7 :: |
364 |
196 |
7 :: |
364 |
renhoelder
| Kommentaarid: 75 loe/lisa |
71 |
16.11.2012 23:11:06
| Tanel kirjutas: |
Etz, jah, aga HV avalehe uudis ka ju vaja teha  |
Otseloomulikult, aga ma arvan et ei tee nüüd ka midagi halba, kui ma viitan seoses sellega ka sinna teemasse...
| ot: |
Vähemalt veendud, et su Uudiste toimetamine pole asjata vaev, keegi vähemalt loeb neid... |
196 |
Syncmahv
16.11.2012 23:12:52
| renhoelder kirjutas: |
Väga teemasse pilt, sama jutt oli DX 11'ga
102 |
Goon
UrmoZ
17.11.2012 00:04:56
HV-s on nüüd animeeritud .gif failid lubatud?
_________________ Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri! |
| Kommentaarid: 226 loe/lisa |
206 |
renhoelder
17.11.2012 00:11:01
UrmoZ, hmm...ei olnud teadlik ausalt öelda, et on keelatud. Võibolla lihtsalt reede õhtu ja keegi pole veel jõudnud postitusi kustutada?
Mis uut üldse on DirectX 11 vs DirectX 11.1?
71 |
Taun0
17.11.2012 00:13:36
nojah, aga mis siin imestada? XP peal tehti sama trikki.
_________________ www.elektron.ee |
| Kommentaarid: 68 loe/lisa |
62 |
17.11.2012 00:14:41
Eks Wiki aitab http://en.wikipedia.org/wiki/Direct3D#Direct3D_11
Direct3D 11.1 is an update to the API that will initially ship with Windows 8. The Direct3D runtime in Windows 8 features DXGI 1.2 and requires new WDDM 1.2 device drivers.[28]
Preliminary version of the Windows SDK for Windows 8 Developer Preview was released on September 13, 2011.[29] The new API features shader tracing, support for video playback, shader processing of video resources, and on-the-fly swapping between Direct3D 10 and 11 contexts and feature levels. Direct3D 11.1 also features minor updates to the shader language, such as larger constant buffers and optional double-precision instructions, as well as improved blending modes and mandatory support for 16-bit color formats to improve the performance of entry-level GPUs such as Intel HD Graphics.[28][30] |
7 :: |
364 |
Hardi
| Kommentaarid: 85 loe/lisa |
71 |
renhoelder
17.11.2012 00:21:53
Mõni mäng toetab DirectX 11.1 ka ? Päris paljud saavad siin ka DirectX 9 peal ka hakkama, nii et vist väga põdeda pole mõtet.
71 |
17.11.2012 00:25:33
renhoelder, konsoolid ja nende ajast maas raud on selle põhipõhjuseks...
196 |
renhoelder
17.11.2012 00:29:47
Etz, jäävad jalgu master race'ile Aga no, seni kuni pole ühtegi atraktsiooni veel välja kuulutatud mis DirectX 11.1 nõuab pole vist väga häda inimestel kes Start nuppu kaotada kardavad
71 |
KohviPaus
17.11.2012 00:30:20
| Endal ei hakka juba see konsooli bashimine üle viskama teil? Täiesti teemast mööda.
| Kommentaarid: 14 loe/lisa |
12 |
ufo56
17.11.2012 00:30:44
| UrmoZ kirjutas: |
HV-s on nüüd animeeritud .gif failid lubatud?  |
Kuna need keelatud olnud ? Avataris ja allkirjas ei või olla
Lae pildid -> pilt.io |
| Kommentaarid: 79 loe/lisa |
67 |
17.11.2012 00:33:42
| KohviPaus kirjutas: |
| Endal ei hakka juba see konsooli bashimine üle viskama teil? Täiesti teemast mööda. |
| ot: |
Mismõttes bashimine, need jooksevad ju alles DX9 peal nagu näiteks XboX ...siin pole midagi bashida... |
Kui tahad, et su reliis jookseks nii PC`l kui ka konsoolil, ei saa sa väga seal uute API`dega lihtsalt majandada,
kui sa just 2`te game enginet ehk sisuliselt kahte eri mängu ei tee...
196 |
KohviPaus
17.11.2012 00:35:56
| Nii ja mida täpselt puutub terve konsooli majandus hetkel DX 11.1? Isegi 7 ei saa seda täies mahus aga esimene asi on kohe konsoolid hambusse. Ära hakkab tüütama juba, pea igas topicus mingi soigumine nende üle.
12 |
renhoelder
17.11.2012 00:37:32
| KohviPaus, kui see minu pihta käis, siis imo ei olnud nagu bashimine, heal juhul "sõbralik tögamine". Oman mängimiseks nii PC'd kui konsooli, nii et väga bashida ei näe vajadust kumbagi, mõlemil on omad eelised ja miinused.
71 |
17.11.2012 00:37:34
| Nii ja mida täpselt puutub terve konsooli majandus hetkel DX 11.1? Isegi 7 ei saa seda täies mahus aga esimene asi on kohe konsoolid hambusse. Ära hakkab tüütama juba, pea igas topicus mingi soigumine nende üle. |
You tottally missed the point...
