KillerXP
20.08.2012 02:55:20
Ehk siis defender möllab. Aga paras jama ikkagi. Endalgi on nimetatud kaks urgast hosts failis kirjas
Teip
20.08.2012 13:02:45
| Kas mängud saab käima kuidagi, ühel on väga vaja spider solitairi taguda, ütleb et toetuseta piirkond jne.
AJ
20.08.2012 23:49:42
Microsoft simplifies Windows 8 EULA, rewrites terms -- TechSpot
OEM
The software is licensed, not sold. Under this agreement, we grant you the right to install and run one copy only on the computer with which you acquired the software (the licensed computer)...
RETAIL UPGRADE
We do not sell our software or your copy of it – we only license it. Under our license, we grant you the right to install and run that one copy on one computer (the licensed computer), for use by one person at a time, but only if you comply with all the terms of this agreement. Typically, this means you can install one copy of the software on a personal computer and then you can use the software on that computer.
PERSONAL USE LICENSE (SYSTEM BUILDER) FOR WINDOWS 8 PRO
We do not sell our software or your copy of it – we only license it. Under our license, we grant you the right to install and run that one copy on one computer (the licensed computer) as the operating system on a computer that you build for your personal use, or as an additional operating system running on a local virtual machine or a separate partition, subject to the restrictions outlined under “Are there things I’m not allowed to do with the software?”
For your convenience, we’ve organized this agreement into two parts. The first part includes introductory terms phrased in a question and answer format; the Additional Terms and Limited Warranty follow and contain greater detail. You should review the entire agreement, including any linked terms, because all of the terms are important and together create this contract that applies to you.
The "System Builder" license, which is now known as a "Personal Use" license, affords end-users the ability to buy and install the software themselves. This is quite a departure from the current System Builder license, an agreement which expressly prohibits this behavior.
If you noticed, referenced in the EULA is also a section labeled, "Are there things I'm not allowed to do with the software?". The following paragraph is text from that portion of the agreement.
You may not install the software as an operating system on any computer except one that you are building for your own use or as an operating system running on a local virtual machine or a separate partition. You may not install the software on a computer that is running a non-genuine Windows operating system. |
21.08.2012 10:31:21
Seega siis saavad eraisikud system builder litsentsiga windowsi osta ilma system builderiks registreerumata? Või mis?
Või tähendab see lihtsalt seda, et vanasti ei saanud system builder iseendale windowsi "müüa", aga nüüd saab? Ja ikkagi peab system builderiks registreeruma, kui seda osta tahad? Ma pole nende vanade reeglitega nii kursis.
Ja palju selle hind oem litsentsiga windowsist siis erinema hakkab, kui hakkab?
d3t
21.08.2012 10:39:08
Dogbert, System builderiks OEM ostmiseks enam vaja pole (selleks registreerumine on tarvis ainult siis kui eesmärgiks on edasimüük). Nüüd on OEM versioon saadaval ka eraisikutele seega kui sa tahad ilma igasuguse toeta versiooni mis oleks seotud kindla emaplaadiga siis palun, osta OEM versioon. Rohkem infot hetkel pole.
_________________ next.Insiders - koht mängijatele ja tehnikahuvilistele toredaks ajaveetmiseks.
The_Boss
21.08.2012 13:39:09
Mul on HV-ga ja Win8-ga ühendatud sama e-mail. Kui HV-s tuleb PS, saadab see teate e-mailile. Jama on selles, et win8-s olles ma kuskilt ei näe, et e-mail tulnud. Ainult start-i minnes on seda märgata. Kuidagi desktopi notificationi selle kohta saaks, et uus e-mail tulnud?
Muid probleeme praeguseks märkanud pole.
21.08.2012 13:50:46
| The_Boss kirjutas: |
Muid probleeme praeguseks märkanud pole. |
Aga kas sul on Desktopi all see "näitamine" ka aktiivseks tehtud, et paremale märkide ritta see ilmub?
The_Boss
21.08.2012 14:02:13
Arvatavasti ei ole. Tahakski teada, kuidas seda saaks.
Kui keegi IM-ga midagi saadab, siis näitab küll ära, aga meile ei näita.
d3t
21.08.2012 14:18:48
| d3t kirjutas: |
| Dogbert, System builderiks OEM ostmiseks enam vaja pole (selleks registreerumine on tarvis ainult siis kui eesmärgiks on edasimüük). Nüüd on OEM versioon saadaval ka eraisikutele seega kui sa tahad ilma igasuguse toeta versiooni mis oleks seotud kindla emaplaadiga siis palun, osta OEM versioon. Rohkem infot hetkel pole. |
Ühesõnaga kehtestati globaalselt enam-vähem sama seis, mis mõned aastad tagasi Eestis vahepeal juba kehtis. Täpsemat infot veel ei ole, nii et küllap siis ei ole ka seda infot, kas koos Windowsiga mingit rauakola peab ka ostma või saab nüüd täitsa ilma?
Hakkan originaalartiklit nüüd lugema.
