uus teema   vasta Tarkvara »  Arvutimängude foorum »  FIFA 13 märgi kõik teemad loetuks
mine lehele 1, 2, 3 ... 54, 55, 56  järgmine
KrisVr
sõnum 15.05.2012 14:39:19 FIFA 13 vasta tsitaadiga
    • Arendaja: EA Canada(EA Sports)
    • Väljaandja: Electronic Arts
    • Väljalaske kuupäev: September 28, 2012
EA Sports has officially lifted the wraps on FIFA 13 and introduced this year's big gameplay improvements, with Complete Dribbling, First Touch Control and Attacking Intelligence all coming to this year's model.
Complete Dribbling's a feature that's partly inspired by this year's FIFA Street reboot, allowing players to dance around the ball and face their opponents at all times.
First Touch Control, meanwhile, adds a more random element when players take the ball, with player attributes now playing a larger role in the control of a ball.
Attacking Intelligence lends AI partners a more creative mindset when going forwards, seeing them finding space and using it more smartly - and it's an introduction designed to counter-balance the Tactical Defending that was introduced last year.
Elsewhere, additions have been made to the Impact Engine that was introduced in FIFA 12, with some of the more notable bugs being ironed out and with a greater emphasis placed on off-the-ball physicality.
The free kick system has also been expanded. Attackers can now trigger crossover runs, fake-outs and lay-offs designed to encourage a twitchy wall to jump early. On the defensive side, more players can be added to the wall, and players in the wall can charge the kick spot with the press of a button. They can also shuffle forward slightly to close the distance between them and the ball. If they do this too much, the referee will start showing cards. The new system should provide some entertaining cat and mouse contests in multiplayer.
Channon also confirmed that the PC version of Fifa 13 WILL be the same as console versions this year, continuing a trend started by Fifa 12.
viimati muutis KrisVr 11.08.2012 12:17:02, muudetud 1 kord
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 27
taizon
sõnum 15.05.2012 14:46:15 vasta tsitaadiga
Loodan et ei tule sama sitt kui FIFA 12. Gameplay on kohutav minu arust. FIFA 11 on igati parem kui 12. Ja celebrations on ka v2ga jubedad 12s.
Kac.
Kac.
sõnum 15.05.2012 14:51:10 vasta tsitaadiga
Jeps. Loodan ka siis midagi head.
LoL'is zoDzo
IvarV
IvarV
sõnum 15.05.2012 16:45:01 vasta tsitaadiga
isiklikult kardan, et tuleb pmst täpselt samasugune, nagu 12 oli.
Ertai
Ertai
sõnum 15.05.2012 22:47:29 vasta tsitaadiga
Fifa 12 oli minu jaoks edasiminek FIFA 11st, suur edasiminek. Usun, et tuleb üpris hea.
Kommentaarid: 52 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 47
henryKI11
henryKI11
sõnum 21.05.2012 21:54:16 vasta tsitaadiga
graafikat seal eriti ei muudeta , parandatakse kohtunikke impact enginit ja rünnet
taizon
sõnum 22.05.2012 11:35:35 vasta tsitaadiga
celebration-eid tuleks ka veidi muuta minu arust. Goal replay v6iks olla veidi parem.
tauno98
tauno98
sõnum 06.07.2012 09:27:14 vasta tsitaadiga
Mis celebrationitel viga on paremad kui 11 minuarust?!
WUBWUBWUBWUB
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 37
GTR
GTR
sõnum 06.07.2012 10:17:50 vasta tsitaadiga
Replay võimalus võiks tõesti kohe palju pikem olla, samamoodi salvestamine ka. Mitte ei salvesta mingi SD kvaliga mõttetut lühikest klippi mida on luubiga isegi halb vaadata.
Fraps'iga võib ka lindistada väravaid aga iga hea värava korral ei hakka frapsiga seda uncompressed videot ka lindistama ja kõvaketast täitma nende suurte failidega.
Kommentaarid: 118 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 111
Makux
sõnum 06.07.2012 12:00:22 vasta tsitaadiga
Konami on selle replay süsteemi hästi lahendanud. EA võiks õppust võtta. Salvestad replay failina ning hiljem saad sättida kaameranurki jms.
Redikate
Redikate
sõnum 06.07.2012 16:26:36 vasta tsitaadiga
Makux kirjutas:
Yes! Please!
Peale replay systemi polegi vist eriti muud mis väga kriitiline oleks. Võibolla võiks mängijad paremini audist palli kätte saada (praegu üritavad korduvalt palli kätte saada, aga feilivad, isegi kui jalge-ees). Mänguelamus on muidu väga hea ning tunde sinna alla maetud kõvasti.
taizon kirjutas:
Siitpoolt ootaks mingeid argumente. Miks sitt? Gameplay kohuvtav? Keyboardiga mängid või?
