uus teema   vasta Tarkvara »  Arvutimängude foorum »  Command & Conquer (2013) märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
SinineSiil
SinineSiil
sõnum 21.02.2011 21:30:02 Command & Conquer (2013) vasta tsitaadiga
In the near future, world leaders are mere seconds from signing a global treaty and bringing an end to war as we know it when a devastating terrorist attack rips through the peace conference, killing all in attendance. In a world left with no politicians, diplomats, or activists, only the Generals remain. It’s up to you to assume their roles, command of their forces, and put an end to global terrorism once and for all.
All-out War – Take control of three unique factions, competing for resources, building up your base of operation, and leading massive batteries of tanks, soldiers, and aircraft into battle.
Uncanny Sense of Realism – Frostbite 2 technology allows for visceral, visually stunning conflict at an epic scale. Incredibly detailed units and environments, dynamic physics, and exhilarating visual effects bring the battle to life in ways never before seen. This is the closest thing to real war without the consequences.
New Ways to Dominate or Ally with your Friends – Go beyond classic deathmatch with a selection of new multiplayer game modes, designed with both cooperative and competitive play in mind.
Thrilling Campaign – Command the war on terror in an electrifying single-player campaign. Experience the dramatic story from multiple perspectives—from heroic General to crazed terrorist—while engaging the enemy in pulse-pounding tactical combat.
Ever-evolving Experience – Enhance your game with an expanding array of downloadable content. From maps and units to factions, campaigns, and more, the fight against terrorism is deeper than ever.
http://www.commandandconquer.com/en/games/bygameid/cncgenerals2
Link
viimati muutis SinineSiil 29.10.2012 23:59:28, muudetud 8 korda
Lovvi
Lovvi
sõnum 21.02.2011 21:32:59 vasta tsitaadiga
Seda "innovative new concepts"i me juba nägime CC4-ga...
Kommentaarid: 60 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 57
SinineSiil
SinineSiil
sõnum 21.02.2011 21:35:46 vasta tsitaadiga
Loodetavasti õppis EA sellest ikkagi, et ei tee sama viga enam.
Mafia
Mafia
sõnum 21.02.2011 22:07:13 vasta tsitaadiga
CC4 on jubedaim mida strateegiaga teha võib... kogu RTSi võlu oli kadunud seal :S
Bawse
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 17
SinineSiil
SinineSiil
sõnum 19.05.2011 17:34:31 vasta tsitaadiga
Tehti foorum kuhu inimesed saavad soovitada ideid mängu loomiseks:
http://www.commandandconquer.com/forums/forumdisplay.php?44-Community-Developer-Area
Killer85
sõnum 20.05.2011 15:15:03 vasta tsitaadiga
Peale RA3 proovimist ei julge küll ühtegi EA (strateegia)mängu ette võtta. Isegi kui tasuta saaks.
heretic666
heretic666
sõnum 20.05.2011 15:28:03 vasta tsitaadiga
sul on vedanud et c&c 4 ei proovinud
SinineSiil
SinineSiil
sõnum 20.05.2011 15:34:07 vasta tsitaadiga
Parim uue ajastu C&C oli Generals Zero hour. Kuigi see päris õige C&C ei olnud. C&C3 oli ka väga hea.
RA3 ei meeldinud mulle nii väga kui eelmised mängud. Mäng läks valesse suunda sellega.
Üldine lemmik C&C on mul ikkagi RA2.
Tahan, et mängu valem jääks samaks nagu varem. Kuigi seda vist ei juhtu kuna kriitikud vinguvad, et midagi uut ei tooda mängu sisse.
bloodraven
sõnum 20.05.2011 16:11:47 vasta tsitaadiga
generals oli jumala kuld .. mulle väga meeldis .. RA2 õudus .. suutsin vist 1 campaigni leveli teha ja delete ... jube
martin366
martin366
sõnum 20.05.2011 16:52:57 vasta tsitaadiga
Generals: Zero Hour ja CnC3: Kanes Wrath parimad ikke icon_smile.gif
Kommentaarid: 185 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 172
Väikemees
Väikemees
sõnum 20.05.2011 17:06:39 vasta tsitaadiga
martin366 kirjutas:
Peaks ütlema sama, CnC3 vb tundsin laevadest nati puudust aga muidu ikkagi hea.
Uus võiks tulla kahe mainitud osa sarnane aga üksusi võiks rohkem olla erinevaid.
