praegune kellaaeg 15.12.2025 05:08:09
kembadesig
13.11.2012 17:55:06
Olen neid klappe korduvalt soovitanud (AH-D1100) ja sellise raha eest nagu Amazonist need kättesaadavad on, ma ütleks et paremat asja on keeruline otsida. Omasin neid klappe juba mõned ajad tagasi, esmamulje oli hea. Seda siis nii heli osas kui ka klappide kergusest ja mugavusest rääkides.
Esimesel korral kui karbist välja sai võetud, tundus kuidagi naljakas ja odav plastik ning ei paistnud see klapp üldse suurena. Kuid kui pähe sai pandud ning veidi aega kuulatud, muutus arvamus tunduvalt positiivsemaks. Viisakas, minimaalne ning tagasihoidlik välimus, ülim kergus ja mugavus, hea heli kvaliteet. Kaasas oli lisaks korralik kaabli pikendus ning nahast kott klappide transportimiseks/eeskujuliku välimuse säilitamiseks.
It's tough following on the heels of one of the most successful 'on-ear' sealed headphones ever, but the DENON AH-D1100 almost lives up to its famous forebearer, the [discontinued] DENON AH-D1001. Larger 50mm dome drivers (versus 40mm for the D1001) along with slightly bigger earcup dimensions provide full musical body and big bottom-end authority with a deep tone that blooms with hip-hop, blues and modern rock recordings. If not correctly amped with some audio sources, the AH-D1100 potent low-bass response can sound slightly uncontrolled as it supports pleasing vocal midranges transitioning into smooth upper treble definition. Demanding classical & symphonic fans seeking extreme upper highs transparency and soundstage 'air' (depth) may find themselves wanting for more resolution in the top-most edges of the frequency range. The new earcup cushions on the AH-D1100 verge on true 'full-size' dimensions and will plushly surround the ears on most wearers. These larger, softer DENON earpad cushions and the closed-back construction helps provide isolation and good listening privacy, a handy plus for the office cubicle, dorm room or city park.
The DENON AH-D1100 has a circumaural ('around the ear') construction design and come in a framed black on gun-metal earcup/headband color scheme -- way hip -- with the classic DENON logo emblazoned across the outer earcups. The non-detachable, modular cord arrangement allows for short cable runs or a longer runs when employing the included extension cords for those needing a longer reach to their audio source. The new DENON earpad cushions are a soft, nuzzly glove-leather material that is durable for the long haul and won't dry out and rot in any climate. |
_________________ Sounds?... |
| Kommentaarid: 73 loe/lisa |
65 |
pots4t4j4
13.11.2012 22:14:57
Jutu jätkuks, sain siis oma MH1 kätte, kõik on tore ja kõlavad kenasti ( juhe on ebamugav ja nõme see ka headfi.org lehel kirjas)
Aga tuleb välja, et oleks pidanud selle headfi.org lehe lingi läbi lugema, seal selgelt kirjas et MH1 (livesound/older version) kõlab normaalselt ainult siis kui answer call nuppu all hoida, mis seals ikka oma rumalus, tellin link
siis MH1C variandid ka ära mis peaksid igalpool kenasti mängima.
Helikvaliteediga olen kindlasti rahul kõlavad väga selgelt ja madalaid on ka piisavalt, oleks võinud ainult enne tellimist täpsemalt lugeda
Kohale jõudsid ka kiiresti 7.11.12 tellisin ja täna õhtul 13.11.12 jõudsid kenasti ümbrikus kohale.
24€ eest on raske paremaid klappe leida ma ütleks.
Peab need praegused MH1 versioonid lihtsalt kellelegi Nokia/LG/S/SE telefoni omanikule maha müüma sest seal need vist töötavad kenasti.
OMTP and CTIA (both are organizations for mobile standards). For OMTP, the TRRS plug is wired as [Left-Right-Mic-Ground] (from tip-to-sleeve); for CTIA, the TRRS is wired as [Left-Right-Ground-Mic]. Since OMTP was initially endorsed by Ericsson (and Nokia, which still uses the OMTP standard), all of their cellphone, including those under the Sony Ericsson branding, uses this standard. It also got adopted by a few other cellphone manufacturers as standard before mid 2011, such as LG, Motorola, Sony and Samsung. In mid 2010, the OMTP organization transitioned itself into another organization (the WAC, if you are interest to know), and the OMTP standard for headset was subsequently being phased out by most manufacturers within the following year (* it takes time to sell off old models) in favor of the CTIA standard. Part of the big reason for adapting the CTIA standard might be due to the fact that it is the standard used by Apple on their iDevice, which represent a big share of the headset market. Standardization demands from political groups (i.e. the EU) also played a role to push for one headset standard that will work on both Android and iOS, as well as most dumbphones (except for Nokia, which doesn’t like to play with other for now).
