13.03.2012 21:51:46
Euroopa Komisjon süüdistab ACTA läbikukkumises sotsiaalvõrgustikke, kavatseb edasi minna IPRED direktiiviga |
link :: Techdirt
Euroopa Komisjoni President José Manuel Barroso süüdistab ACTA läbikukkumises sotsiaalvõrgustikke. 22-sel veebruaril toimunud komisjoni istungi protokollist lähtub, et Barroso peab ACTA läbikukkumise süüdlaseks avalikke debatte ja organiseerituid ACTA vastaseid kampaaniaid erinevates sotsiaalvõrgustikes. Kuigi ACTA on hindamiseks saadetud Euroopa Kohtusse, kummutamaks sotsiaalvõrgustikes levinud "valeväited" ACTA kahjulikkuse kohta interneti- ja sõnavabadusele, kavatsetakse seniks edasi minna 2004-ndast aastast kehtiva IPRED direktiivi täiendusega, millega kehtestataks sisuliselt Euroopa versioon USA SOPA-st, millega tahetakse internetiteenuse pakkujad teha vastutavaks nende kanalites liikuva sisu üle.
Here's what the President of the European Commission, José Manuel Barroso, said about ACTA:
The President introduced the topic, commenting on the intensity and scale of the public debate and the organised campaign against the Anti-Counterfeiting Trade Agreement (ACTA). There were those in particular who felt that the agreement would lead specifically to an unwarranted restriction on freedom of expression and democracy on the Internet, and would distort the reasonable balance between intellectual property rights and other fundamental rights.
He therefore felt that the Court of Justice of the European Union should be asked to confirm the Commission’s position in this matter, namely that ACTA was consistent and compatible with the Treaties and with the Charter of Fundamental Rights of the European Union. He suggested that that day’s discussion should consider that point, but also the question of when would be an appropriate time to refer the matter to the Court, and the possibility of consulting Parliament and the Council with a view to adopting a common approach in this matter. |
What's extraordinary is that no less than three other commissioners also spoke at the meeting about the importance of social networks, and the need to grapple (tõlge: kähmlema) with them.
Viviane Reding:
| She concluded by highlighting the rising influence of social networks on the Internet and the need for the Commission to take account of this in its communication policy and in dealing with various dossiers. Instructions had already been given to the communication units in the Directorates-General. |
Neelie Kroes:
| She concluded by stressing the need for appropriate communication on the agreement, without waiting for the Court’s opinion, targeted particularly at the various stakeholders involved and social networks. |
Michel Barnier:
| was also of the opinion that the key role of social networks in public debate in Europe forced the Commission to think carefully about adapting some of its means of communication and that Members should discuss the matter as soon possible. |
What emerges very clearly from this is that the most senior politicians in the European Union are completely nonplussed by the power of social networks to mobilize not just Net activists but ordinary Internet users, and are struggling to deal with it. I think we can expect to see attempts to neutralize that new force by "reaching out" to social networks in a variety of ways in the coming months. One area where that will clearly happen is for the forthcoming update on the EU's "IPR Enforcement Directive", generally known as IPRED. The Commission meeting referred to it explicitly:
As regards the planned revision of the 2004 Directive on enforcement of intellectual property rights, the Commission needed to adopt a prudent and balanced approach to this politically delicate exercise, and take account of existing texts on the protection of data and privacy in the areas of telecoms and fundamental rights.
The EC knows that it must be very careful here, because the measures already mooted for the next version of IPRED are very close to some of SOPA's bad ideas -- for example, turning ISPs into copyright cops. The European Commission has observed what happened in the US, and is clearly very concerned that the IPRED update will meet the same opposition from those mysterious, uncontrollable social networks as SOPA/PIPA did and ACTA is now doing.
Loe ka Techdirt artiklit.
HV valuutakalkulaator |
Osiris
13.03.2012 22:14:17
Ehk teisisõnu - kui on käsk antud ACTA vastuvõtmiseks siis seda tehakse ükskõik mis vahenditega. Öelgu inimesed mida tahes ikka tehakse nii nagu käsk on.
iceincube
13.03.2012 22:19:12
Ma usun, et siiski meil (rahval) peaks olema kõrgeim võim.
Lihtsalt tundub, et siin sõjas on tulemas veel mitu lahingut.
kermo144
13.03.2012 22:30:31
See küll hea ei ole
13.03.2012 22:55:16
Igati huvitav, kuidas kõik äkki ja korraga internetti korraga järjest rohkem kontrollida tahavad ning küberjulgeoleku-paanikat järjest üles keerutavad.
Euroopa Liit, USA, Venemaa, Hiina ... kõigil on mingid karmid IT-piitsad kõigi vastu valmis pandud...
olavsu1
külaline
14.03.2012 00:26:43
tahanteada, varem oli asi lihtne. rahvast juhiti kirikukantslitest. ja rahvas teadis seda mis kirikuõpetaja ütles.
