Forza Horizon is an open-world game based around a fictitious festival called the Horizon Festival, set in Colorado, USA. The game incorporates many different gameplay aspects from previous Forza Motorsport titles, like the large variety of cars, realistic physics and high definition graphics. The aim is to progress through the game by means of obtaining "Wristbands" by driving fast, destroying property, winning races and other driving antics. Horizon is set to feature the physics of Forza 4, which have been optimised to work on the 65 variants of terrain said to be present in the game. Players will be able to drive anywhere their cars can reach, such as fields and plains.[3]
Multiple race types are included, from drift to rally and point-to-point races. AI traffic will be present on the roads, which provides a new dynamic to the Forza racing system.[3] Players may also challenge other Horizon festival drivers they encounter in a one-on-one race to a given location. The location is random each time, and the AI have the ability to use shortcuts to their advantage.[4] Races will take place at different times throughout the day/night cycle included in the game, including night races.[3] A skill system is implemented in the game; players earn street cred during races by driving aggressively. Acts such as as drifting, jumping over obstacles and getting a car on two wheels all contribute to the cred. These can be chained together in a combo, which in turn affects the money players are paid at the end of a given race.[5] Cred also affects a player's popularity level in the game. As a player's popularity increases new special events are unlocked, such as races against helicopters and planes.[5]
Mõnus mix Forzast, Test Drivest ja Need for Speedist. Graafika on kena ning Colorado näeb väga ilus välja. Peab mainima, et level ja enviroment disain tundub väga supper, erinevalt enamusest free roam auto mängudest (ala NFS) kus lihtsalt väga igav on sõita kuna kaart on igav... Juhitavus oli täitsa ok simcade forza 4 mõjutustega. Esimesed 2 raadiot on head (bass arena ja pulse) aga see indie rock raadio oleks võinud olemata olla imo või pannud mingit korralikumat rokki/metalli sinna
Aga üldiselt on mäng see mida ma oleks oodanud uutelt Need for Speedidelt, selle asemel et neid burnoudistada... _________________ Bawse
Ei jõudnud veel sõitugi alustada, kui juba käis see moneyspilleri y0y00 stiil, muusika ja üleüldine tdu2 laadne teema närvidele. Miks ei võiks menüüd ja kõik sellega kaasnev olla rahulik, vaoshoitud ja viisakas nagu forza4-s.
Aga sõita oli mõnus. Päris seda õiget forza4 simu fiilingut muidugi kätte ei saanud millegipärast, aga ootame full versiooni ära. Horizonis on lõpuks rehvitossuga ka vaeva nähtud ja toss on julgelt paksem ja mõnusam võrreldes eelnevate forzadega.
käik abid maha ja viimane raskus aste peale siis on täitsa ok. muidu on lihtsalt läbimängimise vaev. ei oodanudki simu aga no söidad sa kruusal või asfaltil vahet pole, vöid rahulikult mölemal driftida _________________ JÖUDU!
musa on alguses ok, pärast on sellest dubstepist kopp ees. vörreldes most wantediga tundub see hetkel parem mäng olevat. kuigi olles alles natuke mänginud(loe roosa käepaele juures veel) on see ikka läbisöitmise vaev. _________________ JÖUDU!
Mängisin kuskil tunnikese täna. Tundub tore ja internetis free roaming on kindlasti üks tore tegevus, peab lihtsalt sõpru ootama, et nad mängu kätte saaks.
Kuna kõik kommenteerivad muusikat siis ega ma siis mainimata saa jätta... Kohe sai muidugi vahetatud rock raadio peale ja oli natuke parem. Rääkides helist, siis autode helid on kuidagi palju nõrgemad kui FM4's, ka siis kui muusikat vaiksemaks keerata. Kahju natuke. _________________ Xbox LIVE gamertag: xSullx ; Forza Motorsport 4 gallery on Flickr.