401 |
asdasd
14.11.2012 12:20:17
| kembadesig, tänud kerge ülevaate eest. Tellisin ära. Järgmise nädala jooksul peaks kohal olema. Saan võrrelda levinud Sony stuudio klappidega MDR-7506 - hetkel nendel vasakus kõrvas membraani juures midagi lahti - puhtalt bassi (synte) kuulates on "põrinat" kuulda. Peaks parandama, aga konstruktsioon tundub ka habras, et ei taha väga lõhkuda.
| Kommentaarid: 14 loe/lisa |
Siim159
15.11.2012 19:20:49
Ostsin siis Sennheiser MX680i klapid ära Soundshopist (tehti veidike alaekat ka ). Tunduvad täitsa ok, kui jooksma jõuan, vaatab, kuidas püsivad ja üldiselt tunduvad. Jama ainult see, et helireguleerimist ja pause/play nupud (vb ehk mikker ka? Pole testinud) töötavad vist vaid Apple toodetega....
| Kommentaarid: 22 loe/lisa |
21 |
Raudo
15.11.2012 19:24:56
Koduseks muusika kuulamiseks kasutan vanu Logitech Z cinema juuste... paras keberniit nendega igakord, kui k2ima tahad panna, enne arvuti sisse lylitamist peavad k6llid USB pesas olema, muidu arvuti ei taha aru saada, et midagi kylge yhendatud uusi ka ei raatsi osta, kuna nii v2he on aega yldse normaalselt muusikat kuulata, tavaliselt enne linna minekut s6pradega paar lugu meeleolu loomiseks
| Kommentaarid: 7 loe/lisa |
namstoop
15.11.2012 19:29:56
Keegi Jays a-Jays ONE+ kasutab koos mõne Android telefoniga? handsfree ikka funktsioneerib normaalselt?
http://soundshop.ee/index.php?id=1586&toode=Jays%20a-Jays%20ONE+
| Kommentaarid: 72 loe/lisa |
63 |
pots4t4j4
15.11.2012 21:45:41
| miks üldse 40€ eest raisata nende peale telli ebayst sony MH1C ja minek
401 |
kembadesig
15.11.2012 21:48:07
| Raudo kirjutas: |
Koduseks muusika kuulamiseks kasutan vanu Logitech Z cinema juuste... paras keberniit nendega igakord, kui k2ima tahad panna, enne arvuti sisse lylitamist peavad k6llid USB pesas olema, muidu arvuti ei taha aru saada, et midagi kylge yhendatud uusi ka ei raatsi osta, kuna nii v2he on aega yldse normaalselt muusikat kuulata, tavaliselt enne linna minekut s6pradega paar lugu meeleolu loomiseks  |
Sellegipoolest võiks ju see "meeleolu loomine" ja hea kvaliteediga muusika nautimine ilma selle keberniidita ning hea mugavuse ja kõige muu kaasaskäivaga olla.
65 |
Amphor
02.12.2012 18:50:51
Minu esmaspäeval kätte saadud Panasonic RP-HTX7med purunesid otsikust juba neljapäevasel päeval, otsik murdus pooleks, osa jäi arvutisse, osa juhtme külge. Kasutasin esipaneeli porte ning katlustan, et tegu võis olla ka tooliga, mis kuidagi imelikult nende vastu sõitis ja neid väänas. Igatahes, sai ostetud uus otsik, joodetud traadid õigesse kohta, kuid ikka häält ei tee. Ostsin teise otsiku ning proovisin seekord alguses ilma jootmiseta, vaid neid kinni hoides õigetes kohtades, ning ikka ei tee klapid krabinatki. Kas tõesti vedas nii, et klapid läksid suhteliselt korraga kahest erinevast kohast katki!?
edit: teisel korral sai välgumihklit traatide jurues kasutatud ja tundus sõrmedega kinni hoides töötavat enam vähem, ragises jms kll, kokku joota ei jõudnud veel
_________________ Kui postitus on sisulage, siis loetakse signatuuri
viimati muutis Amphor 02.12.2012 23:19:08, muudetud 2 korda |
| Kommentaarid: 36 loe/lisa |
34 |
Laurman
02.12.2012 21:47:32
Nädalake tagasi andsid minu Denon C551-d saba. Ühe kuulari juurest hakkas juhe ragistama ja lõpuks ei teinud sedagi. Kuna jootmine endal käpas pole ja juba mõnda aega on kõrv kihelenud millegi uue ja parema vastu siis sai vaadatud midagi uut.