Point oli pigem selles, et kuni asi peab olema multiplatvorm ehk jooksma nii konsoolil, Windows 7, windows 8 või tont teab mis keskkonnas veel,
võib meile pakkuda eksklusiivselt mingile OS`ile või platvormile kasvõi DirectX 220.22 , reaalset tolku on sellest developeritele ja kasutajatele vähe...
viimati muutis Etz 17.11.2012 00:41:25, muudetud 2 korda |
196 |
KohviPaus
17.11.2012 00:39:27
renhoelder, Ei, ei käinud sinu pihta
12 |
renhoelder
17.11.2012 00:41:03
| KohviPaus, üleüldiselt, mul jäi millegipärast tunne, et keegi ei basninud siin kedagi. Lihtsalt tekkis vast küsimus kui vajalik või tähtis see .1 üldse on.
71 |
KohviPaus
17.11.2012 00:42:30
Ah siis võib ka hetkel süüdi olla kui midagi valesti aru sain, vabandan.
12 |
196 |
17.11.2012 14:56:09
| Etz kirjutas: |
renhoelder, konsoolid ja nende ajast maas raud on selle põhipõhjuseks...  |
F1 2012 näitelks ka konsoolidel, aga PC-l DX10 ja uuemad kaardid ainult toetatud, seega ei tea midagi. Pigem vist on tekkinud kriitiline hulk DX11 kaarte omavaid inimesi, keda on rohkem kui DX9 kaarte omavaid inimesi, et võib DX9 toe eemaldada: http://store.steampowered.com/hwsurvey
| Kommentaarid: 92 loe/lisa |
Xloaded
külaline
17.11.2012 17:30:28
Olen peale win8. väljatulekut avastanud ridamisi assju mida win 7 enam ei ole ja põhjuse on MS otse välja öelnud: "EI toeta enam antud lisasi/funktsiooni win7-me jaoks kuna keskenduvad täielikult win8 arendamisele" Väga kurb ja uskumatu. Alati on MS Windows ostetud kuna sellega on saanud kaasa pikkaajalise suppordi ja toe, mida linux/os jne ei saanud. Hetkel on aga nii, et Linux teeb oma LTS versioonide toega juba windowsile silmad ette.
Samas olen märganud, et vanemale rauale on igati win8 tuge arendatuid, samas win7 uuendused on jagu ajale jalgu jäänud ja uusi silmapiiril ei paista....
KohviPaus
17.11.2012 17:42:49
XP saab update veel kuni 2014. Seega 13 aastat. Ma arvan, et see piisavalt LTS
12 |
Xloaded
külaline
17.11.2012 17:55:26
XP saab update veel kuni 2014. Seega 13 aastat. Ma arvan, et see piisavalt LTS |
Ma ei mõtle selliseid hädapäraseid uuendusi mida pakutakse.
Suurima pahameele siiani on tekitanud see, et MS on hakanud keerama kinni win7 funktsioone/lisasi....olgu siis põhjused mis iganes. Ehk muudab mingi aeg meelt või tuleb mingi win9 mis kõik eelnevad mured lahendab.
UB
17.11.2012 17:55:27
Mina olen üks neist, kes saab DX9ga suurepäraselt hakkama ning ei oma ühtegi sellist arvutit, mis suudaks mängudes erilist silmailu pakkuda, nii et see point müügiedu küll ei suurenda. Nagunii saavad enamus kasutajaid selle uue OSi koos uue arvutiga. Endal on veel kolm arvutit Vista aegadest töös ning vahepeal on üks tekkinud ka Windows 7 ajal. Kui vahepeal arvutiostu plaanis ei ole, siis ei saa ka uut OSi proovida, enne tuleb järgmine versioon peale
| Kommentaarid: 45 loe/lisa |
39 |
KohviPaus
17.11.2012 17:56:56
| Xloaded kirjutas: |
Suurima pahameele siiani on tekitanud see, et MS on hakanud keerama kinni win7 funktsioone/lisasi....olgu siis põhjused mis iganes. Ehk muudab mingi aeg meelt või tuleb mingi win9 mis kõik eelnevad mured lahendab. |
Miks funktsioonid nad kinni keerand on siis? Kui sa mõtled seda mis tulid Win8'ga aga Win7'le veel pole siis saa aru, et see on üks nipp kuidas uut Windowsi maha müüa.
12 |
Xloaded
külaline
17.11.2012 18:03:29
| Xloaded kirjutas: |
Miks funktsioonid nad kinni keerand on siis? Kui sa mõtled seda mis tulid Win8'ga aga Win7'le veel pole siis saa aru, et see on üks nipp kuidas uut Windowsi maha müüa. |
Esime asi mis kohe meelde tuli on "gadgets" - kui nüüd neid lisama minna siis saad teate, et enam ei toetata bla bla lbaa..
Renka
17.11.2012 18:15:27
Sa tood selle millegipärast välja nagu oleks tegu halva asjaga
61 |
Xloaded
külaline
17.11.2012 18:20:36
| Renka kirjutas: |
Sa tood selle millegipärast välja nagu oleks tegu halva asjaga  |
Fakt on fakt!
See kellele ema kellele tütar on maitse asi!