Forza huvilised liituge! Forza Motorsport Eesti
Hakkab pihta, täpselt sama kamm, mis Forza4-ga eelmine aasta, mis tuli Inglismaalt 14-st päeva, minu väidetavalt 8 päeva tagasi posti pandud mäng pole ikka veel kohal. See pole võimalik, et 1st class air mail tuleks Inglismaalt 8 päeva. Inglased on ikka räiged valetajad _________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
oh johhaidii kui mitu korda on mul asi Eesti Posti taga seisnud, ei oska kokku lugedagi. Mitu korda on olnud nii, et tädid vannuvad letis, et pole sellist asja neil ja mingi hetk hiljem tuleb teade, et kas tulete järgi ka vä, sest muidu hakkame seda tagasi saatma? _________________ !!
Oleks võinud siis eelmisest korrast õppust võtta ja muude kanalite kaudu mäng soetada _________________ Päevad lõpevad siis, kui lased neil minna...
M: Cannondale Tract kiiver (uus; Polar White; Large) - 40€
NeroEST, siin teemas piisavalt erinevaid poode:
https://foorum.hinnavaatlus.ee/viewtopic.php?t=390147
"Kammi läbi" ja telli kust kõige soodsam/kiirem/parem jne... _________________ Päevad lõpevad siis, kui lased neil minna...
Ma võin öelda, kust ei tasu tellida. ShopTo.Net-ist, 9 päeva väidetavast teelepanekust möödas ja ikka ei ole veel mäng kohal. _________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
Ons' ka hea mäng siis v?
Kas juhitavus on tõesti forza 4-st näiteks hullem? Et nagu täielik arkaad ikka jah? Kuidas rooliga on mängida?
Hullem on väga subjektiivne mõiste. Reaalsem see kindlasti pole, pigem rohkem lihtsamaks tehtud. Kuid on ilusti aru saada, et on FM4 sugulane ja kindlasti on kübeke reaalsem kui mõned muud levinumad arkaad sõidumängud. Ise ütleks, et üks parimatest "simkaad" variantidest ja open-world mängu jaoks sobib see stiil hästi.
Mäng mulle meeldib, pole veel väga süveneda jõudnud (on kolmas käepael hetkel) aga kogu maailm on hästi lahendatud ja paarutamist ning avastamist jagub seal küllaga. _________________ Xbox LIVE gamertag: xSullx ; Forza Motorsport 4 gallery on Flickr.
Kui teha Rival sõitu mõnel rajal kas ma saan vastasteks samadel raskussätetel vastased ? Väga aus ei ole nt kui ise kasutan ABS ja rewind off ja see kellest kiiremat aega tahan teha sõidab assisted brake ja wheel jne.
Rivals võtab ainult aja järgi.
Aga ABS oli sul natuke halb näide. Sest ABS maas pidurdab paremini kui ABS abi peal. Seega peaksid olema kiirem inimesest, kes kasutab ABS pidurdus abi (nii see oli vähemalt Forza Motorsport mängudes). Sama on ka manuaal kastiga, see on eelis, sest käiguvahetused on kiiremad. Muud asjad pigem nipet-näpet tunde küsimus. _________________ Xbox LIVE gamertag: xSullx ; Forza Motorsport 4 gallery on Flickr.
Sellesmõttes olen nõus, et Turn10 võttis ja näitas igasugustele Need for Speedidele ja Test Drivedele ära, kuidas mängu peab tegema.
Mõnus Dirt 2 vibe on sees kuidagi, kogu atmosfäär on hea.
See ongi täpselt selline mäng, millest kunagi Forza 3 ja 4a mängides sai unistatud. Oleks vaid need for speed vabaduse, test drive atmosfääri ja forza 4 mootoriga mäng...
Here it is!
Bar on nii kõrgele aetud, et EA games võiks NFSi tootmise ära lõpetada ja oma raha Turn 10le anda:)
Omad Forza 4a ja Horizonit, oled set for lifetime ( kuni järgmise forzani;) )
Here it is!