Valihelis olid kohapeal kuulamiseks 100€ hinnaklassis Beyerdynamicu MMX 101iE ja Grado iGi. Esimene jättis ülevaadete puhul päris hea mulje ja olin 80% kindel, et nendega ma sealt ka minema jalutan. Gradod aga jäid ülevaadetes kesiseks ja eriti ühestki otsast muljet ei avaldanud. Kuulates olid Beyerdynamicud päris räpase helipildiga, madalsagedused ja madalam ots kesksagedustest istusid nagu üksteise kukil meenutades läbi padja muusika kuulamist. Poleks ma hinda teadnud siis oleks nende hinnaks umbes poole vähem pakkunud. Ühesõnaga ei kõlvanud. Gradod olid aga tõsine positiivne üllatus. Kõla oli meeldivalt soe, natukene kesksagedusi esile tõstev aga üldiselt väga meeldiv.
Nüüd on neid Gradosid umbes nädalake kuulatud ja peab tõdema, et detaili on palju rohkem, kui denonitel. Kahjuks on (väga madal) bass natuke tagasihoidlikum ega eristu nii hästi, aga kõrgete ja kesksageduse täpsus ja detailsus teevad selle tasa. Üldse kõlavad need Gradod väga suurelt meenutades hoopis suuremaid klappe. Kaasasolevad kõrvavahud on nii mugavad et kõrvas neid praktiliselt ei tunne ja isolatsioon on parem kui neil kummijurakatel. Igatahes mina olen rahul.
97 |
03.12.2012 20:00:36
nüüd kui mul juba paar kuud jeybird sprint klapid olemas, siis nüüd nad yllitasid veel parema versiooni. enne seda tuli oodata 2 aastat, nüüd vaid 4-5 kuud
krt nad varem ei võinud seda teha
aku vastupidavus on ikka mega, levi on parandatud i, samas hind on kõrge, ca 159$
http://www.jaybirdgear.com/bluebuds-x-bluetooth-headphones/
uusi ma küll hetkel enam ostma ei hakka, kuigi tahaks
CoiL
04.12.2012 15:51:54
Tuli ka isu helikvaliteeti uuendada ja kuna ammu oli isu korralike kõrvaklappide järgi, siis sai uuritud ja puuritud ning tellisin endale sellise kompoti:
Aune T1 Tube DAC/Amp (6922 lambiga)
Superlux HD-681 - peamiselt elektroonilise ja bassirikkama muusika jaoks
Superlux HD-662F - proge rock, Metal jms. jaoks
Molematele klappidele teen filtrid vahele: http://rockgrotto.proboards.com/index.cgi?board=review&action=display&thread=4769
Kuna mulle meeldib igasugu nikitsemine, siis plaanis klappe kroom/seemis nahaga ja Tamme/Mahagoniga tuunida ;P
Aune T1`st rohkem juttu siin: http://rockgrotto.proboards.com/index.cgi?board=talk&action=display&thread=8297
Igatahes peaks suht jõhker bang-for-a-buck kompott tulema Aga eks näis kui asjad käes, siis kirjutan siia ka kindlasti muljeid.
E:
| krist2an kirjutas: |
| Sain just Superlux HD681 kätte. Väga odavad stuudioklapid, aga heli on tõesti hinna kohta super. Nagu mitmetes ülevaadetes mainitud, siis kõrged toonid võivad veidi väsitama hakata, aga võrreldes PortaPro'dega on heli mõnusalt tasakaalus ja neutraalne. Kvaliteet on nii ja naa, iseenesest on asju mis on väga korralikult tehtud: juhe on korralik paks ning liitekohad vastupidavad (erinevalt PortaPro'st kus ma kardan kogu aeg, et juhe tuleb klappide küljest lahti), aga 19.90€ eest ei saa väga kvaliteetset materjalivalikut oodata, seega plasti leidub ohtrasti ning padjad on tehtud kunstnahast. Siiski, ma ostuga väga rahul. |
Tee filter mod ja peaksid veelgi paremini kõrvu hellitama
| Kommentaarid: 95 loe/lisa |
83 |
asdasd
04.12.2012 16:06:12
CoiL, kas ma sain õigesti aru sealt foorumist, et Amp on ligi 150€ väärt ja need klapid 20-30€? Etnagu.. how does that work?