Kõige rohkem mulle meeldibki nendes baaside ehitamine, see peab kindlasti sees olema, mingi ringiliikuva mammutiga enam jamada ei viitsiks.
heretic666
heretic666
sõnum 20.05.2011 20:45:40 vasta tsitaadiga
martin366 kirjutas:
cnc 3 oli hea senikaua, kuni base def ehitamist nerfiti. War factory püsti ja click fest, kes kõige ennem külili "8" arvuga tanke enne jõuab klikkida, on võidumees.
C&C lemmikud tiberian sun (free game), ra2, generals ja loomulikult renegade.
Väikemees
Väikemees
sõnum 20.05.2011 20:59:35 vasta tsitaadiga
Aga mingeid sarnaseid mänguseeriaid vist pole rohkem?
nah
nah
sõnum 20.05.2011 21:09:37 vasta tsitaadiga
heretic666 kirjutas:
martin366 kirjutas:
Kommentaarid: 150 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 141
Asgate
sõnum 13.07.2011 13:35:10 vasta tsitaadiga
Väikemees kirjutas:
C&C 3 TW ja KW mängijana olen endale leidnud uue variandina Supreme Commander 2.
Kui C&C 4 välja tuli oli ootused suured, sai uuest peast kohe ära ostetud, millegi pärast ei istunud see mäng kuidagi mulle! Story sain õnneks ikka läbi tehtud.
Ootame ja vaatame mida järgmine title toob.
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 13
madfury
madfury
sõnum 13.07.2011 15:22:14 vasta tsitaadiga
Ra1 ja Generals seeria lemmikud. Ja seda ma ei usu, et PC exclusive.
Avatar by Flacko
caarel123
caarel123
sõnum 17.07.2011 19:25:04 vasta tsitaadiga
tiberian sun. jääb parimaks. endal oli too esimene strateegia mäng elus mida pelasin. võiks midagi sarnast tulla
Mis vahe on tegelikkusel ja reaalsusel? Vahet pole!
Kommentaarid: 83 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 74
XATM092
XATM092
sõnum 06.12.2011 08:48:17 vasta tsitaadiga
http://www.ubergizmo.com/2011/12/ea-registers-domain-names-that-points-to-new-command-and-conquer-game/
Kommentaarid: 40 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 37
Muhekas
Muhekas
sõnum 06.12.2011 10:19:18 vasta tsitaadiga
Njah pole mingit vana arvutirisu ka kuhu win98 peale lasta ja ra1 ja esimesi osi mängida kuna ma ise ka olin ra fänn algusest peale kui see ilmus siis aastaid tagasi ilmus selline asi nagu red alert first decade esimesest osast kuni zero hourini välja kuid esimesi ei saa mängida sest pilt liiga halb uue masinaga icon_sad.gif ei aita ka need run win98 ja muud moded
Olenemata olukorrast, jää iseendaks ja samas lugupidavaks.
Rubic
sõnum 06.12.2011 14:54:29 vasta tsitaadiga
El-Fuego kirjutas:
W7 -el on ju võimalik panna seaded W98 tasemele...kas see ei aita?
Firefly
Firefly
sõnum 06.12.2011 15:02:22 vasta tsitaadiga
Uuendagu Generals: Zero Hour ära ja pappi voolab ojadena. Pole vaja mingit lollust välja mõelda icon_rolleyes.gif
Kommentaarid: 151 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 141
Muhekas
Muhekas
sõnum 06.12.2011 15:10:29 vasta tsitaadiga
Rubic kirjutas:
El-Fuego kirjutas:
ei aidanud pilt on ikka t2iesti kohutav
madfury
madfury
sõnum 06.12.2011 15:42:15 vasta tsitaadiga
El-Fuego, Puust ja punaseks. Paras jändamine on, aga võimalik.
Avatar by Flacko
10.10.10
10.10.10
sõnum 06.12.2011 16:02:31 vasta tsitaadiga
sõnum 06.12.2011 16:23:20 vasta tsitaadiga
tuleb kah jätta märk igaks juhuks teemasse maha.
ja zero hour sakkis. c&c on seal küljes lihtsalt kleebis, umbes nagu punased r-tähed 1.3 civicute küljes.
- londiste
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Command & Conquer (2013) mine lehele 1, 2, 3, 4, 5, 6, 7, 8, 9  järgmine
