• Arendaja: EA Canada(EA Sports)
• Väljaandja: Electronic Arts
• Väljalaske kuupäev: September 28, 2012
EA Sports has officially lifted the wraps on FIFA 13 and introduced this year's big gameplay improvements, with Complete Dribbling, First Touch Control and Attacking Intelligence all coming to this year's model.
Complete Dribbling's a feature that's partly inspired by this year's FIFA Street reboot, allowing players to dance around the ball and face their opponents at all times.
First Touch Control, meanwhile, adds a more random element when players take the ball, with player attributes now playing a larger role in the control of a ball.
Attacking Intelligence lends AI partners a more creative mindset when going forwards, seeing them finding space and using it more smartly - and it's an introduction designed to counter-balance the Tactical Defending that was introduced last year.
Elsewhere, additions have been made to the Impact Engine that was introduced in FIFA 12, with some of the more notable bugs being ironed out and with a greater emphasis placed on off-the-ball physicality.
The free kick system has also been expanded. Attackers can now trigger crossover runs, fake-outs and lay-offs designed to encourage a twitchy wall to jump early. On the defensive side, more players can be added to the wall, and players in the wall can charge the kick spot with the press of a button. They can also shuffle forward slightly to close the distance between them and the ball. If they do this too much, the referee will start showing cards. The new system should provide some entertaining cat and mouse contests in multiplayer.
Channon also confirmed that the PC version of Fifa 13 WILL be the same as console versions this year, continuing a trend started by Fifa 12.
viimati muutis KrisVr 11.08.2012 12:17:02, muudetud 1 kord
Replay võimalus võiks tõesti kohe palju pikem olla, samamoodi salvestamine ka. Mitte ei salvesta mingi SD kvaliga mõttetut lühikest klippi mida on luubiga isegi halb vaadata.
Fraps'iga võib ka lindistada väravaid aga iga hea värava korral ei hakka frapsiga seda uncompressed videot ka lindistama ja kõvaketast täitma nende suurte failidega.
Konami on selle replay süsteemi hästi lahendanud. EA võiks õppust võtta. Salvestad replay failina ning hiljem saad sättida kaameranurki jms.
Yes! Please!
Peale replay systemi polegi vist eriti muud mis väga kriitiline oleks. Võibolla võiks mängijad paremini audist palli kätte saada (praegu üritavad korduvalt palli kätte saada, aga feilivad, isegi kui jalge-ees). Mänguelamus on muidu väga hea ning tunde sinna alla maetud kõvasti.
taizon kirjutas:
Loodan et ei tule sama sitt kui FIFA 12. Gameplay on kohutav minu arust. FIFA 11 on igati parem kui 12. Ja celebrations on ka v2ga jubedad 12s.
Siitpoolt ootaks mingeid argumente. Miks sitt? Gameplay kohuvtav? Keyboardiga mängid või?
Celebrationite olulisusest ei saa aru, mis vahet on mida need vennad peale väravat teevad?
Pealegi 12'nes on ~60 erinevat celebrationit mida teha annab, jääb väheks või? _________________ http://nodejs.org/
"I'm also a person. Programming is just one thing I do."
No vanasti oli ka FIFA-des täpselt samasugune asi. EA puhul on asi ilmselt selles, et nad ei tahagi lasta inimestel oma kõvakettale kordusi salvestada, vaid kõik peavad ikka nende serverisse videosid laskma.
Keegi Ultimate editioni pre-orderinud ka? (saab 25 gold packi kaasa vms)
Kui jah, siis mis hinnaga ja kust? _________________ http://nodejs.org/
See viimane video on küll ülimalt vinge, pöidlad püsti. Minu mäletamist mööda kasutati ühes Fifas väravavahtide liigutuste tegemiseks Petr Cechi. Aga Fifa 12 on kindlalt kõige võimsam Fifa läbi aegade, ise olen mänginud Fifa seeriaid oma 15 aastat ning üleminek Fifa 11 pealt Fifa 12 peale oli kindlasti kõige tugevam. Pole ühtegi Fifat nii kaua mänginud kui Fifa 12, isegi praegu on seda igati mõnus onlines mängida. Jään ootama Fifa 13 ja loodan, et tase ei lange, kuid ma pole pettunud, kui ei tehta nii suurt arengut nagu Fifa 12 seeriaga.
Keegi ei tea, kas pre-orderit kuskilt mujalt riigist saab ikka teha?
50€ on ikka kole kirves nagu. _________________ http://nodejs.org/
www.amazon.com saab dollarihinnaga kätte, kui billing aadress US aadressina panna
peale müüki tulekut saab selle pela ilmselt 15-20€ kätte _________________ ☠
Kuskilt siit foorumist silma jäänud, et keegi tellis Origin'ist 19EUR'i eest. Muidugi valis mingi teise regiooni. Keegi äkki viitsib järgi vaadata, kust odavamalt saaks !
Mingisuguse Aasia proxyga sai proovitud, kui BF3 Premi hullus peal oli. Ei ta kas enam ka nii odav on.