PS: Sain oma Denon AHD1100'd ka amazonist kätte (~2 nädalat tagasi). Üllatavalt kiire post jälle. On olnud piisavalt aega neid kuulata ja võrrelda eelmiste MDR-7506'tega. Lühidalt - hämmastavalt head klapid muusika nautimiseks. 50mm driver VS MDR'ide 40mm annab tunda. MDR'id on palju vaiksemad samal volüümi tasemel ja neil tundub palju väiksem 'soundstage' olevat. Samas Sony'd on arusaadavamalt rohkem stuudio suunitlusega - keskmised sagedused tugevamad ja üldine sageduste pilt tasasem/ühtlasem. Aga jah MDR'id ei suuda kunagi sellist bassi välja mängida, et tunned klappi kõrva vastus rappuvat (peaaegu masseerib pead). Klapid pakuvad minujaoks just seda mida ootasin - kuulata selgemalt ja paremini kõiki nüansse/modulatsioone, mida artistid madalamatesse sagedustesse kirjutavad. Sellise raha eest nagu amazonist sain oleks küll äärmiselt kahju olnud need "maha magada".
Peab muidugi ära mainima, et konstruktsioon (hõbedane osa) on lihtsalt uskumatult kohutavast plastikust, mis tundub äärmiselt habras ja tekitab raamis naginaid (Näiteks vaikselt kuulates ja samal ajal süües (lõualuid liigutades) kuuled naksumist). Konstruktsiooni õrnusest olin muidugi enne amazonist lugenud ja teadsin, millega arvestada enamvähem. (Kumbki asi mind otseselt ei häiri. Tuleb hoida korralikult ja mitte süüa muusikat kuulates )
LauriTed
04.12.2012 16:25:38
| asdasd, need tõesti väärt klapid. Palju see saatmine amazonist tuli ja ms hind kokku oli?
228 |
asdasd
04.12.2012 16:43:25
| 55€+15€ post. Sain 70€(+sendid) eest. Hetkel vist nende hind natuke tõusnud, näitab 70€+post (et 85 läheks nüüd tellides kokku). Enne tehingu lõpetamist annab arvest täieliku ülevaate (vat jne).
CoiL
04.12.2012 19:06:39
asdasd, hind ja firmamärk ei määra üsna tihti mitte essugi! Enamus Superlux`i klapid ei ole oma ehituslike materjalide poolest kvaliteetne kraam aga need driverid, mis nendel klappidel sees, on tekitanud üsna palju head vastukaja foorumites ja ülevaadetes. Uuri natuke netist ja näed, et tegu väga hea bäng-foor-ö-bakk klappidega, eriti kui teha filter-mod.
Muidugi eks oma kõrv on kuningas ja eks näis kui asjad kätte saan.
Miks Aune T1? Esiteks teised odavamad alternatiivid mis enda jaoks välja juurisin, nt. Aune X1, FiiO E10, Audinst HUD-mini (Muses OPAMP) jmt. ei olnud oma hinnaga niipalju odavamad (arvestades juurde tellitavaid OPAMPe), et öelda T1-le ei. Mõtlesin, et kui kavatsen taolise summa juba DAC/amp`le panna, siis selles hinnaklassis võtta parim ja hetkel tundub selleks olevat Aune T1. Lisaks on see superhea plug-n-play ühilduvusega ja heli läbi lampide on mulle alati kordades rohkem istunud.
Miks Superlux`i klapid? Nagu ütlesin on tegu megahea diiliga ning mulle meeldib asju ümber ehitada. Mõtlesin, et ideaalne võimalus katsetada ja miskit pole ju kahetseda ka kui pekki läheb, 24€ ei ole just teab mis kadu. Beyerdynamic jms. klappe ei raatsi nagu lammutama ja ümber ehitama hakata (ega polegi vaja) aga vähem lõbu kordades rohkema paberi eest
HD-681 ja HD-662F on saanud tohutult suurt positiivset vastukaja ja paljud eelistavad neid kõvasti kallimate ja tuntumate asemel.