Celebrationite olulisusest ei saa aru, mis vahet on mida need vennad peale väravat teevad?
Pealegi 12'nes on ~60 erinevat celebrationit mida teha annab, jääb väheks või?
http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
t2ring
t2ring
sõnum 09.07.2012 10:11:27 vasta tsitaadiga
Jään kindlasti ootama thumbs_up.gif Fifa12 oli juba minu arust täitsa korralik, edasi saab minna ainult veel paremaks.
Kommentaarid: 97 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 94
lenc
sõnum 11.07.2012 12:58:56 vasta tsitaadiga
Makux kirjutas:
No vanasti oli ka FIFA-des täpselt samasugune asi. EA puhul on asi ilmselt selles, et nad ei tahagi lasta inimestel oma kõvakettale kordusi salvestada, vaid kõik peavad ikka nende serverisse videosid laskma.
KrisVr
sõnum 11.08.2012 12:14:51 vasta tsitaadiga
Link
henryKI11
henryKI11
sõnum 14.08.2012 13:32:30 vasta tsitaadiga
Link
Redikate
Redikate
sõnum 14.08.2012 15:38:06 vasta tsitaadiga
Keegi Ultimate editioni pre-orderinud ka? (saab 25 gold packi kaasa vms)
Kui jah, siis mis hinnaga ja kust?
http://nodejs.org/
GTR
GTR
sõnum 14.08.2012 15:43:15 vasta tsitaadiga
Ainult Originist saab vist Ultimate Editioni osta.
Asi mingi 20 EUR'i tavahinnast kallim kui ma ei eksi...
Saabu
Saabu
sõnum 14.08.2012 20:28:16 vasta tsitaadiga
http://www.youtube.com/watch?v=IYzxXZY-aAQ
http://mixturesport.com/wp-content/uploads/2012/08/208264_463492927024262_720429796_n.jpg
Hirff
Hirff
sõnum 15.08.2012 10:54:45 vasta tsitaadiga
See viimane video on küll ülimalt vinge, pöidlad püsti. Minu mäletamist mööda kasutati ühes Fifas väravavahtide liigutuste tegemiseks Petr Cechi. Aga Fifa 12 on kindlalt kõige võimsam Fifa läbi aegade, ise olen mänginud Fifa seeriaid oma 15 aastat ning üleminek Fifa 11 pealt Fifa 12 peale oli kindlasti kõige tugevam. Pole ühtegi Fifat nii kaua mänginud kui Fifa 12, isegi praegu on seda igati mõnus onlines mängida. Jään ootama Fifa 13 ja loodan, et tase ei lange, kuid ma pole pettunud, kui ei tehta nii suurt arengut nagu Fifa 12 seeriaga.
hendrik32
sõnum 15.08.2012 14:16:30 vasta tsitaadiga
Saabu kirjutas:
henryKI11
henryKI11
sõnum 15.08.2012 18:30:54 vasta tsitaadiga
Link
hendrik32
sõnum 15.08.2012 20:08:47 vasta tsitaadiga
henryKI11 kirjutas:
Link
Tundub sujuvam olevat kui FIFA 12.
libe
kvaliteetne mees
libe
sõnum 19.08.2012 20:09:10 vasta tsitaadiga
Ertai
Ertai
sõnum 19.08.2012 20:46:39 vasta tsitaadiga
Infona kuskilt, et Ultimate Teamis on nüüd ja "headtohead" stiilis lisa.
henryKI11
henryKI11
sõnum 21.08.2012 01:03:22 vasta tsitaadiga
IvarV
IvarV
sõnum 21.08.2012 09:14:22 vasta tsitaadiga
jonathan19
jonathan19
sõnum 22.08.2012 13:35:23 vasta tsitaadiga
See tore kui drogba chelseas ja persie arsenalis oleks aga need vist muudetakse ära või mis?
hendrik32
sõnum 22.08.2012 13:50:16 vasta tsitaadiga
jonathan19 kirjutas:
Täismänguks on arvatavasti meeskonnad ära uuendatud ning enamus mängijad oma õigetes klubides.
Ertai
Ertai
sõnum 22.08.2012 17:37:30 vasta tsitaadiga
hendrik32 kirjutas:
Täpselt nii.
Ka jaanuaris tehakse suurem update ja lükatakse mehed õigetesse klubidesse. Eriti Ultimate Teamis siis.
Redikate
Redikate
sõnum 23.08.2012 20:05:42 vasta tsitaadiga
Keegi ei tea, kas pre-orderit kuskilt mujalt riigist saab ikka teha?