Nüüd on aga suur vaenlane internet ja kontrollijatel on vesi ahjus, inimesed ei loegi ametlikke lehti, vaid teevad omi lehti.
Varsti võtame jälle ridvad ja vahetame kena veekogu kaldal uudiseid ja anekdoote .
cubedude
14.03.2012 00:39:00
See on lihtsalt vana maailma püüe saavutada uuesti võimu uue maailmakorra vastu. fakt on see, et see mis toimis väga hästi paarkümmend aastat tagasi, ei pruugi enam sugugi nii kergelt minna ja suurim põhjus miks nii on, ongi just internet. Kahjuks aga vana maailma juhtidel on raha nagu muda ning seda nad ka kasutavad et proovida jõuga taas tippu minna. Ise usun et võitlus tuleb hea nende poolt aga rahvast nii kiirelt ei lange. Täpselt nii nagu olavsu1 ütles
14.03.2012 08:12:51
olavsu1: Pole hullu, vähemalt USA kõikvõimalikud valitsused ja juristid istuvad järjest rohkem koos, koostades järjest uusi ja uusi piibel-memosid teemadel Küberjulgeolek ja kuidas ikka kõik teised riigid Küber-sõda USA-le kuulutada tahavad.
PS: Kunagi mingi muu teema sees sai vist isegi mingi taolise "Piibli" link ära toodud.
Aeron
14.03.2012 08:18:10
Oeh, kurb kui sõnavabadus on süüdi milleski... ikka haige suhtumine on mingitel tegelastel.
_________________ Võib öelda, et ma olen liigselt enesekeskne, aga mind see ei häiri
Tulge kõik HV rahvaga jalkat mängima!| |
mteachx
Leinö
14.03.2012 09:00:34
Mis ora neil nüüd pe*ses on?
Meediahaidel vähe raha?
0n3_Sh0t
14.03.2012 09:55:08
Eesti poliitikategelaste poolt öeldi välja et ACTA sisuliselt ei muuda midagi. Nagu näha siis ei muudagi, on olemas ka teised hoovad mille kaudu internetiliiklus kontolli alla saada. Kurb on muidugi see, et sõidetakse üle lihtsate inimeste võimalustest ja veeretatakse kõik teenusepakkujate kraesse.
Päevalehtede sisu korrigeeritakse ju iga päev ja ei lasta üldiselt trükki lehte, mille sisu on ebasobilik. Sisu eest vastutab esmajoones ikkagi toimetaja. Kas Internetiga tuleks käituda samamoodi raske on siin seisukohta võtta. Lokkav piraatlus näitab seda, et raha eest pakutav teenus ei ole tarbijale kättesaadav või on ebamõistlikult ebameeldivaks tehtud teenuse kasutamine. Või on lihtsalt teenus liiga kallis.
Tundub, et sellised tsenseerimise käigud on olnud juba ammu plaanis, kuid tänu sotsiaalvõrkudele on tähelepanelikemate inimeste üleskutsed leidnud ka passivsemate tähelepanu.
viimati muutis 0n3_Sh0t 14.03.2012 10:44:01, muudetud 1 kord |
iceincube
14.03.2012 10:05:03
| Eks see kõige suurem probleem olegi eliidil, et mainstream meedia kõrvale on tekkinud kanalid ja uudised mille levimine neile väga meeltmõõda pole.
Leinö
14.03.2012 10:09:33
Enamjaolt kättesaadamatu.. Ja ka hind on kirves
Sarjad näiteks, meil näidatakse aint A-rühma ja muid selliseid, uuemad sarjad jäävad aint USAsse..
Reklaame näidatakse tv-s vaat et rohkemgi kui sarja.
DVD-sid on kallis osta, netist ostes hind on samasugune. Ja kui ongi mingi soodustus, siis on teatud regioonile ainult.
Programmide kohapealt, õnneks on tulnud vabavaralisi (libreoffice, gimp jms), mis siis asendavad mäekõrguste hindadega "tarbekaupu"
mario20031
14.03.2012 10:51:52
nothing important
viimati muutis mario20031 19.08.2012 01:23:33, muudetud 1 kord |
Lotharius
rallisibul
14.03.2012 11:54:54
| Leinö kirjutas: |
Programmide kohapealt, õnneks on tulnud vabavaralisi (libreoffice, gimp jms), mis siis asendavad mäekõrguste hindadega "tarbekaupu" |
Programmide suhtes on jah asi etemaks läinud ning kannatab neid vabavara alternatiive küll kasutada, samas sageli selle interface'i poole pealt jäävad nad ikka tasulistele alla ning päris kõiki asju ei ole võimalik teha või ei ole neid nii kerge teha, kuid siiski tuleb nentida, et hakkama saab ja ei pea plekkima.