Hea mäng!
ZorroZip kirjutas:
Nõustus Nero'ga, ma ei ole ühtegi automängu nii kaifinud, nagu horizoni.
Seestvaade, abs ja traction off ning tuunitud cabrio corvette = epic fun!
Öösel S65 AMG = visualgasm.
Kiitma peab Horizoni ja tööd, mida Playground games tegi väga kindlasti. Oleks kuskil 4-5 aastat tagasi, meeldiks see mäng mulle palju rohkem (mitte, et hetkel ei meeldiks). Lihtsalt Forza Motorsport seeriaga olen nii ära harjunud, et ma juba igatsengi auto seadistamist ja rajal sekundi sajandikke maha lihvimist selle tulemusel.
Ning kuna enamus sõidud on väga sarnased (va. paar sõitu, mis on 100% kiirteel ja ainult tippkiiruse peale) siis ei tule mul ka soovi osta erinevaid autosid. Igas klassis on üks keskmine tagaveoline, üks 4-veoline (et kruusal sõita) ja üks suurema tippkiirusega auto. Nagu juba arusaada on minu jaoks see "Motorsport" jupp, mida ma igatsen. Aga nagu mainitud, poleks Forza Motorsport 2, 3 ja 4 olnud, oleks Horizon tõesti perfektne sõidumäng.
Kui Horizon on nüüd "mainstream'im" siis ehk hakkab Forza Motorsport süvenema rohkem just ringraja sõidule veel enam simulaatori nurga alt, mis oleks väga teretulnud.
tegin just dariuse vastu viimase showdowni ära. See kõige viimane lõik on kuradi keeruline.. 2 korda läks valesti ja pidin uuesti sõitma lisaks.. 1087Kw Veyron SS ei ole just kõige parem masin selle jaoks _________________ ..||..
Sain ka lõpuks oma ShopTo.Net-ist eeltellitud mängu kätte, ning eile õhtul veidi ka tiirutasin. Tundub kuidagi laialivalguv see asi, pole ilusat ja ühtset menüüsüsteemi, on vaid juhuslike autodega juhuslik kulgemine. Ja krt, kuidagi ei saa selgeks, kummaga on parem, kas rooliga või puldiga. Asfaltikatsed on kindlalt rooliga, ning kruus ja kiirteed juhuslikult vastutulevate autodega jälle puldiga paremad, ning enamus katseid on ju mix nendest kolmest. _________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
Horizon on oma edetabelitega ikka tõsiselt ämbrisse astunud. Ma ei räägigi sellest, et võid sõidu ajal nii palju kordi tagasi kerida ja kurve lõigata, kui ise tahad, tulemuse saad kirja ka siis, kui stardis otsa ümber keerad ja 200m tagasi sõidad. Varsti läheb ilmselt jälle totaalseks kustutamiseks nagu FM4-s, kui tüübid aru saavad, millise jama nad on korraldanud. _________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
Raske uskuda. Point selles ongi, et Horizon ei võta end nii tõsiselt ja pole otseselt simu. Ringiajad tulevad kõik puhtad, olenemate millega sa vahepeal hakkama saad - ei tule seda kolmnurga märki nagu FM4's. Ja selles mängus polegi seda puhtate ringide süsteemi rakendatud. Seega ma ei usu, et LB'de puhastus teemakohane oleks.
Sain ka hommikul peale 3 nädalat oma mängu kätte. Esmamulje on OK. Sõit isegi kõige raskema leveliga kulgeb tõesti kõvasti lihtsamalt võrreldes fm4-ga ja see pidu peo otsa rahabosside stoori käib ka natuke närvidele. Aga no S65-ga öösel kanjonite vahel kruiisida on päris cool
edit: kas kedagi ei kipu häirima liiga vaikne mootoriheli? Kui volüümi juurde keerata on juba ka environmenti ja rehvide müra liiga suur. Forza 4-s tuli nagu mootorisound paremini esile. Sõitsin ühte rallit Minidega ja no niipalju oli muud müra ümber, et vahel jäi käiguvahetus kahe silma vahele, sest lihtsalt ei kuulnud pöördeid.
