Tahavad accounti, et pärast kellelegi käbe maha müüa. Loll ostja, kes odavat võtit otsib jääb kõigest ilma, mängust ja rahast.
Edit (Nvrmind, ajasin sassi)
Noh, kes teab, mis neil peas on ja kuidas pikema aja peale nende tegutsemisplaan välja näeb. Hetkel tundub mõttekam olla nänni kokku ajada, et siis RMAH-s "ausalt" ärida.
viimati muutis Archangel 27.05.2012 18:50:30, muudetud 1 kord
1. Võti?
2. Tasub mainida, et enamus battle.net kasutajate äri käib paypali kaudu, kus on moodus raha 'tagasisaamiseks'.
Üks võimalik skeem on muidugi see, et:
1) Häkker müüb konto maha ning saab suvalisele paypali kontole pooleks tunniks raha, enne kui see tagasi võetakse.
2) Häkker ostab selle poole tunni sees oma peamisele kasutajale kulda/esemeid.
3) Raha võetakse tagasi, kulla-/esemetemüüjad jäävad rahast ilma ning häkker on rikas.
Originally Posted by Blizzard (Official Forums)
The post on the main page said that NONE of the hacking victims had authenticators. Are you saying that there were hacked accounts with an authenticator?
Sorry for not being more specific on that. The hacks I was referring to were from the last five years of WoW compromises, not the current D3 compromises. None of the D3 compromises that we've checked have actually had authenticators, despite their claims.
I got hacked 2 days ago. How'd that happen, bliz?
I just checked your account, and it has never had either the physical or mobile authenticator attached to it. You did have the dial-in authenticator attached, but it's level of security is far below the physical and mobile. It's meant to be used in addition to the main authenticator, not in place of.
Hmmmmm.
I'll bring up the idea of renaming the dial-in authenticator to my management. At the very least, maybe remove "authenticator" from its name so that people do not get it confused with the main authenticator (physical or mobile).
viimati muutis Psych0 27.05.2012 19:00:26, muudetud 4 korda
Tegelasi pole mõtet varastada müümise eesmärgil, kuna 1-60 tehakse ära mõne tunniga. Seega nad võivad neid lvl 60 tegelasi ise ka valmis vorpida, pole mõtet varastada ja tõmmelda.
Eriti kuna tegelase kättesaamiseks vaja rohkem infi, kui ainult sisselogimise parool.
Mis tegelasi? Nad müüvad kontot. Kustutavad kõik charid kontolt ära, et ostja arvaks nagu uus jne.
Psych0 kirjutas:
Kui nad su parooli ära muudavad, siis see on ainult neile kahjuks, kui sa samal ajal online oled, sest sa muudaksid ise omakorda selle ära jnejne. Samas, kui sa online oled ning nad sisselogivad, saad sina disconnecti, mille peale sina sisselogid ning nemad disconnecti saavad ehk nad näevad, et praegu pole mõtet 'üritada'. Parem mõne tunni pärast, kui sa magad, et nad rahulikult askeldada saaksid.
Mul juhtus see. Ühekorra sain veel sisse aga teine kord tuli juba error ja häkker sai väga lihtsalt kõike muuta. 2 min hiljem juba teade mailis, et parool ka muudeti. Ja sittagi ei saa teha vaid recovery või support.
Nüüd kontkat täis mingeid lv1 vendi ja muid tundmatuid. Ilmselt minu kontol keegi mängis ka veel.
Kas blizzard seda kulla kantimist uurib ka üldse? _________________ zero
Cromaclear, I feel you. Barbariga igast trikke proovinud, DW, 2h, 1h+ shield, erinevaid builde. Tavalised kollid saab veel kuidagi puruks, aga eliidid tapavad nii kiiresti ära et siga ka ei söö.. Peab ikka mingid kümned miljonid kulda kokku ajama vist ja mingi eriti hullu geari ostma.
Mingid itemid, nagu string of ears 20% melee dmg reduction + 32% block chance kilp + Justice lantern sõrmus mis annab block chance ja Helm of command vms mis annab ka veel block chance, nii saab 50-51% block chance kokku ja mingi ~30% melee dmg reduction from items. Aga no, parim kilp blokib vist kuni 3700 dmg vms, ma sain oma 72% dmg reductioni ja 350 phys resistancega 57k hiti act kahes, hp on 40k, arvuta kuidas tahad, ellu väga ei jää.
Aga kui vaadata kuidas see Kripp barbarit act 2 mängis, jube igav ikka. Barbar nagu kaotab oma mõtte ära kui teda peab ka mängima nagu mingit glass cannonit ja sealjuures pole ta veel eriline cannon ka, rohkem nagu glass tongipüss vms .
mul oli munk 17 h ja 32 minutiga juba seal kust hetkel edasi ei saa.... _________________ Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda.
