In the near future, world leaders are mere seconds from signing a global treaty and bringing an end to war as we know it when a devastating terrorist attack rips through the peace conference, killing all in attendance. In a world left with no politicians, diplomats, or activists, only the Generals remain. It’s up to you to assume their roles, command of their forces, and put an end to global terrorism once and for all.
All-out War – Take control of three unique factions, competing for resources, building up your base of operation, and leading massive batteries of tanks, soldiers, and aircraft into battle.
Uncanny Sense of Realism – Frostbite 2 technology allows for visceral, visually stunning conflict at an epic scale. Incredibly detailed units and environments, dynamic physics, and exhilarating visual effects bring the battle to life in ways never before seen. This is the closest thing to real war without the consequences.
New Ways to Dominate or Ally with your Friends – Go beyond classic deathmatch with a selection of new multiplayer game modes, designed with both cooperative and competitive play in mind.
Thrilling Campaign – Command the war on terror in an electrifying single-player campaign. Experience the dramatic story from multiple perspectives—from heroic General to crazed terrorist—while engaging the enemy in pulse-pounding tactical combat.
Ever-evolving Experience – Enhance your game with an expanding array of downloadable content. From maps and units to factions, campaigns, and more, the fight against terrorism is deeper than ever.
Parim uue ajastu C&C oli Generals Zero hour. Kuigi see päris õige C&C ei olnud. C&C3 oli ka väga hea.
RA3 ei meeldinud mulle nii väga kui eelmised mängud. Mäng läks valesse suunda sellega.
Üldine lemmik C&C on mul ikkagi RA2.
Tahan, et mängu valem jääks samaks nagu varem. Kuigi seda vist ei juhtu kuna kriitikud vinguvad, et midagi uut ei tooda mängu sisse.
Generals: Zero Hour ja CnC3: Kanes Wrath parimad ikke
cnc 3 oli hea senikaua, kuni base def ehitamist nerfiti. War factory püsti ja click fest, kes kõige ennem külili "8" arvuga tanke enne jõuab klikkida, on võidumees.
C&C lemmikud tiberian sun (free game), ra2, generals ja loomulikult renegade.
Aga mingeid sarnaseid mänguseeriaid vist pole rohkem?
C&C 3 TW ja KW mängijana olen endale leidnud uue variandina Supreme Commander 2.
Kui C&C 4 välja tuli oli ootused suured, sai uuest peast kohe ära ostetud, millegi pärast ei istunud see mäng kuidagi mulle! Story sain õnneks ikka läbi tehtud.
Ootame ja vaatame mida järgmine title toob.
tiberian sun. jääb parimaks. endal oli too esimene strateegia mäng elus mida pelasin. võiks midagi sarnast tulla _________________ Mis vahe on tegelikkusel ja reaalsusel? Vahet pole!
Njah pole mingit vana arvutirisu ka kuhu win98 peale lasta ja ra1 ja esimesi osi mängida kuna ma ise ka olin ra fänn algusest peale kui see ilmus siis aastaid tagasi ilmus selline asi nagu red alert first decade esimesest osast kuni zero hourini välja kuid esimesi ei saa mängida sest pilt liiga halb uue masinaga ei aita ka need run win98 ja muud moded
W7 -el on ju võimalik panna seaded W98 tasemele...kas see ei aita?
tuleb kah jätta märk igaks juhuks teemasse maha.
ja zero hour sakkis. c&c on seal küljes lihtsalt kleebis, umbes nagu punased r-tähed 1.3 civicute küljes. _________________ - londiste
Generals/Zero Hour oli ikka üle prahi omal ajal, sai segi mingid ajad tagasi veel laksitud seda. Kahjuks wide screen toe puudumine on selline tugevam miinus praegusel ajal. Aga ei ootame vaatame mis tuleb. _________________ Rolling Thunder
Mina oleks elu õnnelik kui cc teeks zero hour-i uuele mootorile ja uue graafikaga. aga et põhimõte jaaks samaks. Vat see oleks üle pika aja parim mäng.
El-Fuego, No problemo, juhtub. Parem muljeta, kas said ka kenasti tööle. Sa ausalt tekitasid mul ka väikese sügeluse see asi uuesti tööle panna, aga ma pean siis mingeid plaate ja asju otsima. _________________ Avatar by Flacko
Ma sain esimese RA ilma mingisugse jamamiseta tööle Win7 peal.
Patch peale ja asi korras.
Ei oska enam sellele patchile viidata, kuna ma mängisin seda pool aastat tagasi ja enam poles see mul arvutil peal.
Et siis homme esimene video?
Mis teema siis see oli, et C&C üldse ära lõpetati, vahepeal.. _________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
muideks kui kellelgi on huvi siis mul on sümboolse summa eest ära anda 2 originaal keyd c&c generalsi oma kunagi sai ostetud generals ei mäleta mis plaatidest sai kuid geyd on mul kuskil isegi olemas koos raamatuga
PS!vaatasin siis plaati kuid ei näinud seal explorides küll mingit kausta mis sisaldaks patchi
Väga väga meenutab generalsi. Too auto mis lendab meenutab Technicali GLA osapoolelet.
Tagataustal masin on ilmselt uus Quad cannon.
Tahaks teada mis mootoril mäng jookseb. Kas kasutatakse ikka RNA mootorit või on mingi täiesti uus mootor.
Kui on täiesti uus siis peab lootma, et modimine ol ikka lubatud ja lihtne nagu enne.
"A new Bioware studio"?
Siis, ei peaks ju muretsema, et nad ainult RPG'sid teha oskavad, kuna uus stuudio. Aga mis sai Victory Games stuudioost? Kas nad teevad koostööd või mida?