Esimesest päevast on mind see väga häirinud. See vana Minida sõit, millest räägid on üks hullematest näidetest. Kui tahad mootori heli kuulda on siuke tunne, et pead valima kas Lamborghini või Ferrari - peaasi, et V12 mootor oleks. Pettumust valmistav natukene. _________________ Xbox LIVE gamertag: xSullx ; Forza Motorsport 4 gallery on Flickr.
Sai vöetud rally pack lisaks, mu meelest kuidagi ülimäära raske, no esimese raksuga sain 32'seks, pole nagu kehv rallitaja omast arust, ning tavamängus ei ole ka nii et köik on köige lihtsama peal, mängin keskmise raskus astmega, ning enamus abisid on maas, ainult veojöukontroll ja abs-pidurid vist olid peal(samad seaded mis tavamängus).
Esimesse kontrollpunkti jöuan esimesena ja sealt edasi hakkab langus, on keegi sama kogenud või lihtsalt olengi nii koba ja vaja lihtsalt tuimalt harjutada? Auto seadetes on ka köik "rally" asjad peal ja liigub suht väledalt, ning söiduvötted peaks ka olema suht okeid. _________________ JÖUDU!
seda, et
lampi sattus playlisti Avicii - Levels ja mul tuli automaatselt Forza Horizon meelde.
Ma pole seda vist nüüdseks ca pool aastat mänginud, kuid piisas ühest loost, et meenutada kui awesome mäng see oli.
Faktimeenutus, et forza horizon on parim open-world automäng. _________________ Winter is coming...
Sai läbi foorumi ostetud kasutatud Collectors Edition, aga mäng on soome keeles.
Kas asi selles, et võib-olla sai pandud Soome oma regiooniks ?
Lisaks on olemas xbox Gold membership ja siit ka küsimus, et kas regiooni vahetades kaotan Gold membershipi ?
Horizon sai just online pärast ostetud, aga no krt soome keeles mäng on ajuvaba
EDIT: kuidas aru saada , et mäng on bannitud ? Multiplayeris (soome keeles Moninpeli-s) ei leia nagu kohta, kus saaks niisama ringi sõita, kus oleksid ka teised inimesed. Kui otsida mingit online sõitu, siis ringrajasõitu olen saanud teha... kuid mäng sai ostetud just sellepärast, et kui on igav, siis teha aega parajaks kellegagi vähe dragida, niisama cruisida vms... aga no ei saa aru, KUIDAS.. palun abi
Kas kellelgi oleks jagada 1000 Club ja Season Passi DLC installikat?
Ostsin Collectors Editioni ja isegi õnnestus veel Season Pass USA gamestopist võtta, kuid 1000 Club oli tasuta lisa ja seda enam XBL vahendusel ei jagata (oktoobris vist pandi putka kinni). Season Passiga on ka jama, sest auto pakid ei tööta või siis mäng üritab mingeid lisafaile võrgust otsida, mida seal ei eksisteeri enam (samas Rally Expansion hakkas ilusti tööle).
Pistsin oma vana plaadi masinasse ja töötab nagu lubatakse, kogu stuff, 9,5GB, tõmmati serverist ja mitte bittigi plaadi pealt. Kuigi vaid 5 aastat on ilmumisest möödas ja mahtu on vähemalt 2-3 kordistatud mõjub graafika täieliku 80ndatena, ilmselt on FM7 mu nägemismeele täiesti peesse keeranud _________________ Give a man a computer program and you give him a headache, but teach him to program computers and you give him the power to create headaches for others for the rest of his life... R. B. Forest