DVD jms füüsilisel kujul oleva meedia vastu on mul juba kerge tõrge. Ma tõesti ei viitsi mingit plaadiladu koju tekitada, eriti siis, kui ma vaatan filmi 90% tõenäosusega vaid ühe korra ning mul on alternatiivina võimalik kõik filmid ühele 3.5" seadmele mahutada.
Aeron
14.03.2012 11:59:29
Mina paneks oma pitseri alla. Ma imsestan tegelikult, et ISP'd ei ole lipulaevad anti sopa/ipred'i/acta vastu...
fallout3
14.03.2012 12:21:15
| Aeron kirjutas: |
| Ma imsestan tegelikult, et ISP'd ei ole lipulaevad anti sopa/ipred'i/acta vastu... |
ACTA vastu on nad oma arvamuse juba välja öelnud. Aga enne seda tuli lihtsalt ära oodata, kuni avalikkus oma arvamuse valjult kuuldavaks teeb, muidu oleks liigagi lihtne näpuga näidata kasumiahnete ISPde poole, kes tahavad varastamise vahendamisest tulu teenida ja on äriliste huvide tõttu kallutatud.
Wilts
14.03.2012 14:22:50
Ostetav/allalaetav mäng on 2-3x kallim kui dvd plaadil, prinditud raamatu ja kaantega ???
Filmidest ma olen vist ühte näinud mille sai osta ja alla laadiga, ja oli müügis kohe koos plaadi versiooniga.
Mida nad tra. pidurdavad.
Pira... mängudel peaks demo olema samamoodi kohustuslik nagu muul kaubal krdi. eestikeelne juhend!
Kui korralik asi teha siis ostetakse sada nagunii mitte ei pirata.
Näiteks "Stargate sg1" on kenasti 1-10 + filmid olemas ja ei kahetse, et ostsin!
Avatar on tavaline ja extended jne.
Aga mingeid poolikuid ja ära lõpetatud tv seriaale on ikka suht nadi plaadil osta.
või filmi mille kõige huvitavam koht on trailer`is
Ja kust krdi. p. vanu häid filme osta saab?
blu-ray fift element on ikka sigaraske leid mõistliku hinnaga!
Aeron
14.03.2012 14:43:51
Nja, Starcraft 2 Blizzardi veebis oli veel mõnda aega tagasi müügis @ 60 € / DD versioon.
Karbi oma saab zavvist mingi 40 € ringis. Dunno miks peaks DD oma ostma sellisel juhul.
Kuna DD vara tootmine on mõnedel hinnagutel kuni 10x odavam, kui plaatide vorpimine, siis võiks see ka hindades kajastuda.
Steam on hea näide DD võidukäigust. Ostetakse küll, kui on normaalne toode, mida on lihtne tarbida.
Igasugune tsenseerimine - press/veeb/sots meedia/ISP survestamine on utter BS ja peaks sõnavaba EU/EC agendast küll maha tõmbama.
Igast sõnavõtud teemal, et organiseeritud sotsemeedia survel kukkus mingi asi läbi on lihtsalt nii ajulage, et anna armu. Pmt öeldakse ju seda, et rahva tahtel kukkus nende "hea plaan läbi" ja nüüd on vaja asemikku.
Ei ole vaja. Esimest korda on võimalik nii paljudel inimestel oma arvamust avaldada. Harjugu ära sellega.
lopes39
14.03.2012 15:13:14
oleks siis nii et need autorid kes asju teevad nagu muusikud saaksid selle eest raha kui keegi vahele võetakse nende muusika piramisest aga, muusikud ei saa selle eest mitte pennigi.
väga arusaamatu on minujaoks need autorikaitse ühingud kes nõuavad mingeid ulme summasi piramise eest ja seda raha ei anta autoritele vaid läheb autoriõiguste firmadele..
kust vähegi võimalik inimesi ülelasta siis selleks on vaja võimalikult palju igasugu haigeid seadusi välja mõelda nagu acta
see acta võiks eestlasele teha miinimum palga 1000 euro peale et iga inimene saaks endale iga kuu lubada mõne filmi või mängu ostmist siis oleksin ma acta poolt aga kuna meil on sellised palgad siis peab lihtsalt enamus asju pirama
iceincube
14.03.2012 15:23:02
Mind huvitaks üks asi- palju neid autoreid, kes seal EAKO all on -
1. pole kunagi ise piranud (või ei tegele sellega praegu)
2. toetavad ACTA't ja muud perverssust mis toodetakse
2010
14.03.2012 17:51:16
Nõus |
Nõus 100%
| lopes39 kirjutas: |
see acta võiks eestlasele teha miinimum palga 1000 euro peale et iga inimene saaks endale iga kuu lubada mõne filmi või mängu ostmist siis oleksin ma acta poolt aga kuna meil on sellised palgad siis peab lihtsalt enamus asju pirama |
Aeron
14.03.2012 17:53:25
Re: Nõus |
| 2010 kirjutas: |
Nõus 100%
| lopes39 kirjutas: |