Sai ka vahepeal nats mängitud. Algul guest pass'iga kõik charid nii palju, kui sai. Keskmiselt paar minti alla 1.5h läks seal igaühega. Seejärel aga mõtlesin, et piisavalt hea asi küll, et võib ära osta
Igatahes nüüd on üks munk normalist läbi joostud ~15h'ga ning järgmises raskustasemel sai just skeleton king'i maha. Diablo ise oli üllatavalt lihtne ära tappa. Paljud teised (mini) bossid olid oluliselt keerulisemad, rääkimata paarist juhtumist, kus oli korraga sadakond mob'i koos paari eliitide kambaga kõik korraga kallal
Oleks teadnud, et suvalise leveliga gem'e saab panna ka lowbie gearile oleks asi oluliselt kiiremini käinud. Dualwield kus kummagil relval 35hp per hit gem'id sees ning tankin seal raskusastmel suht kõike
Muud nodi peale gem'ide pole senini ostnud veel ning arvatavasti ei hakka lähiajal tegema ka, kogu papp läheb nii ehk naa praegu professionite leveldamiseks ning stash'i laiendamiseks. Hoarder, nagu ma olen. _________________ Teach a man to reason and he'll think for a lifetime
Väike soovitus: ära enne flawless square crafti (seda samuti mitte) gemme. AHst on odavam osta kui maksta seda 'tasu' jewelcrafterile, et craftida. Üks flawless square maksab AHs ~5k, craftimine maksab aga 20k + materjalid.
Siin sõber andis DH nende def värkide arendamise alla.Hetkel mingi 17k HP ja lihtsalt DPS nii kõrge kui vähegi võimalik.Ja infernos diablo juures hetkel.Ise sain siiani ACT 1 tehtud infernos. _________________ ''Not everything that shines is gold''
Enne kui ostad uuri millega tegemist.
Saan igat suvalist Valve asja võrgus probleemideta mängida, torrenteid tirida vms.
Aga vot Diablo III mängida ei saa.
Muudkui Connection lost. Error 3007. iga 1-5 min järel.
Foorumitest kõik juba läbi katsetanud ja proovinud, ei miskit, pikim aeg mis mängida sain oli vist ca 15min.
Tuleb vist asi sügiseni ootele panna, lootuses et selleks ajaks on midagi parandatud. _________________ Experience is what you get when you don't get what you want.
bladerunner, Äkki on see nende Thompsoni ruuterite jura? Ma vahetasin oma ruuteri välja ja üheski mängus ple enam mitte mingit neti jura. _________________ Minu Youtube - HDTanel
That's weird, I wonder if it's based on ... yeah I have no idea. It could be correct as while people play multiplayer games with their friends (and by the current stats about 1/5 are in multiplayer games) not too many open up their games to public. The rumors of public game hacking could also be scaring people away from it (which is nonsense, FYI). Anyway, hundreds and hundreds of thousands of people are currently playing on the Americas server alone, and we're not fully into peak hours. On a Wednesday.
Häirib see hülgemöla Official foorumis, kus kaebatakse, et mäng on suremas, et ainult 20k mängijat online. Tähele panemata, et tegemist on ainult ühe serveriga ning ainult Public Gamedega, mis on vbl 10-20% kogu mängijate baasist üldse.
Tema sõnadest võib välja lugeda, et oma 200k min. on iga hetk sees olenemata päevast. Tip tunnil veel rohkem.
Bashiok ütles ka, et see nädalavahetus purustatakse vist kõik rekordid samaaegselt sisselogitud mängijate numbritega. Võimalik, et mingi pool milli per server ma pakuks.
<b>piixu</b> mingu actII ja monk. Shieldiga ei toida, dw 20k+ dps ei toida.
buildi taga kinni siis ehk? Ma lasen shieldiga act2tes farmi. Eks on champ packe mida peab lolliks kitema või abusema portalit, et serrenity cd oodata aga üldiselt on täitsa talutav. Märkasin, et läks märgatavalt kergemaks kui ostsin 1,6 speediga relva. Spirit regen suurem. '400 life on hit' gem sees.
Working as intended _________________ www.oggym.ee // OG Gym // Pärnu, Roheline 74
ootan meeleldi häckimist või mingit socalled bugi.. pole siiamaani ühetgi fakti nende olemasolust minu jaoks.
EDIT: kui item sold hetk enne seda kui sina clickid siis tuleb raha su kontole tagasi. endal läks 20 tundi ükskord sellega. _________________ Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda.
Ilmselgelt need 7 milli mängijat pigistavad mistahes bugid igast featurist välja ning jooksutavad serverid surma äärele. Homme peaks siis teadma saama, mis Blizzardi plaanid on ja mis on ETA suurematele patchidele.
Sooviksin ka esialgu siis guestpassi, kui kellelgi on üle ehk? Mängima hakkan niivõinaa, lihtsalt aja küsimus, mis päev omale key saan. _________________ Fotolõuend - Fototapeet - Disaingraafika - Dekoratiivkleebised
Isegi soomes on raske leida karbiversiooni. Ainult mingites supermarketites leidub mõni. Diablo 3 maania on ikka suht võimas. Võtaks ka 1 quest passi, saaks teada kas läppar veab välja või mitte.