Vot nii
83 |
asdasd
05.12.2012 08:52:27
CoiL, on sul millegagi võrrelda ka neid "Superluxe"? Hind ja firmamärk pigem just üsna tihti määrab kvaliteedi, need on ikka erandid millest sa räägid. Olen ka lugenud kõike head koss portapro'de kohta ja osade madalama otsa sennheiserite kohta audiofiilide foormitest ja ka siitsamast foorumist - kuid praktikas on ikkagi totaalselt erinevad hinnaklassid totaalselt teistsuguse heli representatsiooniga. (Mitte, et portaprodel halb heli on, aga neid tõesti ei anna panna lähedalegi mingitele 100€+ klappidele.)
Ma pigem kipun arvama lihtsa loogika põhjal, et need superluxid on sellise "talutava" heliga. Lihtne oleks ka ühed tellida paarikümne euroga, aga klappe juba piisavalt ja ega seal midagi oodata pole.
Sellest mõttest saan sul muidugi aru, et kadu pole suur neid ära rikkudes mingi modifikatsiooniga (kui peaks midagi viltu minema).
Aune T1 huvitaks ennasti - ebayst tellisid?
ihvike
05.12.2012 09:08:39
Segan veidi vahele - olenemata sellest, mis kusagil foorumis räägitakse, ei ole absoluutselt mitte mingisugust mõtet hakata passiivfiltrit kõrvaklappidele juurde vägistama.
Kui on vaja ekvalaiserit, siis selle saab tekitada arvutis või mp3mängijas. Klappide ülemise otsa esitus on nagunii täiesti individuaalne ja kui kellegi teise filtrit kasutada, siis on äärmiselt tõenäoline, et tulemuseks on täielik porno, eriti arvestades seda, et passiivfilter on üks õnnetu asi, täpsusest ei saa eriti rääkida. Aga just täpsust on seal klappide ülemises otsas vaja, väga kitsad sagedusvahemikud on resonatsis ja neid tasub maha tõmmata. Aga mitte nii, et pool kuuldavat sagedusvahemikku on mingil määral maha tõmmatud, kuid resonantsid peksavad ikka 10 dB muust üle.
lugemist siit http://www.head-fi.org/t/413900/how-to-equalize-your-headphones-a-tutorial
ja siit http://www.head-fi.org/t/615417/how-to-equalize-your-headphones-advanced-tutorial-in-progress
| Kommentaarid: 12 loe/lisa |
12 |
CoiL
05.12.2012 10:12:15
asdasd, ihvike, mis ma ütlesin - kui kätte saan ja oma kõrvaga kuulen, siis eks näis kuidas need klapid on.
ihvike, ma lugesin terve selle teema läbi ja ütlen seda ainult üks kord - ma ei viitsi, ei taha sinu negatiivset (minu jaoks) nö. "hala" kuulata. Mul ei ole vaja sinu teooriat kuulata, mille oled endale täiesti ühesuunaliselt pähe võtnud, pidevalt tahad teiste arvamuste kohta tõestusi jne. Mind TÕESTI ei huvita mida sina arvad, sest reaalne kogemus nende klappidega puudub nii minul kui ka eeldatavasti sinul! Eks näis kui klapid kätte saab ja kuidas kostub minu kõrvale, justnimelt MINU kõrvale. Iga inimese kuulmine on erinev ja võib-olla ei olegi mingeid filtreid juurde vaja. Ja kui MINU kõrvade jaoks on kõrgeid helisid palju, panen selle filtri vahele ning kui on hea MINU kõrvadele, siis mind TÕESTI ei koti see terooria millega sa siin teemas pidevalt paugutad.
Teooriat võib inimene lugeda palju tahes, kuid praktika võib kõrvaklappide maailmas igale inimesele erinevalt lõppeda, olgu see siis kergelt pseudo või mitte. Oled sa sellele mõelnud, et see teooria mida sina endale nö. tõeks oled võtnud, võib ka sinu mõtlemist ja kuulmist pseudo-tasandil muuta? Mõtle natuke selle üle.
