionitest ja ikka sama jutt. teisi mänge ei proovinud (ilmselt jookseksin need ka iGPU peal.., mis hetkel lisaks on.)
sirvides jõudsin selliste teemadeni: probleem youtubes, probleemi teema battlelogis, overclock.net teema asja kohta.
Pilt sellest, kuidas mu brauseri nurk välja nägi, allpool tavaline siis võrdluseks. Ja BF3 visatud error.
Igatahes deinstall ja vanale süsteemile tagasiminek. Kurb, ideaalis oleks tahtnud, et igapäevased asjad jooksevad iGPU peal ja vajadusel võetakse dGPU võimsus mängu.
chesm6mmi
chesm6mmi
sõnum 09.01.2013 22:19:45 vasta tsitaadiga
proovisin ka aga win8 toetust veel pole niiet ei jõudnud kuskile kahjuks :/
Kommentaarid: 107 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 102
sõnum 09.01.2013 23:06:03 vasta tsitaadiga
Etz kirjutas:
rmc kirjutas:
keegi bf3 mängijatest Virtu't ka kasutab ?
Teoorias vinge asi, praktikas üpriski kasutu ja mittetoimiv... icon_neutral.gif
BF3 näiteks crashib, Firefox hakab veiderdama, jms...
BF3 teemast..
Krooms
Krooms
sõnum 11.01.2013 07:59:41 vasta tsitaadiga
Jep. Ma olin ka selle jama ohver. Viimati keeras kompu ikka täiega tuksi, kui üritasid mingid mängu mängida. Ühesõnaga proovis programm kogu aega mingisuguse serveriga kuskil ühendust võtta ja lõi CPU ja RAM-i näitajad kõik 100%. Ning arvutisse ilmus selline asi nagu "Ekag20nt.exe".Googles on sellest jamas kirjas küll. icon_rolleyes.gif
Minu arvutist nüüdsest Virtu Lucid puudub. Lugege siit. http://battlelog.battlefield.com/bf3/forum/threadview/2832654624997501182/
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 30
dex
dex
sõnum 27.09.2013 12:29:54 vasta tsitaadiga
Nüüd pool aastat mööda läinud. Virtust väljas 3 versiooni. Kas midagi on muutunud paremaks?
Ise kunagi proovisin, siis toimis küll starcraft 2, skyrim jne kuni max payne 3 tulid app crashid, siis sai uninstalli. Kui palju asi reaalselt voolu kokku hoiab, ütleme kooslus i5 2500k + 680gtx?
Süümi, juumi, makkami ja kui tüüle nakkami...
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 86