PlatoonSgtElias kirjutas:
TG784 puhul on mul asi korras olnud aga mul on eespool ja huawei ont ja elioni fiiber. Võimalik, et TG784 on ka pisut teisiti konfitud aga selle kohta ma enam ei mäleta. Nimelt oli ühel hetkel TDU2 mängimisega probleeme ja siis sai seal mingit konfi näpitud. Võimalik, et midagi seoses QoSiga.
Lol. Tegin huvi pärast Nephalem buffiga paar Azmodan run'i. Kukkus siuke Templari vidin, mis tundub olema väärtuslikuim asi mida leidnud. AH hindu vähemalt vaadates. Kahju, et ise Templarit ei kasuta. Kuid raha ongi rohkem vaja.
Tundub, et Nephalem buffiga saab ikka kenasti looti kokku ajada. Eks ainult aja küsimus millal midagi head endale paiskub. Azmodan run'i käigus saad ka tema naisekese maha lüüa seega kokku kukub oma 5-7 rare per jooks + 10-15 sinist. Mingi 20-30 minti läheb vbl.
Pandav värk.
Nii sai siis Hell läbi, 60 ka ära grinditud ja nüüd siis vaja hakata geari kokku ajama.
Sooviks siis vähe infot targematelt, et mida siis stackida jms. Olen barbarian ja nagu ma aru saand olen siis
Co-op jaoks pmst sitaks resit , hp, ja armorit ja ka MF võimalikult kõrgeks, et manti kukuks!?
Ei teagi mis teha sellega ,et kas jääda selliseks 50/50 tank ja dps või minna full tankiks vms? Kui saaks pidevalt
co-op teha siis vist võiks isegi full tank olla aga samas siis ei kannata üksi vist üldse mängida.
tore on AH-st 700k eest asju osta, rahast ilma aga asju pole 5+ süsteem
Endal oli ka sama jama aga see item tekkis hiljem completed alla ja sain selle stashi saata. (umbes 30min läks aega - eile õhtul 23:00 ajal). Niiet tundub et AH lag vms.
Ei suuda ükski klass lihtsalt dämmi tankida. Barbar suudab hea geariga küll mõne sekundi kauem füüsilist dmg kannatada, kuid spelldmg tapab ikka ära. Videos tal lihtsad rare pakid v.a üks. _________________ Liitu Z.ai coding plaaniga ja saa 10% soodust! Liitu Wise'ga!
CW on AE ja damage reduce,
WOTHF on single target damage. Lisaks on tal huvitav omadus mobe 'ministunis' hoida, saab suuremaid mobe kes sulle muidu haiget teeks vabalt 'tankida'. Championite vastu ei tööta see küll. Kirsiks koogi peal on 3s hit projectile ehk siis ranged ability ka olemas vajadusel (ofc se dps seal pole teab mis metsik aga mõnes kohas ilma ei saa). Muidugi võib selle välja vahetada kui ei sobi playstylega. näiteks blindi võtta v hoopis miskit muud.
Nende kahega vastavalt olukorrale dpsin.
Tempest Rush on väga hea escape skill kui ta parajasti töötab. Vahel on 'rubberband effect' ehk siis tõmbab su starting positsioonile tagasi.
Muu peaks enda eest ise rääkima. Ilma nende passiviteta ma ennast infernos väga ei näe (vähemalt kuni overgeared pole).
On keegi uurinud, millised boonused arvestatakse relva kuvatava DPSi sisse ning millised mitte? Avastasin, et klassispetsiifilist stat'i sinna sisse ei loeta. Aga näiteks+x% dmg või +x% critical hit damage?
+% damage, + x-y Z type damage, +% attack speed
need on kindlasti DPS numbri sees juba.
main statid (dex,str,int) ning socektist saadav boonus ei ole.
Kaua teil läks, et esmakordselt läbida
diablo 1 normal
diablo 2 normal
diablo 3 normal?
Tegin hiljuti D1 läbi Sorcereriga. Paar tundi läks ainult. Kuid samas mingi vend teeb 3 minutiga: http://www.youtube.com/watch?v=dW8XorD9RwI
D2 võttis ilmselgelt kauem aega, kui 1. kord seda mängisin, sest olin siis suht noob. Pärast seda olen teinud D2 kümneid kordi läbi ja keskmine run on umbes võrdne D3 omaga. (4-5h?)
kui üks ruby relva sisse visata siis peaks relva dpsi number tõusma. aga crit hit/dam ei peaks seal sees olema, pead ei anna. _________________ Chuck Norris on juba 2 aastat surnud. Vikatimees kogub siiamaani julgust, et seda talle öelda.
Sul on õigus, miskipärast mul see kahe silma vahele jäänud. Criti boonused ei tohiks nagu relvale eraldi mõjuda jah kuigi ka ei tea täpselt, pole väga kohanud selliseid.