21.08.2012 15:31:45
Internet Explorer 10 RTM Benchmarked
http://www.ngohq.com/news/22226-internet-explorer-10-rtm-benchmarked.html
Conclusions:
According to our benchmarks results, Internet Explorer 10 seems to deliver better performance than its predecessor. Microsoft has done a great job improving IE's JavaScript performance. In addition, the 64-bit version has been dramatically improved and no longer buggy like it used to be in IE9. There is even a significant reduction in memory usage. Therefore, IE10 is clearly an update you should look forward to. |
The_Boss
21.08.2012 20:27:21
Ma tegelikult Metro UI IE-d mõtlesingi tänasest kasutama hakata. Aga suutsin ikka enne firefoxi ära tõmmata
Kuhu ma probleeme peaksin reportima.
Avastasin siis sellise asja:
Läksin kodust ära, arvuti jätsin käima. Tagasi tulles oli nagu ikka, sleepi läinud vist (ekraan must, ma täpsemalt ei vaatanud, kas arvuti käib või mitte. häält pole, nagu alati) Äratasin ta siis üles. Nagu ikka üles äratades, peab sisse logima (by default). Varem oli mulle tulnud meil ning IM ja nende teated olid siis üleval paremas nurgas. Kui kohe nende peale vajutada, ei saanud pmst midagi teha. Kõik oli segamini ja midagi aru ei saanud. ctrl alt del abil sain välja logida ja siis uuesti sisse logida ja siis oli alles korras.
AJ
tont23
21.08.2012 22:07:33
kellelgi sellist jama kah olnud et mängus kursorit pole?cod 4 on taoline anomaalia
tundub et mängud ei tööta küll korralikult(vb on asi selles et katsetan läpaka peal)...muidu on nagu enamvähem
hepman
22.08.2012 00:56:28
Metro kasutajaliides on vähemalt suuremal ekraanil tõeline produktiivsuse pidur - minu 19" ekraan näitab nüüd sama palju infot kui 10" tahvel. Iseenesest uus Start menüü rakenduste käivitamiseks asjalik (kui iga rakendus sinna automaatselt oma 5 ikooni ei paneks)
Ja vähemalt praegusel hetkel ei tööta rakendus Kaardid ning ükski rakendustepoest leitud mäng - automaatne sulgumine
AutoCAD kah enam ei tööta
Draco
22.08.2012 08:10:45
No nii, Windows 8 (90 day trial) peale pandud teisele kettale Windows 7 kõrvale esialgu ja asialgu nagu töötab.
AMD driverid peal ja korras, Creative driverid peal ja korras, nüüd vaja ainult Console Launcher ära oodata.
Õhtul vaatan kas Razeri driverid ka peale lähevad ja siis juba mõned vajalikud programm mida tööjaoks vaja on.
Kettad ACHI peal installimisest saati kuna installisin USB pulgalt mitte plaadilt (et plaadilt installida peab lükkama kettad IDE peale muidu ei tunne plaati ära , vähemalt minu arvutil)
Seega, testime edasi
_________________ Purgatory Judgement |
eltso
22.08.2012 08:56:29
| hepman kirjutas: |
AutoCAD kah enam ei tööta  |
Minul töötavad nii kaardid kui ka mängud ja "metrost" saad kõik ebavajaliku eemaldada ja jätta sinna vaid vajalik, siis ei peaks ta kohe kindlasti liiga vähe infot mahutama.
The_Boss
22.08.2012 15:04:17
Jälle üks bug avastatud, seekord "sõnumside" appiga. Kui mingi hetk eemaldasin internetikaabli ja hiljem tagasi panin, siis sõnumside app ei taha kuidagi tagasi võrku ronida. Aitab windowsist välja-sisse logimine.
WäntWõll
make.believe
22.08.2012 15:58:10
| Oot täpsustage teadjamad, kas on liikvel kaks erienvat buildi n-ö ametlikust RTM-sit?
prtv
22.08.2012 15:59:45
| WäntWõll kirjutas: |
| Oot täpsustage teadjamad, kas on liikvel kaks erienvat buildi n-ö ametlikust RTM-sit? |
Buildi numbrid on samad, aga hashid on erinevad :/ Ma ise loodan, et vanemale lekkele saab ikka võtme peale lükata, mille MSDNAA'st nüüd paari päeva pärast peaks saama.
_________________ |
22.08.2012 16:02:05
Loomulikult saab
WäntWõll
make.believe
22.08.2012 16:12:52
OK selge pilt
Kuna testin siin paari juttu siis tahtsin teada, kas neil võib ka kapotiall olla erinevusi, kus tarkvara võib paigaldusel erivalt käituda.
Aga räsi erinevuse puhul ei tohiks sseal vahet olla.
22.08.2012 16:15:49
No võtke nüüd üks notepadi fail ja kirjutage sinna lause. Tehke sellest hash. Nüüd lisage failis lause lõppu kaks punkti ja salvestage ning tehke järgime hash.
Lihtsalt see, et hash on erinev, tähendab, et muudatus võib olla IMEpisikene
22.08.2012 17:09:24
| Kui build number on sama, siis ei saa OS-i koodis erinevust olla. Ilmselt muutsid nad seal plaadil miskit muud.