50€ on ikka kole kirves nagu.
http://nodejs.org/
Ertai
Ertai
sõnum 23.08.2012 20:10:35 vasta tsitaadiga
Redikate kirjutas:
Ilmselt kasutaja zpsy kaudu saab.
libe
kvaliteetne mees
libe
sõnum 23.08.2012 20:22:31 vasta tsitaadiga
Redikate kirjutas:
www.amazon.com saab dollarihinnaga kätte, kui billing aadress US aadressina panna
peale müüki tulekut saab selle pela ilmselt 15-20€ kätte
henryKI11
henryKI11
sõnum 30.08.2012 19:22:51 vasta tsitaadiga
Link
coolmode
coolmode
sõnum 06.09.2012 15:48:09 vasta tsitaadiga
Huvitav kas Eesti koondis ka sisse pannakse?
Ertai
Ertai
sõnum 06.09.2012 17:33:54 vasta tsitaadiga
coolmode kirjutas:
tahaks loota, kuigi hästi ei usu. selleks peame kvalifitseeruma ilmselt MMile, siis kindlasti icon_smile.gif
henryKI11
henryKI11
sõnum 07.09.2012 14:18:01 vasta tsitaadiga
Link
Link
Arx07
Arx07
sõnum 07.09.2012 15:32:55 vasta tsitaadiga
Log
sõnum 07.09.2012 15:41:14 vasta tsitaadiga
Arx07 kirjutas:
Mingi haige <b>piix</b> möliseb seal viimases videos icon_eek.gif
Tüüp on seeni söönud võimidagi...
Kommentaarid: 113 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 103
IvarV
IvarV
sõnum 07.09.2012 17:18:12 vasta tsitaadiga
Mingit soodukaga preorderit pole veel?
GTR
GTR
sõnum 07.09.2012 17:26:04 vasta tsitaadiga
http://www.cjs-cdkeys.com/products/FIFA-13-CD-Key-for-Origin.html
Peaks olema usaldusväärne koht
IvarV
IvarV
sõnum 07.09.2012 17:35:54 vasta tsitaadiga
Krt ikka suht kallis, tõmbab vist zpsylt või kelleltki pärast riliisi key ja läheb.
GTR
GTR
sõnum 07.09.2012 17:37:00 vasta tsitaadiga
Eks peale väljatulekut saab vast mingi 20 euriga kätte arvatavasti küll
Kromosoom
sõnum 07.09.2012 19:51:28 vasta tsitaadiga
Kuskilt siit foorumist silma jäänud, et keegi tellis Origin'ist 19EUR'i eest. Muidugi valis mingi teise regiooni. Keegi äkki viitsib järgi vaadata, kust odavamalt saaks icon_smile.gif !
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 2
Mustakurmu
Mustakurmu
sõnum 08.09.2012 01:28:32 vasta tsitaadiga
Arx07 kirjutas:
Kommentaarid: 34 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
Jack Vegas
Jack Vegas
sõnum 08.09.2012 10:07:46 vasta tsitaadiga
Kromosoom kirjutas:
Mingisuguse Aasia proxyga sai proovitud, kui BF3 Premi hullus peal oli. icon_biggrin.gif Ei ta kas enam ka nii odav on.
IvarV
IvarV
sõnum 08.09.2012 13:42:06 vasta tsitaadiga
Google esimeste tulemuste järgi saab India proxyga ostes 11£ eest, see peaks olema 14-15€ umbes.
Keegi proovida viitsib, siis õpetus on siin:
http://xslcss.com/~xslcss/index.php/forum/24-other-games/22723-pre-order-fifa-13-for-p11-pc
Endal krediitkaarti pole, seetõttu ei saa osta (alaealine, SEB virtuaalset ei lasta teha.)
GTR
GTR
sõnum 09.09.2012 17:42:08 vasta tsitaadiga
http://www.buygamecode.com/cd-key-fifa-13-pc-origin-cd-keys
keegi teab antud netipoe kohta midagi? eesti firma nagu näha.. TUID OÜ, Kärberi 33-76, Tallinn,13919
Võtaksin vast sealt kui asi usaldusväärne...
Anna tooli
sõnum 09.09.2012 17:44:46 vasta tsitaadiga
https://foorum.hinnavaatlus.ee/viewtopic.php?p=7254625#7254625
Kommentaarid: 367 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 301
KrisVr
sõnum 10.09.2012 15:07:28 vasta tsitaadiga
Täpsemalt kella 11:00 ajal! Mängida saab AC Milan, Arsenal, Borussia Dortmund, Juventus ja Manchester City meeskondadega.
Paulz
sõnum 10.09.2012 15:18:21 vasta tsitaadiga
Kell 11 päeval jah? Ei jõua juba ära oodata. Ise olen tõbine ka niiet ongi tegevus päevaks olemas
Kommentaarid: 14 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 11
uus teema   vasta Tarkvara »  Arvutimängude foorum »  FIFA 13 mine lehele 1, 2, 3 ... 54, 55, 56  järgmine