Igatahes on mul hea meel, et sul on oma arvamus ja omad kõrvad - need ei ole minu kõrvad. Minul on oma arvamus ja omad kõrvad. Kui tõesti on need Superlux`id jamad minu jaoks, siis eks nii ka ütlen siin teemas ja valin endale mingi uue toote. Aga millelegi peab inimene ostu sooritades toetuma ja kuna need klapid on laialdaselt positiivset vastukaja saanud, siis ei näe põhjust miks mitte see asi ära proovida, eriti veel sellise hinna eest. Kui MINU kõrvade jaoks piisavalt nö. vau soundiga siis olen rahul ja teemal .
asdasd, Aune T1 jah muidu eBay`st (UK) tellitud.
Igatahes kui pean neid klappe heaks, siis palun väga, luban Tartus külla tulla ja proovime/võrdleme klappe. Mul oleks ainult hea meel, kui leiaksin enda kõrva jaoks sedasi märgatavalt paremad klapid ja mõistliku hinnaga.
Kena päeva kõigile!
83 |
ihvike
05.12.2012 10:37:56
Kui sa paned mingi suvalise filtri sinna vahele, saavutad sa midagi, mille üle sul ei ole kontrolli. Okei, muidugi saab ka passiivfiltriga kitsaid tippe maha võtta, kuid see on siis juba selline keeruline filter, nagu su teisel lingil - ja sagedus tuleb ikka oma kõrvade järgi valida. Passiivfilter toob paratamatult oma probleemid kaasa nagunii - faasikarakteristik läheb metsa poole ja tundlikkus kehvemaks.
Küsimus ei ole mingis negatiivses "halas" vaid selles, kuidas asjad tegelikult on. Ma ise kasutan ka ekvalaiserit isegi oma DT880 klappidega, kuid loomulikult arvutis pesitsevat lineaarse faasiga parameetrilist ekvalaiserit just nendel sagedustel, mis minu kõrvale probleemiks on. Kuna see, millised sagedused muret tekitavad, on iga inimese jaoks individuaalne, ei ole teiste settingutest kasu. No näiteks, mul on selline pilt kasutusel:
Point just selles ongi, et inimesed kuulevad erinevalt ja kui sa kellegi teise parameetrite järgi valitud filtri oma klappidele vahele paned, on äärmiselt väike tõenäosus, et see teeb seda, mida vaja just sinu jaoks.
Link su enda lingitud foorumisse, kus üks postitus räägib sisuliselt seda sama juttu - http://rockgrotto.proboards.com/index.cgi?action=display&board=review&thread=4769&page=1#58722
12 |
asdasd
05.12.2012 15:28:29
ihvike, las ta harjutab tinutamist paarikümne eurose elemendi peal. Nothing wrong with that.
Ja Colili ei maksa end väga haavatult tunda kui mõni siin su projekti vundameti õõnestab natuke, võimalik et tinutad enda jaoks plaatinum heliga klapid ja oled rahul.
Kui heli on nii subjektiivne, siis eks me üritame ka oma natuke kallimaid investeeringuid kaitsta.
Mina igatähes olen huvitatud, mis su keevitusest kokku tuleb, aga kui sul millegagi otseselt võrrelda ei ole, siis njah..
CoiL
12.12.2012 22:12:53
asdasd, ma ei ostnud neid klappe tinutamise harjutamiseks (mida ma oskan ammuilma). Tõesti võimalik, et "tinutan" enda kõrvade jaoks head klapid millega olen rahul.
Mina ei tundnud ennast kuidagi haavatuna. Oma kõrv on kuningas. Seda veel näeb/kuuleb, mis sealt tuleb. Enne kui teie ja mina ei oma reaalset aimu millega tegu, pole mõtet ka siin teemas ilkuda.
E:
Klapid käes, HD-662F ja HD-681. Hetkel peas HD-662F ja MINU kõrva jaoks just nii nagu ka foorumites kirjas - kõrgeid liiga palju. Täpsemat EQ-t ei ole veel jõudnud näppida aga tundub, et see liigne kõrgete piik on ka sealkandis nagu ülevaadetes mainitakse.
Kohe poodi 6,3mm pesasid tooma ja õhtupoole filtreid tegema. Igatahes MINU kõrvad kinnitavad, et pauku on selle raha eest meeletult!
HD-681 ei ole veel jõudnud proovida aga isegi need nö. FLAT heliga HD-662F suudavad madalaid basse moonutusteta hästi mängida.
Infoks niipalju, et mingi nö. bass-head ma ei ole, eelistan pigem neutraalset ja kesksageduste poolset heli. Lood mida hetkel kuulan klappidest ja mille kohta bassi hetkel kiiruga kommenteerin:
1) http://store.origamisound.com/track/takeover
2) http://store.origamisound.com/track/vesper-2
3) http://store.farver.nu/track/divorce-original-mix
4) http://www.youtube.com/watch?v=brQ3sb6FAh4
Sissemängimisse mitte-uskujatele infoks niipalju, et võtan klapid peast ja jätan 24h sisse mängima Eks näis mis pärast minu pseudo-kõrvad kostavad
Aune T1 võim veel tulemata aga saan võib-olla rock-grotto foorumi kaudu mõned ülbemad lambid ka külge ;P
E2:
Niih, peale mõningast kuulamist sellised esmamuljed ilma võimenduseta (Aune T1 veel tulekul), otse arvuti integreeritud helikast ja tarkvaralise EQ-ga...
HD-681
~6Khz kandis liiga palju kõrgeid. Kui EQ-st -3 kuni -6db @ 6Khz maha tirida, siis on bueno. Seevastu bass on üllatavalt hea. Selliseid lugusid nagu Jamie woon - night air ( http://www.youtube.com/watch?v=EL0pTo9Z_XU ) , EPROM - Metahuman ( http://www.youtube.com/watch?v=sqvhVb9Bip8 ) ja Blak Nite - Dope Machine ( http://store.darkclover.ro/track/dope-machine )
on täielik nauding kuulata. Ei oleks uskunud, et need klapid nii madalaid helisid puhtalt mängida suudavad
Mugavad ja minu jaoks paraja raskusega aga padjad sellisest kergelt nö. "kleepuvast" tehismaterjalist. Samas kui sellele ei mõtle, siis ka ei häiri kuna see heli mis sealt klappidest tuleb paneb sellise pisiasja koheselt unustusse.
24€ eest Pillipood.ee-st on see täielik pauk imho! http://shop.pillipood.ee/327817/0/readmore/64556 Soovitan kindlasti! See 24€ on maha visatud raha selle heli eest mis sealt tuleb.
HD-662F
Samuti 6Khz-i kandis kõrgeid liiga palju, jällegi aitab -3 kuni -6db. Bassi kohta niipalju, et ülimadalat otsa on vähem kui HD-681`l kuid seda bassi nö. kick`i on sellevõrra rohkem ja rock, metal jazz muusikale tundub kübeke paremini sobivat kui HD-681. Muidugi eks mängib rolli ka kinnine vs. pool-lahtine klappide ehitus.
Padjad on paremast materjalist kui HD-681`l kuid mind isiklikult häiris ja ajas lausa pea valutama peale 15min kuulamist nende klappide kokkusurumise jõud. Sellest sai õnneks lahti kerge klappide lahtipoole väänamisega.
Üldiselt võttes on tegu üsna sarnase helipildiga klappidega ja kui katsetamishuvi puudub, siis soovitan erinevate stiilide kuulamiseks võtta HD-681.
HD-662F on ~17€ kallim ka: http://shop.pillipood.ee/327817/0/readmore/116657
Saaks nüüd Aune T1 ka kätte siis oleks minu jaoks üüber!
83 |
krist2an
13.12.2012 12:47:13
Mu HD-681 on hoolimata odavast plastikust väga hästi vastu pidanud, õnneks on see plastmass suhteliselt tugev ja jäik. Need kunstnahast padjad on kahtlased küll, ajavad kõrvad higistama. Samas praeguse ilmaga õues megahea neid kanda, kõrvadel hea soe . Ise tellisin otse Thomannist, seega maksin vaid 19€, sellise hinna eest paremaid klappe ei saa.
| Kommentaarid: 42 loe/lisa |
41 |
flameas
13.12.2012 12:49:15
KEegi mõndasi mugavaid ja hea heliga in-ear klappe hinnaga max 50€ oskab pakkuda?
| Kommentaarid: 91 loe/lisa |
81 |
tiith
maxnorm
13.12.2012 12:55:16
| flameas kirjutas: |
KEegi mõndasi mugavaid ja hea heliga in-ear klappe hinnaga max 50€ oskab pakkuda?  |
Sennheiser CX 300-II...minu arust.
| Kommentaarid: 21 loe/lisa |
19 |
